SDT 9204,TERMINAT 70%
dany
  • Răspunsuri 52
  • dany
    23
  • zal
    17
  • EmyRulz
    8
  • AV1000
Asta e o schema a amplificatorului Naim NAP 250(hi end :smt003 ). Desigur tranzistorii se pot schimba cu unii mai de actualitate.Nu mi-am dat seama ca BC 239C are o tensiune asa de mica. Nu vad care ar fi problema cu filtrul de pe intrare(pana la urma suntem in audio nu in RF), dar se poate pune un cond de 150-200 pf in locul celui de 330.Pt mai multe detalii despre constructie uita-te aici: http://www.diyaudio.com/forums/showthread.php?s=&threadid=5372&perpage=25&highlight=&pagenumber=2@zal pai R2+R3 nu e impedanta care se vede intre baza T1 si masa(adica impedanta de intrare a amplifului, pt ca impedanta de intrare T1 e mult mai mare)?
Am vazut pe diyaudio zice de ceva PCB,daca are cineva cont pe forumul acesta si poate il rog sa posteze un cablaj al amplifului,si inca ceva tranzistorii MPS,ZTX,MJEnu apar pe stoc la magazinului de unde imi cumpar eu piese,nu au ceva echivalentemai usor de procurat?Sper ca pot folosi in schema SDT9204,si nu am nevoie de alti trz. ms
Nu e cablajul detaliat si nu cred ca e originalul dar daca l-ai cerut ia de aici :cat despre tranzistori uite ce zice cineva :" Zetex ceased production of these to the beginning of the year, but Naim always got their transistors from another supplier respective second source (someone mentioned it on the Naim forum, but I cannot remember the brand).Have in mind that the Naim stuff was designed in the 70ies, and the choice of transistors simply reflects the standard of that time. Of course you can use BC384 or BC214 which are the generic numbers for said Zetex variants. Or even more modern devices, like BC550C, BC550C. Or even more standard hi-end transistors like the common Hitachi 2SC1775/2SA872 or Toshiba 2SC2240/2SA940.Almost any small signal NPN and PNP transistors will work in a Naim preamp circuit.Neil McBride did use the Toshiba 2SC2547A for the NPN small signal transistor, but I do not like that choice.I prefer 2SC2240 for the NPNs and 2SA872 for the VAS.regards, Hartmut"
Da se pot modifica tensiunile de alimentare la +/- 44VLa tensiunea asta se va disipa mai putina putere si cred ca merg si tranzistorii tai. Oricum daca faci aceasta modificare va scadea un pic sensibilitatea de intrare dar nu e nicio problema. Daca vrei sa ai aceeasi sensibilitate de iesire trebuie marita un pic R14.
Mersi,am optat pt o varianta mai sigura 2X75w de la Electronica industriala,zilele acestea rezolv cu cablajul dupa care am sa postez si poze.
E vorba de fapt de Electro-Mures. Si nu schemele erau slabe ci calitatea pieselor si executia la amplifurile românesti, toate initial au fost realizate ca prototipuri cu piese bune si lucrate ingrijit, la trecerea in productie s-au facut tot felul de compromisuri tehnice si inlocuiri de piese care stricau totul. Plus ca se lucra cu navetisti si oameni fara talent in meserie. Cine se pricepea si avea rabdare, dupa ce-si cumpara una, se punea pe imbunatatiri. :smt003
Daca tot s-a facut la productie de serie nu se gaseste un cablaj pt acest amplif sau macar asemanator.thx
  • 2 săptămâni mai târziu...
E simplu de facut, iar daca ar fi sa-ti dau o sugestie, cauta un cablaj de la un amplif asemanator ca schema si refoloseste-o.
Mersi mult,pana la urma am facut cabalajul in paint,pt. corodare am folosit metoda xerox+fier de calcat,toate piesele pt varianta stereo au fost undeva la 40 lei,am insa niste nelamuriri, pt acest amplif am nevoie de intarziere la cuplarea boxelor?potentiometrul de 250 ohmi cum trebuie reglat?(eu l-am reglat in asa fel incat sa am +1,1v in baza prefinalului),ma intereseaza ceva date despre acest amplif(Putere,Thd,Frecventa,Tipul Amplifului)Ce sigurante sa pun pe alimentare pentru varianta stereo?Dar pe iesirea amplifului?(am pus 1 A si am ars)
Alimentat de la o sursa +-33v de 2 A eu zic ca se aude chiar foarte bine.
Cateva poze:
Posted Image
Posted Image
Posted Image
E destul de bine cum ai reglat finalul, +1,1V ai masurat in baza la trz prefinal npn, fata de masa, sau si mai bine fata de iesire, banuiesc. Masoara si intre b-e trz finali, ar trebui sa ai cam 0,5V la fiecare, daca e o diferenta mai mare, poti sa mai maresti cite putin pina se egalizeaza, ai grija sa nu depasesti 0,6V ca or sa fiarba trz finali. Vad ca nu ai pus trz superdioda pe radiatorul trz finali, fa macar sa stea lipit (nu in scc) cu radiatorul unui trz prefinal.Ai nevoie de un circuit de intirziere la cuplarea difurilor la pornire, mai bine faci o protectie intreaga cu TA7317P sau uPC1237A.Daca folosesti difuri de 8Ohmi poti sa pui sigurante de 2A pe ramuri, la fiecare amplif, dublezi ptr difuri de 4Ohmi (totusi va fi cam greu sa duca de 4Ohmi). Ai pus siguranta pe iesire, in cazul ei va trebui sa fie mai mare ca de cele de pe alimentare (3...4A).La filtrul de pe iesire, pune condensatorul la 100V si rez la 1W.Bravo, sa continui munca!
offtopic: la un amplif stereo de vreo 2*30-35w problema este ca se incinge un final mai tare decat celalalt pe ambele canale.pe unul am cam0.1v si p celalalt 0.5v intre B-E pe ambele canale.sa fiede la sursa deoarece am o dif de 0,3-0,5 v intre ramuri?
Mersi,reglat la 1,1v a mers cam 10 minute fara nici o problema,la volum destul de mare (sarcina 4ohmi),fara sa se incalzeasca finalii,doar prefinalii s-au dezmortit,Zilele acestea fac si perechea (pt stereo) ,am sa postez poze cu amplifu 'aranjat'.
