Curatenia in atelier: Electronice, electrice, scule, IT, diverse
djlove
Actualizare periodica cu cele disponibile in acest moment
Se merge pe primul venit primul servit, fara rezervari...
Trimit prin posta sau curier (curier la preturi avantajoase la plata in avans 15-20lei)
Pentru mai multe fotografii sau detalii va rog sa ma contactati in privat
SURUBURI:
1. Suruburi M2.5x6mm, cap cruce tip PZ, punga 100buc, 8lei/set;
2. Suruburi M3x4mm, cap stea tip TX10, punga 100buc, 7lei/set;
3. Suruburi M3x4mm, cap cruce tip PH, punga 100buc, 8lei/set;
4. Suruburi M3x6mm, cap cruce tip PH, punga 100buc, 8lei/set;
5. Suruburi M3x8mm, cap stea tip TX10, punga 100buc, 7lei/set;
6. Suruburi M3x10mm, cap cruce tip PH, punga 100buc, 9lei/set;
7. Suruburi M3x16mm, cap stea tip TX10, punga 100buc, 12lei/set;
8. Piulite M3, punga 100buc, 5lei/set;
9. Saibe grower M3, diametru exterior 5.5mm, punga 100buc, 4lei/set;
10. Saibe M3, diametru exterior 7mm, punga 100buc, 4lei/set;
11. Suruburi M4x8mm, cap imbus, punga 50buc, 10lei/set;
12. Suruburi M4x10mm, cap cruce tip PZ, punga 50buc, 7lei/set;
13. Suruburi M4x15mm, cap minus , punga 50buc, 8lei/set;
14. Saibe M4, diametru exterior 9mm, punga 50buc, 3lei/set;
15. Piulite M4, punga 50buc, 4lei/set;
16. Piulita M4 cu blocaj din inox A2, Punga 50buc, Bossard, Cod TME: B4/BN637 , 8lei/punga
DISTANTIERE METALICE:
17. Distantier metal M2.5x13mm, filet interior pe toata lungimea, 0.7lei/buc
18. Distantier metal M2.5x17mm, filet interior pe toata lungimea, 0.7lei/buc
19. Distantier metal M2.5x18mm, filet interior + exterior, 0.8lei/buc
20. Distantier metal M2.5x33mm, filet interior pe toata lungimea, 1leu/buc
21. Distantier metal M3x20mm, filet interior + exterior, 0.8lei/buc
22. Distantier metal M3x25mm, filet interior + exterior, 0.9lei/buc
23. Distantier metal M4x5mm, filet interior + exterior, 0.7lei/buc
24. Distantier metal M4x15mm, filet interior + exterior, 1.3lei/buc
25. Distantier metal M4x60mm, filet interior + exterior, 2lei/buc
26. Distantier metal M5x30mm, filet interior + exterior, 2.6lei/buc
DISTANTIERE POLIAMIDA:
27. Distantier poliamida M3x10mm filet interior + exterior, 0.8lei/buc
28. Distantier poliamida M3x19mm filet interior pe toata lungimea, 1leu/buc
29. Distantier poliamida M4x15mm filet interior + exterior, 1leu/buc
30. Distantier poliamida M4x20mm filet interior pe toata lungimea, 1.1lei/buc
31. Distantier poliamida M4x50mm filet interior pe toata lungimea, 1.4lei/buc
32. Distantier plastic, lungime 27mm, gaura cu holzsurub 3mm la un capat si celalt capat se prinde in tabla/PCB in gaura de 4mm, 1.5lei/buc
33. Distantier poliamida, lungime 15mm, la un capat are gaura cu filet  M3, iar la celalat capat se prinde in tabla PCB in gaura de 3.8mm, 1.8lei/buc
COMPONENTE:
34. Sursa Meanwell NOUA 50W,  24V 2.2A, reglabil intre 21 si 28 V, model RS-50-24, 25lei
35. Sursa Meanwell NOUA  24V, 50W, 2,2A, reglabil intre 21 si 28 V,model LRS-50-24, 28lei
36. Sursa Meanwell NOUA, 75W, 24V, 3.2A reglabil intre 21 si 28 V, model RS-75-24, 32lei
37. Sursa Phoenix contact NOUA, de calitate, cu prindere pe sina, 24V reglabil, 1.75A, 45lei
38. Sursa Meanwell  NOUA 24V 1A cu prindere pe sina, model MDR-20-24, 35lei
39. Sursa Meanwell  Recuperata dar testata OK, 24V reglabil, 2A cu prindere pe sina, model DR-4524, 32lei
40. Sursa 24V 2.1A Momentum, Recuperata dar testata OK, 20lei
41. Sursa in comutatie Recuperata 230V, iesire 32V – 940mA, 16V, 625mA, provine din sursa imprimata HP - 20lei
42. Sursa Recuperata din incarcator laptop Acer iesire 15V, 5A - 20lei
43. Suport metalic NOU, THERMALTRONICS pentru role fludor, ESD, model  TMT-SSH100, 100lei
44. Curatitor span metalic varfuri statie lipit ERSA 008M, calitate extra - 10lei
45. Cablu Vention Cablu; USB 2.0; USB A mufă,USB C mufă; nichelat; 1m; 480Mbps; cod COKSF, NOU - 10lei
46. Set Nou de manşoane termocontractabile; 2: 1; 100mm; neagră; 170buc, cod TME CB-HFT-SET2-BK, 38lei
47. Set 4 markere colorate Schneider Maxx 290, 10lei
48. Set NOU cabluri FLUKE ; Unom: 30V; Inom: 15A; Lung: 0,9m, model TL932, 80lei
49. Cabluri din silicon de cea mai buna calitate pentru surse de laborator (max 19A), lungime 1m, cablul este foarte flexibil similar cu cel de la testerele de aparate de masura Fluke, 75lei
50. Cablu NOU Dell VGA to VGA, 8lei
51. Cablu NOU Dell USB 3.0, 1.8m, 6lei
52. Cablu NOU conexiune covor ESD cu capsa si papuc - 5lei
53. Organizator cabluri PC/TV, are scai si prinde cablurile la un loc, fiind si usor demontabil, 3lei/bucata
54. Kit preamplificator stereo AD-007, cu CI NE5532N, nu cunosc starea lui daca este functional - 15lei
55. Mouse NOU cu fir DELL, model MS116-BK, 28lei
56 Etichete pentru cabluri/conducte Phoenix contact kmk uv 40x17mm, se prind cu soricei ~50buc= 10lei
57. Bratara ESD NOUA, sunt 2 culori rosu si albastru - 5lei/buc
58. Card SD Kingston Canvas Select Plus, 32GB, 100MB/s - 10lei
59. Priza trifazica 32 A SCAME, combinata cu monofazica, NOUA - 40lei
60. Surubelnita ESD safe WERA PH1x80mm, NOUA, calitate extra - 20lei, la TME depaseste 40lei
61. Spray curatare cablaje PCC 400ml, cod TME: PCC/400, 38lei
62. Cuptor din imprimanta laser A4, Netestat, pentru cine face cablaje cu metoda de transfer termic - 15lei
63. Pensule rotunde 50, 60 si 65mm diametru - 15lei toate 3
64. Transformator bine ecranat, made in Japan, cumparat de pe forum, tensiunile se vad in poza, dimensiuni 85mm inalime, 10cm latime, 9cm lungime - 30lei
65. Siguranta automata 3 poli Eaton, NOUA, 40A, 4.5kA PL4 - 40lei
66. Stecher 16A pentru priza fara impamantare, 4lei
67. Varf letcon JBC tip surubelnita 2x0,9mm; longlife C470013 serie 251014 NOU, 100lei, pretul in magazin depaseste 250lei pentru acest model
68. HUB USB 3.0 + 1 x port Gigabit LAN Negru, Delock 62653, model de peste 200lei in magazin -  100lei
69. Fludor cu plumb 1mm, 100grame, SN60 PB40 - 25lei
70. Set 4 cleme legaturi electrice in pietene distributie 63A Schneider barclic  21098 - 30lei
71. Releu de monitorizare a tensiunii; succesiune faze; 3UG; DPDT Siemens trifazic, NOU  - 250lei
72. Placa de dezvolatare NUCLEO-G071RB, compatibila Arduino, inclusiv cu shielduri, dar cu procesor mult mai puternic - 45lei
73. Shield compatibil Arduino WIFI cu ESP8266 - 20lei
74. Cleme Wago 221-412 100buc, 100lei cutia
76. Cleme Wago 221-415 25buc, 55lei cutia
77. Transmitator radio pentru DSLR NIKON, blitz, fara baterii - 25lei
78. Ventilator: DC; axial; 24VDC; 120x120x25mm; 183,83m3/h; 44,5dBA, SUNON, NOU, 25lei
79. Telemetru cu ultrasunete SKIL model 0520 cu husa inclusa, 100lei
80. Set 2 borne crocodil; 30A; MUELLER ELECTRIC, Capacitate prindere: max.16mm, cod TME: BU-112-5,  10lei
81. Relee 24V, 6 A, 2 modele mixate, 2lei/buc sau 15lei/10 bucati
82. Diverse placute RAM, 12lei toate
83. Condensatori ceramici 4.7nF/100V, set de 100buc, 4lei/set
84. Cleme NOI legaturi electrice cu prindere pe sina Weidmuller pentru impamantare WPE 6mmp, 2.5lei/buc
85. Papuci tip saiba M5 1.5-2.5mmp punga de 100buc, 8 lei punga
86. Suruburi vechi M3 diverse 100buc, 4lei
87. Suruburi vechi M4 diverse 100buc, 5lei
88. Trusa NOUA biti si prelungitor BOSCH in carcasa de plastic reziztent 24 piese - 50lei
89. Pastile vidia noi, 6lei/bucata
90. Rola fludor 500grame, de cea mai buna calitate Felder Germany, diametru 0.75mm, 120lei
91. Condensatori MKP 3.3uf/275vAC 32x18mm, inaltime 33mm, distanta intre pini 28mm, NOI, 6lei/buc
92. Sfic NOU 125mm Knipex ESD,   65lei
93. Cutter NOU Unior 556A, 10lei
94. Lame de rezerva cutter UNIOR 556.1B, 8lei/buc,
95. Ruleta NOUA Holex  462010 – 5m, 25lei
96. Set surubelnite Wago 210-722, cod TME: WG0-210722, 50lei/set
97. Penseta ascutita otel inoxidabil antimagnetic 125mm ESD NOUA, Holex Germany - 40lei
98. Dezizolator  cabluri si fire Nou Knipex 1609501 made in Germany - 85lei
99. Varf Wera, NOU, dublu PH1+PH2 , lungime 175mm - 22lei
100. Surubelnita lata Wago 210-721 NOUA - 25lei
101. WAGO-210658 Surubelnita cotita Wago 210, lata 3.5mm, 15lei
103. Cleste 160mm Klauke KL010160IS pentru taiat cablu din aluminiu si cupru cu un diametru maxim de 16 mm NOU - 180lei
105.  Radiator aluminiu, lungime 14cm, latime 9.5cm, inaltime totala 6.5cm - pret 10lei
106. MOUSE wireless 1600DPI cu butoane suplientare programabile Delock 12493, utilizat, dar in stare foarte buna, include si receptorul USB - 30lei
108. Rezistente NOS 620 Ohmi 16W - 1leu/buc, mai sunt 6 bucati
109. Ventilator silentios Enermax 12VDC 120mm calculator cu senzor de temperatura si leduri albastre care se pot opri din intrerupator - 12lei
110. Cutie cu cleme Wago din seria 222: 11buc cu 2 piste, 1buc cu 3 piste si 15buc cu 5 piste + suporti prindere pe sina, Tot ce se vede in foto - 50lei
112.  Rola fludor 1kg, de cea mai buna calitate Felder Germany, diametru 1mm, 220lei
113. Tool operare cleme cu 3 piste Wago 860-393, 15lei
114. Cheie flex + 3 imbusuri - 10lei
116. Varf Wera PH0x50mm - 8lei
117. Foarfeca Holex made in Germany 100mm - 23lei
118. Surubelnita PB Swiss Tools PH0 NOUA, L - 140 mm, ESD - 23lei
119. Surubelnita PB Swiss Tools PH2 NOUA,  ESD - 30lei
120. Surubelnita PB Swiss Tools Pz2 NOUA,  ESD - 30lei
121. Cleşte automat de legat cabluri NOU, Holex made in Germany - 250lei
124. Set 2 ventilatoare metalice 120mm, luate de la targ, ambele sunt functionale, cel cu fire are pale metalice si cred ca la 110V, celalat la 120V are palele crapate dar functioneaza si asa. Pret pe ambele 15lei
125. Rigla metalica Garant Germany din inox  gravata laser - 20lei
126. Hub USB 3.0 7 porturi, NOU, Logilink model UA0308 V2.0 pret 150lei, peste tot depaseste 200lei acest model, in carcasa metalica
127. Geanta Laptop Targus 15. 6 inch, noua, sta si aduna praful degeaba,
Dimensiuni 387 x 267 x 42 mm  - 60lei
128.Condensatori NOI Epcos, super calitate, MKT  X2  22nF/275V, distanta intre pini 15mm, pret pe 10 buc - 2.5lei
129.Condensatori NOI WIMA, hartie metalizata MP3 Y2  6.8nF 250V , distanta intre pini 15mm, pret pe 10 buc - 5lei
130. Condensatori NOI hartie metalizata 100N+150R 440V RIFA cod TME PMZ 2035 RE, distanta intre pini 25mm, pret pe buc - 4lei
131. Stabilizator NOU de tensiune 7915; liniar -15V; 1A ; TO220 - 1leu/buc
132. Lot 20 bucati carcase duble DVD NOI de calitate, Amaray - 10lei
133. Lot imbusuri, tot ce se vede in foto - 6lei
134. Switch 5 porturi Gigabit Tplink TL-SG1005D - 35lei
135. Modem USB Huawei E220, Retele: HSDPA/HSUPA/3G/EDGE/GPRS, Benzi 2G: 850/900/1800/1900, Benzi 3G: 850/1900/2100 - 15lei
136. Cablu NOU USB 2.0 A la USB C, 3A, 1.5m, Vention COKBG sigilat - 12lei
137. Bit NOU, Milwaukee impact PZ2 150mm - 20lei
138. Lot diverse montaje (TDA2003, TDA2004, etc) toate din foto - 10lei
139. Markere noi, negre, permanente Schneider cu varf 0.7mm - 3.5lei/bucata
140. Adaptor USB la PS2 - 3lei
141. Bobine SMD 12x12mm, inaltime 9mm, 100uH, 2.5A, Recuperate de pe placi noi, neutilizate, 2lei/buc
142. Senzor de masura curent NOU max. 100A, ACS752 SCA-100 , ALLEGRO 5lei/buc
143. Supercondensatori 0.22F, 3.6V , diametru 10mm, grosime 5mm, Recuperati de pe placi noi, neutilizate, 2.5lei/buc
144. Supercondensatori 0.1F, 5.5V , diametru 13mm, inaltime 9mm, Recuperati de pe placi noi, neutilizate, 3.5lei/buc
145. Conector M4 cupru cu montaj pe PCB, OSTERRATH, cod TME: 73-3299-21/0030, 0.25lei/buc
146. DC-DC converter SMD, Recom R1SE-0505-R 5V, 200mA, recuperate de pe placi noi, 4lei/buc
147. DC-DC converter THT, Recom R-785.0-0.5,  5V, 500mA, Vin max 32V, recuperate de pe placi noi, 5lei/buc
148.  DC-DC converter SMD ,LM 2576-ADJ,  Vout ajustabila , 3A, Vin max 32V, recuperate de pe placi noi, 7lei/buc
150. Display 2 linii, 16 caractere cu lumina fundal alba si scrisul negru, produse de Lehner Dabitros Germany, NOI, 18lei
151. Radiator aluminiu Tip H lungime 17cm, latime 8cm, inaltime 10cm, pret 25lei
152. Radiator aluminiu Tip H lungime 40cm, latime 12cm, inaltime 12cm, pret 100lei
153. Husa filtre foto MATIN, NOUA ,30lei/buc
154. Kilometraj mecanic pentru bicicleta, rezistent la apa, fara baterie, cablu 86 cm, rotund, negru 30 lei
155. Cablu NOU DELL  conecatre monitor la laptop USB C to USB C  4k - 50lei
156. Cablu NOU, Delock mini display port to display port 4k - 45lei
157. Cablu NOU de calitate audio Clicktronic RCA to RCA 1m dublu ecranat, placat cu aur - 50lei
158. Interfata usb3.2 to gigabit ethernet + 3 porturi usb extra Delock 62653, NOUA - 150
159. Adaptor chei Milwaukwee NOU 1/2 interior la 3/4 exterior - 30lei
  • Răspunsuri 46
  • djlove
    36
  • imreberes
  • dan cod
  • PavelR
  • 2 săptămâni mai târziu...
Se adauga:
162. Alimentator nou Laptop DELL 65W USB C - 120lei
163. Adaptor USB 3.0 la Gigabit LAN, NOU, Delock 62121 - 110lei
164. Convertor, ICP DAS, I-7561 Convertor industrial bidirectional, 1 port USB la 1 port RS-232/422/485, cu izolatie optica, NOU in cutie sigilat - 400lei
SURUBURI:
https://i.imgur.com/W8Ep7rh.jpeg
COMPONENTE:
61. Spray curatare cablaje PCC 400ml, cod TME: PCC/400, 35lei
63. Pensule rotunde 50, 60 si 65mm diametru - 12lei toate 3
124. Set 2 ventilatoare metalice 120mm, luate de la targ, ambele sunt functionale, cel cu fire are pale metalice si cred ca la 110V, celalat la 120V are palele crapate dar functioneaza si asa. Pret pe ambele 10lei
135. Modem USB Huawei E220, Retele: HSDPA/HSUPA/3G/EDGE/GPRS, Benzi 2G: 850/900/1800/1900, Benzi 3G: 850/1900/2100 - 10lei
160. Alcool Izopropilic 0.5L - 20lei
161. Card extensie PC: PCIe; PCIe,USB A soclu x2,USB C soclu, NOU sigilat Logilink PC0090 - 180lei
