organigrama dupa cod
Vizitator na1981
  • Răspunsuri 3
  • XAN77
  • Eugenn
nu stiu cine ar fi dispus, organigrama face parte din procesu de creare a unui program , este o etapa dinaintea scrierii codului, cand se face schema logica cu ce se doreste. Tu acum ca sa faci organigrama dupa cod trebe sa deslusesti absolut tot ce face codul, cand vei fi terminat organigrama vei sti codu pe derost si nu numai, te alegi cu ceva informatii . Da nu stiu cat de realizabil este. Succes .
Vizitator na1981
;**********************************************;Main program voor de dci_bus;kan momenteel het volgende;een 4 bits lcd aansturing;bij het opstarten verschijnt er op het display; "DCI-BUS INIT OK"; "waiting for data..;Daarna kan er een tekst van 20 char lang naar het display verzonden; worden via de seriële poort.; dit werkte uitstekend op 15-3-2001;;pin for 4 bit connections:;;LCD -> AT90S8515;DB4 -> PD4;DB5 -> PD5;DB6 -> PD6;DB7 -> PD7;E -> PD2 ;RS -> PD3;R/W -> GROUND = write;signals PC and station;=========================================================================;PC signals; ____ __________________;Send data__________| |__| |____________________________;;; __________ __________________________;RTS |________________________________|;;;;Station signals;; ___________ ;Send data___________________________________________| |__________;;; ________________________________________ ________;PORTB 3 | |_____________|;;;**********************************************.include "c:\progra~1\avr_asm\appnotes\8515def.inc" ;.include "c:\avrtools\appnotes\8515def.inc".def text = r0 ;for rs-port.def count1 = r10 ;for wait instructions.def count2 = r11 ;for wait instructions.def count3 = r12 ;for wait instructions.def count4 = r13 ;for wait instructions.def ax = r16 .def bx = r17.def cx = r18.def dx= r19.def lcd_temp = r20 ;;for lcd display.def col = r21 ;collum display.def x_counter = r22 ;counter for display.def ex = r23.def fx = r24.def hx = r25;ram ram ram ram ram ram ram ram ram ram ram ;static var .equ e = 2 ;enable voor display .equ rs = 3 ;register selectie voor display.equ addr=$100 ;voor bijhouden adres .equ jumpers=$101;sram van $60....025F.equ P_String =$60 ;start address of SRAM array #1;.equ P_String2 =$74 ;start address of SRAM array #2.cseg.org $000rjmp reset ;reset handle ;************************** ;begin to init the hardware ;**************************reset: ;init stackpointer for 8515 ldi ax,ramend out spl,ax ;set lowbyte for sp ldi ax,high(ramend) out sph,ax ;set highbyte for sp ;portd 2...7 outputs ldi ax,0b11111100 out ddrd,ax ldi ax,0b00000000 out portd,ax ;portc all inputs ldi ax,0b00000000 out ddrc,ax ;portb 0...4 outputs 5 input 6..7 outputs ldi ax,0b11011111 ;00011111 out ddrb,ax ldi ax,0b11111111 ;0b11011111 pin5 pull-up patch 18-3-2002 out portb,ax ;porta all outputs ldi ax,0b11111111 out ddra,ax ;porta all output ldi ax,0b11111111 out porta,ax ;init uart portd pin0 en pin1 ldi ax,1 ;12 of 11=19200 boud 1 =115200 out ubrr,ax ;load baudrate ; sbi ucr,chr9 ;9 char long rjmp init_lcd ;init lcd display ;***************** ;delay instructions ;*****************w_1ms: ldi ax,0 mov count1,ax mov count2,ax ldi ax,10;16 ;16 = ca. 1ms mov count3,ax ldi ax,255 mov count4,ax rjmp zaehl w_5ms: ldi ax,0 mov count1,ax mov count2,ax ldi ax,60;80 ;80 = ca. 5ms mov count3,ax ldi ax,255 mov count4,ax rjmp zaehlw_16ms: ldi ax,0 mov count1,ax mov count2,ax ldi ax,255 ;255 = ca. 16ms mov count3,ax ldi ax,255 mov count4,ax rjmp zaehlzaehl: inc count1 cpse count1,count4 rjmp zaehl ldi ax,0 mov count1,ax inc count2 cpse count2,count3 rjmp zaehl ret ;******** ;LCD init ;********func_set_: sbi portd,e ;switch lcd on rcall w_1ms ;wait 1ms ldi lcd_temp,0b00100001 ;0b00101000 = 4 bits mode out portd,lcd_temp cbi portd,e retfunc_set: ; set 4 bits mode sbi portd,e ;switch lcd on ;wait 1ms rcall w_1ms ldi lcd_temp,0b00100100 ;0b00101000 = 4 bits mode out portd,lcd_temp cbi portd,e rcall w_1ms sbi portd,e ;switch lcd on ;wait 1ms rcall w_1ms ;wait 1ms ldi lcd_temp,0b10000100 ;0b00101000 = 4 bits mode out portd,lcd_temp cbi portd,e ;switch lcd off retdisp_onoff: sbi portd,e ;switch lcd on rcall w_1ms ;wait 1ms ldi lcd_temp,0b00000100 ;display on/off out portd,lcd_temp cbi portd,e ;switch lcd off rcall w_1ms sbi portd,e ;switch lcd on ;wait 1ms rcall w_1ms ldi lcd_temp,0b11100100 ;0b00101000 = 4 bits mode out portd,lcd_temp cbi portd,e ;switch lcd off retclear: sbi portd,e ;switch lcd on rcall w_1ms ;wait 1ms ldi lcd_temp,0b00000100 ;display clear out portd,lcd_temp cbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms sbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms ldi lcd_temp,0b00010100 ;display clear out portd,lcd_temp cbi portd,e ;switch lcd off retentry_mode: sbi portd,e ;switch lcd on rcall w_1ms ;wait 1ms ldi lcd_temp,0b00000100 ;entry mode out portd,lcd_temp cbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms sbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms ldi lcd_temp,0b01100100 ;entry mode out portd,lcd_temp cbi portd,e ;switch lcd off retret_home: sbi portd,e ;switch lcd on rcall w_1ms ;wait 1ms ldi lcd_temp,0b00000100 ;00000010;return home befehl out portd,lcd_temp cbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms sbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms ldi lcd_temp,0b00100100 ;entry mode out portd,lcd_temp cbi portd,e ;switch lcd off ret sh_right: sbi portd,e ;switch lcd on rcall w_1ms ;wait 1ms ldi lcd_temp,0b00010100 ;function shift right out portd,lcd_temp cbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms sbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms ldi lcd_temp,0b11000100 ;function shift right out portd,lcd_temp cbi portd,e ;switch lcd off ret sh_left: sbi portd,e ;switch lcd on rcall w_1ms ;wait 1ms ldi lcd_temp,0b00010100 ;function shift left out portd,lcd_temp cbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms sbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms ldi lcd_temp,0b100000100 ;function shift left out portd,lcd_temp cbi portd,e ;switch lcd off ret x_set: cpse x_counter,col ;if x_counter = col rjmp x_high retx_high: sbi portd,e ;switch lcd on rcall w_1ms ;wait 1ms ldi lcd_temp,0b00010100 ;move cursor right out portd,lcd_temp cbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms sbi portd,e ;switch lcd off rcall w_1ms ;wait 1ms ldi lcd_temp,0b01000100 ;move cursor right out portd,lcd_temp cbi portd,e ;switch lcd off inc x_counter ;increase x_counter rjmp x_set ;and x_set again line1: rcall ret_home ;ret_home ldi x_counter,1 ;set counter to 1 rcall x_set rjmp send1 ;begin to send line2: rcall ret_home ;rethome sbi portd,e ;switch lcd on rcall w_1ms ;wait 1ms ldi lcd_temp,0b11000100 ;upperline out portd,lcd_temp cbi portd,e ;switch lcd on rcall w_1ms ;wait 1ms sbi portd,e ;switch lcd on rcall w_1ms ;wait 1ms ldi lcd_temp,0b00000100 ;upperline out portd,lcd_temp cbi portd,e ;switch lcd on ldi x_counter,1 ;counter = 1 rcall x_set ;goto x rjmp send1 ;begin to sendsend1: ;;;;;lpm ;load zeichen ld text,Z+ ldi cx,0 cpse text,cx ;if there are still characters rjmp send2 ;then send it rjmp send_end ;else go backsend2: sbi portd,e ;switch lcd on sbi portd,rs ;send data rcall w_1ms ;wait 1ms mov lcd_temp,text ori lcd_temp,0b00001100 out portd,lcd_temp ;write data to port cbi portd,e ;switch lcd off rcall w_1ms sbi portd,e ;switch lcd on ;sbi portd,rs ;send data rcall w_1ms mov lcd_temp,text rol lcd_temp rol lcd_temp rol lcd_temp rol lcd_temp ori lcd_temp,0b00001100 out portd,lcd_temp ;write data to port rjmp send3 send3: cbi portd,e ;switch lcd off cbi portd,rs ;data = instruction rjmp send1 send_end: cbi portd,e ;switch lcd off cbi portd,rs ;data = instruction ret ;go back init_lcd: ldi ax,10 ;30 ms rcall delay rcall func_set_ rcall w_16ms ;wait16ms rcall func_set_ rcall w_16ms ;wait16ms rcall func_set_ rcall w_16ms ;wait16ms rcall func_set_ rcall w_16ms ;wait16ms rcall func_set ;function set ldi ax,10 ;30 ms rcall delay rcall w_5ms ;wait 5ms rcall func_set ;function set rcall w_1ms ;wait 1ms rcall func_set ;function set rcall w_5ms ;wait 1ms rcall func_set ;function set rcall w_5ms ;wait 1ms rcall disp_onoff ;display on/off rcall w_5ms ;wait 1ms rcall clear ;clear display rcall w_5ms ;wait 1ms rcall entry_mode ;entry mode rcall w_5ms ;wait 1ms rcall func_set ;function set rcall w_5ms ;wait 1ms rcall disp_onoff ;display on/off rcall w_5ms ;wait 1ms rcall entry_mode ;entry mode rcall w_5ms ;wait 1ms ;**************************************** ;write init text to display ;**************************************** ;write first row on display ;load first 16 char to string ldi ZH,high(F_TABLE*2) ldi ZL,low(F_TABLE*2) ;init Z-pointer ldi YH,high(P_string) ldi YL,low(P_string) ;init Y-pointer ldi ax,16 rcall flash2ram ;copy 17 bytes ;load addres to string ldi YH,high(P_string) ldi YL,low(P_string+16) ;init Y-pointer ;place addres from 4021 in the variable addr ;------------------- ;in ax,pinc ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;take addres from 4021 ldi ex,0 ldi fx,1 ldi hx,0 ldi dx,0b10111111 ;strobe hoog 00000010 out portb,dx ldi ax,1 ;ax bx cx for delay!!!! rcall delay ldi dx,0b00111111 ;strobe laag out portb,dx ldi ax,1 ;ax bx cx for delay!!!! rcall delayloop10: ;start loop sbis pinb,5 ;porta pin 5 high? Skip next inst. if bit 0 in Port a set rjmp loop15 ; Bit not set or hx,fxloop15: lsl fx ;set bit een plaats naar links ldi dx,0b01111111 ;clock hoog 00000001 out portb,dx ldi ax,1 ;ax bx cx for delay!!!! rcall delay ldi dx,0b00111111 ;clock laag out portb,dx ldi ax,1 ;ax bx cx for delay!!!! rcall delay inc ex ldi dx,8 cp ex,dx brne loop10 ;hx = status jumpers now mov ax,hx sts jumpers,ax ;store status jumpers ;for pc make addres ldi dx,0b00111111 and ax,dx ;2 high bits not use for addres <64! mov bx,ax ldi cx,32 add ax,cx ;addres + 32 sts addr,ax ;store addres mov ax,bx ;from bin to decimal AX= LSD BX=MSD clr bx ;clear result MSDbBCD8_1:subi AX,10 ;input = input - 10 brcs bBCD8_2 ;abort if carry set inc BX ;inc MSD rjmp bBCD8_1 ;loop againbBCD8_2:subi AX,-10 ;compensate extra subtraction ;write addres to string ldi cx,48 add ax,cx add bx,cx mov text,bx st Y+,text ;store data to BLOCK2 mov text,AX st Y+,text ;store data to BLOCK2 ;write 2 x space to string ldi dx,32 mov text,dx st Y+,text ;store data to BLOCK2 st Y+,text ;store data to BLOCK2 ;end with zero ldi dx,0 mov text,dx st Y+,text ;store data to BLOCK2 ;write string on display ldi zl,low(P_string) ;set pointer to ldi zh,high(P_string) ;the text ldi col,1 ;set column rcall line1 ;set line ;write second row to string ldi ZH,high(F_TABLE2*2) ldi ZL,low(F_TABLE2*2) ;init Z-pointer ldi YH,high(P_string) ldi YL,low(P_string) ;init Y-pointer ldi ax,20 rcall flash2ram ;write string to display ldi zl,low(P_string) ;set pointer to ldi zh,high(P_string) ;the text ldi col,1 ;set column rcall line2 ;set line rjmp main ;let's go... ;***************************************************************************;*;* "char_ram";*;* This subroutine copies a block of data from the rs_port in a block of SRAM ;* The following parameters must be set up prior to calling the subroutine:;*;;* Y-pointer: start of RAM area to copy to;* ramsize : size of block to copy;***************************************************************************;***** Code ;char_ram:;char_ram1:; sbi ucr,rxen ;set reciver bit... ; sbis usr,rxc ;wait for a valuable ; rjmp char_ram1 ; in text,udr ;read valuable ; cbi ucr,rxen ;clear register ; st Y+,text ;store data to BLOCK2; dec ax ;;char_ram2:; sbi ucr,rxen ;set reciver bit... ; sbis usr,rxc ;wait for a valuable ; rjmp char_ram2 ; in text,udr ;read valuable ; cbi ucr,rxen ;clear register ; st Y+,text ;store data to BLOCK2; dec ax ;; brne char_ram1 ;if not done, loop more; ldi dx,0; mov text,dx ;eindig string met een null; st Y+,text ;store data to BLOCK2; ret;okgedeelte:; rcall rs_rec; st Y+,text ;store data to BLOCK2; dec ax ;; brne char_ram ;if not done, loop more; ; ldi dx,0; mov text,dx ;eindig string met een null; st Y+,text ;store data to BLOCK2; ret;***************************************************************************;*;* "flash2ram";*;* This subroutine copies a block of data from the Program memory (Flash) ;* to the internal SRAM. The following parameters must be set up prior to ;* calling the subroutine:;* Z-pointer: Flash block start address x 2 (WORD oriented code segment);* Y-pointer: ram block start address;* romsize: block size;*;* Number of words :5 + return;* Number of cycles :10 x block size + return;* Low Registers used :1 (r0);* High Registers used :1 (flashsize);* Pointers used :Y, Z;*;***************************************************************************;***** Subroutine Register variables;***** Code flash2ram: lpm ;get constant st Y+,text ;r0 ;store in SRAM and increment Y-pointer adiw ZL,1 ;increment Z-pointer dec ax brne flash2ram ;if not end of table, loop more ret;***************************************************************************;*;* "ram2ram";*;* This subroutine copies one block of data from one SRAM area to another.;* The following parameters must be set up prior to calling the subroutine:;*;* Z-pointer: start of RAM area to copy from;* Y-pointer: start of RAM area to copy to;* ramsize : size of block to copy;*;* Number of words :4 + return;* Number of cycles :6 x block size + return;* Low Registers used :1 (ramtemp);* High Registers used :1 (ramsize);* Pointers used :Y, Z ;*;***************************************************************************ram2ram: ld text,Z+ ;get data from BLOCK1 st Y+,text ;store data to BLOCK2 dec ax ; brne ram2ram ;if not done, loop more ret;**********************************************************************;subroutine to receive 1 byte from the uartt;text :received char;**********************************************************************;rs_rec: ; sbi ucr,rxen ;set reciver bit... ; sbis usr,rxc ;wait for a valuable ; rjmp rs_rec ; in text,udr ;read valuable ; cbi ucr,rxen ;clear register ; ret ;**********************************************************************;subroutine for transmit a byte to the uart;text :char to transmit;**********************************************************************;rs_send: ;*******write to port; sbi ucr,txen ;set sender bit ; sbis usr,udre ;wait till register is cleared ; rjmp rs_send ; out udr,text ;send char to rs232 ; cbi ucr,txen ;clear sender bit ; ret ;go back ;************************************************************;subroutine for delay ;ax= 5 = 1/2sec;************************************************************DELAY: ; ldi ax,5 ;triple nested FOR loopcagain: ldi bx,255 ;giving about 1/2 secondmagain: ldi cx,255 ;delay on 4 MHz clockfagain: dec cx brne fagain dec bx brne magain dec ax brne cagain ret;*************************************************************************** ;************************************* ;main program ;*************************************;***************************************************************************main: cbi portb,1 ;set uitgang 1 portb show init OK patch 15-3-2002 cbi portb,3 ;3 enable rs232 for input main1: ;receive data for 9bit and addres main2: ;255 received? sbi ucr,rxen ;set receiver bit... sbis usr,rxc ;wait for a valuable rjmp main2 in text,udr ;read valuable cbi ucr,rxen ;clear register ldi ex,10 cp text,ex ;10 received? brne main2 ;nee back main3: ;255 received? sbi ucr,rxen ;set reciver bit... sbis usr,rxc ;wait for a valuable rjmp main3 in text,udr ;read valuable cbi ucr,rxen ;clear register ldi ex,10 cp text,ex ;10 received? brne main2 ;nee back main5: ;addres received? sbi ucr,rxen ;set receiver bit... sbis usr,rxc ;wait for a valuable rjmp main5 in text,udr ;read valuable cbi ucr,rxen ;clear register lds dx,addr cp text,dx brne main2 ;Nomain10: ;received char == addres cbi portb,2 ;2 led receive bussy ;get data rs485 sbi ucr,rxen ;set reciver bit... sbis usr,rxc ;wait for a valuable rjmp main10 in text,udr ;read valuable cbi ucr,rxen ;clear register com text out porta,text ;set portamain20: ;get the next 40 char for the display ;get first 20 char and place it in P_string; cbi portb,3 ;enable rs232 in; ldi YH,high(P_string) ;(not necessary in this specific case) ldi YL,low(P_string) ;init Y-pointer ldi ax,40 ;20 ;get next 20 char and place it in P_string2 ; ldi YH,high(P_string2) ;(not necessary in this specific case);x ldi YL,low(P_string2) ;init Y-pointer;x ldi ax,20;x rcall char_ram ;copy 20 bytes +0main50: ;copy 40 bytes from rs485 to ram sbi ucr,rxen ;set reciver bit... sbis usr,rxc ;wait for a valuable rjmp main50 in text,udr ;read valuable cbi ucr,rxen ;clear register st Y+,text ;store data to BLOCK2 dec ax ;; brne char_ram1 ;if not done, loop moremain51: sbi ucr,rxen ;set reciver bit... sbis usr,rxc ;wait for a valuable rjmp main51 in text,udr ;read valuable cbi ucr,rxen ;clear register st Y+,text ;store data to BLOCK2 dec ax ;main52: sbi ucr,rxen ;set reciver bit... sbis usr,rxc ;wait for a valuable rjmp main52 in text,udr ;read valuable cbi ucr,rxen ;clear register st Y+,text ;store data to BLOCK2 dec axmain53: sbi ucr,rxen ;set reciver bit... sbis usr,rxc ;wait for a valuable rjmp main53 in text,udr ;read valuable cbi ucr,rxen ;clear register st Y+,text ;store data to BLOCK2 dec ax cpi ax,0 brne main50 ;if not done, loop more ldi dx,0 mov text,dx ;eindig string met een null st Y+,text ;store data to BLOCK2main100: ;transmit addres and data from portc rcall w_5ms ;rcall w_5ms ;patch 14-2 sbi portb,3 ;enable rs485 out lds text,addr ;first send addresmain101: ;Write to rs485 sbi ucr,txen ;set sender bit sbis usr,udre ;wait till register is cleared rjmp main101 out udr,text ;send addres to rs485 cbi ucr,txen ;clear sender bit ;send portb to rs485 in ax,pinc ;send info portb to rs485main102: ;write to rs485 sbi ucr,txen ;set sender bit sbis usr,udre ;wait till register is cleared rjmp main102 out udr,ax ;send PINC to rs485 cbi ucr,txen ;clear sender bit ;send again addres lds text,addr ;send again addresmain103: ;write to rs485 sbi ucr,txen ;set sender bit sbis usr,udre ;wait till register is cleared rjmp main103 out udr,text ;send addres to rs485 cbi ucr,txen ;clear sender bit rcall w_1ms ;patch 22-1-2002 cbi portb,3 ;0;enable rs232 for input sbi portb,2 ;led receive bussy main150: ;write strings to display ;first P_string to row 1 ldi zl,low(P_string) ;set pointer to ldi zh,high(P_string) ;the text ldi col,1 ;set column rcall line1 ;set line ;P_string2 to display ldi zl,low(P_string+20) ;set pointer to ldi zh,high(P_string) ;the text ldi col,1 ;set column rcall line2 ;set line main_end: ;cbi portb,3 ;0;enable rs232 for input ;sbi portb,2 ;led receive bussy rjmp main1 ;;************* ;text constant FLASH EEPROM;************* F_TABLE: ;17 lang .db 32 ,32 ,68 ,67 ,73 ,45 ,66 ,85 ,83 ,32 ,65 ,100,100,114,58 ,32,0 ; D C I - B U S A d d r : F_TABLE1: ;5 lang .db 51 ,55,32,42,0 ; F_TABLE2: .db 32, 119,97 ,105,116,105,110,103,32 ,102,111,114,32 ,100,97 ,116,97,46,33,32,0 ; w a i t i n g f o r d a t a . !
Macar daca era in C. In asm e cam greu de deslusit un program facut de altcineva.
Daca e un program pentru afisat text pe un LCD gen 44780 cred ca e mai usor de facut programul de la 0 decat de inteles de la altcineva. Am facut acum cativa ani un prog in asm pentru afisat pe LCD bazat pe controller KS0066U - Samsung, de genul celor de la C0met AC162 - si a iesit la vreo 150-200 instructiuni - nu am reusit sa fac sa mearga generarea de caractere speciale.
Pentru KS0066U am folosit acest datasheet:
http://www.datasheetarchive.com/pdf/1914414.pdf
