frantuzu_lan Postat Martie 3, 2008 Partajează Postat Martie 3, 2008 Am nevoie de un program care sa inregistreze 7 zile sa stocheze pe hdd si apoi sa o ia de la cap .. camera de supraveghere este:- Camere IP miniatura cu iluminator model EC-800 (CMOS) Camera 1/4 " Color CMOS 307,200 Pixels (VGA) SensorLens Board Lens Type, 6.0mm, F1.8.System ? CPU / Encode Chip: SOC/ JPEG Encode Chip (VGA)? Video Compression: M-JPEG? Audio Compression: ADPCM 8kbps? Image Size (HxV): 640x480 (VGA) , 320x240 (CIF) , 160x120 (QCIF)? Image Quality: 3 Level ( High , Mediem , Low )? Frame Rate: Up to 12fps@VGA , 25fps@CIF? Protocol: TCP/IP , ARP , ICMP , HTTP , SMTP , FTP , DHCP , DNS , DDNS , NTP , PPPoE Interface ? Ethernet: 100Base-TX / 10Base-T (RJ-45x1)? Status LED: Power , LAN & WLAN? DI: Sensor in x 1? Button: Reboot / Restore factory default? Power Supplied: DC Jack (5V)? Night Vision: Auto , IR-LED x 6 (L10)Software Function ? User Management: Two layers (Administrator / Guest)? Network Setting: IP & Domain name (Fixed , DHCP , PPPoE , DDNS ) , HTTP Port number? Image Setting: Resolution ( 640x480 , 320x240 , 160x120 )Parameter (Brightness,Contrast, Saturation,Sharpness)? Camera Setting: Camera Name , date/time (NTP , manual) , Frequency (60/50Hz)? Email / FTP: Email , FTP setting --> action (auto,manually)? Motion Detection: Enable/Disable (Two region setting)? Snapshot: Auto via FTP/Email , Manually? Record: Manually (AVI *Microsoft DirectX8.1,VGA Card 32bit true color)? Number of clients: 4System Requirements ? Operation System: Microsoft Windows 98/ME/2000/XP/2003? Browser: Microsoft Internet Explorer 5.x or aboveOther ? EMC / Safety: FCC / CE? Power Requirements: DC 5V 2A? Temperature: Operation 0 °C ~ 50 , Storage -20 °C ~ 70 °CAcestea sunt detaliile despre ea Pls Help Link spre comentariu
Kiusro Postat Iulie 2, 2008 Partajează Postat Iulie 2, 2008 salut, ai incercat Cam Wizard? http://www.ledset.com/camwiz/download/C ... nstall.zip Link spre comentariu
