Diverse
Robert22
  • Răspunsuri 61
  • Robert22
    49
  • sonic11
  • hamatdumitru
  • mcxc
1-Sursa in comutatie PTE250 bec Halogen 12vca,mai multe detalii in poze.Noi nefolosite,disponibil 9buc.-50lei/buc
https://imgur.com/7XQ37MC
https://imgur.com/a7r8gMr
2-Boxe auto SEG in stare foarte buna estetic si functional. 70lei/set
https://imgur.com/PAI2dxG
https://imgur.com/EZsGQwW
https://imgur.com/SB06rSU
3-Motorase pas cu pas recuperate 40lei tot ce apare in poze.
https://imgur.com/JWDkX1S
4-Electronica sistem 5.1 Clatronic functional complect cum apare in poze 40lei.
https://imgur.com/UJTuoL2
https://imgur.com/62Ltopb
https://imgur.com/UEH0jeL
5-Placi ptr recuperat piese contine si comenzile motoarelor de la pct 3 pret 30lei.
https://imgur.com/U8INXi6
https://imgur.com/pcifXZr
6-Module amplificator WuMetru cu LM3915,Eg cu LA3600,cum se vede in poze,amplificatorul este din revista Tehnium 100w4ohm,35lei tot ce se vede in poze.
https://imgur.com/Viwl5mk
https://imgur.com/1hBbtaj
https://imgur.com/TDDpjkK
https://imgur.com/DP7QZce
7-Comanda motor poarta electrica contine placa baza/modul receptor/telecomanda,nu cunosc starea lor deci se vand ca defecte,sunt 2 module ,pret ptr tot ce se vede in poze 70lei.
https://imgur.com/uA4mKWh
https://imgur.com/XSZMQcN
8-Tuner si deck AKAI,tuner are ata scala lipsa dar functioneaza,deck are lipsa alimentarea si Wumetrele,se vand ptr piese pret ptr ambele,50lei.
https://imgur.com/Itc4Z19
https://imgur.com/dxOZ6Sy
https://imgur.com/rmOK3Ej
9-Modul GPS navi auto Pioneer cum apare in poza,nu cunosc starea ei,ptr piese 30lei.
https://imgur.com/kuEZtqj
10-Diferite trafuri si bobine recuperate pret ptr tot ce se vede in poze,35lei.
https://imgur.com/E1Ta52k
Editat de Robert22
Rog eu:
La 22.08.2024 la 22:31, Robert22 a spus:
4-Comanda motor poarta electrica contine placa baza/modul receptor/telecomanda,nu cunosc starea lor deci se vand ca defecte,sunt 2 module ,pret ptr tot ce se vede in poze 70lei.
5-Diferite trafuri si bobine recuperate pret ptr tot ce se vede in poze,35lei.
  • 2 săptămâni mai târziu...
-Expediez in tara cu posta sau curier ,transportul este suportat de cumparator .
-Plata se face in avans in cont.
6-Placa de baza ASUS Sabertooth 990 fx netestat ptr piese 80 lei.
https://imgur.com/AAOwaxn
https://imgur.com/KvhkDyB
7-Cass portabil Poppy CS-560 posibilitate alimentare pe baterii si reteaua de 220v,probat cu baterii cam caraie potentiometru de volum dar functioneaza nu am cablu ptr alimentare, se vinde cum apare in poze cu husa de transport. 60lei.
https://imgur.com/yc5FOIr
https://imgur.com/l11K3Ie
https://imgur.com/ssto3DB
https://imgur.com/AgvaHoJ
Editat de Robert22
1-Sursa in comutatie PTE250 bec Halogen 12vca,mai multe detalii in poze.Noi nefolosite,disponibil 9buc.-30lei/buc
2-Boxe auto SEG in stare foarte buna estetic si functional. 50lei/set
3-Motorase pas cu pas recuperate 30lei tot ce apare in poze.
4-Comanda motor poarta electrica contine placa baza/modul receptor/telecomanda,nu cunosc starea lor deci se vand ca defecte,sunt 2 module ,pret ptr tot ce se vede in poze 50lei.
5-Diferite trafuri si bobine recuperate pret ptr tot ce se vede in poze,25lei.
6-Placa de baza ASUS Sabertooth 990 fx netestat ptr piese 70 lei.
7-Cass portabil Poppy CS-560 posibilitate alimentare pe baterii si reteaua de 220v,probat cu baterii cam caraie potentiometru de volum dar functioneaza nu am cablu ptr alimentare, se vinde cum apare in poze cu husa de transport. 50lei.
8-Set Boxe AmazonBasics r30peu noi in cutie desfacuta ptr proba disponibile 4 set-uri pret 200lei/set
https://imgur.com/66lf3Oo
https://imgur.com/IDAAkij
https://imgur.com/KvEUGa1
https://imgur.com/2UvtL3c
6-Cass portabil Poppy CS-560 posibilitate alimentare pe baterii si reteaua de 220v,probat cu baterii cam caraie potentiometru de volum dar functioneaza nu am cablu ptr alimentare, se vinde cum apare in poze cu husa de transport. 50lei.
7-Set Boxe AmazonBasics r30peu noi in cutie desfacuta ptr proba disponibile 4 set-uri pret 200lei/set
8-Tuner de dimensiune mica WEGA T210 in stare de functionare pret 60lei
https://imgur.com/we4G4BO
Acum 8 ore, hamatdumitru a spus:
Rog eu:
Sa notat.
Se adauga:
-Eq amplificat auto doar alimentat in rest netestat 70 lei.
https://imgur.com/EkH0ieK
https://imgur.com/q5g5Su7
https://imgur.com/wKpF9F5
-Amplificator 2.1 netestat 15lei
https://imgur.com/crah0LB
https://imgur.com/58zAsZK
Editat de Robert22
