Vizitator adrianpruna Postat Iulie 4, 2008 Partajează Postat Iulie 4, 2008 Buna ziua, In primul rand tin sa multumesc tuturor ce m-au ajutat pana in momentul de fata , am avut 2 proiecte pe care le-am finalizat , si de care sunt mandru cum au iesit :smt033 In continuare , as dori sa imi fac un subwoofer, si m-am gandit la urmatoarele difuzoare Woofer 20cm Visaton VS-W200S/8 Technical Data: Rated power 75 W Maximum power 115 W Nominal impedance Z 8 Ohm Frequency response fu?6000 Hz (fu: Lower cut-off frequency depending on cabinet) . Mean sound pressure level 88 dB (1 W/1 m) Maximum cone displacement 20 mm Resonance frequency fs 30 Hz Magnetic induction 1,1 T Magnetic flux 600 ?Wb Height of front pole-plate 5 mm Voice coil diameter 35 mm Height of winding 12 mm Cutout diameter 184 mm Net weight 1,5 kg D.C. resistance Rdc 6,0 Ohm Mechanical Q factor Qms 3,59 Electrical Q factor Qes 0,36 Total Q factor Qts 0,33 Equivalent volume Vas 70 l Effective piston area Sd 214 cm? Dynamically moved mass Mms 26 g Force factor Bxl 9,0 T m Inductance of the voice coil L 2,2 mH si Woofer 25cm Visaton VS-W250/8 Technical Data: Rated power 90 W Maximum power 130 W Nominal impedance Z 8 Ohm Frequency response fu?6000 Hz (fu: Lower cut-off frequency depending on cabinet) . Mean sound pressure level 90 dB (1 W/1 m) Resonance frequency fs 37 Hz Magnetic induction 1,0 T Magnetic flux 660 ?Wb Height of front pole-plate 6 mm Voice coil diameter 35 mm Height of winding 12 mm Cutout diameter 236 mm Net weight 1,5 kg D.C. resistance Rdc 6,8 Ohm Mechanical Q factor Qms 3,57 Electrical Q factor Qes 1,00 Total Q factor Qts 0,78 Equivalent volume Vas 135 l Effective piston area Sd 360 cm? Dynamically moved mass Mms 27 g Force factor Bxl 6,4 T m Inductance of the voice coil L 1,1 mH Ma puteti ajuta cu niste pareri ?... Difuzoarele sunt ok ptr un subwoofer?Cum ar trebui sa fie incinta?Activ sau pasiv? Amplificator am un Sony STR-DG 500,detalii http://www.price.ro/specificatii_sony_str-dg_500_42743.htm Link spre comentariu
EmyRulz Postat Iulie 4, 2008 Partajează Postat Iulie 4, 2008 Reciverul ala Sony are iesirea pentru subwoofer doar pe semnal, deci trebuie neaparat sa il faci activ.La difuzoare, primul merge bine in incinta bass-reflex, dar se poate si in incinta inchisa si are frecventa de rezonanta mai jos decat al doilea. Celalat merge cam numai in incinta inchisa, dar va trebui sa fie destul de mare. Asa la o prima vedere eu l-as alege pe primul, pentru ca este mai versatil si pot sa experimentez mai mult cu el. Link spre comentariu
Vizitator adrianpruna Postat Iulie 4, 2008 Partajează Postat Iulie 4, 2008 m-am jucat putin cu winisd ptr modelul w200s 8 , si mi-au rezultat urmatoarele calcule ptr o o incinta inchisa Driver : Visaton W 200 S 8 Project by : v3nom Project for : v3nom -- Number of drivers : 1 Box type : Closed Box size : 19.5 l Relative Freq Gain SPL [Hz] [dB] [dB] 20.00 -20.35 67.65 25.00 -16.53 71.47 30.00 -13.46 74.54 35.00 -10.94 77.06 40.00 -8.86 79.14 45.00 -7.14 80.86 50.00 -5.73 82.27 55.00 -4.58 83.42 60.00 -3.65 84.35 65.00 -2.91 85.09 70.00 -2.33 85.67 75.00 -1.87 86.13 80.00 -1.51 86.49 85.00 -1.22 86.78 90.00 -1.00 87.00 95.00 -0.82 87.18 100.00 -0.68 87.32 -- Generated with WinISD[0.44] freeware © Juha Hartikainen You can download your own copy from : http://www.linearteam.org o sa caut sa achizitionez si eu modelul de difuzor incinta sa o fac din pal de 18 sau 22 mm?este ok daca o fac inchisa,sau sai fac o ventilatie ? am gasit pe un site niste recomandari ptr diful asta recommended cabinet 1: closed cabinet with 9 L volume from 80/50 Hz (-3dB/-8dB) recommended cabinet 2: 26 L volume bass reflex cabinet with 47 cm long HP100 reflex tube from 44/34 Hz (-3dB/-8dB). ce parere aveti ? Link spre comentariu
Mihai Cimpoeru Postat Iulie 4, 2008 Partajează Postat Iulie 4, 2008 Cu un -3 db la 65 hz nu e subwoofer ! Incerca o incinta mai mare astfel incat sa obtii un f3 mai jos de 45 hz pentru subwoofer ! Ai grija si la cursa difuzorului ! eventual vezi ce recomanda producatorul.LE: ti-am simulat eu o incinta de 40l acordata la 38 hz si ai un f3 pe la 38 hz . Link spre comentariu
EmyRulz Postat Iulie 4, 2008 Partajează Postat Iulie 4, 2008 Daca vrei sub-woofer si sa iti coboare in frecventa, fa o incinta bass-reflex. Cum wooferul are fs de 30Hz nu vei putea obtine o frecventa f3 mai mica de atat. Iti trebuie o incinta de cam 50L ca sa obtii un f3 aproape de acesta valoare. Pentru constructie e bine sa folosesti un material mai gros, dar nu e suficient, trebuie sa il si ranfosrsezi. Link spre comentariu
Vizitator adrianpruna Postat Iulie 4, 2008 Partajează Postat Iulie 4, 2008 din ceea ce am cautat pe net , am gasit un model de subwofer , care imi place , am vazut ca se potriveste si se poate folosi si modelul de difuzor ales de mine pentru subwoofer , w200s 8 ohm...Technical Data:Rated power 75 WMaximum power 115 WNominal impedance Z 4 OhmFrequency response 30 - 2000 HzMean sound pressure level 85 dB (1 W/1 m)Principle of Housing BassreflexNet volume 39 lOuter dimension height 396 mmOuter dimension width 320 mmOuter dimension depth 430 mmCabinet parts list for 1 boxParts Size (mm) QuantityMaterial: 19 mm chipboard or MDFTop and bottom panel 282 x 389 2Side panels 396 x 389 2Rear panel 396 x 320 1Brace 358 x 100 1Brace 282 x 100 1Material: 22 mm MDF or woodFront panel 396 x 320 1In addition, it is also possible to use the 8 ohm version of the woofer (W 200 S 8 OHM, W 200 SC 8 OHM) if the amplifier used does not allow lower impedance speakers to be connected or if several subwoofers are to be combined.arata ceva in genul asta Link spre comentariu
EmyRulz Postat Iulie 4, 2008 Partajează Postat Iulie 4, 2008 Da pare ok proiectul, cred ca vei avea un F3 in jur de 40 hz. Link spre comentariu
Vizitator adrianpruna Postat Iulie 5, 2008 Partajează Postat Iulie 5, 2008 o intrebare as mai avea , un filtru activ ptr acest subwoofer unde as putea gasi ? o sa ma apuc de treaba , o sa revin cu rezultate...plus cu poze de la celelalte proiecte finalizate... filtru activ , e ceva de capul lui ?... http://www.e-piese.ro/shop/kit_amplific ... oofer.html unde gasesc si eu un panou de legatura intre subwoofer si statie?(ca sa se inteleaga : la statie am iesire rca , iar ptr subwoofer borna de conectare sa fie tot cu rca, am cautat dar nu am gasit :( ,sper ca ati inteles)sau daca pot gasi o legatura alta decat rca - rca sunt disponibil sa o fac , numai sa mi-o spuneti , ptr moment am un lapsus ...multumesc anticipat Link spre comentariu
Vizitator drakosss Postat Iulie 17, 2008 Partajează Postat Iulie 17, 2008 Ai facut subwooferul? daca da cum se aude?As vrea sa fac si eu acelasi proiect. Link spre comentariu
Administratori Badman Postat Iulie 17, 2008 Administratori Partajează Postat Iulie 17, 2008 Daca vrei un filtru activ meserias uite aici http://www.hi-end.ro/modul-filtru-subwo ... -1503.html Link spre comentariu
