Spitfire Postat Februarie 9 Partajează Postat Februarie 9 Ma tem ca va jucati cu focul folosind electrod de inox/nicrom ca electrod negativ...aerul contine apa, umiditatea dintr-o incapere de locuit are 45...55% nivel de saturatie cu vapori de apa, practic, se produce o electroliza subtila in aer, in care catodul doneaza ioni din masa lui, otravind aerul cu diverse tipuri de ioni de crom, inclusiv cel hexavalent! https://en.wikipedia.org/wiki/Hexavalent_chromium "Toxicity Many hexavalent chromium compounds can be carcinogens (IARC Group 1), especially if airborne and inhaled where they can cause lung cancer. Positive associations have also been observed between exposure to chromium(VI) compounds and cancer of the nose and nasal sinuses.[8] Workers in many occupations are exposed to hexavalent chromium. Problematic exposure is known to occur among workers who handle chromate-containing products and those who grind and/ or weld stainless steel.[9] Workers who are exposed to hexavalent chromium are at increased risk of developing lung cancer, asthma, or damage to the nasal epithelia and skin.[5] Within the European Union, the use of hexavalent chromium in electronic equipment is largely prohibited by the Restriction of Hazardous Substances Directive and the European Union regulation on Registration, Evaluation, Authorisation and Restriction of Chemicals.[10] https://phoenixmodels.ro/ro/88-tije-carbon Mai bine dati 10-15 lei pe o tija de carbon si stati fara grija. Link spre comentariu
Alic Postat Februarie 9 Autor Partajează Postat Februarie 9 Acum 37 minute, Spitfire a spus: Ma tem ca va jucati cu focul folosind electrod de inox/nicrom ca electrod negativ...aerul contine apa, umiditatea dintr-o incapere de locuit are 45...55% nivel de saturatie cu vapori de apa, practic, se produce o electroliza subtila in aer, in care catodul doneaza ioni din masa lui, otravind aerul cu diverse tipuri de ioni de crom, inclusiv cel hexavalent! Ma bagati in sperieti. Iau tija de carbon acum. Vad ca au si de un milimetru. Asta nu se mai descompune? Link spre comentariu
Stefan Postat Februarie 12 Partajează Postat Februarie 12 La 09.02.2025 la 22:41, Alic a spus: Iau tija de carbon acum Îți trimit așa ceva? Am luat 10m https://a.aliexpress.com/_ExN9a5I Nu știu dacă e bun de ceva sau cum o să-i fac prinderea la HV. Link spre comentariu
Alic Postat Februarie 12 Autor Partajează Postat Februarie 12 O fi bun de ceva? Înțeleg că sunt niște fire subțiri de carbon [ chinezesc ] acoperite de un tub siliconic. Lițele alea de carbon ce diametru au? Fă-i o poză să văz mai bine minunea. Tu pentru ce l-ai luat, să încălzești ceva? Link spre comentariu
Stefan Postat Februarie 12 Partajează Postat Februarie 12 Le fac o poza diseară, sunt subțiri dar nu știu sa zic ce secțiune. Initial doream sa-mi fac un fel covoraș încălzit alimentat printr-un dimmer, abia după ce am citit mesajele voastre cu bara de carbon m-am gândit la firul asta. Link spre comentariu
Alic Postat Februarie 12 Autor Partajează Postat Februarie 12 (editat) Pare interesant cablul asta. O sa fac o comanda de 20 m. Poate incerci sa-l bagi in priza si sa masori temperatura + curentul. Nu e mare lucru sa pui un cablu cu stecher. Ce usor este sa-i spun altuia ca nu-i mare lucru... La cate am eu de facut si nu le mai termin. Editat Februarie 12 de Alic Link spre comentariu
vlad751 Postat Februarie 12 Partajează Postat Februarie 12 Pare a fi o rezistenta de degivrare Link spre comentariu
Alic Postat Februarie 12 Autor Partajează Postat Februarie 12 Uite ce fac unii cu acest cablu. Il rog pe validae sa mute intr-un topic nou chestia asta. Cred ca poate fi utila pentru unii mai indemanatici. Link spre comentariu
Marele Savant Postat Februarie 12 Partajează Postat Februarie 12 Acum 3 ore, vlad751 a spus: Pare a fi o rezistenta de degivrare Exact aia este, scrie si pe site! Link spre comentariu
daniels Postat Februarie 12 Partajează Postat Februarie 12 O undita (varga) din fibra de carbon. Daca nu merge instalatia te calmezi la pescuit. 1 Link spre comentariu
Stefan Postat Februarie 12 Partajează Postat Februarie 12 @Alic trebuia să te las pe tine să-l testezi primul. Acum 10 ore, Alic a spus: niște fire subțiri de carbon Până acum nu dezizolasem capetele. Firele de carbon sunt extrem de subțiri și îmi e imposibil să măsor diametrul unei fibre, firele de păr uman (din cap) par groase în comparație cu astea. Prima dată l-am alimentat câteva secunde pentru a verifica dacă nu ia foc din prima. După aceea, l-am lăsat un minut și ceva, dar nu am mai rezistat nici la mirosul greu de suportat, deși sunt răcit și abia respir pe nas, și nici de teama că ceva ar putea lua foc. Nu am înțeles dacă siliconul mirosea așa sau praful alb (talc?) care era aplica și cumva a dispărut, oricum nasol cu aerisitul la ora asta și pe caniculă. https://streamable.com/e5e72h Am văzut fir pentru degivrare electrica și arătat mult mai serios și sigur in exploatare și nici nu se incalzea în halul ăsta. Degivrarile pe care le-am văzut aveau controler de temperatura dar ăla monitoriza doar punctul de temperatura minimă pentru a știi când să conecteze alimentarea cablului. Curentul măsurat de contor pentru 10m este de 0,756-0,753A. Link spre comentariu
ex.escu Postat Februarie 12 Partajează Postat Februarie 12 Cablul de incalzire are o anumita putere disipata/metru liniar ; am folosit 2 buc.x8m (33ohm/m, eticheta cf-12r-50r) in paralel pentru a repara un panou radiant, acum un an; conteaza mult modul in care se face sertizarea . Se pot face panouri radiante folosind placi ceramice , ca in clip; se pot gasi si cu termostat incorporat, ucrainene . 1 Link spre comentariu
Alic Postat Februarie 13 Autor Partajează Postat Februarie 13 În cursul săptămânii următoare vor sosi cablajele. Luni, 24.02.2025 le trimit către voi. Ionizare plăcută! Link spre comentariu
daniels Postat Marți la 15:44 Partajează Postat Marți la 15:44 La 30.01.2025 la 19:20, Alic a spus: Ce e ăla? Am schimbat electroliticii si am incercat cu o bujie (SINTEROM) Link spre comentariu
