Scule si accesorii care imi prisosesc
xaxa
Scule si accesorii care imi prisosesc. Numai cu plata in avans in cont.
Prefer predare personala. Trimit in tara cu Posta Romana (+15 lei transport) sau curier cu plata transportului la destinatar, dar nu promit rapiditate in expediere.
Va rog postati aici, nu pe PM
1. Spirale de precizie, noi, coada de 3mm, productie KEMMER, HAM, HPTEC, HAWERA, UNION TOOL, Ø0,35mm, Ø0,5mm, Ø0,95mm, Ø1,05mm., Ø0,95mm, Ø1,2mm, Ø1,25mm, Ø1,35mm, Ø1,55mm, Ø1,85mm, Ø1,90mm, unele dimensiuni doar citeva bucati
set 10 buc fiecare dimensiune – 20 lei
https://imgur.com/qbTdoLc
2. Ambori/centratoare HSS, noi, set 5 buc. , 1,5/4, 2/5, 2,5/6, 3/8, 4/10 (Ø virf/ Ø corp) - 25 lei
https://imgur.com/VlP91cf
3. Fierastrau pt taieri marunte, lama cca 21cm, nou - 10 lei
https://imgur.com/ZVjnL7r
4. Surubelnita si biti, trusa chinezeasca 115 piese, noua - 25 lei REZERVAT
https://imgur.com/d4teqP6
https://imgur.com/BhA8DFS
5. Splitter HDMI nou, 1 intrare x 2 iesiri, nu functioneaza ambele simultan - 10 lei
https://imgur.com/TLEnZiY
6. Set Forstner folosit, perfect functional, Ø15, Ø 20, Ø 25, Ø 30, Ø 35 - 25 lei
https://imgur.com/n7Eeb5c
7. Sablon balamale mobile Ø35mm, nou - 10 lei
https://imgur.com/m8QxJRu
8. Adaptor penseta freza, de la Ø 10mm la Ø 8mm, nou, nu merge la Makita 3711 - 10 lei
https://imgur.com/b8O3jUP
9. Miner letcon Parkside, bonus la cumparaturi pentru cine il doreste
https://imgur.com/4qs7O2q
11. Ghidaj pentru masa de frezare Workzone, 10x13x45cm, nou. Se adapteaza usor si la alte mese de acelasi format. Din plastic, cu reglaj fin, racord pentru furtunul de aspiratie si gauri pentru accesorii. - 75lei
https://imgur.com/9q8y0a6
https://imgur.com/AI0eCtu
https://imgur.com/3dd2jRz
https://imgur.com/NRjiamS
https://imgur.com/bFl8DJ9
3. Piesa de la o drujba, noua, nu stiu modelul, - 10 lei
https://imgur.com/nWZVyWu
https://imgur.com/3XGUOub
15. Feon cu casca, folosit, functional, - 20lei
https://imgur.com/yQcRmbU
https://imgur.com/jp6GbQq
https://imgur.com/Rb2lS0I
16. Disc adaptor pt bormasina, cu Velcro, nou, -15lei
https://imgur.com/QVPC0cz
se adauga
17. Flanse pt. trecere prin fereastra
Flanse din aluminiu pentru trecerea prin fereastra a cosului de la soba, centrala termica, a tubului de aerisire de la hota, a tubulaturii de la unitatile mobile de aer conditionat sau de evacuare a prafului. Fiind din aluminiu nu se degradeaza (nu devin friabile) din cauza expunerii la temperaturi inalte sau joase.
Diametrul interior 110mm. Grosimea maxima a geamului 6mm. In cazul unei ferestre duble, distanta minima intre panourile de sticla 20mm.
25lei setul, 40 lei amindoua
https://imgur.com/82qQjFz
18. Lot 5 casete originale in buna stare – 25 lei
https://imgur.com/I67l8YL
19. Suport CDuri, folosit, in perfecta stare – 10 lei
https://imgur.com/05gpiMM
20. Sistem alarma CERBER, functional, nu mai stiu modelul, daca e cineva interesat pot cauta si cutia, pretul e fara cutie – 100 lei
https://imgur.com/wcx0Etr
21. Casete MiniDV, 60 minute, inregistrate o singura data, trebuie sa le sterg – 5 lei/buc.
https://imgur.com/tNi0LUt
Asta este tot.
13. Piesa de la o drujba, noua, nu stiu modelul, - 10 lei
20. Sistem alarma CERBER C41V1v4, functional, daca e cineva interesat pot cauta si cutia, pretul e fara cutie – 100 lei
Manualul de instalare si utilizare aici
https://www.scribd.com/document/337388302/cerberC41V1V4-instalare-1-pdf
22. Set opritoare usa/fereastra autoadezive, Ø30mm si 40mm – 10 lei
https://imgur.com/mhf1yLZ
23. Dispozitiv pentru taiat hirtie, chinezesc, nou - 20lei
https://imgur.com/abokSXn
24. Set senzori magnetici, noi - 5lei
https://imgur.com/IHpRlON
Editat de xaxa
salut,
nu trimit ramburs. dar e retinut pina duminica, nu am apucat sa intru pe  site ca sa fac modificarea
Dar daca se hoataraste sa ii ia, cred ca mai am ceva intr-o cutie, doarf sa imi fac timp sa o scot de pe unde este dosita
deci
2. Ambori/centratoare HSS -RETINUT
Editat de xaxa
25. Ambori/centratoare HSS, noi, set 5 buc. , 2/5, 2,5/6, 3/8, 4/10, 5/12 (Ø virf/ Ø corp) - 25 lei
