Sevice meniu tv combo (cu video ) Thomson
  • Răspunsuri 2
  • djvas
Zile populare
Am gasit pe net si s-a rezolvat.THOMSON CTV SERVICE ACCESS CODES Models. 14CB25UT 20CB25UT 21CB25FT EUROCOMBO 2 Service Mode To access the service / hotel mode: Ensure TV Is tuned in Switch the TV off at the mains Press the STOP and PR+ buttons and hold while switching on the set Press the "MAGENTA" Text button on the remote control to step through the menu selections After selection press the "OK" button Use the "ARROW" keys to make selections and confirmations To temporarily exit from the service mode press the "EXIT" button Exit the service mode by switching off the set TV parameters are set using a 16 digit number. Do not change this number without reference to the service manual
