Masina de bobinat trafo
Vizitator gobolino
  • Răspunsuri 194
  • doru3160
    21
  • cristi_ro
    13
  • Dan57
    13
  • MifTy
    9
Vizitator marian_ariciuc
foarte tare... am desenat cablaj, am printat, noroc ca n-am corodat ca mi-a dat prin minte: ''poate nu gasesc uC cu o astfel de carcasa(SMD 28 pini)''...si chiar asa e...concluzia: cumpar uC-ul(oricare as gasi...) si apoi desenez :bataie ...
am nevoie de ceva indrumari la programarea ATmaga 168...pentru inceput:am un USBasp, am construit cablajul de lucru cu mufa ISP, cred ca am desenat fara greseli(nu pun nici un uC in soclu fara sa masor tensiunile...)mai multi mi-au recomandat Kahzama AVR programmer, de la Dl. Dan57 am un text despre cum sa setez fuse bitii:
„Lock bit protection modes Mode1Aplication protection Mode1Boot loader protection Mode1Fuse Bits RSTDISBL=0 disable DWEN=0 dis SPIEN=0 enable WDTON=0 dis EESAVE=0 dis CKDIV8=0 dis GKOUT=0 disBoot reset vector dis BOOTSZ=0 Boot reset vector at 1C00h (boot size 1024 words)Brown out BODLEVEL=111 Set Brown out detect to disableClock option and start-up time CKSEL=0010, SUT=10 Int.RC osc 8Mhz, start-up time 6CK+65ms Oscilator calibration bytes Calibration value write at address: 00000000”
Deci:Selectez din acea lista(lock bits, H fuse, L fuse, E fuse) insa mi-e cam neclar la E fuse: a) BOOTSZ=0 Boot reset vector at 1C00h si eu am infereastra Kahzama:”dolar”1C00(fara h)b) Boot reset vector Enabled [bOOTRST=0] – nu este ‚pomenit’ in document...am facut niste print screenuri:post-1-1398295153_thumb.jpgpost-1-139829515305_thumb.jpgpost-1-139829515311_thumb.jpg astept un raspuns, sa vad daca e corect sau nu
avrdude: warning: cannot set sck period. please check for usbasp firmware update.avrdude: error: programm enable: target doesn't answer. 1 avrdude: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check.avrdude done. Thank you.
  • 1 lună mai târziu...
Fiindca subiectul a amortit putin si suntem la atelierul mecanic, va prezint, mai jos, scula pe care am facut-o zilele trecute, din materiale recuperate, fara prea mari pretentii, insa deja si-a dovedit utilitatea -vezi ultima poza!
Cred ca imaginile postate sunt edificatoare si voi mai adauga doar ca s-a folosit lemn de frasin, rulmentul este 6204 recuperat de la o pompa, iar pentru fixarea platanului (de la picupul Pacific) pe bara filetata si pe dimensiunea interioara a rulmentului, dar si pentru manerul de rotire al platanului, am folosit 2 bolturi uzate de la pistonul de Trabant (care stateau pe undeva) asa s-a nimerit si, s-a nimerit bine :da Fiecare poate folosi oricare alta teava,bucsa si orice alt rulment care ar avea cote imperecheate.
Pentru fixarea rulmentului in lemn (pe exterior), desi nu a fost neaparat nevoie, avand grija la pilirea locasului de fixare a acestuia, am folosit banalul poxipol.
Restul a fost lemnarie si clei + fieratanii si suduri.
Salut initiativa de a se face o sectiune de lucru cu lemnul!
Felicitari pentru constructie si mai ales pentru modul practic si economic cum ai realizat-o. Masina de bobinat, de tip "manivela", cu raportul de transmitere 1:1, are intr-adevar cea mai larga utilizare printre amatori. Privind lucrurile in mod critic, as putea sa spun ca daca inaltai axa manivelei putin mai sus, relativ la stativ, aveai o excelenta masina de bobinat universala, utilizabila inclusiv la rebobinarea motoarelor electrice. Pentru o si mai buna functionalitate a dispozitivului, poti renunta la cel de al doilea lagar, caz in care singurul lagar ramas se va consolida eventual prin utilizarea a doi rulmenti in loc de unul - pentru stabilitate. Pentru rigidizarea constructiei, se vor face doua gusee dispuse atat spre partea cu manivela, cat si spre arborele filetat pentru fixarea bobinei si care vor intari singura placa port-lagar din lemn ramasa. Un exemplu de design pentru un dispozitiv pentru bobinat motoare electrice, este reprezentat in succesiunea de imagini 3D atasata mai jos. Dispozitivul se ataseaza foarte simplu la masina de bobinat pe care ai realizat-o, prin introducerea pe arborele de fixare a masinii a ansamblului din figura, centrat pe gaura centrala a liniarului. Piesele principale, pot fi de asemenea confectionate din lemn de esenta tare, sau eventual din textolit.post-27597-139829555753_thumb.png
Propun o schema de numarator pentru masina de bobinat.Numararea se face cu un disc cu fante care se monteaza pe axul principal.Din sw1 se selecteaza binar numarul de fante al discului (2 - 256). Este important ca cele doua optocuploare sa fie in quadratura. Circuitul detecteaza automat sensul. Numarul minim de fante recomandat pentru functionare sigura este de 10. Peste 50 de fante apar probleme mecanice, fiind din ce in ce mai greu sa potrivim cele doua fante ale optocuploarelor, sau creste prea mult diametrul discului. R4 - R6 se aleg in functie de optocuploarele pe care le detineti.Din JP3-JP4 se alege anclansarea releului - la egalitatea cu setarea tumblerelor sau la ajungerea la zero a numaratorului (indiferent ca numaratorul numara in sus sau in jos).Eu l-am facut sa numere in jos pe masura ce numarul de spire bobinate creste. Astfel setez din tumblere nr. de spire dorit, apoi pornesc motorul masinii si aceasta se opreste la zero (cu releul din schema).
NUMARATOR.pdf
  • 3 săptămâni mai târziu...
