Controler selectie surse / volume atenuator
danzup
yo9hnf a facut un sumar al paginilor si ii multumesc pentru acest lucru.
Analizator + corector ATMEGA32 http://elforum.info/viewtopic.php?f=35&t=29786&start=800
Conectare module http://elforum.info/viewtopic.php?f=35&t=29786&start=550
PGA2310 + Atmega 8 viewtopic.php?f=37&t=119742
PGA2310 + Atmega8515 + schema http://elforum.info/viewtopic.php?f=35&t=29786&start=575
PGA2310 + Atmega8515 + schema http://elforum.info/viewtopic.php?f=35&t=29786&start=175
Potentiometru + Atmega8 http://elforum.info/viewtopic.php?f=35&t=29786&start=750
Potentiometru + Atmega8515 http://elforum.info/viewtopic.php?f=35&t=29786&start=750
Potentiometru + Atmega8515 http://elforum.info/viewtopic.php?f=35&t=29786&start=25
Potentiometru + Attiny2313 http://elforum.info/viewtopic.php?f=35&t=29786&start=750
R-2R + Atmega8 http://elforum.info/viewtopic.php?f=35&t=29786
R-2R + Atmega8515 http://elforum.info/viewtopic.php?f=35&t=29786&start=750
Relee + Atmega8 http://elforum.info/viewtopic.php?f=35&t=29786&start=225
TDA7313 + Atmega8515 http://elforum.info/viewtopic.php?f=35&t=29786&start=750
TDA7318 + Atemega8 + PCB http://elforum.info/viewtopic.php?f=35&t=29786&start=775
TDA7318 + Atmega8 + schema http://elforum.info/viewtopic.php?f=35&t=29786&start=750
TDA7318 + Atmega8515 http://elforum.info/viewtopic.php?f=35&t=29786&start=750
TDA8421 + Atmega8515 http://elforum.info/viewtopic.php?f=35&t=29786&start=800
Testare telecomanda Atmega8515 http://elforum.info/viewtopic.php?f=35&t=29786&start=750
Tester telecomanda Atmega8 http://elforum.info/viewtopic.php?f=35&t=29786&start=825
Versiune Group-Buy - firmare 2.2 si 2.3 http://elforum.info/viewtopic.php?f=35&t=29786&start=825
Am facut un add-on pentru preamplificatoare, pe care daca vrei sa-l faceti, va dau tot ajutorul posibil... :
- microcontrolerul este atmega8 avr
- comanda selectia de pana 8 surse de semnal
- volum cu attenuator R/2R logaritmic ladder
- LCD pentru afisarea informatiilor
- comanda cu telecomanda infrarosu codare Rc5 :
Prima data cind porneste afiseaza pe LCD mesajul privind versiunea de soft si apoi trece singur in stand-by oprind si LCD-ul . Apasand butonul on/off sau cu telecomanda porneste ,afiseaza apoi inputul selectat si nivelul volumului memorat .
La oprire memoreaza ultimele selectii la input si volum .
Schema v1.6 :
Later Edit : am adaugat conectorul ISP (in system programming)pentru a actualiza firmware .
Posted Image
Schema relee- attenuator :
Posted Image
C.I. pcf comanda direct relee de 5 Volti / 2 contacte .
Am in lucru alte 2 variante una mai hi-end si una chiar mai ieftina ca asta . La finalizare o sa postez .
Daca vreti sa va definiti butoanele din telecomanda pot sa va dau variante de programe pe care il incarcati ,apasati butoanele , va notati codul butoanelor si apoi editind programul inlocuiti cu codurile butoanelor in cod acolo unde am scris .
( cod scris pentru Sirc - Sony , Nec si RC6. Atentie - pentru telecomenzi Sony si NEC va trebuie ctrl_lcd_m8_v015.bas respectiv ctrl_lcd_m8_v017.bas ) .Varianta asta e pasiva .
- poza in timpul lucrului la prototipul cu potentiometru alps pentru volum :
http://i26.tinypic.com/29ndks5.jpg
- poza in timpul lucrului la prototipul cu attenuator R/2R pentru volum :
http://i30.tinypic.com/29bf1qw.jpg
Later edit : intotdeauna spre sfarsit se afla variante mai noi de firmware ! Verificati versiunea .
Varianta hi-end are in serie 23 de rezistente si 24 de relee , iar reglajul va emula un reglaj cu comutare rotativa pentru 24 de pozitii ...
Schema :
Posted Image
De aici rezulta ca trebuie sa am numai pentru volum 3 pcf8574ap ( 8 iesiri x 3 = 24 de relee) si inca un pcf8574ap pentru selectia de intrari .
Asta va afisa in schimb volumul de la 0 la 23 si nu atenuare ca varianta cu R/2R cu 6 relee.
Am o varianta de schema cu Atmega8515 unde se folosesc doar pinii avr ului ( fara nimic altceva ).Asta e varianta ieftina despre care vorbeam mai sus .O sa postez si asta peste cateva zile !
Daca vreti puteti realiza hardware de la adresa :http://www.vaneijndhoven.net/jos/relaixed/ fara pic-ul de acolo ci cu controlerul meu varianta ctrl_lcd_m8_v019.bas. Cine vrea sa-l ceara .
E interesanta si varianta cu afisaj cu LED-uri , dar se gaseste rotary switch ? Oricum o sa fac schema postata , la sfarsitul saptamanii viitoare o sa-mi vina integratele PCF8574A , pana atunci am timp de proiectare.
Pai asta e problema : nu se gasesc rotary switch pe la noi ..........
dar cele patru butoane : V+ V- S+ si S- le inlocuiesc cu succes .
Ma refeream la schema respectiva fara pagina pe care scrie " Balanced preamp - Digital control ".
http://www.vaneijndhoven.net/jos/relaix ... _mar08.pdf
Dar se poate pune in loc de lcd din varianta cu avr 2 digiti pe care sa afisam volumul si eventual S1... S8 cand se selecteaza sursele ..
Mi-ai dat o idee !
:smt003
Varianta cu tranzistoare si astfel puteti folosi orice relee : la 9 V , 12V sau 24V.
Posted Image
si partea de relee pentru aceasta versiune :
Posted Image
si respectiv atasata versiunea de soft.
Revin un pic mai tarziu cu versiunea atmega8515 .
Schema :
Posted Image
atenuatorul audio :
Posted Image
Are numai 6 intrari .
Restul asemanator cu celelalte .
Updatat soft versiunea 1.0
Prima data cind porneste afiseaza pe LCD mesajul privind versiunea de soft si apoi trece singur in stand-by oprind si LCD-ul . Apasand butonul on/off sau cu telecomanda porneste ,afiseaza apoi inputul selectat si nivelul volumului memorat . La oprire memoreaza ultimele selectii la input si volum .
Si varianta "ieftina" face lucrurile astea ?
Toate fac acelasi lucru ! In soft doar partea de iesire e diferita !
Singurul fusebit care trebuie scris la microcontrolere AVR atmega 8 si atmega 8515 , la progamare este : " internal oscilator rc 8Mhz ".
Eventual programez gratuit atmelul pentru cine vrea !
Daca vrea cineva numai 4 intrari (adica si mai ieftin, renuntand la 2 tranzistoare si 2 relee ) sa zica : modificam softul imediat .
Softul asa cum e acum, raspunde la telecomanda universala rc5 la urmatoarele butoane : V+ ,V- ,Ch+( P+), Ch-(P-), on/off .
  • 2 săptămâni mai târziu...
