ciprysat Postat Noiembrie 30, 2024 Partajează Postat Noiembrie 30, 2024 Va salut. Am facut acest proiect https://github.com/e2002/yoradio Merge dar problema este ca daca pica internetul nu se mai reconecteaza streamul respectiv de radio doar daca ii dau conect din interfata. Se poate adapta la codul respectiv ceva sa ruleze in bucla sa verifice sa zicem la 1 min daca este conectat ? /* ============================================================================================================ * ёRadio * ============================================================================================================ * Web-radio based on * ESP32-audioI2S https://github.com/schreibfaul1/ESP32-audioI2S * or/and * ESP32-vs1053_ext https://github.com/schreibfaul1/ESP32-vs1053_ext * libraries * ============================================================================================================ * Project home https://github.com/e2002/yoradio * Wiki https://github.com/e2002/yoradio/wiki * Описание на 4PDA https://4pda.to/forum/index.php?s=&showtopic=1010378&view=findpost&p=112992611 * Как это прошить? https://4pda.to/forum/index.php?act=findpost&pid=112992611&anchor=Spoil-112992611-2 * ============================================================================================================ * Here goes! * ============================================================================================================ */ #include "Arduino.h" #include "src/core/options.h" #include "src/core/config.h" #include "src/core/telnet.h" #include "src/core/player.h" #include "src/core/display.h" #include "src/core/network.h" #include "src/core/netserver.h" #include "src/core/controls.h" #include "src/core/mqtt.h" #include "src/core/optionschecker.h" extern __attribute__((weak)) void yoradio_on_setup(); void setup() { Serial.begin(115200); if(LED_BUILTIN!=255) pinMode(LED_BUILTIN, OUTPUT); if (yoradio_on_setup) yoradio_on_setup(); config.init(); display.init(); player.init(); network.begin(); if (network.status != CONNECTED && network.status!=SDREADY) { netserver.begin(); initControls(); display.putRequest(DSP_START); while(!display.ready()) delay(10); return; } if(SDC_CS!=255) { display.putRequest(WAITFORSD, 0); Serial.print("##[BOOT]#\tSD search\t"); } config.initPlaylistMode(); netserver.begin(); telnet.begin(); initControls(); display.putRequest(DSP_START); while(!display.ready()) delay(10); #ifdef MQTT_ROOT_TOPIC mqttInit(); #endif if (config.getMode()==PM_SDCARD) player.initHeaders(config.station.url); player.lockOutput=false; if (config.store.smartstart == 1) player.sendCommand({PR_PLAY, config.store.lastStation}); } void loop() { telnet.loop(); if (network.status == CONNECTED || network.status==SDREADY) { player.loop(); //loopControls(); } loopControls(); netserver.loop(); } #include "src/core/audiohandlers.h" Link spre comentariu
