Windows Postat Duminică la 15:03 Autor Partajează Postat Duminică la 15:03 La 13.12.2024 la 22:05, Windows a spus: Marfa este noua, posibil unele ambalaje deteriorate. Posibil si ceva marfa netestata, dar e specificat. Trimit prin Fancurier, (SUNT ZILE TRANSPORT GRATUIT PE OLX ) daca aveti cont OLX coletul cu verificare costa undeva la 10 - 25 lei, POSTA, EASYBOX PLATA INTEGRALA IN CONT. Cu rosu bolduit intrari noi, cu portocaliu bolduit marfa trimisa/rezervata/discutii 1. Element peltier cu dispozitiv recirculare lichid(asa pare) https://ibb.co/SchBJvB https://ibb.co/yWx9WJJ https://ibb.co/TLPVJbn https://ibb.co/sWpDtZQ https://ibb.co/TW8ts3V 50 lei 2. Carucior pliabil rosu https://ibb.co/tDRQy96 https://ibb.co/JC0hwjQ https://ibb.co/x55q3RY 125lei ...sau 2 rate 3. RUZIZAO laboratory power supply 30V 5A, laboratory power supply with 3-digit LED display, adjustable switching power supply upgrade encoder button, mini laboratory sursa de laborator https://ibb.co/0yXJLpC https://ibb.co/C1fPqRH https://ibb.co/fpJVLDJ https://ibb.co/RTy9t0T https://ibb.co/NnGns6X https://ibb.co/WHKRPCH https://ibb.co/2qQR3Yk https://ibb.co/pJ4cWbP https://ibb.co/Sx7rCMm https://ibb.co/f9Tk25Z https://ibb.co/p0hS9SX 200 lei 4. Newbealer Mini Travel Iron with Switchable Voltage-220V 120V, Compact Iron for Clothes No Steam , Ceramic Surface, 150 C Hot Press with Spray Bottle, Bag and Silicon Mini fier de calcat https://ibb.co/MGzRdVY https://ibb.co/LnvqxdL https://ibb.co/bQWZPwv https://ibb.co/GtkMyzv https://ibb.co/82JZ6JH https://ibb.co/FqbtC3r 40 lei 5. Lampa LED cu lupa marita, Izoxis, negru, 10 nivele intensitate, 65x15x5cm SPECIFICATII LAMPEI: culoare neagra material: fier altele: PP + sticla + cauciuc iluminare din spate: LED Numar de LED-uri: 72 lentila de marire: da x 3 culoare de iluminare: alb cald, alb neutru si alb rece numarul de niveluri de intensitate a luminii: 10 diametru lupa: 10,5 cm grosimea maxima a blatului pentru montarea lampii: 5 cm dimensiuni: 65 x 15 x 5 cm greutate: 640 g greutate pachet: 1.037 kg https://ibb.co/nsqfgns https://ibb.co/kxPspX6 https://ibb.co/bbyX0yq https://ibb.co/8P290x6 https://ibb.co/sW6NKYX https://ibb.co/HzKhH33 https://ibb.co/X22jZRN https://ibb.co/mqCBDvJ https://ibb.co/xGC1tGy https://ibb.co/5BxJP81 https://ibb.co/f9jLXzS 60 lei 6. Controler incubator ( sau pentru orice alta automatizare) https://ibb.co/XxN2GkN https://ibb.co/f00RpCv https://ibb.co/P9c8rFh https://ibb.co/FsNpY1m https://ibb.co/g93G9z8 https://ibb.co/0mj862P https://ibb.co/JpNFKJf https://ibb.co/5hfGqVP https://ibb.co/pPrC2DT https://ibb.co/wBJCCSj 40 lei 7. Organizator auto de montat in spatele scaunelor https://ibb.co/y0Mh7Fr https://ibb.co/XJy6F8Z https://ibb.co/m0KfcZ4 https://ibb.co/QNM00tj 30 lei 8. Memorii laptop SODIMM DDR4 DDR5 8GB/16GB https://ibb.co/m47d37r https://ibb.co/BPgMjFt https://ibb.co/CtvHgTf https://ibb.co/PQ9X9gZ https://ibb.co/7tGYnFT https://ibb.co/f4MDJnF https://ibb.co/FKr7zC8 https://ibb.co/QjfcMyP https://ibb.co/6Wk6dY4 preturi intre 70-190 lei 9. Sovol SV06 Plus SV04 Textured PEI Print Bed Printing Plate Magnetic 3D Printer Platform 310 x 320 mm for Ender 3 Max NEO CR-10 V2 CR-10 V3 CR-10S PRO V2 CR-X YOOPAI PEI Print Plate 310x320mm, Double-Sided Black Textured PEI Magnetic Spring Steel Print Bed for Creality CR10 CR10S 10S Pro V2 V3, Ender 3 Max, AnyCubic Mega X-5698794-4221764 Pat magnetic 310x320mm pentru imprimanta 3D 2 buc https://postimg.cc/gallery/Chb4qFW 35 lei bucata 10. Incarcatoare pentru orice tip de laptop mufa specifica fiecarului model, mufa Type C https://ibb.co/jGyxCSW https://ibb.co/m5S778B https://ibb.co/jZtMq8h https://ibb.co/mRDXJ4S https://ibb.co/0n7Pj42 https://ibb.co/16mtCrd https://ibb.co/QnrJZyG https://ibb.co/kDwvBGd https://ibb.co/TqPSgKn https://ibb.co/fSkBfBg https://ibb.co/9b6qBD4 https://ibb.co/z8R6kgK https://ibb.co/tP25LMr https://ibb.co/K5kCv9N https://ibb.co/PcN3Vjs 45 lei pana in 100W, 55 lei Type-C, Apple, 100 lei peste 100W 11. EC1-12706 Dual Core Semiconductor Refrigeration Thermoelectric Peltier Cooling System 120W Window Air Conditioner Element peltier https://ibb.co/hWD6KXp https://ibb.co/87G2Xzg https://ibb.co/2cFFLDK https://ibb.co/8MCZ896 https://ibb.co/z2mPmSV https://ibb.co/GdyDmMY https://ibb.co/3v23cw3 50 lei 12. Treedix soldering iron set, 8W wireless soldering iron soldering set with adjustable temperature from 330 to 450 C, including USB cable, soldering wire, iron stand with sponge, 3 soldering tips for soldering Mini letcon cu incarcare type C https://ibb.co/5vr6wwB https://ibb.co/0sJHD36 90 lei setul, 2 seturi disponibile 13. CREWORKS Step Up Down Voltage Converter Convert 110V 220V 3000W with Automatic Cut-off Transformer with 110V 220V Sockets 5V USB Ports Automatic Transformer https://ibb.co/HBMWfPY https://ibb.co/Jjf8r5z https://ibb.co/5hjfDbp https://ibb.co/nkxyQd8 https://ibb.co/CHLTr8Q https://ibb.co/WG7mfD0 https://ibb.co/Bjr7XdF https://ibb.co/QXCSm5g https://ibb.co/qnrmPhB https://ibb.co/tYqQ9ST https://ibb.co/J3VrwCG 380lei 14. MOTOPOWER MP00205A 12V 800mA Automatic Battery Charger for Cars, Motorcycles, ATVs, RVs, Powersports, Boat Incarcator, desulfator automat https://ibb.co/GHyMpCY https://ibb.co/7tT3XPN https://ibb.co/mvKJ0rH https://ibb.co/6NNBJsL https://ibb.co/fCWYPMc https://ibb.co/jk3mZSS https://ibb.co/ccqXxMS https://ibb.co/yyrCNjG https://ibb.co/brr9fCX https://ibb.co/ZJdNjnb https://ibb.co/BHh3nTm 55 lei 15. husa piele naturala Samsung A53 5G https://ibb.co/3fTpC51 https://ibb.co/pvhm1QX https://ibb.co/6XNbCyR https://ibb.co/wMC6Y60 https://ibb.co/Wsczncd https://ibb.co/2vRszty https://ibb.co/KssvjsF 15 lei 16. ANJANK Extremely Loud Wireless Vibrating Alarm Clock with Electric Shaker for No Hearing, Hard of Hearing, Deep Sleep, Dual Alarm, Battery Backup, USB Charger 2 Ceasuri cu afisaj foarte mare noi in cutie https://ibb.co/GnZsYp5 https://ibb.co/kMYpzRR https://ibb.co/f2ZGvXg https://ibb.co/8rjh502 https://ibb.co/bK1kmbC https://ibb.co/cNhtX6T https://ibb.co/r6nC67w https://ibb.co/51PKnvC https://ibb.co/0FwwsfD 35 lei buc 17. MP5 player, Radio, Carplay, navigatie cu Android mirror link (posibil sa nu mearga cu android peste 6 sau 7) telecomanda, camera spate https://ibb.co/YPSFCyq https://ibb.co/CBztpSz https://ibb.co/F6JDPvY https://ibb.co/f8hg91c https://ibb.co/SvV0mdL https://ibb.co/v30d62G https://ibb.co/ZNYzRtZ https://ibb.co/Sxd2Wfh https://ibb.co/TR5VSFN https://ibb.co/8xQpr3g https://ibb.co/zFNr45b https://ibb.co/F7w78QB https://ibb.co/mDYdLPH https://ibb.co/yfKxXTQ https://ibb.co/60TGNYF https://ibb.co/vzt3nPH https://ibb.co/47QfQK3 https://ibb.co/Hx4M6PW https://ibb.co/4Y334z5 https://ibb.co/xYLPCtw https://ibb.co/wLnfXqs 165 lei disponibile 4 buc doua buc cu urme de montare pe masina dar par noi 140 lei 18. set 4 lampi led cu incarcare solara si cred ca au si detector miscare, 3 nivele de aprindere https://ibb.co/YjJ5tMv https://ibb.co/hKt8RQJ https://ibb.co/khKfCCK https://ibb.co/165jdSv https://ibb.co/FsdHNSQ https://ibb.co/VBk2gyf https://ibb.co/WWhMqbC https://ibb.co/T8swKJx 60 lei setul 19. TREKOLOGY Large Inflatable Pillow - ALUFT Ultra Camping Pillow for Beach and Camping, Inflatable Pillow for Outdoor Adventures Perna gonflabila https://ibb.co/4s48H5g https://ibb.co/THTVypr https://ibb.co/k6txtYS https://ibb.co/BVTryRN https://ibb.co/nnbx34S https://ibb.co/tD3PJxw 20 lei 20. SVNOOC 24V 4A Power Supply 96W Charger 100 240V AC to DC Converter LED Transformer with 5.5mmx 2.5mm Plug for CCTV Camera LCD Monitor DC Pump Fan CE Certificate EU Plug inncarcator 24V 4A https://ibb.co/qJRXjK4 https://ibb.co/fCWN1Y4 https://ibb.co/tqYsTDg https://ibb.co/42k96G9 https://ibb.co/RTqHpNy 25 lei 21. Bzocio 1Din Car Radio CD DVD Player External Stereo Interface USB Port Navigation GPS Car Universal https://ibb.co/PZSh3gr https://ibb.co/rZWwnvB https://ibb.co/SXGG0jq https://ibb.co/W2JNRTS https://ibb.co/whJb8rq https://ibb.co/Tt4s1fx 20 lei 22. Magneti neodim 500 buc 5mmx5mmx2mm https://ibb.co/T41GmxC https://ibb.co/QKZGdJZ https://ibb.co/RBzXrvK 85 lei 23. FTDLCD 15.6 inch LCD Touch Screen Digitizer Display Screen Assembly for HP Pavilion x360 Convertible 15-dq0000ng 15-dq1433ng 15-dq1001ng 15-dq1002ng 15-dq1131ng 15-d-5355429-3969958 ansamblu display cu touch https://ibb.co/dB3FQn2 https://ibb.co/SRf5Qm4 https://ibb.co/r43tmvC 380 lei 24. Mini freza cordless cu multe varfuri si sabloane de desenat modele https://ibb.co/S63SWny https://ibb.co/TwDKspW https://ibb.co/YNTNTtS https://ibb.co/r5tQMmB https://ibb.co/3YTV24Y https://ibb.co/R3fc8Qy https://ibb.co/DKmqKw4 https://ibb.co/ySJPzvr https://ibb.co/kDts6mb https://ibb.co/KVkwzZb https://ibb.co/Lk3QMFk https://ibb.co/mXvQ1k4 https://ibb.co/tshbydz https://ibb.co/xYfWYyp https://ibb.co/0mGJCTV 90 lei 25. 26. Becuri auto led H4 cu ventilator https://ibb.co/XSqy2kP https://ibb.co/FHwHQMS https://ibb.co/mJ6C3FS https://ibb.co/3f80mY3 https://ibb.co/0M3jC9v https://ibb.co/6DdTHxQ https://ibb.co/mJ1dLDj https://ibb.co/BfpW4ck 40 lei 27. Controler incubator, second hand https://ibb.co/2gJLQkN https://ibb.co/3dW1kyx https://ibb.co/grfnX7d https://ibb.co/zrNNtCn https://ibb.co/4pgfqjJ https://ibb.co/hmc9Pjh https://ibb.co/wBb71WN 40 lei 29. Capsator electric, ambalaj deteriorat, 2 seturi capse si un set cuie https://ibb.co/sKVKvW1 https://ibb.co/qNQzzqG https://ibb.co/ZSs2KMR https://ibb.co/Mc6n3Hk 40 lei 30. Aparat contra tantarilor alimentare usb https://ibb.co/tDvZBGL https://ibb.co/H75q6cj https://ibb.co/0Q5gKLT https://ibb.co/pXmXBpr https://ibb.co/wywfDtx 15 lei ambele, unul fara ambalaj 31. 18 x Brand New Samsung Galaxy A71A Case, Flexible Material, TPU Material, Scratch-Resistant, Maximum Protection, Black carcase silicon Samsung A71 https://ibb.co/309z3GG https://ibb.co/q91DNS4 2,5 lei buc 32. Displayuri cu touch https://postimg.cc/gallery/3hHDX79 10 lei toate, nu mai este cel de apple 33. OMPHOBBY 900mAh 3.7v Li-ion 18350 battery OSHM2344 baterii 18350 https://ibb.co/rw8ZBbv https://ibb.co/37Y1JKv 25 lei 34. Disk Safe timed locker, phone locker with timer phone shutdown video games, social media, self-control timer locker container storage box for addiction management Cutie plastic cu cifru electronic, timer... https://ibb.co/0YvmPXx https://ibb.co/qyqyhVS https://ibb.co/y4TcCJg https://ibb.co/fC4m3XB https://ibb.co/3NL3hFh https://ibb.co/dGt90hJ https://ibb.co/G2J3TmQ 15 lei 35. OBD 2 tester auto nu necesita laptop https://ibb.co/DYk2hpt https://ibb.co/v4VnhPJ https://ibb.co/jMRfr2p https://ibb.co/KrgNDhN https://ibb.co/VDhCVxv https://ibb.co/GMxs8N4 https://ibb.co/h9ZCVZ9 https://ibb.co/zNJpGKh https://ibb.co/qFQ2J5F https://ibb.co/YLF9czB https://ibb.co/VYtbncS https://ibb.co/LQvb3m4 75 lei 2 modele 36. KKMOL Presentation Clicker, Presentation Remote Control, Powerpoint Remote Control, Pointer for Presentations, PPT Red Pointer, USB Presenter for PPT Windows XP 7 8 10 Mac OS Linux pointer prezentari https://ibb.co/DWQg68N https://ibb.co/dQ04wGw 25 lei 37. KKMOL presentation remote control, Powerpoint remote control, pointer for presentations, PPT red pointer, USB 2.4 GHz presenter for PPT Windows XP 7 8 10 Mac OS Linux pointer prezentari, alim cu 2 baterii AAA, fara https://ibb.co/pKn3sCL https://ibb.co/0jG8VBf https://ibb.co/64550gL https://ibb.co/VH1KP5r 25 lei 38. Husa impermeabile - waterproof telefon Samsung A54 https://ibb.co/k6Bvwym https://ibb.co/7pyNMxx https://ibb.co/9TtMK94 10 lei 39. Dispozitiv pentru seringi cu flux printat 3D https://ibb.co/qyYz9pn 20 lei 40. 4 seturi telecomenzi radio https://ibb.co/6BYWBpB https://ibb.co/ww56jXy https://ibb.co/M7NbPzZ https://ibb.co/BNTVVb7 https://ibb.co/xGdnz3r https://ibb.co/M8X5Pw5 https://ibb.co/XkTVFV1 https://ibb.co/w66myzn https://ibb.co/rFW9JBN https://ibb.co/JQdNzCC https://ibb.co/rxPfBVQ https://ibb.co/82KxB8m https://ibb.co/LCFh7TX 30 lei setul 41. set 5 aparate de masura luxmetru, decibelmetru, clampmetru, multimetru si detector cabluri https://ibb.co/XpXdXTY https://ibb.co/7p76BPb https://ibb.co/4K5Fkjx https://ibb.co/p4yFJMR https://ibb.co/C6qcWv4 https://ibb.co/YT9NW5V https://ibb.co/k8tPBLg https://ibb.co/yYv8g1S https://ibb.co/WHR5SQG https://ibb.co/31YFS1R https://ibb.co/XsKgNyD https://ibb.co/GQ3MgPT https://ibb.co/1fHfn9K https://ibb.co/YL4dxnb https://ibb.co/HqYtmjk https://ibb.co/6Y6kmG1 https://ibb.co/TR7zc2g https://ibb.co/TwYfZcQ https://ibb.co/fXwJ5xy https://ibb.co/XVN83JV https://ibb.co/ssTgh6H https://ibb.co/xHgQH6K https://ibb.co/NmCBVzY https://ibb.co/RS5tQFT https://ibb.co/1Q2wVKb https://ibb.co/mF5mGnn 250 lei 42. 3.7V 3000mAh NiMH rechargeable battery, POWO18B with NiMH battery protection box, NO 1818-666-888B battery, perfect for flashlight, camera, small fan, doorbell baterii 4 bucati https://ibb.co/qmrc30z https://ibb.co/bNMs7Jr https://ibb.co/fkgJjSn https://ibb.co/jVxmtwY https://ibb.co/wLfCL4z https://ibb.co/ZSmqDcy 35 lei 43. Huse deosebite piele naturala vintage pentru telefon, etc de pus la curea https://ibb.co/dWhYbGr https://ibb.co/vPFbXsV https://ibb.co/27WHS1H https://ibb.co/gg2f6Kj https://ibb.co/5T119MF https://ibb.co/gg2f6Kj https://ibb.co/fnPbYfD 30 lei buc 44. Cotiere genunchiere copii pentru bicicleta/trotineta/etc marimea L https://ibb.co/FbfGmnF https://ibb.co/9pY4QzH https://ibb.co/9bDWpCv https://ibb.co/R7xxmDF https://ibb.co/Dwt3xSS 25 lei 45. Surse 30V 10A https://ibb.co/fvtVyL7 https://ibb.co/TgHnXCr https://ibb.co/c146DQQ https://ibb.co/NnBV5wp https://ibb.co/9rH2gNT https://ibb.co/g4XvBKp https://ibb.co/KmP92MC https://ibb.co/DPF5WNd https://ibb.co/Bz3MSp4 https://ibb.co/vsNkh0S https://ibb.co/YhRHfg3 https://ibb.co/jbkmR53 https://ibb.co/xDyjbM7 https://ibb.co/Trc0kZH https://ibb.co/x5bkvTq https://ibb.co/85d4gLx https://ibb.co/Gnt7Wnv https://ibb.co/R9Cgj9B https://ibb.co/sRHxL4f 325 lei buc 46. Detector radiatii nucleare https://ibb.co/ZMsqyGz https://ibb.co/484yMXW https://ibb.co/Js31QWQ https://ibb.co/NNp49T9 https://ibb.co/S6J8wfp https://ibb.co/4KFt7bQ 25 lei buc 47. KG316T timer, LCD display, timer switch, time switch, microcomputer, 220V, resistance 25A, electric timer second hand https://ibb.co/1TZdM9j https://ibb.co/HYx86QJ https://ibb.co/yQ1BrRv https://ibb.co/gjgprxP https://ibb.co/ZT6YkpT 25lei 48. 2PCS UV Lamp E27 Bulb Transparente, becuri UV https://ibb.co/wRbXq0v https://ibb.co/60XwdF7 35 lei 50. 9W 365nm UV Lamp 4 lampi UV, neprobate, nu stiu daca sunt direct la 230V https://ibb.co/JCQK03w https://ibb.co/4MdYBnC 10 lei toate 51. Awootsv Priză temporizatoare electrică digitală cu afișaj LCD 10 funcții aleatorii configurabile antiefracție Conectare interioară întrerupător temporizator electric pentru lumini și aparate de uz casnic, 3680W 2 buc https://ibb.co/nbG9W3N https://ibb.co/pLHxhF1 https://ibb.co/mJWg4YY https://ibb.co/KKRMXG4 https://ibb.co/k5hysNm https://ibb.co/c2QC7Ky https://ibb.co/GkcHBZB 30 lei ambele 52. Aideepen 3 x 3S 20A Li-ion Lithium Battery Charger Board PCB BMS 12.6V Cell Module Overcharge Overcurrent Short Circuit Protection BMS-uri 3S https://ibb.co/mGbZXb3 https://ibb.co/b2fK1QM 10 lei buc, disponibile 2 buc 53. Adaptor combinat M.2 NVME PCIE SSD la SFF-8654 NGFF SATA SATA la SATA 2 în 1 pentru placa de bază (NVME SSD la SATA nu funcționează pe acest adaptor) https://ibb.co/TRNf9Mg 20 lei 54. ECOTISH Women s Backpack in Soft Leather Casual School Daypack 2 in 1 as Backpack and Shoulder Bag, Women s Fashion Bag and Shoulder Backpack for School, Shopping, PLUS geanta de umar Rucsac piele ecologica si geanta de umar din piele naturala https://ibb.co/xmZz8tF https://ibb.co/HgD36q6 35 lei buc 55. extensii cabluri PC https://ibb.co/ZMyNkYp https://ibb.co/jkqDG77 https://ibb.co/Lnb20tY https://ibb.co/RBVdm21 40 lei 56. YYSG Vacuum Bags 6 Pack 60x40cm, Vacuum Bags for Clothes, 80 More Storage Space, Reusable Travel Space Saving, Vacuum Storage Bags for Clothes Duvets Bedding Pillows Blankets 6 pungi vacuum set sigilat https://ibb.co/wz5Wb5Y https://ibb.co/3N9jym8 https://ibb.co/tXPkfvZ https://ibb.co/gRLjYSB 20 lei + 10 pungi si pompa 40 lei (50 lei tot) 57. Pyrography Machine, 100W wood burner set with 2 pens and 33 pcs wire tips, pyrography station burning iron pyrography equipment adjustable from 0-750 C, double Aparat pirogravura dublu https://ibb.co/tpjNy69 https://ibb.co/drjJSt0 https://ibb.co/nz1V1NQ https://ibb.co/vP1Tv4V https://ibb.co/3F0HYL6 https://ibb.co/gVS8dWG https://ibb.co/vkxSKs5 https://ibb.co/xMmx58V https://ibb.co/dgZVgF2 https://ibb.co/vznc6L7 https://ibb.co/YdpVkVx 140 lei 58. ORIGBELIE External DVD Drive USB 3.0 Type C, CD DVD -RW Burner with USB Ports and SD TF Card Reader, External CD Drive for Laptop Desktop MacBook Windows 11 10 8 7 XP Vista Linux Mac Ambalaj carton https://ibb.co/nbVhFZk https://ibb.co/Rz6MWD1 https://ibb.co/DrJprM0 https://ibb.co/D5Th8Vf https://ibb.co/4tgmq06 https://ibb.co/DQWyzY2 https://ibb.co/5cBzjnx https://ibb.co/NLyGRXJ https://ibb.co/ggzNHmb https://ibb.co/gvtbRV8 https://ibb.co/NtXYqhw https://ibb.co/wcMZJt5 https://ibb.co/VvD5CcS https://ibb.co/VWzDfCD https://ibb.co/SK4Sn8Z https://ibb.co/njBWKmF https://ibb.co/2ZVW7SQ https://ibb.co/7vW8X95 https://ibb.co/BZ5P0L7 https://ibb.co/RHKyWWX https://ibb.co/hVHvJPG https://ibb.co/80GQnJW https://ibb.co/vdb0wvx https://ibb.co/gJ2Yb9w https://ibb.co/NtXwc9j https://ibb.co/Cv7Th0h https://ibb.co/kqbyp67 55 lei mai multe buc, disponibil unul SH, fara cititor carduri si usb-uri suplimentare la 25 lei, 3 simple la 30lei si un bluray extern la 100 lei (netestat suficient sa fiu sigur ca e ok, pare nou) 59. Pancellent PH meter, PH TDS EC and temperature 4 in 1 set, water quality tester ATC for drinking water swimming pool aquarium pools, conductivity meter with high accuracy and LCD display blue mai multe seturi https://ibb.co/WDFBDBH https://ibb.co/y0zS8tg https://ibb.co/B22z1B7 https://ibb.co/QpP1yx1 https://ibb.co/gJC28fS https://ibb.co/GTYWCXk https://ibb.co/XCtbBQx https://ibb.co/NmFrRNw 20 lei setul 60. Transformator 230v la 110V 300W https://ibb.co/WPYcvpZ https://ibb.co/x7qRyxQ https://ibb.co/cCqRhnr https://ibb.co/gF58bnC 50 lei, stoc 2 buc 61. Smoke detector networked, AEGISLINK set of 6 wireless smoke detectors with replaceable battery, fire alarm with transmission range of over 250 m, test mute button, auto-check function, S-RF220 detectoare de fum, bulk https://ibb.co/Qc3xmdX https://ibb.co/09fjw7J https://ibb.co/TvVSCfR https://ibb.co/bNghb3g https://ibb.co/vz68mwx https://ibb.co/ZVf68nH https://ibb.co/J5tFxZq https://ibb.co/ZHT72Bh https://ibb.co/QNK1byZ 35 lei buc, 5 buc 62. Networkable combined smoke and carbon monoxide detector, AEGISLINK smoke detector networked, 2 IN-1 CO detector with replaceable battery and 250 m transmission range, SC-RF220 detectoare monoxid carbon si fum bulk https://ibb.co/1qFw7Bn https://ibb.co/bspvw3q https://ibb.co/qxG3d1H https://ibb.co/G30BHPs https://ibb.co/WgS597C https://ibb.co/nDgnh3N https://ibb.co/q0M4JLY https://ibb.co/hX6GkgJ 45 lei disponibile 2 buc 63. Pedală de chitară multi-efect LEKATO pentru chitară bas electrică cu încărcare în infraroșu, editare, înregistrare pe telefon pe computer, tuner, ieșire căști de 3,5 mm, timp de lucru 8 ore https://ibb.co/Wk3KMfJ https://ibb.co/vX3PRkM https://ibb.co/3sTyCGG https://ibb.co/ypPC5N3 https://ibb.co/NpQsv5h https://ibb.co/g4PCmMH https://ibb.co/NsbRbGn https://ibb.co/0KtW739 https://ibb.co/MskqxMb https://ibb.co/GcKt6jJ https://ibb.co/yPxh89x 100 lei 64. Detector inteligent de fum X-Sense XS01-M, Wi-Fi, compatibil cu FS31 FS61 FS121, stația de bază SBS50 și aplicația X-Sense Home Security, semnal de avertizare 85 dB, mini detector de fum și incendiu în rețea https://ibb.co/JvJbD01 https://ibb.co/7VhNC7b https://ibb.co/wW3F4Cc https://ibb.co/sbQDVhD https://ibb.co/NYgDHzY 45 lei 65. Detector inteligent de fum WiFi wireless HEIMAN, cu 5 ani de viață a bateriei, senzor fotoelectric, EN14604, avertizare baterie scăzută https://ibb.co/bFFRkwg https://ibb.co/3BHv7MY 45 lei 66. Set de 3 detectoare de fum RAKELL, baterie 10 ani, alarmă sonoră 85 dB, testat 14604, senzor fotoelectric https://ibb.co/vkfvhyv https://ibb.co/rHBrksc https://ibb.co/jGHDLGZ https://ibb.co/6HML1Ds https://ibb.co/cvjDqLL https://ibb.co/ZBsTHq8 https://ibb.co/3yF5pPt 110 lei 67. Cabluri audio aurite, prelungitor type-C, audio apple https://ibb.co/S70DfH9 https://ibb.co/SJ2N41V https://ibb.co/q9FLpSJ https://ibb.co/vD18430 https://ibb.co/xmtWdrK https://ibb.co/G7tGgLW https://ibb.co/rZspwvs https://ibb.co/NVRzgS5 https://ibb.co/8KSGtMy https://ibb.co/gFPZKqY https://ibb.co/vHK6NxC 35 lei buc audio, 15 lei buc celelalte 68. Detectoare fum diverse https://ibb.co/2nNHQqq https://ibb.co/4F0sFf3 https://ibb.co/y83Vxfn https://ibb.co/mFzjgKR https://ibb.co/nCCdbbF https://ibb.co/Jj31DXz https://ibb.co/tMkyKTz https://ibb.co/kg6p3mg https://ibb.co/9gf2m60 https://ibb.co/ZN1FTMS https://ibb.co/KGFWjf9 https://ibb.co/C6sZrDk https://ibb.co/yST9krH https://ibb.co/gwB4kFZ https://ibb.co/vQv2VWS 35 lei buc, 140 lei set de 5 69. 70. Fokky digital to analog audio converter 192khz DAC model HS200 https://ibb.co/5cr1tBR https://ibb.co/WWckHKY https://ibb.co/WyBNHHq https://ibb.co/qskvLf8 https://ibb.co/vkZXL1n https://ibb.co/5shZW2n https://ibb.co/YWwdMv2 https://ibb.co/svP9KHS 35 lei 71. Transformator 230V la 110V si invers 500VA https://ibb.co/9qqtgfL https://ibb.co/bHmJ493 https://ibb.co/DG6HsbW https://ibb.co/hBYxHJV https://ibb.co/85zN67D https://ibb.co/JrfKBNS https://ibb.co/xCRJRTT 125 lei buc, mai multe buc disponibile 72. Obd2 Activator de imobilizare Activator Drive Box Edc15 Me7 Caracteristici: 1.Professional de fabricație, această cutie este perfect pentru a se potrivi pentru SEAT Cordoba / Ibiza / Toledo / Toledo. 2. Domeniul de aplicare este larg, sunt aplicabile atât motorina, cât și benzina, deci nu este nevoie să vă faceți griji cu privire la inadecvare. 3. Este ușor de utilizat, doar conectați-l, nu există pași complicați și timpul dvs. nu va fi pierdut. 4.It este compact, nu ocupă spațiu, are doar dimensiuni de 8,7x4,5x2,5cm / 3,4x1,8x1in și este ușor de transportat. Îl puteți lua oriunde. 5. A fost supus unor teste extinse de calitate și siguranță pentru a asigura performanțe fiabile. Specificație: Tip element: OBD2 Imobilizator Material: ABS Culoare: Negru Tensiune: DC 12V Model de corespondență: EDC15 (motorină) și ME7 (benzină) Dimensiune: Aprox. 8,7x4,5x2,5cm/3,4x1,8x1in (Datorită măsurării manuale, poate exista o abatere de 1-2 mm) Ghidul utilizatorului: Doar conectați cutia de acționare EDC15 / ME7 la mufa de diagnosticare (OBD2) a vehiculului, apoi conectați OBD2 și comutați la "oprit" pe cutia de unitate. După numai 20 până la 30 de secunde, blocarea antifurt nu mai necesită un computer. Fitment: Fit pentru A2 / A3 / A4 / A6 Fit pentru SEAT Cordoba / Ibiza / Toledo / Toledo Fit pentru SKODA OCTAVIA Fit pentru Skoda Octavia II Fit for Skoda Scout Fit pentru ŠKODA Roomstar Fit pentru SKODA FABIA Fit pentru Skoda Superb (până în 2007 ) Fit for PORSCHE Cayenne (benzină, model vechi) Fit for Bora (din anul 2000) Fit for Caddy (din anul 2000)Fit for EOS Fit for T4 (From year 2000) https://ibb.co/xFC3LDn https://ibb.co/mFRwjLY https://ibb.co/pyJVvD0 100 LEI 73. Lampa acvariu S.H. (sau pt altceva ) multe combinatii luminoase https://ibb.co/cDxpSLY https://ibb.co/k0PTCbY https://ibb.co/F6H4jPt https://ibb.co/4Vw9cSY https://ibb.co/C98yV51 https://ibb.co/jfVb7Ft https://ibb.co/nbMfWm8 https://ibb.co/YLQFKJy https://ibb.co/ZxtdG83 https://ibb.co/mcHpfgq https://ibb.co/48q0bLr https://ibb.co/pnrXBSH https://ibb.co/fnh9NG6 50lei 74. 75. DEWIN Digital Ammeter Voltmeter, PZEM-025 Digital Ammeter DC Voltmeter Battery Tester 0 300A 300V Power Energy Wattmeter 50A second hand https://ibb.co/Nr3FsvT https://ibb.co/SQZ1hF0 https://ibb.co/mNgyZfW https://ibb.co/QHB3tqB https://ibb.co/NTvny06 https://ibb.co/G2H3Xw3 https://ibb.co/pQ11q1y https://ibb.co/swCvQV7 https://ibb.co/B2dksFX https://ibb.co/8Bc1NZW 20 lei 76. Bureti pentru casti https://ibb.co/JBr3cpG https://ibb.co/tCCV6xJ https://ibb.co/yPw8BPf https://ibb.co/CBk8y4T https://ibb.co/Jy4ncjN https://ibb.co/mhvBSFb https://ibb.co/c1Md4Tk 5 lei perechea, primul model 7 perechi 77. Uscator filament imprimanta 3D, SUNLU, pare folosit, dar in stare excelenta https://ibb.co/bdk1vY5 https://ibb.co/RDfCn1g https://ibb.co/Z8YZrtg https://ibb.co/v4L07kv https://ibb.co/CshRTZ3 https://ibb.co/4mPZ3My https://ibb.co/W2kBC1T https://ibb.co/GRJ12Xv https://ibb.co/mB7pgMb https://ibb.co/3FchVdB https://ibb.co/tq7KgF9 https://ibb.co/xH3PRrq 130 lei Link spre comentariu
giliman66 Postat Duminică la 20:39 Partajează Postat Duminică la 20:39 6. Controler incubator ( sau pentru orice alta automatizare ) 40. seturi telecomenzi radio https://ibb.co/82KxB8m - 2set Detalii mesaj Link spre comentariu
Windows Postat Luni la 04:56 Autor Partajează Postat Luni la 04:56 Acum 8 ore, giliman66 a spus: 6. Controler incubator ( sau pentru orice alta automatizare ) 40. seturi telecomenzi radio https://ibb.co/82KxB8m - 2set Detalii mesaj Aveti MP Link spre comentariu
Windows Postat Luni la 21:22 Autor Partajează Postat Luni la 21:22 La 15.12.2024 la 17:03, Windows a spus: Marfa este noua, posibil unele ambalaje deteriorate. Posibil si ceva marfa netestata, dar e specificat. Trimit prin Fancurier, (SUNT ZILE TRANSPORT GRATUIT PE OLX ) daca aveti cont OLX coletul cu verificare costa undeva la 10 - 25 lei, POSTA, EASYBOX PLATA INTEGRALA IN CONT. Cu rosu bolduit intrari noi, cu portocaliu bolduit marfa trimisa/rezervata/discutii 1. Element peltier cu dispozitiv recirculare lichid(asa pare) https://ibb.co/SchBJvB https://ibb.co/yWx9WJJ https://ibb.co/TLPVJbn https://ibb.co/sWpDtZQ https://ibb.co/TW8ts3V 50 lei 2. Carucior pliabil rosu https://ibb.co/tDRQy96 https://ibb.co/JC0hwjQ https://ibb.co/x55q3RY 125lei ...sau 2 rate 3. RUZIZAO laboratory power supply 30V 5A, laboratory power supply with 3-digit LED display, adjustable switching power supply upgrade encoder button, mini laboratory sursa de laborator https://ibb.co/0yXJLpC https://ibb.co/C1fPqRH https://ibb.co/fpJVLDJ https://ibb.co/RTy9t0T https://ibb.co/NnGns6X https://ibb.co/WHKRPCH https://ibb.co/2qQR3Yk https://ibb.co/pJ4cWbP https://ibb.co/Sx7rCMm https://ibb.co/f9Tk25Z https://ibb.co/p0hS9SX 200 lei 4. Newbealer Mini Travel Iron with Switchable Voltage-220V 120V, Compact Iron for Clothes No Steam , Ceramic Surface, 150 C Hot Press with Spray Bottle, Bag and Silicon Mini fier de calcat https://ibb.co/MGzRdVY https://ibb.co/LnvqxdL https://ibb.co/bQWZPwv https://ibb.co/GtkMyzv https://ibb.co/82JZ6JH https://ibb.co/FqbtC3r 40 lei 5. Lampa LED cu lupa marita, Izoxis, negru, 10 nivele intensitate, 65x15x5cm SPECIFICATII LAMPEI: culoare neagra material: fier altele: PP + sticla + cauciuc iluminare din spate: LED Numar de LED-uri: 72 lentila de marire: da x 3 culoare de iluminare: alb cald, alb neutru si alb rece numarul de niveluri de intensitate a luminii: 10 diametru lupa: 10,5 cm grosimea maxima a blatului pentru montarea lampii: 5 cm dimensiuni: 65 x 15 x 5 cm greutate: 640 g greutate pachet: 1.037 kg https://ibb.co/nsqfgns https://ibb.co/kxPspX6 https://ibb.co/bbyX0yq https://ibb.co/8P290x6 https://ibb.co/sW6NKYX https://ibb.co/HzKhH33 https://ibb.co/X22jZRN https://ibb.co/mqCBDvJ https://ibb.co/xGC1tGy https://ibb.co/5BxJP81 https://ibb.co/f9jLXzS 60 lei 6. Controler incubator ( sau pentru orice alta automatizare) https://ibb.co/XxN2GkN https://ibb.co/f00RpCv https://ibb.co/P9c8rFh https://ibb.co/FsNpY1m https://ibb.co/g93G9z8 https://ibb.co/0mj862P https://ibb.co/JpNFKJf https://ibb.co/5hfGqVP https://ibb.co/pPrC2DT https://ibb.co/wBJCCSj 40 lei 7. Organizator auto de montat in spatele scaunelor https://ibb.co/y0Mh7Fr https://ibb.co/XJy6F8Z https://ibb.co/m0KfcZ4 https://ibb.co/QNM00tj 30 lei 8. Memorii laptop SODIMM DDR4 DDR5 8GB/16GB https://ibb.co/m47d37r https://ibb.co/BPgMjFt https://ibb.co/CtvHgTf https://ibb.co/PQ9X9gZ https://ibb.co/7tGYnFT https://ibb.co/f4MDJnF https://ibb.co/FKr7zC8 https://ibb.co/QjfcMyP https://ibb.co/6Wk6dY4 preturi intre 70-190 lei 9. Sovol SV06 Plus SV04 Textured PEI Print Bed Printing Plate Magnetic 3D Printer Platform 310 x 320 mm for Ender 3 Max NEO CR-10 V2 CR-10 V3 CR-10S PRO V2 CR-X YOOPAI PEI Print Plate 310x320mm, Double-Sided Black Textured PEI Magnetic Spring Steel Print Bed for Creality CR10 CR10S 10S Pro V2 V3, Ender 3 Max, AnyCubic Mega X-5698794-4221764 Pat magnetic 310x320mm pentru imprimanta 3D 2 buc https://postimg.cc/gallery/Chb4qFW 35 lei bucata 10. Incarcatoare pentru orice tip de laptop mufa specifica fiecarului model, mufa Type C https://ibb.co/jGyxCSW https://ibb.co/m5S778B https://ibb.co/jZtMq8h https://ibb.co/mRDXJ4S https://ibb.co/0n7Pj42 https://ibb.co/16mtCrd https://ibb.co/QnrJZyG https://ibb.co/kDwvBGd https://ibb.co/TqPSgKn https://ibb.co/fSkBfBg https://ibb.co/9b6qBD4 https://ibb.co/z8R6kgK https://ibb.co/tP25LMr https://ibb.co/K5kCv9N https://ibb.co/PcN3Vjs 45 lei pana in 100W, 55 lei Type-C, Apple, 100 lei peste 100W 11. EC1-12706 Dual Core Semiconductor Refrigeration Thermoelectric Peltier Cooling System 120W Window Air Conditioner Element peltier https://ibb.co/hWD6KXp https://ibb.co/87G2Xzg https://ibb.co/2cFFLDK https://ibb.co/8MCZ896 https://ibb.co/z2mPmSV https://ibb.co/GdyDmMY https://ibb.co/3v23cw3 50 lei 12. Treedix soldering iron set, 8W wireless soldering iron soldering set with adjustable temperature from 330 to 450 C, including USB cable, soldering wire, iron stand with sponge, 3 soldering tips for soldering Mini letcon cu incarcare type C https://ibb.co/5vr6wwB https://ibb.co/0sJHD36 90 lei setul, 2 seturi disponibile 13. CREWORKS Step Up Down Voltage Converter Convert 110V 220V 3000W with Automatic Cut-off Transformer with 110V 220V Sockets 5V USB Ports Automatic Transformer https://ibb.co/HBMWfPY https://ibb.co/Jjf8r5z https://ibb.co/5hjfDbp https://ibb.co/nkxyQd8 https://ibb.co/CHLTr8Q https://ibb.co/WG7mfD0 https://ibb.co/Bjr7XdF https://ibb.co/QXCSm5g https://ibb.co/qnrmPhB https://ibb.co/tYqQ9ST https://ibb.co/J3VrwCG 380lei 14. MOTOPOWER MP00205A 12V 800mA Automatic Battery Charger for Cars, Motorcycles, ATVs, RVs, Powersports, Boat Incarcator, desulfator automat https://ibb.co/GHyMpCY https://ibb.co/7tT3XPN https://ibb.co/mvKJ0rH https://ibb.co/6NNBJsL https://ibb.co/fCWYPMc https://ibb.co/jk3mZSS https://ibb.co/ccqXxMS https://ibb.co/yyrCNjG https://ibb.co/brr9fCX https://ibb.co/ZJdNjnb https://ibb.co/BHh3nTm 55 lei 15. husa piele naturala Samsung A53 5G https://ibb.co/3fTpC51 https://ibb.co/pvhm1QX https://ibb.co/6XNbCyR https://ibb.co/wMC6Y60 https://ibb.co/Wsczncd https://ibb.co/2vRszty https://ibb.co/KssvjsF 15 lei 16. ANJANK Extremely Loud Wireless Vibrating Alarm Clock with Electric Shaker for No Hearing, Hard of Hearing, Deep Sleep, Dual Alarm, Battery Backup, USB Charger 2 Ceasuri cu afisaj foarte mare noi in cutie https://ibb.co/GnZsYp5 https://ibb.co/kMYpzRR https://ibb.co/f2ZGvXg https://ibb.co/8rjh502 https://ibb.co/bK1kmbC https://ibb.co/cNhtX6T https://ibb.co/r6nC67w https://ibb.co/51PKnvC https://ibb.co/0FwwsfD 35 lei buc 17. MP5 player, Radio, Carplay, navigatie cu Android mirror link (posibil sa nu mearga cu android peste 6 sau 7) telecomanda, camera spate https://ibb.co/YPSFCyq https://ibb.co/CBztpSz https://ibb.co/F6JDPvY https://ibb.co/f8hg91c https://ibb.co/SvV0mdL https://ibb.co/v30d62G https://ibb.co/ZNYzRtZ https://ibb.co/Sxd2Wfh https://ibb.co/TR5VSFN https://ibb.co/8xQpr3g https://ibb.co/zFNr45b https://ibb.co/F7w78QB https://ibb.co/mDYdLPH https://ibb.co/yfKxXTQ https://ibb.co/60TGNYF https://ibb.co/vzt3nPH https://ibb.co/47QfQK3 https://ibb.co/Hx4M6PW https://ibb.co/4Y334z5 https://ibb.co/xYLPCtw https://ibb.co/wLnfXqs 165 lei disponibile 4 buc 0 buc cu urme de montare pe masina dar pare noua 140 lei, una de 10 inch wide cu montare pe bord 150 lei 18. set 4 lampi led cu incarcare solara si cred ca au si detector miscare, 3 nivele de aprindere https://ibb.co/YjJ5tMv https://ibb.co/hKt8RQJ https://ibb.co/khKfCCK https://ibb.co/165jdSv https://ibb.co/FsdHNSQ https://ibb.co/VBk2gyf https://ibb.co/WWhMqbC https://ibb.co/T8swKJx 60 lei setul 19. TREKOLOGY Large Inflatable Pillow - ALUFT Ultra Camping Pillow for Beach and Camping, Inflatable Pillow for Outdoor Adventures Perna gonflabila https://ibb.co/4s48H5g https://ibb.co/THTVypr https://ibb.co/k6txtYS https://ibb.co/BVTryRN https://ibb.co/nnbx34S https://ibb.co/tD3PJxw 20 lei 20. SVNOOC 24V 4A Power Supply 96W Charger 100 240V AC to DC Converter LED Transformer with 5.5mmx 2.5mm Plug for CCTV Camera LCD Monitor DC Pump Fan CE Certificate EU Plug inncarcator 24V 4A https://ibb.co/qJRXjK4 https://ibb.co/fCWN1Y4 https://ibb.co/tqYsTDg https://ibb.co/42k96G9 https://ibb.co/RTqHpNy 25 lei 21. Bzocio 1Din Car Radio CD DVD Player External Stereo Interface USB Port Navigation GPS Car Universal https://ibb.co/PZSh3gr https://ibb.co/rZWwnvB https://ibb.co/SXGG0jq https://ibb.co/W2JNRTS https://ibb.co/whJb8rq https://ibb.co/Tt4s1fx 20 lei 22. Magneti neodim 500 buc 5mmx5mmx2mm https://ibb.co/T41GmxC https://ibb.co/QKZGdJZ https://ibb.co/RBzXrvK 85 lei 23. FTDLCD 15.6 inch LCD Touch Screen Digitizer Display Screen Assembly for HP Pavilion x360 Convertible 15-dq0000ng 15-dq1433ng 15-dq1001ng 15-dq1002ng 15-dq1131ng 15-d-5355429-3969958 ansamblu display cu touch https://ibb.co/dB3FQn2 https://ibb.co/SRf5Qm4 https://ibb.co/r43tmvC 380 lei 24. Mini freza cordless cu multe varfuri si sabloane de desenat modele https://ibb.co/S63SWny https://ibb.co/TwDKspW https://ibb.co/YNTNTtS https://ibb.co/r5tQMmB https://ibb.co/3YTV24Y https://ibb.co/R3fc8Qy https://ibb.co/DKmqKw4 https://ibb.co/ySJPzvr https://ibb.co/kDts6mb https://ibb.co/KVkwzZb https://ibb.co/Lk3QMFk https://ibb.co/mXvQ1k4 https://ibb.co/tshbydz https://ibb.co/xYfWYyp https://ibb.co/0mGJCTV 90 lei 25. Pompă de vid electrică de 30 W pentru haine, pompă de vid puternică, eficientă și durabilă, poate fi reutilizată pentru o perioadă lungă de timp https://ibb.co/brWRwC5 https://ibb.co/B3rbLGs https://ibb.co/hy6wHSY 20 lei buc 26. Becuri auto led H4 cu ventilator https://ibb.co/XSqy2kP https://ibb.co/FHwHQMS https://ibb.co/mJ6C3FS https://ibb.co/3f80mY3 https://ibb.co/0M3jC9v https://ibb.co/6DdTHxQ https://ibb.co/mJ1dLDj https://ibb.co/BfpW4ck 40 lei 27. Controler incubator, second hand https://ibb.co/2gJLQkN https://ibb.co/3dW1kyx https://ibb.co/grfnX7d https://ibb.co/zrNNtCn https://ibb.co/4pgfqjJ https://ibb.co/hmc9Pjh https://ibb.co/wBb71WN 40 lei 29. Capsator electric, ambalaj deteriorat, 2 seturi capse si un set cuie https://ibb.co/sKVKvW1 https://ibb.co/qNQzzqG https://ibb.co/ZSs2KMR https://ibb.co/Mc6n3Hk 40 lei 30. Aparat contra tantarilor alimentare usb https://ibb.co/tDvZBGL https://ibb.co/H75q6cj https://ibb.co/0Q5gKLT https://ibb.co/pXmXBpr https://ibb.co/wywfDtx 15 lei ambele, unul fara ambalaj 31. 18 x Brand New Samsung Galaxy A71A Case, Flexible Material, TPU Material, Scratch-Resistant, Maximum Protection, Black carcase silicon Samsung A71 https://ibb.co/309z3GG https://ibb.co/q91DNS4 2,5 lei buc 32. Displayuri cu touch https://postimg.cc/gallery/3hHDX79 10 lei toate, nu mai este cel de apple 33. OMPHOBBY 900mAh 3.7v Li-ion 18350 battery OSHM2344 baterii 18350 https://ibb.co/rw8ZBbv https://ibb.co/37Y1JKv 25 lei 34. Disk Safe timed locker, phone locker with timer phone shutdown video games, social media, self-control timer locker container storage box for addiction management Cutie plastic cu cifru electronic, timer... https://ibb.co/0YvmPXx https://ibb.co/qyqyhVS https://ibb.co/y4TcCJg https://ibb.co/fC4m3XB https://ibb.co/3NL3hFh https://ibb.co/dGt90hJ https://ibb.co/G2J3TmQ 15 lei 35. OBD 2 tester auto nu necesita laptop https://ibb.co/DYk2hpt https://ibb.co/v4VnhPJ https://ibb.co/jMRfr2p https://ibb.co/KrgNDhN https://ibb.co/VDhCVxv https://ibb.co/GMxs8N4 https://ibb.co/h9ZCVZ9 https://ibb.co/zNJpGKh https://ibb.co/qFQ2J5F https://ibb.co/YLF9czB https://ibb.co/VYtbncS https://ibb.co/LQvb3m4 75 lei 2 modele 36. KKMOL Presentation Clicker, Presentation Remote Control, Powerpoint Remote Control, Pointer for Presentations, PPT Red Pointer, USB Presenter for PPT Windows XP 7 8 10 Mac OS Linux pointer prezentari https://ibb.co/DWQg68N https://ibb.co/dQ04wGw 25 lei 37. KKMOL presentation remote control, Powerpoint remote control, pointer for presentations, PPT red pointer, USB 2.4 GHz presenter for PPT Windows XP 7 8 10 Mac OS Linux pointer prezentari, alim cu 2 baterii AAA, fara https://ibb.co/pKn3sCL https://ibb.co/0jG8VBf https://ibb.co/64550gL https://ibb.co/VH1KP5r 25 lei 38. Husa impermeabile - waterproof telefon Samsung A54 https://ibb.co/k6Bvwym https://ibb.co/7pyNMxx https://ibb.co/9TtMK94 10 lei 39. Dispozitiv pentru seringi cu flux printat 3D https://ibb.co/qyYz9pn 20 lei 40. 4 seturi telecomenzi radio https://ibb.co/6BYWBpB https://ibb.co/ww56jXy https://ibb.co/M7NbPzZ https://ibb.co/BNTVVb7 https://ibb.co/xGdnz3r https://ibb.co/M8X5Pw5 https://ibb.co/XkTVFV1 https://ibb.co/w66myzn https://ibb.co/rFW9JBN https://ibb.co/JQdNzCC https://ibb.co/rxPfBVQ https://ibb.co/82KxB8m https://ibb.co/LCFh7TX 30 lei setul 41. set 5 aparate de masura luxmetru, decibelmetru, clampmetru, multimetru si detector cabluri https://ibb.co/XpXdXTY https://ibb.co/7p76BPb https://ibb.co/4K5Fkjx https://ibb.co/p4yFJMR https://ibb.co/C6qcWv4 https://ibb.co/YT9NW5V https://ibb.co/k8tPBLg https://ibb.co/yYv8g1S https://ibb.co/WHR5SQG https://ibb.co/31YFS1R https://ibb.co/XsKgNyD https://ibb.co/GQ3MgPT https://ibb.co/1fHfn9K https://ibb.co/YL4dxnb https://ibb.co/HqYtmjk https://ibb.co/6Y6kmG1 https://ibb.co/TR7zc2g https://ibb.co/TwYfZcQ https://ibb.co/fXwJ5xy https://ibb.co/XVN83JV https://ibb.co/ssTgh6H https://ibb.co/xHgQH6K https://ibb.co/NmCBVzY https://ibb.co/RS5tQFT https://ibb.co/1Q2wVKb https://ibb.co/mF5mGnn 250 lei 42. 3.7V 3000mAh NiMH rechargeable battery, POWO18B with NiMH battery protection box, NO 1818-666-888B battery, perfect for flashlight, camera, small fan, doorbell baterii 4 bucati https://ibb.co/qmrc30z https://ibb.co/bNMs7Jr https://ibb.co/fkgJjSn https://ibb.co/jVxmtwY https://ibb.co/wLfCL4z https://ibb.co/ZSmqDcy 35 lei 43. Huse deosebite piele naturala vintage pentru telefon, etc de pus la curea https://ibb.co/dWhYbGr https://ibb.co/vPFbXsV https://ibb.co/27WHS1H https://ibb.co/gg2f6Kj https://ibb.co/5T119MF https://ibb.co/gg2f6Kj https://ibb.co/fnPbYfD 30 lei buc 44. Cotiere genunchiere copii pentru bicicleta/trotineta/etc marimea L https://ibb.co/FbfGmnF https://ibb.co/9pY4QzH https://ibb.co/9bDWpCv https://ibb.co/R7xxmDF https://ibb.co/Dwt3xSS 25 lei 45. Surse de laborator 30V 10A https://ibb.co/fvtVyL7 https://ibb.co/TgHnXCr https://ibb.co/c146DQQ https://ibb.co/NnBV5wp https://ibb.co/9rH2gNT https://ibb.co/g4XvBKp https://ibb.co/KmP92MC https://ibb.co/DPF5WNd https://ibb.co/Bz3MSp4 https://ibb.co/vsNkh0S https://ibb.co/YhRHfg3 https://ibb.co/jbkmR53 https://ibb.co/xDyjbM7 https://ibb.co/Trc0kZH https://ibb.co/x5bkvTq https://ibb.co/85d4gLx https://ibb.co/Gnt7Wnv https://ibb.co/R9Cgj9B https://ibb.co/sRHxL4f 325 lei buc 46. Detector radiatii nucleare https://ibb.co/ZMsqyGz https://ibb.co/484yMXW https://ibb.co/Js31QWQ https://ibb.co/NNp49T9 https://ibb.co/S6J8wfp https://ibb.co/4KFt7bQ 25 lei buc 47. KG316T timer, LCD display, timer switch, time switch, microcomputer, 220V, resistance 25A, electric timer second hand https://ibb.co/1TZdM9j https://ibb.co/HYx86QJ https://ibb.co/yQ1BrRv https://ibb.co/gjgprxP https://ibb.co/ZT6YkpT 25lei 48. 2PCS UV Lamp E27 Bulb Transparente, becuri UV https://ibb.co/wRbXq0v https://ibb.co/60XwdF7 35 lei 50. 9W 365nm UV Lamp 4 lampi UV, neprobate, nu stiu daca sunt direct la 230V https://ibb.co/JCQK03w https://ibb.co/4MdYBnC 10 lei toate 51. Awootsv Priză temporizatoare electrică digitală cu afișaj LCD 10 funcții aleatorii configurabile antiefracție Conectare interioară întrerupător temporizator electric pentru lumini și aparate de uz casnic, 3680W 2 buc https://ibb.co/nbG9W3N https://ibb.co/pLHxhF1 https://ibb.co/mJWg4YY https://ibb.co/KKRMXG4 https://ibb.co/k5hysNm https://ibb.co/c2QC7Ky https://ibb.co/GkcHBZB 30 lei ambele 52. Aideepen 3 x 3S 20A Li-ion Lithium Battery Charger Board PCB BMS 12.6V Cell Module Overcharge Overcurrent Short Circuit Protection BMS-uri 3S https://ibb.co/mGbZXb3 https://ibb.co/b2fK1QM 10 lei buc, disponibile 2 buc 53. Adaptor combinat M.2 NVME PCIE SSD la SFF-8654 NGFF SATA SATA la SATA 2 în 1 pentru placa de bază (NVME SSD la SATA nu funcționează pe acest adaptor) https://ibb.co/TRNf9Mg 20 lei 54. ECOTISH Women s Backpack in Soft Leather Casual School Daypack 2 in 1 as Backpack and Shoulder Bag, Women s Fashion Bag and Shoulder Backpack for School, Shopping, PLUS geanta de umar Rucsac piele ecologica si geanta de umar din piele naturala https://ibb.co/xmZz8tF https://ibb.co/HgD36q6 35 lei buc 55. extensii cabluri PC https://ibb.co/ZMyNkYp https://ibb.co/jkqDG77 https://ibb.co/Lnb20tY https://ibb.co/RBVdm21 40 lei 56. YYSG Vacuum Bags 6 Pack 60x40cm, Vacuum Bags for Clothes, 80 More Storage Space, Reusable Travel Space Saving, Vacuum Storage Bags for Clothes Duvets Bedding Pillows Blankets 6 pungi vacuum set sigilat https://ibb.co/wz5Wb5Y https://ibb.co/3N9jym8 https://ibb.co/tXPkfvZ https://ibb.co/gRLjYSB 20 lei + 10 pungi si pompa 40 lei (50 lei tot) 57. Pyrography Machine, 100W wood burner set with 2 pens and 33 pcs wire tips, pyrography station burning iron pyrography equipment adjustable from 0-750 C, double Aparat pirogravura dublu https://ibb.co/tpjNy69 https://ibb.co/drjJSt0 https://ibb.co/nz1V1NQ https://ibb.co/vP1Tv4V https://ibb.co/3F0HYL6 https://ibb.co/gVS8dWG https://ibb.co/vkxSKs5 https://ibb.co/xMmx58V https://ibb.co/dgZVgF2 https://ibb.co/vznc6L7 https://ibb.co/YdpVkVx 140 lei 58. ORIGBELIE External DVD Drive USB 3.0 Type C, CD DVD -RW Burner with USB Ports and SD TF Card Reader, External CD Drive for Laptop Desktop MacBook Windows 11 10 8 7 XP Vista Linux Mac Ambalaj carton https://ibb.co/nbVhFZk https://ibb.co/Rz6MWD1 https://ibb.co/DrJprM0 https://ibb.co/D5Th8Vf https://ibb.co/4tgmq06 https://ibb.co/DQWyzY2 https://ibb.co/5cBzjnx https://ibb.co/NLyGRXJ https://ibb.co/ggzNHmb https://ibb.co/gvtbRV8 https://ibb.co/NtXYqhw https://ibb.co/wcMZJt5 https://ibb.co/VvD5CcS https://ibb.co/VWzDfCD https://ibb.co/SK4Sn8Z https://ibb.co/njBWKmF https://ibb.co/2ZVW7SQ https://ibb.co/7vW8X95 https://ibb.co/BZ5P0L7 https://ibb.co/RHKyWWX https://ibb.co/hVHvJPG https://ibb.co/80GQnJW https://ibb.co/vdb0wvx https://ibb.co/gJ2Yb9w https://ibb.co/NtXwc9j https://ibb.co/Cv7Th0h https://ibb.co/kqbyp67 55 lei mai multe buc, disponibil unul SH, fara cititor carduri si usb-uri suplimentare la 25 lei, 3 simple la 30lei si un bluray extern la 100 lei (netestat suficient sa fiu sigur ca e ok, pare nou) 59. Pancellent PH meter, PH TDS EC and temperature 4 in 1 set, water quality tester ATC for drinking water swimming pool aquarium pools, conductivity meter with high accuracy and LCD display blue mai multe seturi https://ibb.co/WDFBDBH https://ibb.co/y0zS8tg https://ibb.co/B22z1B7 https://ibb.co/QpP1yx1 https://ibb.co/gJC28fS https://ibb.co/GTYWCXk https://ibb.co/XCtbBQx https://ibb.co/NmFrRNw 20 lei setul 60. Transformator 230v la 110V 300W https://ibb.co/WPYcvpZ https://ibb.co/x7qRyxQ https://ibb.co/cCqRhnr https://ibb.co/gF58bnC 50 lei, stoc 2 buc 61. Smoke detector networked, AEGISLINK set of 6 wireless smoke detectors with replaceable battery, fire alarm with transmission range of over 250 m, test mute button, auto-check function, S-RF220 detectoare de fum, bulk https://ibb.co/Qc3xmdX https://ibb.co/09fjw7J https://ibb.co/TvVSCfR https://ibb.co/bNghb3g https://ibb.co/vz68mwx https://ibb.co/ZVf68nH https://ibb.co/J5tFxZq https://ibb.co/ZHT72Bh https://ibb.co/QNK1byZ 35 lei buc, 5 buc 62. Networkable combined smoke and carbon monoxide detector, AEGISLINK smoke detector networked, 2 IN-1 CO detector with replaceable battery and 250 m transmission range, SC-RF220 detectoare monoxid carbon si fum bulk https://ibb.co/1qFw7Bn https://ibb.co/bspvw3q https://ibb.co/qxG3d1H https://ibb.co/G30BHPs https://ibb.co/WgS597C https://ibb.co/nDgnh3N https://ibb.co/q0M4JLY https://ibb.co/hX6GkgJ 45 lei disponibile 2 buc 63. Pedală de chitară multi-efect LEKATO pentru chitară bas electrică cu încărcare în infraroșu, editare, înregistrare pe telefon pe computer, tuner, ieșire căști de 3,5 mm, timp de lucru 8 ore https://ibb.co/Wk3KMfJ https://ibb.co/vX3PRkM https://ibb.co/3sTyCGG https://ibb.co/ypPC5N3 https://ibb.co/NpQsv5h https://ibb.co/g4PCmMH https://ibb.co/NsbRbGn https://ibb.co/0KtW739 https://ibb.co/MskqxMb https://ibb.co/GcKt6jJ https://ibb.co/yPxh89x 100 lei 64. Detector inteligent de fum X-Sense XS01-M, Wi-Fi, compatibil cu FS31 FS61 FS121, stația de bază SBS50 și aplicația X-Sense Home Security, semnal de avertizare 85 dB, mini detector de fum și incendiu în rețea https://ibb.co/JvJbD01 https://ibb.co/7VhNC7b https://ibb.co/wW3F4Cc https://ibb.co/sbQDVhD https://ibb.co/NYgDHzY 45 lei 65. Detector inteligent de fum WiFi wireless HEIMAN, cu 5 ani de viață a bateriei, senzor fotoelectric, EN14604, avertizare baterie scăzută https://ibb.co/bFFRkwg https://ibb.co/3BHv7MY 45 lei 66. Set de 3 detectoare de fum RAKELL, baterie 10 ani, alarmă sonoră 85 dB, testat 14604, senzor fotoelectric https://ibb.co/vkfvhyv https://ibb.co/rHBrksc https://ibb.co/jGHDLGZ https://ibb.co/6HML1Ds https://ibb.co/cvjDqLL https://ibb.co/ZBsTHq8 https://ibb.co/3yF5pPt 110 lei 67. Cabluri audio aurite, prelungitor type-C, audio apple https://ibb.co/S70DfH9 https://ibb.co/SJ2N41V https://ibb.co/q9FLpSJ https://ibb.co/vD18430 https://ibb.co/xmtWdrK https://ibb.co/G7tGgLW https://ibb.co/rZspwvs https://ibb.co/NVRzgS5 https://ibb.co/8KSGtMy https://ibb.co/gFPZKqY https://ibb.co/vHK6NxC 30 lei buc audio, 10 lei buc celelalte 68. Detectoare fum diverse https://ibb.co/2nNHQqq https://ibb.co/4F0sFf3 https://ibb.co/y83Vxfn https://ibb.co/mFzjgKR https://ibb.co/nCCdbbF https://ibb.co/Jj31DXz https://ibb.co/tMkyKTz https://ibb.co/kg6p3mg https://ibb.co/9gf2m60 https://ibb.co/ZN1FTMS https://ibb.co/KGFWjf9 https://ibb.co/C6sZrDk https://ibb.co/yST9krH https://ibb.co/gwB4kFZ https://ibb.co/vQv2VWS 35 lei buc, 140 lei set de 5 69. Mini amplificator Bluetooth 600 W Amplificator digital stereo HiFi Amplificator de putere radio FM Amplificator audio Control de bas înalte pentru PC Difuzor audio pentru mașină Amplificator digital Amplificator de putere Hi-Fi Suporta mai multe formate muzicale: card SD, disc U, redare in format MP3, suporta conexiune wireless BT. Două sloturi de intrare pentru microfon: două sloturi de intrare pentru microfon, sistem de karaoke în casă sau mașină. Cu comenzi înalte, bas și volum, foarte ușor de utilizat. Afișaj LCD încorporat, sunet mai puternic: Mini amplificator de putere audio digital HIFI BT. Afișaj LCD încorporat cu lumină de fundal. Distorsiunea redusă oferă un sunet mai clar și mai puternic. Ieșire cu două canale principale: Ieșire cu două canale principale. Cu funcție de telecomandă. Conexiune DC / AC, potrivită atât pentru casă, cât și pentru mașină. NOTĂ: Pentru a proteja mediul înconjurător, telecomanda noastră nu conține baterii buton CR2025, așa că clienții trebuie să le cumpere singuri. https://ibb.co/twfmtz3 https://ibb.co/tMyWXKP https://ibb.co/hZnQ6d8 https://ibb.co/k9Tqt6Y https://ibb.co/cbZzMDG https://ibb.co/rfD3drF https://ibb.co/7gRVx6H https://ibb.co/YyqWBp5 70 lei 70. Fokky digital to analog audio converter 192khz DAC model HS200 https://ibb.co/5cr1tBR https://ibb.co/WWckHKY https://ibb.co/WyBNHHq https://ibb.co/qskvLf8 https://ibb.co/vkZXL1n https://ibb.co/5shZW2n https://ibb.co/YWwdMv2 https://ibb.co/svP9KHS 35 lei 71. Transformator 230V la 110V si invers 500VA https://ibb.co/9qqtgfL https://ibb.co/bHmJ493 https://ibb.co/DG6HsbW https://ibb.co/hBYxHJV https://ibb.co/85zN67D https://ibb.co/JrfKBNS https://ibb.co/xCRJRTT 125 lei buc, mai multe buc disponibile 72. Obd2 Activator de imobilizare Activator Drive Box Edc15 Me7 Caracteristici: 1.Professional de fabricație, această cutie este perfect pentru a se potrivi pentru SEAT Cordoba / Ibiza / Toledo / Toledo. 2. Domeniul de aplicare este larg, sunt aplicabile atât motorina, cât și benzina, deci nu este nevoie să vă faceți griji cu privire la inadecvare. 3. Este ușor de utilizat, doar conectați-l, nu există pași complicați și timpul dvs. nu va fi pierdut. 4.It este compact, nu ocupă spațiu, are doar dimensiuni de 8,7x4,5x2,5cm / 3,4x1,8x1in și este ușor de transportat. Îl puteți lua oriunde. 5. A fost supus unor teste extinse de calitate și siguranță pentru a asigura performanțe fiabile. Specificație: Tip element: OBD2 Imobilizator Material: ABS Culoare: Negru Tensiune: DC 12V Model de corespondență: EDC15 (motorină) și ME7 (benzină) Dimensiune: Aprox. 8,7x4,5x2,5cm/3,4x1,8x1in (Datorită măsurării manuale, poate exista o abatere de 1-2 mm) Ghidul utilizatorului: Doar conectați cutia de acționare EDC15 / ME7 la mufa de diagnosticare (OBD2) a vehiculului, apoi conectați OBD2 și comutați la "oprit" pe cutia de unitate. După numai 20 până la 30 de secunde, blocarea antifurt nu mai necesită un computer. Fitment: Fit pentru A2 / A3 / A4 / A6 Fit pentru SEAT Cordoba / Ibiza / Toledo / Toledo Fit pentru SKODA OCTAVIA Fit pentru Skoda Octavia II Fit for Skoda Scout Fit pentru ŠKODA Roomstar Fit pentru SKODA FABIA Fit pentru Skoda Superb (până în 2007 ) Fit for PORSCHE Cayenne (benzină, model vechi) Fit for Bora (din anul 2000) Fit for Caddy (din anul 2000)Fit for EOS Fit for T4 (From year 2000) https://ibb.co/xFC3LDn https://ibb.co/mFRwjLY https://ibb.co/pyJVvD0 100 LEI 73. Lampa acvariu S.H. (sau pt altceva ) multe combinatii luminoase https://ibb.co/cDxpSLY https://ibb.co/k0PTCbY https://ibb.co/F6H4jPt https://ibb.co/4Vw9cSY https://ibb.co/C98yV51 https://ibb.co/jfVb7Ft https://ibb.co/nbMfWm8 https://ibb.co/YLQFKJy https://ibb.co/ZxtdG83 https://ibb.co/mcHpfgq https://ibb.co/48q0bLr https://ibb.co/pnrXBSH https://ibb.co/fnh9NG6 50lei 74.Lampa wireles multicolora, telecomanda , era noua dar i-am facut 2 semne minuscule cand o probam https://ibb.co/vmbcq4k https://ibb.co/WGYBSry https://ibb.co/v3TX63W https://ibb.co/vvHkpNN https://ibb.co/NKpjztV https://ibb.co/PM8RDq7 https://ibb.co/WBSJCyr https://ibb.co/W3Rm5JH https://ibb.co/qDw8gQp https://ibb.co/8DppYgP https://ibb.co/519bHww https://ibb.co/RY5YhpX https://ibb.co/KrzJy9s https://ibb.co/G90jhYP https://ibb.co/tx380yw https://ibb.co/JkkHDpY https://ibb.co/YPWXJMT 45 lei 75. DEWIN Digital Ammeter Voltmeter, PZEM-025 Digital Ammeter DC Voltmeter Battery Tester 0 300A 300V Power Energy Wattmeter 50A second hand https://ibb.co/Nr3FsvT https://ibb.co/SQZ1hF0 https://ibb.co/mNgyZfW https://ibb.co/QHB3tqB https://ibb.co/NTvny06 https://ibb.co/G2H3Xw3 https://ibb.co/pQ11q1y https://ibb.co/swCvQV7 https://ibb.co/B2dksFX https://ibb.co/8Bc1NZW 20 lei 76. Bureti pentru casti https://ibb.co/JBr3cpG https://ibb.co/tCCV6xJ https://ibb.co/yPw8BPf https://ibb.co/CBk8y4T https://ibb.co/Jy4ncjN https://ibb.co/mhvBSFb https://ibb.co/c1Md4Tk 5 lei perechea, primul model 7 perechi 77. Uscator filament imprimanta 3D, SUNLU, pare folosit, dar in stare excelenta https://ibb.co/bdk1vY5 https://ibb.co/RDfCn1g https://ibb.co/Z8YZrtg https://ibb.co/v4L07kv https://ibb.co/CshRTZ3 https://ibb.co/4mPZ3My https://ibb.co/W2kBC1T https://ibb.co/GRJ12Xv https://ibb.co/mB7pgMb https://ibb.co/3FchVdB https://ibb.co/tq7KgF9 https://ibb.co/xH3PRrq 130 lei 78. Cutter electric stiroflex model mai deosebit https://ibb.co/SrX5X0Q https://ibb.co/DgKxLx1 https://ibb.co/ChycrK4 https://ibb.co/gJ943wD https://ibb.co/nPv9zX4 https://ibb.co/8mH3WWf 100 lei 79. 10mm x 10mm Volume Control Potentiometer Quilted Knob Black Aluminum 6mm Slide Shaft Rotary Knob 5 butoane aluminiu, micute https://ibb.co/2n25VGp https://ibb.co/GPsVKB8 https://ibb.co/02V73v1 20 lei 80. Incarcator baterii 2 modele https://ibb.co/KhnbF5s https://ibb.co/X2y34B5 https://ibb.co/vx6jLgC https://ibb.co/VB10Z5P https://ibb.co/RpC9N1b https://ibb.co/xz0Vg92 https://ibb.co/Bj8tRdz https://ibb.co/r7ps7mV https://ibb.co/tqrGN37 https://ibb.co/CVNH9b0 https://ibb.co/tzs9nQ3 https://ibb.co/KG3j8Nd https://ibb.co/6v5Q6WD https://ibb.co/ysLX0nX https://ibb.co/DpJrK1L 35 lei buc 81. Ecran LCD pentru Samsung Galaxy Tab A8 10.5 2021 SM-X200 SM-X205 cu digitizer tactil cu afișaj LCD plus sticla protectie https://ibb.co/cgNs7dH https://ibb.co/LP91Knr https://ibb.co/K07jHJm 30 lei Link spre comentariu
dan cod Postat Marți la 03:53 Partajează Postat Marți la 03:53 78 as vrea eu dacă poate ajunge pana joi la mine. Și dacă printre ce este aici ar fi un cdrom, writer pe usb m-ar interesa și asa ceva. Dar doar dacă este nou și scrie bine cd și DVD. Link spre comentariu
Windows Postat Marți la 05:41 Autor Partajează Postat Marți la 05:41 (editat) Acum 1 oră, dan cod a spus: 78 as vrea eu dacă poate ajunge pana joi la mine. Și dacă printre ce este aici ar fi un cdrom, writer pe usb m-ar interesa și asa ceva. Dar doar dacă este nou și scrie bine cd și DVD. ok, dvdrw cu usb-uri si cititor card sau de ala simplu mai ieftin? Editat Marți la 05:41 de Windows Link spre comentariu
dan cod Postat Marți la 06:07 Partajează Postat Marți la 06:07 Acum 24 minute, Windows a spus: ok, dvdrw cu usb-uri si cititor card sau de ala simplu mai ieftin? De fapt vreau nu aparat DVD ci DVD writer pe usb dacă este. Nu aparat de ascultat sau cuplat la TV. Îmi trebuie pentru laptop care nu are unitate DVD și trebuie sa scriu niște discuri. Doar asa ceva. Link spre comentariu
Windows Postat Marți la 06:10 Autor Partajează Postat Marți la 06:10 (editat) Acum 19 minute, dan cod a spus: De fapt vreau nu aparat DVD ci DVD writer pe usb dacă este. Nu aparat de ascultat sau cuplat la TV. Îmi trebuie pentru laptop care nu are unitate DVD și trebuie sa scriu niște discuri. Doar asa ceva. DVDRW extern pt PC/laptop cu cititor card si usb este si cum am zis am si simple. Lasati-mi datele pe MP si prin ce transportator trimit( posta/easybox plata in cont). Editat Marți la 06:27 de Windows Link spre comentariu
amudsen Postat Marți la 07:03 Partajează Postat Marți la 07:03 (editat) Buna ziua. As dori pozitia 1 - Car Radio 1 Din with Bluetooth Handsfree IOS Android Mirror Link 9 Inch Touchscreen, with Bluetooth FM Radio USB AUX TF EQ 7 Colors Light Steering Wheel Control Rear View Camera Microphone Multumesc. Editat Marți la 07:05 de amudsen completare Link spre comentariu
mbj57 Postat Marți la 07:30 Partajează Postat Marți la 07:30 Buna ziua, as dori pozitia 59 - Pancellent PH meter, PH TDS EC temperature 4 in 1 - un set si pozitia 80- incarcator baterii modelul cu 2 afisaje Aveti MP Link spre comentariu
Windows Postat Marți la 18:19 Autor Partajează Postat Marți la 18:19 Acum 20 ore, Windows a spus: Marfa este noua, posibil unele ambalaje deteriorate. Posibil si ceva marfa netestata, dar e specificat. Trimit prin Fancurier, (SUNT ZILE TRANSPORT GRATUIT PE OLX ) daca aveti cont OLX coletul cu verificare costa undeva la 10 - 25 lei, POSTA, EASYBOX PLATA INTEGRALA IN CONT. Cu rosu bolduit intrari noi, cu portocaliu bolduit marfa trimisa/rezervata/discutii 1. Element peltier cu dispozitiv recirculare lichid(asa pare) https://ibb.co/SchBJvB https://ibb.co/yWx9WJJ https://ibb.co/TLPVJbn https://ibb.co/sWpDtZQ https://ibb.co/TW8ts3V 50 lei 2. Carucior pliabil rosu https://ibb.co/tDRQy96 https://ibb.co/JC0hwjQ https://ibb.co/x55q3RY 125lei ...sau 2 rate 3. RUZIZAO laboratory power supply 30V 5A, laboratory power supply with 3-digit LED display, adjustable switching power supply upgrade encoder button, mini laboratory sursa de laborator https://ibb.co/0yXJLpC https://ibb.co/C1fPqRH https://ibb.co/fpJVLDJ https://ibb.co/RTy9t0T https://ibb.co/NnGns6X https://ibb.co/WHKRPCH https://ibb.co/2qQR3Yk https://ibb.co/pJ4cWbP https://ibb.co/Sx7rCMm https://ibb.co/f9Tk25Z https://ibb.co/p0hS9SX 200 lei 4. Newbealer Mini Travel Iron with Switchable Voltage-220V 120V, Compact Iron for Clothes No Steam , Ceramic Surface, 150 C Hot Press with Spray Bottle, Bag and Silicon Mini fier de calcat https://ibb.co/MGzRdVY https://ibb.co/LnvqxdL https://ibb.co/bQWZPwv https://ibb.co/GtkMyzv https://ibb.co/82JZ6JH https://ibb.co/FqbtC3r 40 lei 5. Lampa LED cu lupa marita, Izoxis, negru, 10 nivele intensitate, 65x15x5cm SPECIFICATII LAMPEI: culoare neagra material: fier altele: PP + sticla + cauciuc iluminare din spate: LED Numar de LED-uri: 72 lentila de marire: da x 3 culoare de iluminare: alb cald, alb neutru si alb rece numarul de niveluri de intensitate a luminii: 10 diametru lupa: 10,5 cm grosimea maxima a blatului pentru montarea lampii: 5 cm dimensiuni: 65 x 15 x 5 cm greutate: 640 g greutate pachet: 1.037 kg https://ibb.co/nsqfgns https://ibb.co/kxPspX6 https://ibb.co/bbyX0yq https://ibb.co/8P290x6 https://ibb.co/sW6NKYX https://ibb.co/HzKhH33 https://ibb.co/X22jZRN https://ibb.co/mqCBDvJ https://ibb.co/xGC1tGy https://ibb.co/5BxJP81 https://ibb.co/f9jLXzS 60 lei 6. Controler incubator ( sau pentru orice alta automatizare) https://ibb.co/XxN2GkN https://ibb.co/f00RpCv https://ibb.co/P9c8rFh https://ibb.co/FsNpY1m https://ibb.co/g93G9z8 https://ibb.co/0mj862P https://ibb.co/JpNFKJf https://ibb.co/5hfGqVP https://ibb.co/pPrC2DT https://ibb.co/wBJCCSj 40 lei 7. Organizator auto de montat in spatele scaunelor https://ibb.co/y0Mh7Fr https://ibb.co/XJy6F8Z https://ibb.co/m0KfcZ4 https://ibb.co/QNM00tj 30 lei 8. Memorii laptop SODIMM DDR4 DDR5 8GB/16GB https://ibb.co/m47d37r https://ibb.co/BPgMjFt https://ibb.co/CtvHgTf https://ibb.co/PQ9X9gZ https://ibb.co/7tGYnFT https://ibb.co/f4MDJnF https://ibb.co/FKr7zC8 https://ibb.co/QjfcMyP https://ibb.co/6Wk6dY4 preturi intre 70-190 lei 9. Sovol SV06 Plus SV04 Textured PEI Print Bed Printing Plate Magnetic 3D Printer Platform 310 x 320 mm for Ender 3 Max NEO CR-10 V2 CR-10 V3 CR-10S PRO V2 CR-X YOOPAI PEI Print Plate 310x320mm, Double-Sided Black Textured PEI Magnetic Spring Steel Print Bed for Creality CR10 CR10S 10S Pro V2 V3, Ender 3 Max, AnyCubic Mega X-5698794-4221764 Pat magnetic 310x320mm pentru imprimanta 3D 2 buc https://postimg.cc/gallery/Chb4qFW 35 lei bucata 10. Incarcatoare pentru orice tip de laptop mufa specifica fiecarului model, mufa Type C https://ibb.co/jGyxCSW https://ibb.co/m5S778B https://ibb.co/jZtMq8h https://ibb.co/mRDXJ4S https://ibb.co/0n7Pj42 https://ibb.co/16mtCrd https://ibb.co/QnrJZyG https://ibb.co/kDwvBGd https://ibb.co/TqPSgKn https://ibb.co/fSkBfBg https://ibb.co/9b6qBD4 https://ibb.co/z8R6kgK https://ibb.co/tP25LMr https://ibb.co/K5kCv9N https://ibb.co/PcN3Vjs 45 lei pana in 100W, 55 lei Type-C, Apple, 100 lei peste 100W 11. EC1-12706 Dual Core Semiconductor Refrigeration Thermoelectric Peltier Cooling System 120W Window Air Conditioner Element peltier https://ibb.co/hWD6KXp https://ibb.co/87G2Xzg https://ibb.co/2cFFLDK https://ibb.co/8MCZ896 https://ibb.co/z2mPmSV https://ibb.co/GdyDmMY https://ibb.co/3v23cw3 50 lei 12. Treedix soldering iron set, 8W wireless soldering iron soldering set with adjustable temperature from 330 to 450 C, including USB cable, soldering wire, iron stand with sponge, 3 soldering tips for soldering Mini letcon cu incarcare type C https://ibb.co/5vr6wwB https://ibb.co/0sJHD36 90 lei setul, 2 seturi disponibile 13. CREWORKS Step Up Down Voltage Converter Convert 110V 220V 3000W with Automatic Cut-off Transformer with 110V 220V Sockets 5V USB Ports Automatic Transformer https://ibb.co/HBMWfPY https://ibb.co/Jjf8r5z https://ibb.co/5hjfDbp https://ibb.co/nkxyQd8 https://ibb.co/CHLTr8Q https://ibb.co/WG7mfD0 https://ibb.co/Bjr7XdF https://ibb.co/QXCSm5g https://ibb.co/qnrmPhB https://ibb.co/tYqQ9ST https://ibb.co/J3VrwCG 380lei 14. MOTOPOWER MP00205A 12V 800mA Automatic Battery Charger for Cars, Motorcycles, ATVs, RVs, Powersports, Boat Incarcator, desulfator automat https://ibb.co/GHyMpCY https://ibb.co/7tT3XPN https://ibb.co/mvKJ0rH https://ibb.co/6NNBJsL https://ibb.co/fCWYPMc https://ibb.co/jk3mZSS https://ibb.co/ccqXxMS https://ibb.co/yyrCNjG https://ibb.co/brr9fCX https://ibb.co/ZJdNjnb https://ibb.co/BHh3nTm 55 lei 15. husa piele naturala Samsung A53 5G https://ibb.co/3fTpC51 https://ibb.co/pvhm1QX https://ibb.co/6XNbCyR https://ibb.co/wMC6Y60 https://ibb.co/Wsczncd https://ibb.co/2vRszty https://ibb.co/KssvjsF 15 lei 16. ANJANK Extremely Loud Wireless Vibrating Alarm Clock with Electric Shaker for No Hearing, Hard of Hearing, Deep Sleep, Dual Alarm, Battery Backup, USB Charger 2 Ceasuri cu afisaj foarte mare noi in cutie https://ibb.co/GnZsYp5 https://ibb.co/kMYpzRR https://ibb.co/f2ZGvXg https://ibb.co/8rjh502 https://ibb.co/bK1kmbC https://ibb.co/cNhtX6T https://ibb.co/r6nC67w https://ibb.co/51PKnvC https://ibb.co/0FwwsfD 35 lei buc 17. MP5 player, Radio, Carplay, navigatie cu Android mirror link (posibil sa nu mearga cu android peste 6 sau 7) telecomanda, camera spate https://ibb.co/YPSFCyq https://ibb.co/CBztpSz https://ibb.co/F6JDPvY https://ibb.co/f8hg91c https://ibb.co/SvV0mdL https://ibb.co/v30d62G https://ibb.co/ZNYzRtZ https://ibb.co/Sxd2Wfh https://ibb.co/TR5VSFN https://ibb.co/8xQpr3g https://ibb.co/zFNr45b https://ibb.co/F7w78QB https://ibb.co/mDYdLPH https://ibb.co/yfKxXTQ https://ibb.co/60TGNYF https://ibb.co/vzt3nPH https://ibb.co/47QfQK3 https://ibb.co/Hx4M6PW https://ibb.co/4Y334z5 https://ibb.co/xYLPCtw https://ibb.co/wLnfXqs 165 lei disponibile 4 buc 0 buc cu urme de montare pe masina dar pare noua 140 lei, una de 10 inch wide cu montare pe bord 150 lei 18. set 4 lampi led cu incarcare solara si cred ca au si detector miscare, 3 nivele de aprindere https://ibb.co/YjJ5tMv https://ibb.co/hKt8RQJ https://ibb.co/khKfCCK https://ibb.co/165jdSv https://ibb.co/FsdHNSQ https://ibb.co/VBk2gyf https://ibb.co/WWhMqbC https://ibb.co/T8swKJx 50 lei setul 19. TREKOLOGY Large Inflatable Pillow - ALUFT Ultra Camping Pillow for Beach and Camping, Inflatable Pillow for Outdoor Adventures Perna gonflabila https://ibb.co/4s48H5g https://ibb.co/THTVypr https://ibb.co/k6txtYS https://ibb.co/BVTryRN https://ibb.co/nnbx34S https://ibb.co/tD3PJxw 20 lei 20. SVNOOC 24V 4A Power Supply 96W Charger 100 240V AC to DC Converter LED Transformer with 5.5mmx 2.5mm Plug for CCTV Camera LCD Monitor DC Pump Fan CE Certificate EU Plug inncarcator 24V 4A https://ibb.co/qJRXjK4 https://ibb.co/fCWN1Y4 https://ibb.co/tqYsTDg https://ibb.co/42k96G9 https://ibb.co/RTqHpNy 25 lei 21. Bzocio 1Din Car Radio CD DVD Player External Stereo Interface USB Port Navigation GPS Car Universal https://ibb.co/PZSh3gr https://ibb.co/rZWwnvB https://ibb.co/SXGG0jq https://ibb.co/W2JNRTS https://ibb.co/whJb8rq https://ibb.co/Tt4s1fx 20 lei 22. Magneti neodim 500 buc 5mmx5mmx2mm https://ibb.co/T41GmxC https://ibb.co/QKZGdJZ https://ibb.co/RBzXrvK 85 lei 23. FTDLCD 15.6 inch LCD Touch Screen Digitizer Display Screen Assembly for HP Pavilion x360 Convertible 15-dq0000ng 15-dq1433ng 15-dq1001ng 15-dq1002ng 15-dq1131ng 15-d-5355429-3969958 ansamblu display cu touch https://ibb.co/dB3FQn2 https://ibb.co/SRf5Qm4 https://ibb.co/r43tmvC 380 lei 24. Mini freza cordless cu multe varfuri si sabloane de desenat modele https://ibb.co/S63SWny https://ibb.co/TwDKspW https://ibb.co/YNTNTtS https://ibb.co/r5tQMmB https://ibb.co/3YTV24Y https://ibb.co/R3fc8Qy https://ibb.co/DKmqKw4 https://ibb.co/ySJPzvr https://ibb.co/kDts6mb https://ibb.co/KVkwzZb https://ibb.co/Lk3QMFk https://ibb.co/mXvQ1k4 https://ibb.co/tshbydz https://ibb.co/xYfWYyp https://ibb.co/0mGJCTV https://ibb.co/L8yR8Dh https://ibb.co/4sVBtb6 90 lei, 50 lei ultima 25. Pompă de vid electrică de 30 W pentru haine, pompă de vid puternică, eficientă și durabilă, poate fi reutilizată pentru o perioadă lungă de timp https://ibb.co/brWRwC5 https://ibb.co/B3rbLGs https://ibb.co/hy6wHSY 20 lei buc 26. Becuri auto led H4 cu ventilator https://ibb.co/XSqy2kP https://ibb.co/FHwHQMS https://ibb.co/mJ6C3FS https://ibb.co/3f80mY3 https://ibb.co/0M3jC9v https://ibb.co/6DdTHxQ https://ibb.co/mJ1dLDj https://ibb.co/BfpW4ck 40 lei 27. Controler incubator, second hand https://ibb.co/2gJLQkN https://ibb.co/3dW1kyx https://ibb.co/grfnX7d https://ibb.co/zrNNtCn https://ibb.co/4pgfqjJ https://ibb.co/hmc9Pjh https://ibb.co/wBb71WN 40 lei 29. Capsator electric, ambalaj deteriorat, 2 seturi capse si un set cuie https://ibb.co/sKVKvW1 https://ibb.co/qNQzzqG https://ibb.co/ZSs2KMR https://ibb.co/Mc6n3Hk 40 lei 30. Aparat contra tantarilor alimentare usb https://ibb.co/tDvZBGL https://ibb.co/H75q6cj https://ibb.co/0Q5gKLT https://ibb.co/pXmXBpr https://ibb.co/wywfDtx 15 lei ambele, unul fara ambalaj 31. 18 x Brand New Samsung Galaxy A71A Case, Flexible Material, TPU Material, Scratch-Resistant, Maximum Protection, Black carcase silicon Samsung A71 https://ibb.co/309z3GG https://ibb.co/q91DNS4 2,5 lei buc 32. Displayuri cu touch https://postimg.cc/gallery/3hHDX79 10 lei toate, nu mai este cel de apple 33. OMPHOBBY 900mAh 3.7v Li-ion 18350 battery OSHM2344 baterii 18350 https://ibb.co/rw8ZBbv https://ibb.co/37Y1JKv 25 lei 34. Disk Safe timed locker, phone locker with timer phone shutdown video games, social media, self-control timer locker container storage box for addiction management Cutie plastic cu cifru electronic, timer... https://ibb.co/0YvmPXx https://ibb.co/qyqyhVS https://ibb.co/y4TcCJg https://ibb.co/fC4m3XB https://ibb.co/3NL3hFh https://ibb.co/dGt90hJ https://ibb.co/G2J3TmQ 15 lei 35. OBD 2 tester auto nu necesita laptop https://ibb.co/DYk2hpt https://ibb.co/v4VnhPJ https://ibb.co/jMRfr2p https://ibb.co/KrgNDhN https://ibb.co/VDhCVxv https://ibb.co/GMxs8N4 https://ibb.co/h9ZCVZ9 https://ibb.co/zNJpGKh https://ibb.co/qFQ2J5F https://ibb.co/YLF9czB https://ibb.co/VYtbncS https://ibb.co/LQvb3m4 75 lei 2 modele 36. KKMOL Presentation Clicker, Presentation Remote Control, Powerpoint Remote Control, Pointer for Presentations, PPT Red Pointer, USB Presenter for PPT Windows XP 7 8 10 Mac OS Linux pointer prezentari https://ibb.co/DWQg68N https://ibb.co/dQ04wGw 25 lei 37. KKMOL presentation remote control, Powerpoint remote control, pointer for presentations, PPT red pointer, USB 2.4 GHz presenter for PPT Windows XP 7 8 10 Mac OS Linux pointer prezentari, alim cu 2 baterii AAA, fara https://ibb.co/pKn3sCL https://ibb.co/0jG8VBf https://ibb.co/64550gL https://ibb.co/VH1KP5r 25 lei 38. Husa impermeabile - waterproof telefon Samsung A54 https://ibb.co/k6Bvwym https://ibb.co/7pyNMxx https://ibb.co/9TtMK94 10 lei 39. Dispozitiv pentru seringi cu flux printat 3D https://ibb.co/qyYz9pn 20 lei 40. 4 seturi telecomenzi radio https://ibb.co/6BYWBpB https://ibb.co/ww56jXy https://ibb.co/M7NbPzZ https://ibb.co/BNTVVb7 https://ibb.co/xGdnz3r https://ibb.co/M8X5Pw5 https://ibb.co/XkTVFV1 https://ibb.co/w66myzn https://ibb.co/rFW9JBN https://ibb.co/JQdNzCC https://ibb.co/rxPfBVQ https://ibb.co/82KxB8m https://ibb.co/LCFh7TX 30 lei setul 41. set 5 aparate de masura luxmetru, decibelmetru, clampmetru, multimetru si detector cabluri https://ibb.co/XpXdXTY https://ibb.co/7p76BPb https://ibb.co/4K5Fkjx https://ibb.co/p4yFJMR https://ibb.co/C6qcWv4 https://ibb.co/YT9NW5V https://ibb.co/k8tPBLg https://ibb.co/yYv8g1S https://ibb.co/WHR5SQG https://ibb.co/31YFS1R https://ibb.co/XsKgNyD https://ibb.co/GQ3MgPT https://ibb.co/1fHfn9K https://ibb.co/YL4dxnb https://ibb.co/HqYtmjk https://ibb.co/6Y6kmG1 https://ibb.co/TR7zc2g https://ibb.co/TwYfZcQ https://ibb.co/fXwJ5xy https://ibb.co/XVN83JV https://ibb.co/ssTgh6H https://ibb.co/xHgQH6K https://ibb.co/NmCBVzY https://ibb.co/RS5tQFT https://ibb.co/1Q2wVKb https://ibb.co/mF5mGnn 250 lei 42. 3.7V 3000mAh NiMH rechargeable battery, POWO18B with NiMH battery protection box, NO 1818-666-888B battery, perfect for flashlight, camera, small fan, doorbell baterii 4 bucati https://ibb.co/qmrc30z https://ibb.co/bNMs7Jr https://ibb.co/fkgJjSn https://ibb.co/jVxmtwY https://ibb.co/wLfCL4z https://ibb.co/ZSmqDcy 35 lei 43. Huse deosebite piele naturala vintage pentru telefon, etc de pus la curea https://ibb.co/dWhYbGr https://ibb.co/vPFbXsV https://ibb.co/27WHS1H https://ibb.co/gg2f6Kj https://ibb.co/5T119MF https://ibb.co/gg2f6Kj https://ibb.co/fnPbYfD 30 lei buc 44. Cotiere genunchiere copii pentru bicicleta/trotineta/etc marimea L https://ibb.co/FbfGmnF https://ibb.co/9pY4QzH https://ibb.co/9bDWpCv https://ibb.co/R7xxmDF https://ibb.co/Dwt3xSS 25 lei 45. Surse de laborator 30V 10A https://ibb.co/fvtVyL7 https://ibb.co/TgHnXCr https://ibb.co/c146DQQ https://ibb.co/NnBV5wp https://ibb.co/9rH2gNT https://ibb.co/g4XvBKp https://ibb.co/KmP92MC https://ibb.co/DPF5WNd https://ibb.co/Bz3MSp4 https://ibb.co/vsNkh0S https://ibb.co/YhRHfg3 https://ibb.co/jbkmR53 https://ibb.co/xDyjbM7 https://ibb.co/Trc0kZH https://ibb.co/x5bkvTq https://ibb.co/85d4gLx https://ibb.co/Gnt7Wnv https://ibb.co/R9Cgj9B https://ibb.co/sRHxL4f 325 lei buc 46. Detector radiatii nucleare https://ibb.co/ZMsqyGz https://ibb.co/484yMXW https://ibb.co/Js31QWQ https://ibb.co/NNp49T9 https://ibb.co/S6J8wfp https://ibb.co/4KFt7bQ 25 lei buc 47. KG316T timer, LCD display, timer switch, time switch, microcomputer, 220V, resistance 25A, electric timer second hand https://ibb.co/1TZdM9j https://ibb.co/HYx86QJ https://ibb.co/yQ1BrRv https://ibb.co/gjgprxP https://ibb.co/ZT6YkpT 25lei 48. 2PCS UV Lamp E27 Bulb Transparente, becuri UV https://ibb.co/wRbXq0v https://ibb.co/60XwdF7 35 lei 50. 9W 365nm UV Lamp 4 lampi UV, neprobate, nu stiu daca sunt direct la 230V https://ibb.co/JCQK03w https://ibb.co/4MdYBnC 10 lei toate 51. Awootsv Priză temporizatoare electrică digitală cu afișaj LCD 10 funcții aleatorii configurabile antiefracție Conectare interioară întrerupător temporizator electric pentru lumini și aparate de uz casnic, 3680W 2 buc https://ibb.co/nbG9W3N https://ibb.co/pLHxhF1 https://ibb.co/mJWg4YY https://ibb.co/KKRMXG4 https://ibb.co/k5hysNm https://ibb.co/c2QC7Ky https://ibb.co/GkcHBZB 30 lei ambele 52. Aideepen 3 x 3S 20A Li-ion Lithium Battery Charger Board PCB BMS 12.6V Cell Module Overcharge Overcurrent Short Circuit Protection BMS-uri 3S https://ibb.co/mGbZXb3 https://ibb.co/b2fK1QM 10 lei buc, disponibile 2 buc 53. Adaptor combinat M.2 NVME PCIE SSD la SFF-8654 NGFF SATA SATA la SATA 2 în 1 pentru placa de bază (NVME SSD la SATA nu funcționează pe acest adaptor) https://ibb.co/TRNf9Mg 20 lei 54. ECOTISH Women s Backpack in Soft Leather Casual School Daypack 2 in 1 as Backpack and Shoulder Bag, Women s Fashion Bag and Shoulder Backpack for School, Shopping, PLUS geanta de umar Rucsac piele ecologica si geanta de umar din piele naturala https://ibb.co/xmZz8tF https://ibb.co/HgD36q6 35 lei buc 55. extensii cabluri PC https://ibb.co/ZMyNkYp https://ibb.co/jkqDG77 https://ibb.co/Lnb20tY https://ibb.co/RBVdm21 40 lei 56. YYSG Vacuum Bags 6 Pack 60x40cm, Vacuum Bags for Clothes, 80 More Storage Space, Reusable Travel Space Saving, Vacuum Storage Bags for Clothes Duvets Bedding Pillows Blankets 6 pungi vacuum set sigilat https://ibb.co/wz5Wb5Y https://ibb.co/3N9jym8 https://ibb.co/tXPkfvZ https://ibb.co/gRLjYSB 20 lei + 10 pungi si pompa 40 lei (50 lei tot) 57. Pyrography Machine, 100W wood burner set with 2 pens and 33 pcs wire tips, pyrography station burning iron pyrography equipment adjustable from 0-750 C, double Aparat pirogravura dublu https://ibb.co/tpjNy69 https://ibb.co/drjJSt0 https://ibb.co/nz1V1NQ https://ibb.co/vP1Tv4V https://ibb.co/3F0HYL6 https://ibb.co/gVS8dWG https://ibb.co/vkxSKs5 https://ibb.co/xMmx58V https://ibb.co/dgZVgF2 https://ibb.co/vznc6L7 https://ibb.co/YdpVkVx 140 lei 58. ORIGBELIE External DVD Drive USB 3.0 Type C, CD DVD -RW Burner with USB Ports and SD TF Card Reader, External CD Drive for Laptop Desktop MacBook Windows 11 10 8 7 XP Vista Linux Mac Ambalaj carton https://ibb.co/nbVhFZk https://ibb.co/Rz6MWD1 https://ibb.co/DrJprM0 https://ibb.co/D5Th8Vf https://ibb.co/4tgmq06 https://ibb.co/DQWyzY2 https://ibb.co/5cBzjnx https://ibb.co/NLyGRXJ https://ibb.co/ggzNHmb https://ibb.co/gvtbRV8 https://ibb.co/NtXYqhw https://ibb.co/wcMZJt5 https://ibb.co/VvD5CcS https://ibb.co/VWzDfCD https://ibb.co/SK4Sn8Z https://ibb.co/njBWKmF https://ibb.co/2ZVW7SQ https://ibb.co/7vW8X95 https://ibb.co/BZ5P0L7 https://ibb.co/RHKyWWX https://ibb.co/hVHvJPG https://ibb.co/80GQnJW https://ibb.co/vdb0wvx https://ibb.co/gJ2Yb9w https://ibb.co/NtXwc9j https://ibb.co/Cv7Th0h https://ibb.co/kqbyp67 55 lei mai multe buc, disponibil unul SH, fara cititor carduri si usb-uri suplimentare la 25 lei, 3 simple la 30lei si un bluray extern la 100 lei (netestat suficient sa fiu sigur ca e ok, pare nou) 59. Pancellent PH meter, PH TDS EC and temperature 4 in 1 set, water quality tester ATC for drinking water swimming pool aquarium pools, conductivity meter with high accuracy and LCD display blue mai multe seturi https://ibb.co/WDFBDBH https://ibb.co/y0zS8tg https://ibb.co/B22z1B7 https://ibb.co/QpP1yx1 https://ibb.co/gJC28fS https://ibb.co/GTYWCXk https://ibb.co/XCtbBQx https://ibb.co/NmFrRNw 20 lei setul 60. Transformator 230v la 110V 300W https://ibb.co/WPYcvpZ https://ibb.co/x7qRyxQ https://ibb.co/cCqRhnr https://ibb.co/gF58bnC 50 lei, stoc 2 buc 61. Smoke detector networked, AEGISLINK set of 6 wireless smoke detectors with replaceable battery, fire alarm with transmission range of over 250 m, test mute button, auto-check function, S-RF220 detectoare de fum, bulk https://ibb.co/Qc3xmdX https://ibb.co/09fjw7J https://ibb.co/TvVSCfR https://ibb.co/bNghb3g https://ibb.co/vz68mwx https://ibb.co/ZVf68nH https://ibb.co/J5tFxZq https://ibb.co/ZHT72Bh https://ibb.co/QNK1byZ 35 lei buc, 5 buc 62. Networkable combined smoke and carbon monoxide detector, AEGISLINK smoke detector networked, 2 IN-1 CO detector with replaceable battery and 250 m transmission range, SC-RF220 detectoare monoxid carbon si fum bulk https://ibb.co/1qFw7Bn https://ibb.co/bspvw3q https://ibb.co/qxG3d1H https://ibb.co/G30BHPs https://ibb.co/WgS597C https://ibb.co/nDgnh3N https://ibb.co/q0M4JLY https://ibb.co/hX6GkgJ 45 lei disponibile 2 buc 63. Pedală de chitară multi-efect LEKATO pentru chitară bas electrică cu încărcare în infraroșu, editare, înregistrare pe telefon pe computer, tuner, ieșire căști de 3,5 mm, timp de lucru 8 ore https://ibb.co/Wk3KMfJ https://ibb.co/vX3PRkM https://ibb.co/3sTyCGG https://ibb.co/ypPC5N3 https://ibb.co/NpQsv5h https://ibb.co/g4PCmMH https://ibb.co/NsbRbGn https://ibb.co/0KtW739 https://ibb.co/MskqxMb https://ibb.co/GcKt6jJ https://ibb.co/yPxh89x 100 lei 64. Detector inteligent de fum X-Sense XS01-M, Wi-Fi, compatibil cu FS31 FS61 FS121, stația de bază SBS50 și aplicația X-Sense Home Security, semnal de avertizare 85 dB, mini detector de fum și incendiu în rețea https://ibb.co/JvJbD01 https://ibb.co/7VhNC7b https://ibb.co/wW3F4Cc https://ibb.co/sbQDVhD https://ibb.co/NYgDHzY 45 lei 65. Detector inteligent de fum WiFi wireless HEIMAN, cu 5 ani de viață a bateriei, senzor fotoelectric, EN14604, avertizare baterie scăzută https://ibb.co/bFFRkwg https://ibb.co/3BHv7MY 45 lei 66. Set de 3 detectoare de fum RAKELL, baterie 10 ani, alarmă sonoră 85 dB, testat 14604, senzor fotoelectric https://ibb.co/vkfvhyv https://ibb.co/rHBrksc https://ibb.co/jGHDLGZ https://ibb.co/6HML1Ds https://ibb.co/cvjDqLL https://ibb.co/ZBsTHq8 https://ibb.co/3yF5pPt 110 lei 67. Cabluri audio aurite, prelungitor type-C, audio apple https://ibb.co/S70DfH9 https://ibb.co/SJ2N41V https://ibb.co/q9FLpSJ https://ibb.co/vD18430 https://ibb.co/xmtWdrK https://ibb.co/G7tGgLW https://ibb.co/rZspwvs https://ibb.co/NVRzgS5 https://ibb.co/8KSGtMy https://ibb.co/gFPZKqY https://ibb.co/vHK6NxC 30 lei buc audio, 10 lei buc celelalte 68. Detectoare fum diverse https://ibb.co/2nNHQqq https://ibb.co/4F0sFf3 https://ibb.co/y83Vxfn https://ibb.co/mFzjgKR https://ibb.co/nCCdbbF https://ibb.co/Jj31DXz https://ibb.co/tMkyKTz https://ibb.co/kg6p3mg https://ibb.co/9gf2m60 https://ibb.co/ZN1FTMS https://ibb.co/KGFWjf9 https://ibb.co/C6sZrDk https://ibb.co/yST9krH https://ibb.co/gwB4kFZ https://ibb.co/vQv2VWS 35 lei buc, 140 lei set de 5 69. Mini amplificator Bluetooth 600 W Amplificator digital stereo HiFi Amplificator de putere radio FM Amplificator audio Control de bas înalte pentru PC Difuzor audio pentru mașină Amplificator digital Amplificator de putere Hi-Fi Suporta mai multe formate muzicale: card SD, disc U, redare in format MP3, suporta conexiune wireless BT. Două sloturi de intrare pentru microfon: două sloturi de intrare pentru microfon, sistem de karaoke în casă sau mașină. Cu comenzi înalte, bas și volum, foarte ușor de utilizat. Afișaj LCD încorporat, sunet mai puternic: Mini amplificator de putere audio digital HIFI BT. Afișaj LCD încorporat cu lumină de fundal. Distorsiunea redusă oferă un sunet mai clar și mai puternic. Ieșire cu două canale principale: Ieșire cu două canale principale. Cu funcție de telecomandă. Conexiune DC / AC, potrivită atât pentru casă, cât și pentru mașină. NOTĂ: Pentru a proteja mediul înconjurător, telecomanda noastră nu conține baterii buton CR2025, așa că clienții trebuie să le cumpere singuri. https://ibb.co/twfmtz3 https://ibb.co/tMyWXKP https://ibb.co/hZnQ6d8 https://ibb.co/k9Tqt6Y https://ibb.co/cbZzMDG https://ibb.co/rfD3drF https://ibb.co/7gRVx6H https://ibb.co/YyqWBp5 70 lei 70. Fokky digital to analog audio converter 192khz DAC model HS200 https://ibb.co/5cr1tBR https://ibb.co/WWckHKY https://ibb.co/WyBNHHq https://ibb.co/qskvLf8 https://ibb.co/vkZXL1n https://ibb.co/5shZW2n https://ibb.co/YWwdMv2 https://ibb.co/svP9KHS 35 lei 71. Transformator 230V la 110V si invers 500VA https://ibb.co/9qqtgfL https://ibb.co/bHmJ493 https://ibb.co/DG6HsbW https://ibb.co/hBYxHJV https://ibb.co/85zN67D https://ibb.co/JrfKBNS https://ibb.co/xCRJRTT 125 lei buc, mai multe buc disponibile 72. Obd2 Activator de imobilizare Activator Drive Box Edc15 Me7 Caracteristici: 1.Professional de fabricație, această cutie este perfect pentru a se potrivi pentru SEAT Cordoba / Ibiza / Toledo / Toledo. 2. Domeniul de aplicare este larg, sunt aplicabile atât motorina, cât și benzina, deci nu este nevoie să vă faceți griji cu privire la inadecvare. 3. Este ușor de utilizat, doar conectați-l, nu există pași complicați și timpul dvs. nu va fi pierdut. 4.It este compact, nu ocupă spațiu, are doar dimensiuni de 8,7x4,5x2,5cm / 3,4x1,8x1in și este ușor de transportat. Îl puteți lua oriunde. 5. A fost supus unor teste extinse de calitate și siguranță pentru a asigura performanțe fiabile. Specificație: Tip element: OBD2 Imobilizator Material: ABS Culoare: Negru Tensiune: DC 12V Model de corespondență: EDC15 (motorină) și ME7 (benzină) Dimensiune: Aprox. 8,7x4,5x2,5cm/3,4x1,8x1in (Datorită măsurării manuale, poate exista o abatere de 1-2 mm) Ghidul utilizatorului: Doar conectați cutia de acționare EDC15 / ME7 la mufa de diagnosticare (OBD2) a vehiculului, apoi conectați OBD2 și comutați la "oprit" pe cutia de unitate. După numai 20 până la 30 de secunde, blocarea antifurt nu mai necesită un computer. Fitment: Fit pentru A2 / A3 / A4 / A6 Fit pentru SEAT Cordoba / Ibiza / Toledo / Toledo Fit pentru SKODA OCTAVIA Fit pentru Skoda Octavia II Fit for Skoda Scout Fit pentru ŠKODA Roomstar Fit pentru SKODA FABIA Fit pentru Skoda Superb (până în 2007 ) Fit for PORSCHE Cayenne (benzină, model vechi) Fit for Bora (din anul 2000) Fit for Caddy (din anul 2000)Fit for EOS Fit for T4 (From year 2000) https://ibb.co/xFC3LDn https://ibb.co/mFRwjLY https://ibb.co/pyJVvD0 100 LEI 73. Lampa acvariu S.H. (sau pt altceva ) multe combinatii luminoase https://ibb.co/cDxpSLY https://ibb.co/k0PTCbY https://ibb.co/F6H4jPt https://ibb.co/4Vw9cSY https://ibb.co/C98yV51 https://ibb.co/jfVb7Ft https://ibb.co/nbMfWm8 https://ibb.co/YLQFKJy https://ibb.co/ZxtdG83 https://ibb.co/mcHpfgq https://ibb.co/48q0bLr https://ibb.co/pnrXBSH https://ibb.co/fnh9NG6 50lei 74.Lampa wireles multicolora, telecomanda , era noua dar i-am facut 2 semne minuscule cand o probam https://ibb.co/vmbcq4k https://ibb.co/WGYBSry https://ibb.co/v3TX63W https://ibb.co/vvHkpNN https://ibb.co/NKpjztV https://ibb.co/PM8RDq7 https://ibb.co/WBSJCyr https://ibb.co/W3Rm5JH https://ibb.co/qDw8gQp https://ibb.co/8DppYgP https://ibb.co/519bHww https://ibb.co/RY5YhpX https://ibb.co/KrzJy9s https://ibb.co/G90jhYP https://ibb.co/tx380yw https://ibb.co/JkkHDpY https://ibb.co/YPWXJMT 45 lei 75. DEWIN Digital Ammeter Voltmeter, PZEM-025 Digital Ammeter DC Voltmeter Battery Tester 0 300A 300V Power Energy Wattmeter 50A second hand https://ibb.co/Nr3FsvT https://ibb.co/SQZ1hF0 https://ibb.co/mNgyZfW https://ibb.co/QHB3tqB https://ibb.co/NTvny06 https://ibb.co/G2H3Xw3 https://ibb.co/pQ11q1y https://ibb.co/swCvQV7 https://ibb.co/B2dksFX https://ibb.co/8Bc1NZW 20 lei 76. Bureti pentru casti https://ibb.co/JBr3cpG https://ibb.co/tCCV6xJ https://ibb.co/yPw8BPf https://ibb.co/CBk8y4T https://ibb.co/Jy4ncjN https://ibb.co/mhvBSFb https://ibb.co/c1Md4Tk 5 lei perechea, primul model 7 perechi 77. Uscator filament imprimanta 3D, SUNLU, pare folosit, dar in stare excelenta https://ibb.co/bdk1vY5 https://ibb.co/RDfCn1g https://ibb.co/Z8YZrtg https://ibb.co/v4L07kv https://ibb.co/CshRTZ3 https://ibb.co/4mPZ3My https://ibb.co/W2kBC1T https://ibb.co/GRJ12Xv https://ibb.co/mB7pgMb https://ibb.co/3FchVdB https://ibb.co/tq7KgF9 https://ibb.co/xH3PRrq 130 lei 78. 2 controlere temperatura https://ibb.co/8K8vNVD https://ibb.co/3MdbZ9n https://ibb.co/wrQrbzh 50 lei ambele 79. 10mm x 10mm Volume Control Potentiometer Quilted Knob Black Aluminum 6mm Slide Shaft Rotary Knob 5 butoane aluminiu, micute https://ibb.co/2n25VGp https://ibb.co/GPsVKB8 https://ibb.co/02V73v1 20 lei 80. Incarcator baterii 2 modele https://ibb.co/KhnbF5s https://ibb.co/X2y34B5 https://ibb.co/vx6jLgC https://ibb.co/VB10Z5P https://ibb.co/RpC9N1b https://ibb.co/xz0Vg92 https://ibb.co/Bj8tRdz https://ibb.co/r7ps7mV https://ibb.co/tqrGN37 https://ibb.co/CVNH9b0 https://ibb.co/tzs9nQ3 35 lei buc 81. Ecran LCD pentru Samsung Galaxy Tab A8 10.5 2021 SM-X200 SM-X205 cu digitizer tactil cu afișaj LCD plus sticla protectie https://ibb.co/cgNs7dH https://ibb.co/LP91Knr https://ibb.co/K07jHJm 30 lei Link spre comentariu
Windows Postat Ieri la 07:09 Autor Partajează Postat Ieri la 07:09 Azi transport gratuit prin olx. Link spre comentariu
vghesm Postat Ieri la 14:51 Partajează Postat Ieri la 14:51 Bună seara. Nr. 25 încă la mine, vă rog. Mulțumesc. Link spre comentariu
Windows Postat Ieri la 14:59 Autor Partajează Postat Ieri la 14:59 Acum 7 minute, vghesm a spus: Bună seara. Nr. 25 încă la mine, vă rog. Mulțumesc. ok Link spre comentariu
dan cod Postat Ieri la 15:38 Partajează Postat Ieri la 15:38 A ajuns coletul. Mulțumesc. User de încredere. Link spre comentariu
