SirRoger Postat Februarie 20, 2008 Partajează Postat Februarie 20, 2008 Poate cineva sa-mi spuna cum se confectioneaza socul de RF ( de protectie) de la iesirea liniarului?Acela care, in cazul strapungerii condensatorului de separare, pune la masa inalta tensiune.Peste tot in specificatii gasesc comentarii de felul: ,,soc comun de RF"... :smt017 Multumesc, Link spre comentariu
MiniTehnicus Postat Februarie 20, 2008 Partajează Postat Februarie 20, 2008 At the output end of the pi-circuit, a RF-choke between antenna-terminal and earth ensures a low-resistance DC-path, as a safety measure in the event of a short between the anode and the output-circuit. The Telecom authorities also require it. When the anode voltage is shorted to the output, without a DC-path to earth for blowing the HT fuse (the wire-wound resistor in the anode-circuit will curtail the flaming arc across the blown fuse), the antenna cable and antenna will become death traps. An adequate choke is a short ferrite rod with 30?50 turns of 25 SWG enamelled wire. Check it with a GDO for absence of series-resonance in any amateur band.Tot articolul se gaseste aici:http://www.xs4all.nl/~pa0fri/Lineairs/F ... 150eng.htmAn adequate choke is a short ferrite rod with 30?50 turns of 25 SWG enamelled wire. Check it with a GDO for absence of series-resonance in any amateur band.Se foloseste o bara scurta de ferita pe care se bobineaza 30-50 spire cu sarma de 0,5mm CuEm.Bara de ferita se recupereaza de la un aparat de radio AM de buzunar. Link spre comentariu
SirRoger Postat Februarie 21, 2008 Autor Partajează Postat Februarie 21, 2008 Multumesc pt. info !73! Link spre comentariu
