Windows Postat Noiembrie 8, 2024 Autor Partajează Postat Noiembrie 8, 2024 (editat) Pot facilita plata in 2 - 3 rate lunare pentru marfa ce depasete 500 lei, prima rata 50%, plata in cont. Solicitarea de plata in rate se face pe forum, apoi restul in privat. Marfa este noua, posibil unele ambalaje deteriorate. Posibil si ceva marfa netestata, dar e specificat. Trimit prin Fancurier, (ASTAZI TRANSPORT GRATUIT PE OLX ) daca aveti cont OLX coletul cu verificare costa undeva la 10 - 25 lei, POSTA, EASYBOX PLATA INTEGRALA IN CONT. Cu rosu bolduit intrari noi, cu portocaliu bolduit marfa trimisa/rezervata/discutii 1. Digital Ammeter Voltmeter DC 6.5V-100V 100A Multimeter Power Meter Digital Multimeter Ammeter Voltmeter LCD Display Volt Watt Power Energy Meter with 100A 75mV Shunt 2 buc, tipla pe ecran, nu s-au aprins afisajele la 12V, se vand ca atare, macar pentru sunturi https://ibb.co/v3HFf1p https://ibb.co/tPxKk2B https://ibb.co/k85Z6MJ https://ibb.co/6WwkKPv 15 lei buc 2. Headphone Amplifier 4 Channel Ferroalloy Headphone Splitter Amplifier Mono Stereo Monitor Set AMP-i4 with Non-Slip Mat on the Bottom 100-240V EU Plug Amplificator pentru casti, mufe aurite https://ibb.co/2MCY9Nd https://ibb.co/gR95dfJ https://ibb.co/0rJf3zt https://ibb.co/BqKCxSq https://ibb.co/ZLWTF62 https://ibb.co/px443sk https://ibb.co/dtZRn0P https://ibb.co/zs88hS8 https://ibb.co/VQLdmZC https://ibb.co/rkM62xV https://ibb.co/8PthnX4 https://ibb.co/CKyhKFP 80lei 3. RUZIZAO laboratory power supply 30V 5A, laboratory power supply with 3-digit LED display, adjustable switching power supply upgrade encoder button, mini laboratory https://ibb.co/0yXJLpC https://ibb.co/C1fPqRH https://ibb.co/fpJVLDJ https://ibb.co/RTy9t0T https://ibb.co/NnGns6X https://ibb.co/WHKRPCH https://ibb.co/2qQR3Yk https://ibb.co/pJ4cWbP https://ibb.co/Sx7rCMm https://ibb.co/f9Tk25Z https://ibb.co/p0hS9SX 200 lei buc, disponibile 3, ( una e retinuta ) vor mai veni 7 buc 4. Newbealer Mini Travel Iron with Switchable Voltage-220V 120V, Compact Iron for Clothes No Steam , Ceramic Surface, 150 C Hot Press with Spray Bottle, Bag and Silicon Mini fier de calcat https://ibb.co/MGzRdVY https://ibb.co/LnvqxdL https://ibb.co/bQWZPwv https://ibb.co/GtkMyzv https://ibb.co/82JZ6JH https://ibb.co/FqbtC3r 40 lei 5. Hard disc extern Western Digital 1TB second, fara bad-uri in carcasa aluminiu, husa piele ecologica , USB 3.0 https://ibb.co/yp3ChvB https://ibb.co/G3txdD8 https://ibb.co/BBPbYXw https://ibb.co/1JFGvSW https://ibb.co/Ltd1DwS https://ibb.co/0md5hXd 100lei 6. SB Flash Drive, 3 in 1 256GB USB Flash Drive for Phone, USB Stick for Phone, Pad, USB C, Android Phone, PC, Tablet, Computer METALIC https://ibb.co/2gzXR0Y https://ibb.co/XF9y3dW https://ibb.co/vVv3JDm 55 lei 7. Fayrimi Voltage Transformer 110V Step Down Voltage EU Plug Only used by electrical appliances within 70W Transformator coborator 230V - 120V https://ibb.co/B6SC1ST https://ibb.co/Q8qjPJG 30 lei 8. Memorii laptop SODIMM DDR4 DDR5 8GB/16GB https://ibb.co/m47d37r https://ibb.co/BPgMjFt https://ibb.co/CtvHgTf https://ibb.co/PQ9X9gZ https://ibb.co/7tGYnFT https://ibb.co/f4MDJnF https://ibb.co/FKr7zC8 https://ibb.co/QjfcMyP https://ibb.co/6Wk6dY4 preturi intre 70-190 lei 9. Sovol SV06 Plus SV04 Textured PEI Print Bed Printing Plate Magnetic 3D Printer Platform 310 x 320 mm for Ender 3 Max NEO CR-10 V2 CR-10 V3 CR-10S PRO V2 CR-X YOOPAI PEI Print Plate 310x320mm, Double-Sided Black Textured PEI Magnetic Spring Steel Print Bed for Creality CR10 CR10S 10S Pro V2 V3, Ender 3 Max, AnyCubic Mega X-5698794-4221764 Pat magnetic 310x320mm pentru imprimanta 3D 2 buc https://postimg.cc/gallery/Chb4qFW 40 lei bucata 10. Incarcatoare pentru orice tip de laptop mufa specifica fiecarului model, mufa Type C https://ibb.co/jGyxCSW https://ibb.co/m5S778B https://ibb.co/jZtMq8h https://ibb.co/mRDXJ4S https://ibb.co/0n7Pj42 https://ibb.co/16mtCrd https://ibb.co/QnrJZyG https://ibb.co/kDwvBGd https://ibb.co/TqPSgKn https://ibb.co/fSkBfBg https://ibb.co/9b6qBD4 https://ibb.co/z8R6kgK https://ibb.co/tP25LMr https://ibb.co/K5kCv9N https://ibb.co/PcN3Vjs 45 lei pana in 100W, 55 lei Type-C, Apple, 100 lei peste 100W 11. EC1-12706 Dual Core Semiconductor Refrigeration Thermoelectric Peltier Cooling System 120W Window Air Conditioner Element peltier https://ibb.co/hWD6KXp https://ibb.co/87G2Xzg https://ibb.co/2cFFLDK https://ibb.co/8MCZ896 https://ibb.co/z2mPmSV https://ibb.co/GdyDmMY https://ibb.co/3v23cw3 50 lei 12. Treedix soldering iron set, 8W wireless soldering iron soldering set with adjustable temperature from 330 to 450 C, including USB cable, soldering wire, iron stand with sponge, 3 soldering tips for soldering Mini letcon cu incarcare type C https://ibb.co/5vr6wwB https://ibb.co/0sJHD36 90 lei 13. Soldering Iron Set - USB Soldering Iron with 3 Temperature Adjustable 300 -450 , 3 Soldering Tips, Soldering Iron Stand, Solder Wire, Solder Paste, KKMOL Soldering Set for Welding Repair - Blue https://ibb.co/jbbsjtP https://ibb.co/W0ncVrQ https://ibb.co/fqBsBhT https://ibb.co/R0QKjyc 80 lei 14. MOTOPOWER MP00205A 12V 800mA Automatic Battery Charger for Cars, Motorcycles, ATVs, RVs, Powersports, Boat Incarcator, desulfator automat https://ibb.co/GHyMpCY https://ibb.co/7tT3XPN https://ibb.co/mvKJ0rH https://ibb.co/6NNBJsL https://ibb.co/fCWYPMc https://ibb.co/jk3mZSS https://ibb.co/ccqXxMS https://ibb.co/yyrCNjG https://ibb.co/brr9fCX https://ibb.co/ZJdNjnb https://ibb.co/BHh3nTm 55 lei 15. Jadeshay Motor Speed Controller, PWM DC Motor Speed Controller DC 6-60V 12V 24V 36V 48V 30A Stepless Speed Controller Motor Speed Controller with Start-Stop Switch second hand https://ibb.co/d7cdCQd https://ibb.co/7bt3sPR https://ibb.co/GFtM118 https://ibb.co/D7qYwgD https://ibb.co/8b414kZ 25 lei 16. ANJANK Extremely Loud Wireless Vibrating Alarm Clock with Electric Shaker for No Hearing, Hard of Hearing, Deep Sleep, Dual Alarm, Battery Backup, USB Charger 2 Ceasuri cu afisaj foarte mare noi in cutie https://ibb.co/GnZsYp5 https://ibb.co/kMYpzRR https://ibb.co/f2ZGvXg https://ibb.co/8rjh502 https://ibb.co/bK1kmbC https://ibb.co/cNhtX6T https://ibb.co/r6nC67w https://ibb.co/51PKnvC https://ibb.co/0FwwsfD 35 lei buc 17. STK MP1584EN Step Down Buck Converter Adjustable DC-DC 4.5-28V to 0.8-20V Voltage Regulator Module 24V to 12V 9V 5V 3V Regulatoare step down https://ibb.co/k1wLKqv 30 lei 18. Koala Inkjet Photo Paper, Double Sided, Matt, A3, 230 g m , 100 Sheets. Suitable for printing photos, certificates, brochures, flyers, leaflets, greeting cards, calendars, art Hartie foto A3 inkjet, printabila pe ambele fete https://ibb.co/BsJLfFL https://ibb.co/jkWppmm 25 lei 19. TREKOLOGY Large Inflatable Pillow - ALUFT Ultra Camping Pillow for Beach and Camping, Inflatable Pillow for Outdoor Adventures Perna gonflabila https://ibb.co/4s48H5g https://ibb.co/THTVypr https://ibb.co/k6txtYS https://ibb.co/BVTryRN https://ibb.co/nnbx34S https://ibb.co/tD3PJxw 20 lei 20. SVNOOC 24V 4A Power Supply 96W Charger 100 240V AC to DC Converter LED Transformer with 5.5mmx 2.5mm Plug for CCTV Camera LCD Monitor DC Pump Fan CE Certificate EU Plug https://ibb.co/qJRXjK4 https://ibb.co/fCWN1Y4 https://ibb.co/tqYsTDg https://ibb.co/42k96G9 https://ibb.co/RTqHpNy 25 lei 21. Bzocio 1Din Car Radio CD DVD Player External Stereo Interface USB Port Navigation GPS Car Universal https://ibb.co/PZSh3gr https://ibb.co/rZWwnvB https://ibb.co/SXGG0jq https://ibb.co/W2JNRTS https://ibb.co/whJb8rq https://ibb.co/Tt4s1fx 20 lei 22. Magneti neodim 500 buc 5mmx5mmx2mm https://ibb.co/T41GmxC https://ibb.co/QKZGdJZ https://ibb.co/RBzXrvK 85 lei 23. FTDLCD 15.6 inch LCD Touch Screen Digitizer Display Screen Assembly for HP Pavilion x360 Convertible 15-dq0000ng 15-dq1433ng 15-dq1001ng 15-dq1002ng 15-dq1131ng 15-d-5355429-3969958 ansamblu display cu touch https://ibb.co/dB3FQn2 https://ibb.co/SRf5Qm4 https://ibb.co/r43tmvC 380 lei 24. Lumină LED pentru acvariu, 10W alb și albastru pentru acvariu de 40-60 cm, lampă pentru acvariu cu console extensibile, alimentator 12V, lumina reglabila ca intensitate, timer https://ibb.co/2PfKmS5 https://ibb.co/BnJxCN5 https://ibb.co/KLHCFqK https://ibb.co/G2rH3vJ https://ibb.co/h8Mt5dz https://ibb.co/pd00qvT https://ibb.co/MhDhfjk 40 lei 25. Digital Luxmeter Portable Photometer Exposure Meter Illuminance Light Meter with Range up to 200,000 Lux and LCD Display https://ibb.co/WfwjT0J https://ibb.co/hCwF0HZ https://ibb.co/3cXPZz0 https://ibb.co/wWwvdMG https://ibb.co/zn3JwdR https://ibb.co/prSd4hC https://ibb.co/FWHMdX0 70 lei 26. CREWORKS 2000W Transformer 220 110 Voltage Converter from 220-240V to 110-120V with US and Universal Sockets USB Ports Voltage Converter with Toroidal Core from EU https://ibb.co/SrCNjWg https://ibb.co/fMpD3RX https://ibb.co/YZQQ7GJ https://ibb.co/w4qp9wh https://ibb.co/8zKGVmh https://ibb.co/M6FvKzn https://ibb.co/9psJQdc https://ibb.co/Xbm7yTz https://ibb.co/WzVnw9P 250 lei 27. Yinleader 500W 230V to 110V USA voltage converter toroidal transformer 500VA - In 110V or 220V Out 110V and 220V https://ibb.co/L8C9cNp https://ibb.co/CP4X1G0 https://ibb.co/hFRP3fJ https://ibb.co/Q99SPHz https://ibb.co/0GmpD8z 125 lei 29. Carcasă pentru hard disk extern de laptop SSD HDD de la SATA 2.5 la USB 3.2 Gen 1, suport UASP SATA III aluminiu negru, ambalaj deteriorat https://ibb.co/4PmVdr6 https://ibb.co/jGBq4pf https://ibb.co/7vbHPzT https://ibb.co/ThfSL8d 30 lei 30. Aparat contra tantarilor alimentare usb https://ibb.co/tDvZBGL https://ibb.co/H75q6cj https://ibb.co/0Q5gKLT https://ibb.co/pXmXBpr https://ibb.co/wywfDtx 15 lei ambele, unul fara ambalaj 31. Non-Contact Fever Thermometer for Babies and Adults, Digital Forehead Thermometer, Infrared Thermometer with Instant and Accurate Reading, Fever Alarm, Black Termometru IR https://postimg.cc/gallery/zqWVhg1 20 lei 32. Displayuri cu touch https://postimg.cc/gallery/3hHDX79 25 lei toate 33. OMPHOBBY 900mAh 3.7v Li-ion 18350 battery OSHM2344 https://ibb.co/rw8ZBbv https://ibb.co/37Y1JKv 25 lei 34. Disk Safe timed locker, phone locker with timer phone shutdown video games, social media, self-control timer locker container storage box for addiction management Cutie plastic cu cifru electronic, timer... https://ibb.co/0YvmPXx https://ibb.co/qyqyhVS https://ibb.co/y4TcCJg https://ibb.co/fC4m3XB https://ibb.co/3NL3hFh https://ibb.co/dGt90hJ https://ibb.co/G2J3TmQ 15 lei 35. OBD 2 MP69033, nu necesita laptop https://ibb.co/qpp63gt https://ibb.co/GHmXczz https://ibb.co/cLFyfys https://ibb.co/6Rx2NCh https://ibb.co/xYmYBcM https://ibb.co/2Ks1NYS https://ibb.co/whGdg7q https://ibb.co/yPJhBmh 75 lei, disponibile 4 buc 36. KKMOL Presentation Clicker, Presentation Remote Control, Powerpoint Remote Control, Pointer for Presentations, PPT Red Pointer, USB Presenter for PPT Windows XP 7 8 10 Mac OS Linux https://ibb.co/DWQg68N https://ibb.co/dQ04wGw 30 lei 37. KKMOL presentation remote control, Powerpoint remote control, pointer for presentations, PPT red pointer, USB 2.4 GHz presenter for PPT Windows XP 7 8 10 Mac OS Linux alim cu 2 baterii AAA, fara https://ibb.co/pKn3sCL https://ibb.co/0jG8VBf https://ibb.co/64550gL https://ibb.co/VH1KP5r 30 lei 38. Husa impermeabile - waterproof telefon Samsung A54 https://ibb.co/k6Bvwym https://ibb.co/7pyNMxx https://ibb.co/9TtMK94 10 lei 39. Dispozitiv pentru seringi cu flux printat 3D https://ibb.co/qyYz9pn 20 lei 40. Glostars 100W LED UV Blacklight Spotlight, Blacklight Lamp, IP66 Waterproof, 395-400nm UV Party Light with Switch for Bar, Party Accessories, Blacklight Decoration, Stage Lighting lampa UV 250mm x 130mm https://ibb.co/YyqXrgn https://ibb.co/jHpM06L https://ibb.co/Wy3Dddj https://ibb.co/K5kgyjx https://ibb.co/MgXzLrc https://ibb.co/x74s3dL 50lei buc 2 buc 41. Shengruili 2 Pack UV LED Blacklight Spotlight 200W, IP66 Waterproof Blacklight LED Spotlight, UV Spotlight Floodlight for Disco, Glow Party, Halloween Decoration Ca cele de sus, 2 seturi de 2 https://ibb.co/WH9WcZt 60 lei 2 buc 42. 3.7V 3000mAh NiMH rechargeable battery, POWO18B with NiMH battery protection box, NO 1818-666-888B battery, perfect for flashlight, camera, small fan, doorbell 4 bucati https://ibb.co/qmrc30z https://ibb.co/bNMs7Jr https://ibb.co/fkgJjSn https://ibb.co/jVxmtwY https://ibb.co/wLfCL4z https://ibb.co/ZSmqDcy 35 lei 43. Huse deosebite piele naturala vintage pentru telefon, etc de pus la curea https://ibb.co/dWhYbGr https://ibb.co/vPFbXsV https://ibb.co/27WHS1H https://ibb.co/gg2f6Kj https://ibb.co/5T119MF https://ibb.co/gg2f6Kj https://ibb.co/fnPbYfD 30 lei buc 44. Cotiere genunchiere copii pentru bicicleta/trotineta/etc marimea L https://ibb.co/FbfGmnF https://ibb.co/9pY4QzH https://ibb.co/9bDWpCv https://ibb.co/R7xxmDF https://ibb.co/Dwt3xSS 25 lei 45. Hanmatek Digital Oscilloscope 2 Channels 110MhZ Bandwidth 1GS/s Sampling Rate 5mV/Div 7-inch TFT Storage Desktop Oscilloscope https://ibb.co/g61jLFd https://ibb.co/Bt9shPS https://ibb.co/jZ6GzQx https://ibb.co/bd62cx9 https://ibb.co/bR9gSZR https://ibb.co/1KrDsny 800 lei Posibilitate 3 rate lunare, 400, 200, 200 46. Hanmatek Digital Oscilloscope, DOS1104 Portable Professional Oscilloscope Kit with 4 Channels and Screen 7 inch 18 cm, TFT LCD Display, 110 MHz, 100-240 V https://ibb.co/CKR2wS4 https://ibb.co/Nyxqzvq https://ibb.co/yQh1sdD https://ibb.co/F6d45K0 https://ibb.co/BPWXnkk 1000 lei Posibilitate 3 rate lunare, 500, 250, 250 47. KG316T timer, LCD display, timer switch, time switch, microcomputer, 220V, resistance 25A, electric timer second hand https://ibb.co/1TZdM9j https://ibb.co/HYx86QJ https://ibb.co/yQ1BrRv https://ibb.co/gjgprxP https://ibb.co/ZT6YkpT 25lei 48. 2PCS UV Lamp E27 Bulb Transparente https://ibb.co/wRbXq0v https://ibb.co/60XwdF7 35 lei 50. 9W 365nm UV Lamp 4 lampi UV, neprobate, nu stiu daca sunt direct la 230V https://ibb.co/JCQK03w https://ibb.co/4MdYBnC 10 lei toate 51. Incarcator 24V 2,5A https://ibb.co/2nzH9PV https://ibb.co/5BFNJGN https://ibb.co/nDQLBky 20 lei buc, disponibile 2 buc 52. Aideepen 3 x 3S 20A Li-ion Lithium Battery Charger Board PCB BMS 12.6V Cell Module Overcharge Overcurrent Short Circuit Protection https://ibb.co/mGbZXb3 https://ibb.co/b2fK1QM 10 lei buc, disponibile 2 buc 53. Adaptor combinat M.2 NVME PCIE SSD la SFF-8654 NGFF SATA SATA la SATA 2 în 1 pentru placa de bază (NVME SSD la SATA nu funcționează pe acest adaptor) https://ibb.co/TRNf9Mg 20 lei 54. ECOTISH Women s Backpack in Soft Leather Casual School Daypack 2 in 1 as Backpack and Shoulder Bag, Women s Fashion Bag and Shoulder Backpack for School, Shopping, PLUS geanta de umar Rucsac piele ecologica si geanta de umar din piele naturala https://ibb.co/xmZz8tF https://ibb.co/HgD36q6 35 lei buc 55. UNI-T Sound Level Meter https://ibb.co/3mxXLsx https://ibb.co/k2XLxmC 55 lei 56. Pyrography station, Preciva burning iron set with 20-piece tips, pyrography set craft set soldering station soldering iron set temperature adjustable 250 - 750 , pyrography iron for wood, leather and cork Aparat pirogravura https://ibb.co/Nxtt7JZ https://ibb.co/TbtGZBH https://ibb.co/Wkdy78z https://ibb.co/vDJVMvk https://ibb.co/StRpPCK https://ibb.co/kGY4wJX https://ibb.co/rFg0CFt https://ibb.co/1mMYCsr https://ibb.co/9VhJBPR 120 lei 57. Pyrography Machine, 100W wood burner set with 2 pens and 33 pcs wire tips, pyrography station burning iron pyrography equipment adjustable from 0-750 C, double https://ibb.co/tpjNy69 https://ibb.co/drjJSt0 https://ibb.co/nz1V1NQ https://ibb.co/vP1Tv4V https://ibb.co/3F0HYL6 https://ibb.co/gVS8dWG https://ibb.co/vkxSKs5 https://ibb.co/xMmx58V https://ibb.co/dgZVgF2 https://ibb.co/vznc6L7 https://ibb.co/YdpVkVx 160 lei 58. ORIGBELIE External DVD Drive USB 3.0 Type C, CD DVD -RW Burner with USB Ports and SD TF Card Reader, External CD Drive for Laptop Desktop MacBook Windows 11 10 8 7 XP Vista Linux Mac Livrate in huse de catifea neagra, unul in cutie https://ibb.co/nbVhFZk https://ibb.co/Rz6MWD1 https://ibb.co/DrJprM0 45 lei Disponibil unul SH, fara cititor carduri si usb-uri suplimentare la 25 lei 59. SONOFF Smart WLAN Light Bulb E27, B05-BL-A60 9W Wifi Smart Light Bulb Alexa, Multi-Color Dimmable Bulb, Smart LED Lamps APP Control Compatible with Alexa and Google https://ibb.co/rb0zTsb https://ibb.co/XWRYLHx https://ibb.co/RB7SYgy https://ibb.co/7t0szrV https://ibb.co/Kx62wrJ 20 lei 60. ThisRC 433MHz RF Radio Remote Control Switch Wireless 2 Channels AC 220V 230V 240V Wireless Relay Receiver with 2 Transmitters for Garage Door Roller Shutters Lights and Pumps second hand https://ibb.co/fG4BK4F https://ibb.co/RScXJXw https://ibb.co/gzjZ7Ch https://ibb.co/MRBwsc5 https://ibb.co/R0c6gS0 20 lei 61. Smoke detector networked, AEGISLINK set of 6 wireless smoke detectors with replaceable battery, fire alarm with transmission range of over 250 m, test mute button, auto-check function, S-RF220 detectoare de fum, bulk, fara baterii https://ibb.co/Qc3xmdX https://ibb.co/09fjw7J https://ibb.co/TvVSCfR https://ibb.co/bNghb3g https://ibb.co/vz68mwx https://ibb.co/ZVf68nH https://ibb.co/J5tFxZq https://ibb.co/ZHT72Bh https://ibb.co/QNK1byZ 15 lei buc, 6 buc 62. Networkable combined smoke and carbon monoxide detector, AEGISLINK smoke detector networked, 2 IN-1 CO detector with replaceable battery and 250 m transmission range, SC-RF220, set of 3 detectoare monoxid carbon si fum bulk, fara baterii https://ibb.co/1qFw7Bn https://ibb.co/bspvw3q https://ibb.co/qxG3d1H https://ibb.co/G30BHPs https://ibb.co/WgS597C https://ibb.co/nDgnh3N https://ibb.co/q0M4JLY https://ibb.co/hX6GkgJ 25 lei buc, 3 buc 63. SAUGLAE 22W LED Lamps, 180W Incandescent Bulbs Equivalent, 3000K Warm White, 2500Lm, E14 Edison Screw LED Bulbs, 3 Pack becuri led set de 3 buc E14 https://ibb.co/d62tbnv https://ibb.co/1Mmpjkw https://ibb.co/fdp2XxL https://ibb.co/GTMZCD4 https://ibb.co/Wt04rVH https://ibb.co/WDTXtjx 25 lei setul de 3, 2 seturi 64. Pancellent PH meter, PH TDS EC and temperature 4 in 1 set, water quality tester ATC for drinking water swimming pool aquarium pools, conductivity meter with high accuracy and LCD display blue 15 seturi https://ibb.co/WDFBDBH https://ibb.co/y0zS8tg https://ibb.co/B22z1B7 https://ibb.co/QpP1yx1 https://ibb.co/gJC28fS https://ibb.co/GTYWCXk https://ibb.co/XCtbBQx https://ibb.co/NmFrRNw 20 lei setul 65. Lanpn Photo Album 10x15 400 foto, Linen Insert Album for Portrait Format Photos Pictures Gray https://ibb.co/GQTDxw0 https://ibb.co/WKfq4fG 30 lei Editat Noiembrie 8, 2024 de Windows Link spre comentariu
bobomarc Postat Noiembrie 8, 2024 Partajează Postat Noiembrie 8, 2024 (editat) 63 amandoua si 64 un set,am cont olx si 60 si 15 Editat Noiembrie 8, 2024 de bobomarc Link spre comentariu
Windows Postat Noiembrie 9, 2024 Autor Partajează Postat Noiembrie 9, 2024 Acum 20 ore, Windows a spus: Pot facilita plata in 2 - 3 rate lunare pentru marfa ce depasete 500 lei, prima rata 50%, plata in cont. Solicitarea de plata in rate se face pe forum, apoi restul in privat. Marfa este noua, posibil unele ambalaje deteriorate. Posibil si ceva marfa netestata, dar e specificat. Trimit prin Fancurier, (ASTAZI TRANSPORT GRATUIT PE OLX ) daca aveti cont OLX coletul cu verificare costa undeva la 10 - 25 lei, POSTA, EASYBOX PLATA INTEGRALA IN CONT. Cu rosu bolduit intrari noi, cu portocaliu bolduit marfa trimisa/rezervata/discutii 1. Digital Ammeter Voltmeter DC 6.5V-100V 100A Multimeter Power Meter Digital Multimeter Ammeter Voltmeter LCD Display Volt Watt Power Energy Meter with 100A 75mV Shunt 2 buc, tipla pe ecran, nu s-au aprins afisajele la 12V, se vand ca atare, macar pentru sunturi https://ibb.co/v3HFf1p https://ibb.co/tPxKk2B https://ibb.co/k85Z6MJ https://ibb.co/6WwkKPv 15 lei buc 2. Carucior pliabil rosu https://ibb.co/tDRQy96 https://ibb.co/JC0hwjQ https://ibb.co/x55q3RY 150lei negociabil...sau 2 rate 3. RUZIZAO laboratory power supply 30V 5A, laboratory power supply with 3-digit LED display, adjustable switching power supply upgrade encoder button, mini laboratory https://ibb.co/0yXJLpC https://ibb.co/C1fPqRH https://ibb.co/fpJVLDJ https://ibb.co/RTy9t0T https://ibb.co/NnGns6X https://ibb.co/WHKRPCH https://ibb.co/2qQR3Yk https://ibb.co/pJ4cWbP https://ibb.co/Sx7rCMm https://ibb.co/f9Tk25Z https://ibb.co/p0hS9SX 200 lei buc, disponibile 3, ( una e retinuta ) vor mai veni 7 buc 4. Newbealer Mini Travel Iron with Switchable Voltage-220V 120V, Compact Iron for Clothes No Steam , Ceramic Surface, 150 C Hot Press with Spray Bottle, Bag and Silicon Mini fier de calcat https://ibb.co/MGzRdVY https://ibb.co/LnvqxdL https://ibb.co/bQWZPwv https://ibb.co/GtkMyzv https://ibb.co/82JZ6JH https://ibb.co/FqbtC3r 40 lei 5. Hard disc extern Western Digital 1TB second, fara bad-uri in carcasa aluminiu, husa piele ecologica , USB 3.0 https://ibb.co/yp3ChvB https://ibb.co/G3txdD8 https://ibb.co/BBPbYXw https://ibb.co/1JFGvSW https://ibb.co/Ltd1DwS https://ibb.co/0md5hXd 100lei 6. SB Flash Drive, 3 in 1 256GB USB Flash Drive for Phone, USB Stick for Phone, Pad, USB C, Android Phone, PC, Tablet, Computer METALIC https://ibb.co/2gzXR0Y https://ibb.co/XF9y3dW https://ibb.co/vVv3JDm 55 lei 7. Fayrimi Voltage Transformer 110V Step Down Voltage EU Plug Only used by electrical appliances within 70W Transformator coborator 230V - 120V https://ibb.co/B6SC1ST https://ibb.co/Q8qjPJG 30 lei 8. Memorii laptop SODIMM DDR4 DDR5 8GB/16GB https://ibb.co/m47d37r https://ibb.co/BPgMjFt https://ibb.co/CtvHgTf https://ibb.co/PQ9X9gZ https://ibb.co/7tGYnFT https://ibb.co/f4MDJnF https://ibb.co/FKr7zC8 https://ibb.co/QjfcMyP https://ibb.co/6Wk6dY4 preturi intre 70-190 lei 9. Sovol SV06 Plus SV04 Textured PEI Print Bed Printing Plate Magnetic 3D Printer Platform 310 x 320 mm for Ender 3 Max NEO CR-10 V2 CR-10 V3 CR-10S PRO V2 CR-X YOOPAI PEI Print Plate 310x320mm, Double-Sided Black Textured PEI Magnetic Spring Steel Print Bed for Creality CR10 CR10S 10S Pro V2 V3, Ender 3 Max, AnyCubic Mega X-5698794-4221764 Pat magnetic 310x320mm pentru imprimanta 3D 2 buc https://postimg.cc/gallery/Chb4qFW 40 lei bucata 10. Incarcatoare pentru orice tip de laptop mufa specifica fiecarului model, mufa Type C https://ibb.co/jGyxCSW https://ibb.co/m5S778B https://ibb.co/jZtMq8h https://ibb.co/mRDXJ4S https://ibb.co/0n7Pj42 https://ibb.co/16mtCrd https://ibb.co/QnrJZyG https://ibb.co/kDwvBGd https://ibb.co/TqPSgKn https://ibb.co/fSkBfBg https://ibb.co/9b6qBD4 https://ibb.co/z8R6kgK https://ibb.co/tP25LMr https://ibb.co/K5kCv9N https://ibb.co/PcN3Vjs 45 lei pana in 100W, 55 lei Type-C, Apple, 100 lei peste 100W 11. EC1-12706 Dual Core Semiconductor Refrigeration Thermoelectric Peltier Cooling System 120W Window Air Conditioner Element peltier https://ibb.co/hWD6KXp https://ibb.co/87G2Xzg https://ibb.co/2cFFLDK https://ibb.co/8MCZ896 https://ibb.co/z2mPmSV https://ibb.co/GdyDmMY https://ibb.co/3v23cw3 50 lei 12. Treedix soldering iron set, 8W wireless soldering iron soldering set with adjustable temperature from 330 to 450 C, including USB cable, soldering wire, iron stand with sponge, 3 soldering tips for soldering Mini letcon cu incarcare type C https://ibb.co/5vr6wwB https://ibb.co/0sJHD36 90 lei 13. Soldering Iron Set - USB Soldering Iron with 3 Temperature Adjustable 300 -450 , 3 Soldering Tips, Soldering Iron Stand, Solder Wire, Solder Paste, KKMOL Soldering Set for Welding Repair - Blue https://ibb.co/jbbsjtP https://ibb.co/W0ncVrQ https://ibb.co/fqBsBhT https://ibb.co/R0QKjyc 80 lei 14. MOTOPOWER MP00205A 12V 800mA Automatic Battery Charger for Cars, Motorcycles, ATVs, RVs, Powersports, Boat Incarcator, desulfator automat https://ibb.co/GHyMpCY https://ibb.co/7tT3XPN https://ibb.co/mvKJ0rH https://ibb.co/6NNBJsL https://ibb.co/fCWYPMc https://ibb.co/jk3mZSS https://ibb.co/ccqXxMS https://ibb.co/yyrCNjG https://ibb.co/brr9fCX https://ibb.co/ZJdNjnb https://ibb.co/BHh3nTm 55 lei 15. husa piele naturala Samsung A53 5G https://ibb.co/3fTpC51 https://ibb.co/pvhm1QX https://ibb.co/6XNbCyR https://ibb.co/wMC6Y60 https://ibb.co/Wsczncd https://ibb.co/2vRszty https://ibb.co/KssvjsF 15 lei 16. ANJANK Extremely Loud Wireless Vibrating Alarm Clock with Electric Shaker for No Hearing, Hard of Hearing, Deep Sleep, Dual Alarm, Battery Backup, USB Charger 2 Ceasuri cu afisaj foarte mare noi in cutie https://ibb.co/GnZsYp5 https://ibb.co/kMYpzRR https://ibb.co/f2ZGvXg https://ibb.co/8rjh502 https://ibb.co/bK1kmbC https://ibb.co/cNhtX6T https://ibb.co/r6nC67w https://ibb.co/51PKnvC https://ibb.co/0FwwsfD 35 lei buc 17. STK MP1584EN Step Down Buck Converter Adjustable DC-DC 4.5-28V to 0.8-20V Voltage Regulator Module 24V to 12V 9V 5V 3V Regulatoare step down https://ibb.co/k1wLKqv 30 lei 18. Koala Inkjet Photo Paper, Double Sided, Matt, A3, 230 g m , 100 Sheets. Suitable for printing photos, certificates, brochures, flyers, leaflets, greeting cards, calendars, art Hartie foto A3 inkjet, printabila pe ambele fete https://ibb.co/BsJLfFL https://ibb.co/jkWppmm 25 lei 19. TREKOLOGY Large Inflatable Pillow - ALUFT Ultra Camping Pillow for Beach and Camping, Inflatable Pillow for Outdoor Adventures Perna gonflabila https://ibb.co/4s48H5g https://ibb.co/THTVypr https://ibb.co/k6txtYS https://ibb.co/BVTryRN https://ibb.co/nnbx34S https://ibb.co/tD3PJxw 20 lei 20. SVNOOC 24V 4A Power Supply 96W Charger 100 240V AC to DC Converter LED Transformer with 5.5mmx 2.5mm Plug for CCTV Camera LCD Monitor DC Pump Fan CE Certificate EU Plug https://ibb.co/qJRXjK4 https://ibb.co/fCWN1Y4 https://ibb.co/tqYsTDg https://ibb.co/42k96G9 https://ibb.co/RTqHpNy 25 lei 21. Bzocio 1Din Car Radio CD DVD Player External Stereo Interface USB Port Navigation GPS Car Universal https://ibb.co/PZSh3gr https://ibb.co/rZWwnvB https://ibb.co/SXGG0jq https://ibb.co/W2JNRTS https://ibb.co/whJb8rq https://ibb.co/Tt4s1fx 20 lei 22. Magneti neodim 500 buc 5mmx5mmx2mm https://ibb.co/T41GmxC https://ibb.co/QKZGdJZ https://ibb.co/RBzXrvK 85 lei 23. FTDLCD 15.6 inch LCD Touch Screen Digitizer Display Screen Assembly for HP Pavilion x360 Convertible 15-dq0000ng 15-dq1433ng 15-dq1001ng 15-dq1002ng 15-dq1131ng 15-d-5355429-3969958 ansamblu display cu touch https://ibb.co/dB3FQn2 https://ibb.co/SRf5Qm4 https://ibb.co/r43tmvC 380 lei 24. Lumină LED pentru acvariu, 10W alb și albastru pentru acvariu de 40-60 cm, lampă pentru acvariu cu console extensibile, alimentator 12V, lumina reglabila ca intensitate, timer https://ibb.co/2PfKmS5 https://ibb.co/BnJxCN5 https://ibb.co/KLHCFqK https://ibb.co/G2rH3vJ https://ibb.co/h8Mt5dz https://ibb.co/pd00qvT https://ibb.co/MhDhfjk 40 lei 25. Digital Luxmeter Portable Photometer Exposure Meter Illuminance Light Meter with Range up to 200,000 Lux and LCD Display https://ibb.co/WfwjT0J https://ibb.co/hCwF0HZ https://ibb.co/3cXPZz0 https://ibb.co/wWwvdMG https://ibb.co/zn3JwdR https://ibb.co/prSd4hC https://ibb.co/FWHMdX0 70 lei 26. CREWORKS 2000W Transformer 220 110 Voltage Converter from 220-240V to 110-120V with US and Universal Sockets USB Ports Voltage Converter with Toroidal Core from EU https://ibb.co/SrCNjWg https://ibb.co/fMpD3RX https://ibb.co/YZQQ7GJ https://ibb.co/w4qp9wh https://ibb.co/8zKGVmh https://ibb.co/M6FvKzn https://ibb.co/9psJQdc https://ibb.co/Xbm7yTz https://ibb.co/WzVnw9P 250 lei 27. Yinleader 500W 230V to 110V USA voltage converter toroidal transformer 500VA - In 110V or 220V Out 110V and 220V https://ibb.co/L8C9cNp https://ibb.co/CP4X1G0 https://ibb.co/hFRP3fJ https://ibb.co/Q99SPHz https://ibb.co/0GmpD8z 125 lei 29. Carcasă pentru hard disk extern de laptop SSD HDD de la SATA 2.5 la USB 3.2 Gen 1, suport UASP SATA III aluminiu negru, ambalaj deteriorat https://ibb.co/4PmVdr6 https://ibb.co/jGBq4pf https://ibb.co/7vbHPzT https://ibb.co/ThfSL8d 30 lei 30. Aparat contra tantarilor alimentare usb https://ibb.co/tDvZBGL https://ibb.co/H75q6cj https://ibb.co/0Q5gKLT https://ibb.co/pXmXBpr https://ibb.co/wywfDtx 15 lei ambele, unul fara ambalaj 31. Non-Contact Fever Thermometer for Babies and Adults, Digital Forehead Thermometer, Infrared Thermometer with Instant and Accurate Reading, Fever Alarm, Black Termometru IR https://postimg.cc/gallery/zqWVhg1 20 lei 32. Displayuri cu touch https://postimg.cc/gallery/3hHDX79 25 lei toate 33. OMPHOBBY 900mAh 3.7v Li-ion 18350 battery OSHM2344 https://ibb.co/rw8ZBbv https://ibb.co/37Y1JKv 25 lei 34. Disk Safe timed locker, phone locker with timer phone shutdown video games, social media, self-control timer locker container storage box for addiction management Cutie plastic cu cifru electronic, timer... https://ibb.co/0YvmPXx https://ibb.co/qyqyhVS https://ibb.co/y4TcCJg https://ibb.co/fC4m3XB https://ibb.co/3NL3hFh https://ibb.co/dGt90hJ https://ibb.co/G2J3TmQ 15 lei 35. OBD 2 MP69033, nu necesita laptop https://ibb.co/qpp63gt https://ibb.co/GHmXczz https://ibb.co/cLFyfys https://ibb.co/6Rx2NCh https://ibb.co/xYmYBcM https://ibb.co/2Ks1NYS https://ibb.co/whGdg7q https://ibb.co/yPJhBmh 75 lei, disponibile 4 buc 36. KKMOL Presentation Clicker, Presentation Remote Control, Powerpoint Remote Control, Pointer for Presentations, PPT Red Pointer, USB Presenter for PPT Windows XP 7 8 10 Mac OS Linux https://ibb.co/DWQg68N https://ibb.co/dQ04wGw 30 lei 37. KKMOL presentation remote control, Powerpoint remote control, pointer for presentations, PPT red pointer, USB 2.4 GHz presenter for PPT Windows XP 7 8 10 Mac OS Linux alim cu 2 baterii AAA, fara https://ibb.co/pKn3sCL https://ibb.co/0jG8VBf https://ibb.co/64550gL https://ibb.co/VH1KP5r 30 lei 38. Husa impermeabile - waterproof telefon Samsung A54 https://ibb.co/k6Bvwym https://ibb.co/7pyNMxx https://ibb.co/9TtMK94 10 lei 39. Dispozitiv pentru seringi cu flux printat 3D https://ibb.co/qyYz9pn 20 lei 40. Glostars 100W LED UV Blacklight Spotlight, Blacklight Lamp, IP66 Waterproof, 395-400nm UV Party Light with Switch for Bar, Party Accessories, Blacklight Decoration, Stage Lighting lampa UV 250mm x 130mm https://ibb.co/YyqXrgn https://ibb.co/jHpM06L https://ibb.co/Wy3Dddj https://ibb.co/K5kgyjx https://ibb.co/MgXzLrc https://ibb.co/x74s3dL 50lei buc 2 buc 41. Shengruili 2 Pack UV LED Blacklight Spotlight 200W, IP66 Waterproof Blacklight LED Spotlight, UV Spotlight Floodlight for Disco, Glow Party, Halloween Decoration Ca cele de sus, 2 seturi de 2 https://ibb.co/WH9WcZt 60 lei 2 buc 42. 3.7V 3000mAh NiMH rechargeable battery, POWO18B with NiMH battery protection box, NO 1818-666-888B battery, perfect for flashlight, camera, small fan, doorbell 4 bucati https://ibb.co/qmrc30z https://ibb.co/bNMs7Jr https://ibb.co/fkgJjSn https://ibb.co/jVxmtwY https://ibb.co/wLfCL4z https://ibb.co/ZSmqDcy 35 lei 43. Huse deosebite piele naturala vintage pentru telefon, etc de pus la curea https://ibb.co/dWhYbGr https://ibb.co/vPFbXsV https://ibb.co/27WHS1H https://ibb.co/gg2f6Kj https://ibb.co/5T119MF https://ibb.co/gg2f6Kj https://ibb.co/fnPbYfD 30 lei buc 44. Cotiere genunchiere copii pentru bicicleta/trotineta/etc marimea L https://ibb.co/FbfGmnF https://ibb.co/9pY4QzH https://ibb.co/9bDWpCv https://ibb.co/R7xxmDF https://ibb.co/Dwt3xSS 25 lei 45. Hanmatek Digital Oscilloscope 2 Channels 110MhZ Bandwidth 1GS/s Sampling Rate 5mV/Div 7-inch TFT Storage Desktop Oscilloscope https://ibb.co/g61jLFd https://ibb.co/Bt9shPS https://ibb.co/jZ6GzQx https://ibb.co/bd62cx9 https://ibb.co/bR9gSZR https://ibb.co/1KrDsny 800 lei Posibilitate 3 rate lunare, 400, 200, 200 46. Hanmatek Digital Oscilloscope, DOS1104 Portable Professional Oscilloscope Kit with 4 Channels and Screen 7 inch 18 cm, TFT LCD Display, 110 MHz, 100-240 V https://ibb.co/CKR2wS4 https://ibb.co/Nyxqzvq https://ibb.co/yQh1sdD https://ibb.co/F6d45K0 https://ibb.co/BPWXnkk 1000 lei Posibilitate 3 rate lunare, 500, 250, 250 47. KG316T timer, LCD display, timer switch, time switch, microcomputer, 220V, resistance 25A, electric timer second hand https://ibb.co/1TZdM9j https://ibb.co/HYx86QJ https://ibb.co/yQ1BrRv https://ibb.co/gjgprxP https://ibb.co/ZT6YkpT 25lei 48. 2PCS UV Lamp E27 Bulb Transparente https://ibb.co/wRbXq0v https://ibb.co/60XwdF7 35 lei 50. 9W 365nm UV Lamp 4 lampi UV, neprobate, nu stiu daca sunt direct la 230V https://ibb.co/JCQK03w https://ibb.co/4MdYBnC 10 lei toate 51. Incarcator 24V 2,5A https://ibb.co/2nzH9PV https://ibb.co/5BFNJGN https://ibb.co/nDQLBky 20 lei buc, disponibile 2 buc 52. Aideepen 3 x 3S 20A Li-ion Lithium Battery Charger Board PCB BMS 12.6V Cell Module Overcharge Overcurrent Short Circuit Protection https://ibb.co/mGbZXb3 https://ibb.co/b2fK1QM 10 lei buc, disponibile 2 buc 53. Adaptor combinat M.2 NVME PCIE SSD la SFF-8654 NGFF SATA SATA la SATA 2 în 1 pentru placa de bază (NVME SSD la SATA nu funcționează pe acest adaptor) https://ibb.co/TRNf9Mg 20 lei 54. ECOTISH Women s Backpack in Soft Leather Casual School Daypack 2 in 1 as Backpack and Shoulder Bag, Women s Fashion Bag and Shoulder Backpack for School, Shopping, PLUS geanta de umar Rucsac piele ecologica si geanta de umar din piele naturala https://ibb.co/xmZz8tF https://ibb.co/HgD36q6 35 lei buc 55. UNI-T Sound Level Meter https://ibb.co/3mxXLsx https://ibb.co/k2XLxmC 55 lei 56. Pyrography station, Preciva burning iron set with 20-piece tips, pyrography set craft set soldering station soldering iron set temperature adjustable 250 - 750 , pyrography iron for wood, leather and cork Aparat pirogravura https://ibb.co/Nxtt7JZ https://ibb.co/TbtGZBH https://ibb.co/Wkdy78z https://ibb.co/vDJVMvk https://ibb.co/StRpPCK https://ibb.co/kGY4wJX https://ibb.co/rFg0CFt https://ibb.co/1mMYCsr https://ibb.co/9VhJBPR 120 lei 57. Pyrography Machine, 100W wood burner set with 2 pens and 33 pcs wire tips, pyrography station burning iron pyrography equipment adjustable from 0-750 C, double https://ibb.co/tpjNy69 https://ibb.co/drjJSt0 https://ibb.co/nz1V1NQ https://ibb.co/vP1Tv4V https://ibb.co/3F0HYL6 https://ibb.co/gVS8dWG https://ibb.co/vkxSKs5 https://ibb.co/xMmx58V https://ibb.co/dgZVgF2 https://ibb.co/vznc6L7 https://ibb.co/YdpVkVx 160 lei 58. ORIGBELIE External DVD Drive USB 3.0 Type C, CD DVD -RW Burner with USB Ports and SD TF Card Reader, External CD Drive for Laptop Desktop MacBook Windows 11 10 8 7 XP Vista Linux Mac Livrate in huse de catifea neagra, unul in cutie https://ibb.co/nbVhFZk https://ibb.co/Rz6MWD1 https://ibb.co/DrJprM0 45 lei Disponibil unul SH, fara cititor carduri si usb-uri suplimentare la 25 lei 59. SONOFF Smart WLAN Light Bulb E27, B05-BL-A60 9W Wifi Smart Light Bulb Alexa, Multi-Color Dimmable Bulb, Smart LED Lamps APP Control Compatible with Alexa and Google https://ibb.co/rb0zTsb https://ibb.co/XWRYLHx https://ibb.co/RB7SYgy https://ibb.co/7t0szrV https://ibb.co/Kx62wrJ 20 lei 60. 61. Smoke detector networked, AEGISLINK set of 6 wireless smoke detectors with replaceable battery, fire alarm with transmission range of over 250 m, test mute button, auto-check function, S-RF220 detectoare de fum, bulk, fara baterii https://ibb.co/Qc3xmdX https://ibb.co/09fjw7J https://ibb.co/TvVSCfR https://ibb.co/bNghb3g https://ibb.co/vz68mwx https://ibb.co/ZVf68nH https://ibb.co/J5tFxZq https://ibb.co/ZHT72Bh https://ibb.co/QNK1byZ 15 lei buc, 6 buc 62. Networkable combined smoke and carbon monoxide detector, AEGISLINK smoke detector networked, 2 IN-1 CO detector with replaceable battery and 250 m transmission range, SC-RF220, set of 3 detectoare monoxid carbon si fum bulk, fara baterii https://ibb.co/1qFw7Bn https://ibb.co/bspvw3q https://ibb.co/qxG3d1H https://ibb.co/G30BHPs https://ibb.co/WgS597C https://ibb.co/nDgnh3N https://ibb.co/q0M4JLY https://ibb.co/hX6GkgJ 25 lei buc, 3 buc 63. 64. Pancellent PH meter, PH TDS EC and temperature 4 in 1 set, water quality tester ATC for drinking water swimming pool aquarium pools, conductivity meter with high accuracy and LCD display blue 14 seturi https://ibb.co/WDFBDBH https://ibb.co/y0zS8tg https://ibb.co/B22z1B7 https://ibb.co/QpP1yx1 https://ibb.co/gJC28fS https://ibb.co/GTYWCXk https://ibb.co/XCtbBQx https://ibb.co/NmFrRNw 20 lei setul 65. Lanpn Photo Album 10x15 400 foto, Linen Insert Album for Portrait Format Photos Pictures Gray https://ibb.co/GQTDxw0 https://ibb.co/WKfq4fG 30 lei Link spre comentariu
vghesm Postat Noiembrie 10, 2024 Partajează Postat Noiembrie 10, 2024 Bună. Dacă vă rog, puteți să-mi rețineți următoarele: 1. 1 buc. 64. - 1 set Mulțumesc. Link spre comentariu
Windows Postat Noiembrie 11, 2024 Autor Partajează Postat Noiembrie 11, 2024 Acum 12 ore, vghesm a spus: Bună. Dacă vă rog, puteți să-mi rețineți următoarele: 1. 1 buc. 64. - 1 set Mulțumesc. ok Link spre comentariu
Windows Postat Noiembrie 11, 2024 Autor Partajează Postat Noiembrie 11, 2024 La 09.11.2024 la 10:14, Windows a spus: Pot facilita plata in 2 - 3 rate lunare pentru marfa ce depasete 500 lei, prima rata 50%, plata in cont. Solicitarea de plata in rate se face pe forum, apoi restul in privat. Marfa este noua, posibil unele ambalaje deteriorate. Posibil si ceva marfa netestata, dar e specificat. Trimit prin Fancurier, (ASTAZI TRANSPORT GRATUIT PE OLX ) daca aveti cont OLX coletul cu verificare costa undeva la 10 - 25 lei, POSTA, EASYBOX PLATA INTEGRALA IN CONT. Cu rosu bolduit intrari noi, cu portocaliu bolduit marfa trimisa/rezervata/discutii 1. Ampermetru digital Voltmetru DC 6,5V-100V 100A Multimetru Contor de putere Multimetru digital Ampermetru Voltmetru Display LCD Volt Watt Contor de energie cu 100A 75mV Shunt 2 buc, tipla pe ecran, nu s-au aprins afisajele la 12V, se vand ca atare, macar pentru sunturi https://ibb.co/v3HFf1p https://ibb.co/tPxKk2B https://ibb.co/k85Z6MJ https://ibb.co/6WwkKPv 15 lei buc unul retinut 2. Carucior pliabil rosu https://ibb.co/tDRQy96 https://ibb.co/JC0hwjQ https://ibb.co/x55q3RY 140lei negociabil...sau 2 rate 3. RUZIZAO laboratory power supply 30V 5A, laboratory power supply with 3-digit LED display, adjustable switching power supply upgrade encoder button, mini laboratory sursa de laborator https://ibb.co/0yXJLpC https://ibb.co/C1fPqRH https://ibb.co/fpJVLDJ https://ibb.co/RTy9t0T https://ibb.co/NnGns6X https://ibb.co/WHKRPCH https://ibb.co/2qQR3Yk https://ibb.co/pJ4cWbP https://ibb.co/Sx7rCMm https://ibb.co/f9Tk25Z https://ibb.co/p0hS9SX 200 lei buc, disponibile 2, ( una e retinuta ) vor mai veni 7 buc 4. Newbealer Mini Travel Iron with Switchable Voltage-220V 120V, Compact Iron for Clothes No Steam , Ceramic Surface, 150 C Hot Press with Spray Bottle, Bag and Silicon Mini fier de calcat https://ibb.co/MGzRdVY https://ibb.co/LnvqxdL https://ibb.co/bQWZPwv https://ibb.co/GtkMyzv https://ibb.co/82JZ6JH https://ibb.co/FqbtC3r 40 lei 5. Aigostar Led Alb Cald 11W PLC G24 Bec Bec Rețea Lampă 3000K 880 Lumen Unghi de fascicul 360 de grade Becuri 2U 5 bucăți Economisire energie 5 becuri led https://ibb.co/BBtV0vR https://ibb.co/y5DnCN5 https://ibb.co/8b0gSsr 30 lei 6. SB Flash Drive, 3 in 1 256GB USB Flash Drive for Phone, USB Stick for Phone, Pad, USB C, Android Phone, PC, Tablet, Computer METALIC stick usb 256gb https://ibb.co/2gzXR0Y https://ibb.co/XF9y3dW https://ibb.co/vVv3JDm 50 lei 7. Fayrimi Voltage Transformer 110V Step Down Voltage EU Plug Only used by electrical appliances within 70W Transformator coborator 230V - 120V https://ibb.co/B6SC1ST https://ibb.co/Q8qjPJG 30 lei 8. Memorii laptop SODIMM DDR4 DDR5 8GB/16GB https://ibb.co/m47d37r https://ibb.co/BPgMjFt https://ibb.co/CtvHgTf https://ibb.co/PQ9X9gZ https://ibb.co/7tGYnFT https://ibb.co/f4MDJnF https://ibb.co/FKr7zC8 https://ibb.co/QjfcMyP https://ibb.co/6Wk6dY4 preturi intre 70-190 lei 9. Sovol SV06 Plus SV04 Textured PEI Print Bed Printing Plate Magnetic 3D Printer Platform 310 x 320 mm for Ender 3 Max NEO CR-10 V2 CR-10 V3 CR-10S PRO V2 CR-X YOOPAI PEI Print Plate 310x320mm, Double-Sided Black Textured PEI Magnetic Spring Steel Print Bed for Creality CR10 CR10S 10S Pro V2 V3, Ender 3 Max, AnyCubic Mega X-5698794-4221764 Pat magnetic 310x320mm pentru imprimanta 3D 2 buc https://postimg.cc/gallery/Chb4qFW 40 lei bucata 10. Incarcatoare pentru orice tip de laptop mufa specifica fiecarului model, mufa Type C https://ibb.co/jGyxCSW https://ibb.co/m5S778B https://ibb.co/jZtMq8h https://ibb.co/mRDXJ4S https://ibb.co/0n7Pj42 https://ibb.co/16mtCrd https://ibb.co/QnrJZyG https://ibb.co/kDwvBGd https://ibb.co/TqPSgKn https://ibb.co/fSkBfBg https://ibb.co/9b6qBD4 https://ibb.co/z8R6kgK https://ibb.co/tP25LMr https://ibb.co/K5kCv9N https://ibb.co/PcN3Vjs 45 lei pana in 100W, 55 lei Type-C, Apple, 100 lei peste 100W 11. EC1-12706 Dual Core Semiconductor Refrigeration Thermoelectric Peltier Cooling System 120W Window Air Conditioner Element peltier https://ibb.co/hWD6KXp https://ibb.co/87G2Xzg https://ibb.co/2cFFLDK https://ibb.co/8MCZ896 https://ibb.co/z2mPmSV https://ibb.co/GdyDmMY https://ibb.co/3v23cw3 50 lei 12. Treedix soldering iron set, 8W wireless soldering iron soldering set with adjustable temperature from 330 to 450 C, including USB cable, soldering wire, iron stand with sponge, 3 soldering tips for soldering Mini letcon cu incarcare type C https://ibb.co/5vr6wwB https://ibb.co/0sJHD36 90 lei 13. Soldering Iron Set - USB Soldering Iron with 3 Temperature Adjustable 300 -450 , 3 Soldering Tips, Soldering Iron Stand, Solder Wire, Solder Paste, KKMOL Soldering Set for Welding Repair - Blue Mini letcon cu incarcare type C https://ibb.co/jbbsjtP https://ibb.co/W0ncVrQ https://ibb.co/fqBsBhT https://ibb.co/R0QKjyc 80 lei 14. MOTOPOWER MP00205A 12V 800mA Automatic Battery Charger for Cars, Motorcycles, ATVs, RVs, Powersports, Boat Incarcator, desulfator automat https://ibb.co/GHyMpCY https://ibb.co/7tT3XPN https://ibb.co/mvKJ0rH https://ibb.co/6NNBJsL https://ibb.co/fCWYPMc https://ibb.co/jk3mZSS https://ibb.co/ccqXxMS https://ibb.co/yyrCNjG https://ibb.co/brr9fCX https://ibb.co/ZJdNjnb https://ibb.co/BHh3nTm 55 lei 15. husa piele naturala Samsung A53 5G https://ibb.co/3fTpC51 https://ibb.co/pvhm1QX https://ibb.co/6XNbCyR https://ibb.co/wMC6Y60 https://ibb.co/Wsczncd https://ibb.co/2vRszty https://ibb.co/KssvjsF 15 lei 16. ANJANK Extremely Loud Wireless Vibrating Alarm Clock with Electric Shaker for No Hearing, Hard of Hearing, Deep Sleep, Dual Alarm, Battery Backup, USB Charger 2 Ceasuri cu afisaj foarte mare noi in cutie https://ibb.co/GnZsYp5 https://ibb.co/kMYpzRR https://ibb.co/f2ZGvXg https://ibb.co/8rjh502 https://ibb.co/bK1kmbC https://ibb.co/cNhtX6T https://ibb.co/r6nC67w https://ibb.co/51PKnvC https://ibb.co/0FwwsfD 35 lei buc 17. STK MP1584EN Step Down Buck Converter Adjustable DC-DC 4.5-28V to 0.8-20V Voltage Regulator Module 24V to 12V 9V 5V 3V Regulatoare step down https://ibb.co/k1wLKqv 30 lei 18. Koala Inkjet Photo Paper, Double Sided, Matt, A3, 230 g m , 100 Sheets. Suitable for printing photos, certificates, brochures, flyers, leaflets, greeting cards, calendars, art Hartie foto A3 inkjet, printabila pe ambele fete https://ibb.co/BsJLfFL https://ibb.co/jkWppmm 25 lei 19. TREKOLOGY Large Inflatable Pillow - ALUFT Ultra Camping Pillow for Beach and Camping, Inflatable Pillow for Outdoor Adventures Perna gonflabila https://ibb.co/4s48H5g https://ibb.co/THTVypr https://ibb.co/k6txtYS https://ibb.co/BVTryRN https://ibb.co/nnbx34S https://ibb.co/tD3PJxw 20 lei 20. SVNOOC 24V 4A Power Supply 96W Charger 100 240V AC to DC Converter LED Transformer with 5.5mmx 2.5mm Plug for CCTV Camera LCD Monitor DC Pump Fan CE Certificate EU Plug inncarcator 24V 4A https://ibb.co/qJRXjK4 https://ibb.co/fCWN1Y4 https://ibb.co/tqYsTDg https://ibb.co/42k96G9 https://ibb.co/RTqHpNy 25 lei 21. Bzocio 1Din Car Radio CD DVD Player External Stereo Interface USB Port Navigation GPS Car Universal https://ibb.co/PZSh3gr https://ibb.co/rZWwnvB https://ibb.co/SXGG0jq https://ibb.co/W2JNRTS https://ibb.co/whJb8rq https://ibb.co/Tt4s1fx 20 lei 22. Magneti neodim 500 buc 5mmx5mmx2mm https://ibb.co/T41GmxC https://ibb.co/QKZGdJZ https://ibb.co/RBzXrvK 85 lei 23. FTDLCD 15.6 inch LCD Touch Screen Digitizer Display Screen Assembly for HP Pavilion x360 Convertible 15-dq0000ng 15-dq1433ng 15-dq1001ng 15-dq1002ng 15-dq1131ng 15-d-5355429-3969958 ansamblu display cu touch https://ibb.co/dB3FQn2 https://ibb.co/SRf5Qm4 https://ibb.co/r43tmvC 380 lei 24. Lumină LED pentru acvariu, 10W alb și albastru pentru acvariu de 40-60 cm, lampă pentru acvariu cu console extensibile, alimentator 12V, lumina reglabila ca intensitate, timer https://ibb.co/2PfKmS5 https://ibb.co/BnJxCN5 https://ibb.co/KLHCFqK https://ibb.co/G2rH3vJ https://ibb.co/h8Mt5dz https://ibb.co/pd00qvT https://ibb.co/MhDhfjk 40 lei 25. Digital Luxmeter Portable Photometer Exposure Meter Illuminance Light Meter with Range up to 200,000 Lux and LCD Display luxmetru digital https://ibb.co/WfwjT0J https://ibb.co/hCwF0HZ https://ibb.co/3cXPZz0 https://ibb.co/wWwvdMG https://ibb.co/zn3JwdR https://ibb.co/prSd4hC https://ibb.co/FWHMdX0 70 lei 26. CREWORKS 2000W Transformer 220 110 Voltage Converter from 220-240V to 110-120V with US and Universal Sockets USB Ports Voltage Converter with Toroidal Core from EU transformator 120 la 230 si invers 2000W https://ibb.co/SrCNjWg https://ibb.co/fMpD3RX https://ibb.co/YZQQ7GJ https://ibb.co/w4qp9wh https://ibb.co/8zKGVmh https://ibb.co/M6FvKzn https://ibb.co/9psJQdc https://ibb.co/Xbm7yTz https://ibb.co/WzVnw9P 230 lei 27. Yinleader 500W 230V to 110V USA voltage converter toroidal transformer 500VA - In 110V or 220V Out 110V and 220V transformator 120 la 230 si invers https://ibb.co/L8C9cNp https://ibb.co/CP4X1G0 https://ibb.co/hFRP3fJ https://ibb.co/Q99SPHz https://ibb.co/0GmpD8z 115 lei 29. Carcasă pentru hard disk extern de laptop SSD HDD de la SATA 2.5 la USB 3.2 Gen 1, suport UASP SATA III aluminiu negru, ambalaj deteriorat https://ibb.co/4PmVdr6 https://ibb.co/jGBq4pf https://ibb.co/7vbHPzT https://ibb.co/ThfSL8d 30 lei 30. Aparat contra tantarilor alimentare usb https://ibb.co/tDvZBGL https://ibb.co/H75q6cj https://ibb.co/0Q5gKLT https://ibb.co/pXmXBpr https://ibb.co/wywfDtx 15 lei ambele, unul fara ambalaj 31. Non-Contact Fever Thermometer for Babies and Adults, Digital Forehead Thermometer, Infrared Thermometer with Instant and Accurate Reading, Fever Alarm, Black Termometru IR https://postimg.cc/gallery/zqWVhg1 20 lei 32. Displayuri cu touch https://postimg.cc/gallery/3hHDX79 25 lei toate 33. OMPHOBBY 900mAh 3.7v Li-ion 18350 battery OSHM2344 baterii 18350 https://ibb.co/rw8ZBbv https://ibb.co/37Y1JKv 25 lei 34. Disk Safe timed locker, phone locker with timer phone shutdown video games, social media, self-control timer locker container storage box for addiction management Cutie plastic cu cifru electronic, timer... https://ibb.co/0YvmPXx https://ibb.co/qyqyhVS https://ibb.co/y4TcCJg https://ibb.co/fC4m3XB https://ibb.co/3NL3hFh https://ibb.co/dGt90hJ https://ibb.co/G2J3TmQ 15 lei 35. OBD 2 MP69033, tester auto nu necesita laptop https://ibb.co/qpp63gt https://ibb.co/GHmXczz https://ibb.co/cLFyfys https://ibb.co/6Rx2NCh https://ibb.co/xYmYBcM https://ibb.co/2Ks1NYS https://ibb.co/whGdg7q https://ibb.co/yPJhBmh 75 lei, disponibile 4 buc 36. KKMOL Presentation Clicker, Presentation Remote Control, Powerpoint Remote Control, Pointer for Presentations, PPT Red Pointer, USB Presenter for PPT Windows XP 7 8 10 Mac OS Linux pointer prezentari https://ibb.co/DWQg68N https://ibb.co/dQ04wGw 25 lei 37. KKMOL presentation remote control, Powerpoint remote control, pointer for presentations, PPT red pointer, USB 2.4 GHz presenter for PPT Windows XP 7 8 10 Mac OS Linux pointer prezentari, alim cu 2 baterii AAA, fara https://ibb.co/pKn3sCL https://ibb.co/0jG8VBf https://ibb.co/64550gL https://ibb.co/VH1KP5r 25 lei 38. Husa impermeabile - waterproof telefon Samsung A54 https://ibb.co/k6Bvwym https://ibb.co/7pyNMxx https://ibb.co/9TtMK94 10 lei 39. Dispozitiv pentru seringi cu flux printat 3D https://ibb.co/qyYz9pn 20 lei 40. Glostars 100W LED UV Blacklight Spotlight, Blacklight Lamp, IP66 Waterproof, 395-400nm UV Party Light with Switch for Bar, Party Accessories, Blacklight Decoration, Stage Lighting lampa UV 250mm x 130mm Panou lumini UV https://ibb.co/YyqXrgn https://ibb.co/jHpM06L https://ibb.co/Wy3Dddj https://ibb.co/K5kgyjx https://ibb.co/MgXzLrc https://ibb.co/x74s3dL 50lei buc 2 buc 41. Shengruili 2 Pack UV LED Blacklight Spotlight 200W, IP66 Waterproof Blacklight LED Spotlight, UV Spotlight Floodlight for Disco, Glow Party, Halloween Decoration Panou lumini UV Ca cele de sus, 2 seturi de 2 https://ibb.co/WH9WcZt 60 lei 2 buc 42. 3.7V 3000mAh NiMH rechargeable battery, POWO18B with NiMH battery protection box, NO 1818-666-888B battery, perfect for flashlight, camera, small fan, doorbell baterii 4 bucati https://ibb.co/qmrc30z https://ibb.co/bNMs7Jr https://ibb.co/fkgJjSn https://ibb.co/jVxmtwY https://ibb.co/wLfCL4z https://ibb.co/ZSmqDcy 35 lei 43. Huse deosebite piele naturala vintage pentru telefon, etc de pus la curea https://ibb.co/dWhYbGr https://ibb.co/vPFbXsV https://ibb.co/27WHS1H https://ibb.co/gg2f6Kj https://ibb.co/5T119MF https://ibb.co/gg2f6Kj https://ibb.co/fnPbYfD 30 lei buc 44. Cotiere genunchiere copii pentru bicicleta/trotineta/etc marimea L https://ibb.co/FbfGmnF https://ibb.co/9pY4QzH https://ibb.co/9bDWpCv https://ibb.co/R7xxmDF https://ibb.co/Dwt3xSS 25 lei 45. Hanmatek Digital Oscilloscope 2 Channels 110MhZ Bandwidth 1GS/s Sampling Rate 5mV/Div 7-inch TFT Storage Desktop Oscilloscope Osciloscop 2 canale https://ibb.co/g61jLFd https://ibb.co/Bt9shPS https://ibb.co/jZ6GzQx https://ibb.co/bd62cx9 https://ibb.co/bR9gSZR https://ibb.co/1KrDsny 750 lei Posibilitate 3 rate lunare, 350, 200, 200 , doua buc disponibile 46. Hanmatek Digital Oscilloscope, DOS1104 Portable Professional Oscilloscope Kit with 4 Channels and Screen 7 inch 18 cm, TFT LCD Display, 110 MHz, 100-240 V https://ibb.co/CKR2wS4 https://ibb.co/Nyxqzvq https://ibb.co/yQh1sdD https://ibb.co/F6d45K0 https://ibb.co/BPWXnkk 950 lei Posibilitate 3 rate lunare, 450, 250, 250 47. KG316T timer, LCD display, timer switch, time switch, microcomputer, 220V, resistance 25A, electric timer second hand https://ibb.co/1TZdM9j https://ibb.co/HYx86QJ https://ibb.co/yQ1BrRv https://ibb.co/gjgprxP https://ibb.co/ZT6YkpT 25lei 48. 2PCS UV Lamp E27 Bulb Transparente, becuri UV https://ibb.co/wRbXq0v https://ibb.co/60XwdF7 35 lei 50. 9W 365nm UV Lamp 4 lampi UV, neprobate, nu stiu daca sunt direct la 230V https://ibb.co/JCQK03w https://ibb.co/4MdYBnC 10 lei toate 51. Incarcator 24V 2,5A https://ibb.co/2nzH9PV https://ibb.co/5BFNJGN https://ibb.co/nDQLBky 20 lei buc, disponibile 2 buc 52. Aideepen 3 x 3S 20A Li-ion Lithium Battery Charger Board PCB BMS 12.6V Cell Module Overcharge Overcurrent Short Circuit Protection BMS-uri 3S https://ibb.co/mGbZXb3 https://ibb.co/b2fK1QM 10 lei buc, disponibile 2 buc 53. Adaptor combinat M.2 NVME PCIE SSD la SFF-8654 NGFF SATA SATA la SATA 2 în 1 pentru placa de bază (NVME SSD la SATA nu funcționează pe acest adaptor) https://ibb.co/TRNf9Mg 20 lei 54. ECOTISH Women s Backpack in Soft Leather Casual School Daypack 2 in 1 as Backpack and Shoulder Bag, Women s Fashion Bag and Shoulder Backpack for School, Shopping, PLUS geanta de umar Rucsac piele ecologica si geanta de umar din piele naturala https://ibb.co/xmZz8tF https://ibb.co/HgD36q6 35 lei buc 55. UNI-T Sound Level Meter https://ibb.co/3mxXLsx https://ibb.co/k2XLxmC 55 lei 56. Pyrography station, Preciva burning iron set with 20-piece tips, pyrography set craft set soldering station soldering iron set temperature adjustable 250 - 750 , pyrography iron for wood, leather and cork Aparat pirogravura https://ibb.co/Nxtt7JZ https://ibb.co/TbtGZBH https://ibb.co/Wkdy78z https://ibb.co/vDJVMvk https://ibb.co/StRpPCK https://ibb.co/kGY4wJX https://ibb.co/rFg0CFt https://ibb.co/1mMYCsr https://ibb.co/9VhJBPR 120 lei 57. Pyrography Machine, 100W wood burner set with 2 pens and 33 pcs wire tips, pyrography station burning iron pyrography equipment adjustable from 0-750 C, double Aparat pirogravura dublu https://ibb.co/tpjNy69 https://ibb.co/drjJSt0 https://ibb.co/nz1V1NQ https://ibb.co/vP1Tv4V https://ibb.co/3F0HYL6 https://ibb.co/gVS8dWG https://ibb.co/vkxSKs5 https://ibb.co/xMmx58V https://ibb.co/dgZVgF2 https://ibb.co/vznc6L7 https://ibb.co/YdpVkVx 160 lei 58. ORIGBELIE External DVD Drive USB 3.0 Type C, CD DVD -RW Burner with USB Ports and SD TF Card Reader, External CD Drive for Laptop Desktop MacBook Windows 11 10 8 7 XP Vista Linux Mac Livrate in huse de catifea neagra, in cutie// https://ibb.co/nbVhFZk https://ibb.co/Rz6MWD1 https://ibb.co/DrJprM0 https://ibb.co/D5Th8Vf https://ibb.co/4tgmq06 https://ibb.co/DQWyzY2 https://ibb.co/5cBzjnx https://ibb.co/NLyGRXJ 45 lei disponibile 4 buc, disponibil unul SH, fara cititor carduri si usb-uri suplimentare la 25 lei, unul simplu la 35 lei si un bluray extern la 100 lei(netestat suficient sa fiusigur ca e ok, pare nou) 59. SONOFF Smart WLAN Light Bulb E27, B05-BL-A60 9W Wifi Smart Light Bulb Alexa, Multi-Color Dimmable Bulb, Smart LED Lamps APP Control Compatible with Alexa and Google becuri inteligente https://ibb.co/rb0zTsb https://ibb.co/XWRYLHx https://ibb.co/RB7SYgy https://ibb.co/7t0szrV https://ibb.co/Kx62wrJ 20 lei ambele 60. Lanpn Photo Album 10x15 400 foto, Linen Insert Album for Portrait Format Photos Pictures Gray album foto mare https://ibb.co/GQTDxw0 https://ibb.co/WKfq4fG 30 lei 61. Smoke detector networked, AEGISLINK set of 6 wireless smoke detectors with replaceable battery, fire alarm with transmission range of over 250 m, test mute button, auto-check function, S-RF220 detectoare de fum, bulk, fara baterii https://ibb.co/Qc3xmdX https://ibb.co/09fjw7J https://ibb.co/TvVSCfR https://ibb.co/bNghb3g https://ibb.co/vz68mwx https://ibb.co/ZVf68nH https://ibb.co/J5tFxZq https://ibb.co/ZHT72Bh https://ibb.co/QNK1byZ 15 lei buc, 6 buc 62. Networkable combined smoke and carbon monoxide detector, AEGISLINK smoke detector networked, 2 IN-1 CO detector with replaceable battery and 250 m transmission range, SC-RF220, set of 3 detectoare monoxid carbon si fum bulk, fara baterii https://ibb.co/1qFw7Bn https://ibb.co/bspvw3q https://ibb.co/qxG3d1H https://ibb.co/G30BHPs https://ibb.co/WgS597C https://ibb.co/nDgnh3N https://ibb.co/q0M4JLY https://ibb.co/hX6GkgJ 25 lei buc, 3 buc 63.Pancellent PH meter, PH TDS EC and temperature 4 in 1 set, water quality tester ATC for drinking water swimming pool aquarium pools, conductivity meter with high accuracy and LCD display blue 13 seturi testeter PH si calitate apa potabila, acvarii, piecine, etc https://ibb.co/WDFBDBH https://ibb.co/y0zS8tg https://ibb.co/B22z1B7 https://ibb.co/QpP1yx1 https://ibb.co/gJC28fS https://ibb.co/GTYWCXk https://ibb.co/XCtbBQx https://ibb.co/NmFrRNw 20 lei setul 64. YYSG Vacuum Bags 6 Pack 60x40cm, Vacuum Bags for Clothes, 80 More Storage Space, Reusable Travel Space Saving, Vacuum Storage Bags for Clothes Duvets Bedding Pillows Blankets 6 pungi vacuum set sigilat https://ibb.co/wz5Wb5Y https://ibb.co/3N9jym8 20 lei 65. Awootsv Priză temporizatoare electrică digitală cu afișaj LCD 10 funcții aleatorii configurabile antiefracție Conectare interioară întrerupător temporizator electric pentru lumini și aparate de uz casnic, 3680W 2 pachete https://ibb.co/nbG9W3N https://ibb.co/pLHxhF1 https://ibb.co/mJWg4YY https://ibb.co/KKRMXG4 https://ibb.co/k5hysNm https://ibb.co/c2QC7Ky https://ibb.co/GkcHBZB 30 lei ambele 66. Elitech STC-1000HX Controler digital de temperatură Termostat cu termostat de alarmă LED inteligent -50 99 cu senzor AC10 V-220 V https://ibb.co/0r626Rn https://ibb.co/GVQ68qS https://ibb.co/RSxVqXr https://ibb.co/tZw3XVK https://ibb.co/02J5fWj https://ibb.co/qgkDVZ6 40 lei 67. 18 x Brand New Samsung Galaxy A71A Case, Flexible Material, TPU Material, Scratch-Resistant, Maximum Protection, Black carcase silicon Samsung A71 https://ibb.co/309z3GG https://ibb.co/q91DNS4 2,5 lei buc 68. Radio auto CAMECHO dublu DIN cu Mâini libere Bluetooth, Afișaj tactil pentru radio auto de 6,86 inci cu Carplay Android Auto FM Mirror Link SWC, Suportă AUX FM USB Navigatie auto cu android, camera marsarier, etc https://ibb.co/4ZbTkLB https://ibb.co/bzzC2H6 https://ibb.co/2dtshpX https://ibb.co/YWgHLXk https://ibb.co/xfxd5kV https://ibb.co/TLc08jr https://ibb.co/3vpWKMD https://ibb.co/k9X1nhB https://ibb.co/BNSQFtV 175 lei 69. Navigatie auto cu android, camera marsarier, etc https://ibb.co/80vnDqX https://ibb.co/mtwPGpY https://ibb.co/JKXsvJd https://ibb.co/ymTmL6c https://ibb.co/S0FhcBr https://ibb.co/G0vN3NM https://ibb.co/prnjvgM https://ibb.co/34Hcwpn https://ibb.co/16gTH2f https://ibb.co/rFSc1n4 https://ibb.co/Swz4Bg4 https://ibb.co/LkdRHXL https://ibb.co/Phcnk72 https://ibb.co/jMsdg8t https://ibb.co/HC9bYBd 175 lei 70. 2024 Newest Wireless Apple Carplay Android Auto,Portable TouchScreen Automatic Multimedia Player,Autoradio with Mirror Link Siri FM 1080p Backup Camera Bluetooth GPS Navigation Screen for All Vehicles Navigatie auto cu android, montare cu ventuza, nu in bord, lipseste din pacate camera marsarier https://ibb.co/ZY7Q6Zx https://ibb.co/8DCWmxJ https://ibb.co/DKcqjdt https://ibb.co/d5LhxDC https://ibb.co/SQfpys5 https://ibb.co/nQjjJZD https://ibb.co/T1gpwqh https://ibb.co/PgQXbQV https://ibb.co/m9rVyDR https://ibb.co/PzMn0H5 https://ibb.co/4sSKyRK https://ibb.co/mFCdXPb 100 lei 71. Incarcator de baterii EBL cu baterie AA 2800mAh 8 bucati - incarcator de baterii cu 2 porturi USB pentru baterii AA, AAA, NI-MH si dispozitive USB, multi-protecție, afișaj LED pentru baterii https://ibb.co/pyK6B3C https://ibb.co/SVSXptH https://ibb.co/XbR6V9V https://ibb.co/Pgj1J3N https://ibb.co/nLxDNh4 https://ibb.co/nkmJ0ph https://ibb.co/wcZVd4j https://ibb.co/HBf4vtn https://ibb.co/cY4BTWf 100 lei 72. Cutie uscător filament SUNLU S2 cu ventilator, compatibilă cu filament de 1,75 mm, 2,85 mm Capacitate maximă φ210 x 85 mm https://ibb.co/vVTM4s5 https://ibb.co/0rsC2ft https://ibb.co/DLTL89j https://ibb.co/RYrG5tZ https://ibb.co/B26DQ9p https://ibb.co/HhhTYV9 https://ibb.co/tKVcvTm https://ibb.co/WshNjLq https://ibb.co/LQ0JnDh https://ibb.co/ThzLDcK https://ibb.co/56Rbs9t https://ibb.co/5246m75 https://ibb.co/52g92LT 190 lei Link spre comentariu
Barbaro Postat Noiembrie 12, 2024 Partajează Postat Noiembrie 12, 2024 Buna dimineata ! Va rog sa-mi retineti instrumentul ramas de la punctul 1 si un set masura PH meter de la 63. Link spre comentariu
Windows Postat Noiembrie 12, 2024 Autor Partajează Postat Noiembrie 12, 2024 Acum 28 minute, Barbaro a spus: Buna dimineata ! Va rog sa-mi retineti instrumentul ramas de la punctul 1 si un set masura PH meter de la 63. ok Link spre comentariu
bobomarc Postat Noiembrie 13, 2024 Partajează Postat Noiembrie 13, 2024 Am primit coletul,multumesc mult Link spre comentariu
Windows Postat Noiembrie 13, 2024 Autor Partajează Postat Noiembrie 13, 2024 Acum 51 minute, bobomarc a spus: Am primit coletul,multumesc mult Multumesc si eu. Link spre comentariu
Windows Postat Noiembrie 15, 2024 Autor Partajează Postat Noiembrie 15, 2024 Transport gratuit prin fancurier cu vanzare de pe site de vanzari, si discount 5% de Black Friday! Link spre comentariu
vghesm Postat Noiembrie 16, 2024 Partajează Postat Noiembrie 16, 2024 Bună dimineața. Adăugați, vă rog, la cele două articole (1 buc. pct. 1 și 1 buc. pct. 63) cele 2 becuri de la pct. 59 și un detector de fum de la pct. 61, și se pot trimite. Discutăm în privat. Mulțumesc. Link spre comentariu
vghesm Postat Noiembrie 20, 2024 Partajează Postat Noiembrie 20, 2024 Am primit produsele foarte bine ambalate. Recomand, produse de calitate, ambalate cu multă grijă și atenție! Sunt la al treilea set de produse 1 Link spre comentariu
Windows Postat Noiembrie 20, 2024 Autor Partajează Postat Noiembrie 20, 2024 Pot facilita plata in 2 - 3 rate lunare pentru marfa ce depasete 500 lei, prima rata 50%, plata in cont. Solicitarea de plata in rate se face pe forum, apoi restul in privat. Marfa este noua, posibil unele ambalaje deteriorate. Posibil si ceva marfa netestata, dar e specificat. Trimit prin Fancurier, (SUNT ZILE TRANSPORT GRATUIT PE OLX ) daca aveti cont OLX coletul cu verificare costa undeva la 10 - 25 lei, POSTA, EASYBOX PLATA INTEGRALA IN CONT. Cu rosu bolduit intrari noi, cu portocaliu bolduit marfa trimisa/rezervata/discutii 1. 2 MP5 playere, Radio, Carplay, navigatie cu Android mirror link (posibil sa nu meraga cu android peste 6 sau 7) model 1018B SI 1023B, telecomanda, camera spate https://ibb.co/YPSFCyq https://ibb.co/CBztpSz https://ibb.co/F6JDPvY https://ibb.co/f8hg91c https://ibb.co/SvV0mdL https://ibb.co/v30d62G https://ibb.co/ZNYzRtZ https://ibb.co/Sxd2Wfh https://ibb.co/TR5VSFN https://ibb.co/8xQpr3g https://ibb.co/zFNr45b 165 lei buc 2. Carucior pliabil rosu https://ibb.co/tDRQy96 https://ibb.co/JC0hwjQ https://ibb.co/x55q3RY 125lei ...sau 2 rate 3. RUZIZAO laboratory power supply 30V 5A, laboratory power supply with 3-digit LED display, adjustable switching power supply upgrade encoder button, mini laboratory sursa de laborator https://ibb.co/0yXJLpC https://ibb.co/C1fPqRH https://ibb.co/fpJVLDJ https://ibb.co/RTy9t0T https://ibb.co/NnGns6X https://ibb.co/WHKRPCH https://ibb.co/2qQR3Yk https://ibb.co/pJ4cWbP https://ibb.co/Sx7rCMm https://ibb.co/f9Tk25Z https://ibb.co/p0hS9SX 200 lei buc, am mai multe 4. Newbealer Mini Travel Iron with Switchable Voltage-220V 120V, Compact Iron for Clothes No Steam , Ceramic Surface, 150 C Hot Press with Spray Bottle, Bag and Silicon Mini fier de calcat https://ibb.co/MGzRdVY https://ibb.co/LnvqxdL https://ibb.co/bQWZPwv https://ibb.co/GtkMyzv https://ibb.co/82JZ6JH https://ibb.co/FqbtC3r 40 lei 5. Aigostar Led Alb Cald 11W PLC G24 Bec Bec Rețea Lampă 3000K 880 Lumen Unghi de fascicul 360 de grade Becuri 2U 5 bucăți Economisire energie 5 becuri led https://ibb.co/BBtV0vR https://ibb.co/y5DnCN5 https://ibb.co/8b0gSsr 30 lei 6. SB Flash Drive, 3 in 1 256GB USB Flash Drive for Phone, USB Stick for Phone, Pad, USB C, Android Phone, PC, Tablet, Computer METALIC stick usb 256gb https://ibb.co/2gzXR0Y https://ibb.co/XF9y3dW https://ibb.co/vVv3JDm 50 lei 7. Fayrimi Voltage Transformer 110V Step Down Voltage EU Plug Only used by electrical appliances within 70W Transformator coborator 230V - 120V https://ibb.co/B6SC1ST https://ibb.co/Q8qjPJG 30 lei 8. Memorii laptop SODIMM DDR4 DDR5 8GB/16GB https://ibb.co/m47d37r https://ibb.co/BPgMjFt https://ibb.co/CtvHgTf https://ibb.co/PQ9X9gZ https://ibb.co/7tGYnFT https://ibb.co/f4MDJnF https://ibb.co/FKr7zC8 https://ibb.co/QjfcMyP https://ibb.co/6Wk6dY4 preturi intre 70-190 lei 9. Sovol SV06 Plus SV04 Textured PEI Print Bed Printing Plate Magnetic 3D Printer Platform 310 x 320 mm for Ender 3 Max NEO CR-10 V2 CR-10 V3 CR-10S PRO V2 CR-X YOOPAI PEI Print Plate 310x320mm, Double-Sided Black Textured PEI Magnetic Spring Steel Print Bed for Creality CR10 CR10S 10S Pro V2 V3, Ender 3 Max, AnyCubic Mega X-5698794-4221764 Pat magnetic 310x320mm pentru imprimanta 3D 2 buc https://postimg.cc/gallery/Chb4qFW 40 lei bucata 10. Incarcatoare pentru orice tip de laptop mufa specifica fiecarului model, mufa Type C https://ibb.co/jGyxCSW https://ibb.co/m5S778B https://ibb.co/jZtMq8h https://ibb.co/mRDXJ4S https://ibb.co/0n7Pj42 https://ibb.co/16mtCrd https://ibb.co/QnrJZyG https://ibb.co/kDwvBGd https://ibb.co/TqPSgKn https://ibb.co/fSkBfBg https://ibb.co/9b6qBD4 https://ibb.co/z8R6kgK https://ibb.co/tP25LMr https://ibb.co/K5kCv9N https://ibb.co/PcN3Vjs 45 lei pana in 100W, 55 lei Type-C, Apple, 100 lei peste 100W 11. EC1-12706 Dual Core Semiconductor Refrigeration Thermoelectric Peltier Cooling System 120W Window Air Conditioner Element peltier https://ibb.co/hWD6KXp https://ibb.co/87G2Xzg https://ibb.co/2cFFLDK https://ibb.co/8MCZ896 https://ibb.co/z2mPmSV https://ibb.co/GdyDmMY https://ibb.co/3v23cw3 50 lei 12. Treedix soldering iron set, 8W wireless soldering iron soldering set with adjustable temperature from 330 to 450 C, including USB cable, soldering wire, iron stand with sponge, 3 soldering tips for soldering Mini letcon cu incarcare type C https://ibb.co/5vr6wwB https://ibb.co/0sJHD36 90 lei 13. Soldering Iron Set - USB Soldering Iron with 3 Temperature Adjustable 300 -450 , 3 Soldering Tips, Soldering Iron Stand, Solder Wire, Solder Paste, KKMOL Soldering Set for Welding Repair - Blue Mini letcon cu incarcare type C https://ibb.co/jbbsjtP https://ibb.co/W0ncVrQ https://ibb.co/fqBsBhT https://ibb.co/R0QKjyc 80 lei 14. MOTOPOWER MP00205A 12V 800mA Automatic Battery Charger for Cars, Motorcycles, ATVs, RVs, Powersports, Boat Incarcator, desulfator automat https://ibb.co/GHyMpCY https://ibb.co/7tT3XPN https://ibb.co/mvKJ0rH https://ibb.co/6NNBJsL https://ibb.co/fCWYPMc https://ibb.co/jk3mZSS https://ibb.co/ccqXxMS https://ibb.co/yyrCNjG https://ibb.co/brr9fCX https://ibb.co/ZJdNjnb https://ibb.co/BHh3nTm 55 lei 15. husa piele naturala Samsung A53 5G https://ibb.co/3fTpC51 https://ibb.co/pvhm1QX https://ibb.co/6XNbCyR https://ibb.co/wMC6Y60 https://ibb.co/Wsczncd https://ibb.co/2vRszty https://ibb.co/KssvjsF 15 lei 16. ANJANK Extremely Loud Wireless Vibrating Alarm Clock with Electric Shaker for No Hearing, Hard of Hearing, Deep Sleep, Dual Alarm, Battery Backup, USB Charger 2 Ceasuri cu afisaj foarte mare noi in cutie https://ibb.co/GnZsYp5 https://ibb.co/kMYpzRR https://ibb.co/f2ZGvXg https://ibb.co/8rjh502 https://ibb.co/bK1kmbC https://ibb.co/cNhtX6T https://ibb.co/r6nC67w https://ibb.co/51PKnvC https://ibb.co/0FwwsfD 35 lei buc 17. STK MP1584EN Step Down Buck Converter Adjustable DC-DC 4.5-28V to 0.8-20V Voltage Regulator Module 24V to 12V 9V 5V 3V Regulatoare step down https://ibb.co/k1wLKqv 30 lei 18. Koala Inkjet Photo Paper, Double Sided, Matt, A3, 230 g m , 100 Sheets. Suitable for printing photos, certificates, brochures, flyers, leaflets, greeting cards, calendars, art Hartie foto A3 inkjet, printabila pe ambele fete https://ibb.co/BsJLfFL https://ibb.co/jkWppmm 25 lei 19. TREKOLOGY Large Inflatable Pillow - ALUFT Ultra Camping Pillow for Beach and Camping, Inflatable Pillow for Outdoor Adventures Perna gonflabila https://ibb.co/4s48H5g https://ibb.co/THTVypr https://ibb.co/k6txtYS https://ibb.co/BVTryRN https://ibb.co/nnbx34S https://ibb.co/tD3PJxw 20 lei 20. SVNOOC 24V 4A Power Supply 96W Charger 100 240V AC to DC Converter LED Transformer with 5.5mmx 2.5mm Plug for CCTV Camera LCD Monitor DC Pump Fan CE Certificate EU Plug inncarcator 24V 4A https://ibb.co/qJRXjK4 https://ibb.co/fCWN1Y4 https://ibb.co/tqYsTDg https://ibb.co/42k96G9 https://ibb.co/RTqHpNy 25 lei 21. Bzocio 1Din Car Radio CD DVD Player External Stereo Interface USB Port Navigation GPS Car Universal https://ibb.co/PZSh3gr https://ibb.co/rZWwnvB https://ibb.co/SXGG0jq https://ibb.co/W2JNRTS https://ibb.co/whJb8rq https://ibb.co/Tt4s1fx 20 lei 22. Magneti neodim 500 buc 5mmx5mmx2mm https://ibb.co/T41GmxC https://ibb.co/QKZGdJZ https://ibb.co/RBzXrvK 85 lei 23. FTDLCD 15.6 inch LCD Touch Screen Digitizer Display Screen Assembly for HP Pavilion x360 Convertible 15-dq0000ng 15-dq1433ng 15-dq1001ng 15-dq1002ng 15-dq1131ng 15-d-5355429-3969958 ansamblu display cu touch https://ibb.co/dB3FQn2 https://ibb.co/SRf5Qm4 https://ibb.co/r43tmvC 380 lei 24. Mini freza cordless cu multe varfuri si sabloane de desenat modele https://ibb.co/S63SWny https://ibb.co/TwDKspW https://ibb.co/YNTNTtS https://ibb.co/r5tQMmB https://ibb.co/3YTV24Y https://ibb.co/R3fc8Qy https://ibb.co/DKmqKw4 https://ibb.co/ySJPzvr https://ibb.co/kDts6mb https://ibb.co/KVkwzZb https://ibb.co/Lk3QMFk https://ibb.co/mXvQ1k4 https://ibb.co/tshbydz https://ibb.co/xYfWYyp https://ibb.co/0mGJCTV 100 lei 25. Digital Luxmeter Portable Photometer Exposure Meter Illuminance Light Meter with Range up to 200,000 Lux and LCD Display luxmetru digital https://ibb.co/WfwjT0J https://ibb.co/hCwF0HZ https://ibb.co/3cXPZz0 https://ibb.co/wWwvdMG https://ibb.co/zn3JwdR https://ibb.co/prSd4hC https://ibb.co/FWHMdX0 70 lei 26. CREWORKS 2000W Transformer 220 110 Voltage Converter from 220-240V to 110-120V with US and Universal Sockets USB Ports Voltage Converter with Toroidal Core from EU transformator 120 la 230 si invers 2000W https://ibb.co/SrCNjWg https://ibb.co/fMpD3RX https://ibb.co/YZQQ7GJ https://ibb.co/w4qp9wh https://ibb.co/8zKGVmh https://ibb.co/M6FvKzn https://ibb.co/9psJQdc https://ibb.co/Xbm7yTz https://ibb.co/WzVnw9P 230 lei 27. Yinleader 500W 230V to 110V USA voltage converter toroidal transformer 500VA - In 110V or 220V Out 110V and 220V transformator 120 la 230 si invers https://ibb.co/L8C9cNp https://ibb.co/CP4X1G0 https://ibb.co/hFRP3fJ https://ibb.co/Q99SPHz https://ibb.co/0GmpD8z 115 lei 29. Carcasă pentru hard disk extern de laptop SSD HDD de la SATA 2.5 la USB 3.2 Gen 1, suport UASP SATA III aluminiu negru, ambalaj deteriorat https://ibb.co/4PmVdr6 https://ibb.co/jGBq4pf https://ibb.co/7vbHPzT https://ibb.co/ThfSL8d 30 lei 30. Aparat contra tantarilor alimentare usb https://ibb.co/tDvZBGL https://ibb.co/H75q6cj https://ibb.co/0Q5gKLT https://ibb.co/pXmXBpr https://ibb.co/wywfDtx 15 lei ambele, unul fara ambalaj 31. 32. Displayuri cu touch https://postimg.cc/gallery/3hHDX79 10 lei toate nu maieste cel de apple 33. OMPHOBBY 900mAh 3.7v Li-ion 18350 battery OSHM2344 baterii 18350 https://ibb.co/rw8ZBbv https://ibb.co/37Y1JKv 25 lei 34. Disk Safe timed locker, phone locker with timer phone shutdown video games, social media, self-control timer locker container storage box for addiction management Cutie plastic cu cifru electronic, timer... https://ibb.co/0YvmPXx https://ibb.co/qyqyhVS https://ibb.co/y4TcCJg https://ibb.co/fC4m3XB https://ibb.co/3NL3hFh https://ibb.co/dGt90hJ https://ibb.co/G2J3TmQ 15 lei 35. OBD 2 MP69033, tester auto nu necesita laptop https://ibb.co/qpp63gt https://ibb.co/GHmXczz https://ibb.co/cLFyfys https://ibb.co/6Rx2NCh https://ibb.co/xYmYBcM https://ibb.co/2Ks1NYS https://ibb.co/whGdg7q https://ibb.co/yPJhBmh 75 lei, disponibile 3buc 36. KKMOL Presentation Clicker, Presentation Remote Control, Powerpoint Remote Control, Pointer for Presentations, PPT Red Pointer, USB Presenter for PPT Windows XP 7 8 10 Mac OS Linux pointer prezentari https://ibb.co/DWQg68N https://ibb.co/dQ04wGw 25 lei 37. KKMOL presentation remote control, Powerpoint remote control, pointer for presentations, PPT red pointer, USB 2.4 GHz presenter for PPT Windows XP 7 8 10 Mac OS Linux pointer prezentari, alim cu 2 baterii AAA, fara https://ibb.co/pKn3sCL https://ibb.co/0jG8VBf https://ibb.co/64550gL https://ibb.co/VH1KP5r 25 lei 38. Husa impermeabile - waterproof telefon Samsung A54 https://ibb.co/k6Bvwym https://ibb.co/7pyNMxx https://ibb.co/9TtMK94 10 lei 39. Dispozitiv pentru seringi cu flux printat 3D https://ibb.co/qyYz9pn 20 lei 40. Glostars 100W LED UV Blacklight Spotlight, Blacklight Lamp, IP66 Waterproof, 395-400nm UV Party Light with Switch for Bar, Party Accessories, Blacklight Decoration, Stage Lighting lampa UV 250mm x 130mm Panou lumini UV https://ibb.co/YyqXrgn https://ibb.co/jHpM06L https://ibb.co/Wy3Dddj https://ibb.co/K5kgyjx https://ibb.co/MgXzLrc https://ibb.co/x74s3dL 50lei buc 2 buc 41. Shengruili 2 Pack UV LED Blacklight Spotlight 200W, IP66 Waterproof Blacklight LED Spotlight, UV Spotlight Floodlight for Disco, Glow Party, Halloween Decoration Panou lumini UV Ca cele de sus https://ibb.co/WH9WcZt 60 lei 2 buc 42. 3.7V 3000mAh NiMH rechargeable battery, POWO18B with NiMH battery protection box, NO 1818-666-888B battery, perfect for flashlight, camera, small fan, doorbell baterii 4 bucati https://ibb.co/qmrc30z https://ibb.co/bNMs7Jr https://ibb.co/fkgJjSn https://ibb.co/jVxmtwY https://ibb.co/wLfCL4z https://ibb.co/ZSmqDcy 35 lei 43. Huse deosebite piele naturala vintage pentru telefon, etc de pus la curea https://ibb.co/dWhYbGr https://ibb.co/vPFbXsV https://ibb.co/27WHS1H https://ibb.co/gg2f6Kj https://ibb.co/5T119MF https://ibb.co/gg2f6Kj https://ibb.co/fnPbYfD 30 lei buc 44. Cotiere genunchiere copii pentru bicicleta/trotineta/etc marimea L https://ibb.co/FbfGmnF https://ibb.co/9pY4QzH https://ibb.co/9bDWpCv https://ibb.co/R7xxmDF https://ibb.co/Dwt3xSS 25 lei 45. Hanmatek Digital Oscilloscope 2 Channels 110MhZ Bandwidth 1GS/s Sampling Rate 5mV/Div 7-inch TFT Storage Desktop Oscilloscope Osciloscop 2 canale https://ibb.co/g61jLFd https://ibb.co/Bt9shPS https://ibb.co/jZ6GzQx https://ibb.co/bd62cx9 https://ibb.co/bR9gSZR https://ibb.co/1KrDsny 750 lei Posibilitate 3 rate lunare, 350, 200, 200 , doua buc disponibile 46. Hanmatek Digital Oscilloscope, DOS1104 Portable Professional Oscilloscope Kit with 4 Channels and Screen 7 inch 18 cm, TFT LCD Display, 110 MHz, 100-240 V https://ibb.co/CKR2wS4 https://ibb.co/Nyxqzvq https://ibb.co/yQh1sdD https://ibb.co/F6d45K0 https://ibb.co/BPWXnkk 950 lei Posibilitate 3 rate lunare, 450, 250, 250 47. KG316T timer, LCD display, timer switch, time switch, microcomputer, 220V, resistance 25A, electric timer second hand https://ibb.co/1TZdM9j https://ibb.co/HYx86QJ https://ibb.co/yQ1BrRv https://ibb.co/gjgprxP https://ibb.co/ZT6YkpT 25lei 48. 2PCS UV Lamp E27 Bulb Transparente, becuri UV https://ibb.co/wRbXq0v https://ibb.co/60XwdF7 35 lei 50. 9W 365nm UV Lamp 4 lampi UV, neprobate, nu stiu daca sunt direct la 230V https://ibb.co/JCQK03w https://ibb.co/4MdYBnC 10 lei toate 51. Incarcator 24V 2,5A https://ibb.co/2nzH9PV https://ibb.co/5BFNJGN https://ibb.co/nDQLBky 20 lei 52. Aideepen 3 x 3S 20A Li-ion Lithium Battery Charger Board PCB BMS 12.6V Cell Module Overcharge Overcurrent Short Circuit Protection BMS-uri 3S https://ibb.co/mGbZXb3 https://ibb.co/b2fK1QM 10 lei buc, disponibile 2 buc 53. Adaptor combinat M.2 NVME PCIE SSD la SFF-8654 NGFF SATA SATA la SATA 2 în 1 pentru placa de bază (NVME SSD la SATA nu funcționează pe acest adaptor) https://ibb.co/TRNf9Mg 20 lei 54. ECOTISH Women s Backpack in Soft Leather Casual School Daypack 2 in 1 as Backpack and Shoulder Bag, Women s Fashion Bag and Shoulder Backpack for School, Shopping, PLUS geanta de umar Rucsac piele ecologica si geanta de umar din piele naturala https://ibb.co/xmZz8tF https://ibb.co/HgD36q6 35 lei buc 55. UNI-T Sound Level Meter https://ibb.co/3mxXLsx https://ibb.co/k2XLxmC 55 lei 56. Detector de gaz, are acumulator si incarcator microUSB cu fir foarte lung, second hand https://ibb.co/n0F3Xh2 https://ibb.co/BGWmh2Z https://ibb.co/QdYzyzj https://ibb.co/2NwNVts 25 lei 57. Pyrography Machine, 100W wood burner set with 2 pens and 33 pcs wire tips, pyrography station burning iron pyrography equipment adjustable from 0-750 C, double Aparat pirogravura dublu https://ibb.co/tpjNy69 https://ibb.co/drjJSt0 https://ibb.co/nz1V1NQ https://ibb.co/vP1Tv4V https://ibb.co/3F0HYL6 https://ibb.co/gVS8dWG https://ibb.co/vkxSKs5 https://ibb.co/xMmx58V https://ibb.co/dgZVgF2 https://ibb.co/vznc6L7 https://ibb.co/YdpVkVx 160 lei 58. ORIGBELIE External DVD Drive USB 3.0 Type C, CD DVD -RW Burner with USB Ports and SD TF Card Reader, External CD Drive for Laptop Desktop MacBook Windows 11 10 8 7 XP Vista Linux Mac Livrate in huse de catifea neagra, in cutie// https://ibb.co/nbVhFZk https://ibb.co/Rz6MWD1 https://ibb.co/DrJprM0 https://ibb.co/D5Th8Vf https://ibb.co/4tgmq06 https://ibb.co/DQWyzY2 https://ibb.co/5cBzjnx https://ibb.co/NLyGRXJ 45 lei disponibile 2 buc, disponibil unul SH, fara cititor carduri si usb-uri suplimentare la 25 lei, unul simplu la 35 lei si un bluray extern la 100 lei(netestat suficient sa fiu sigur ca e ok, pare nou) 59. Tuner DVB -T / DVB- C, telecomada, receptor wireless pe USB cu antena( merge si la laptop/PC ), micut https://ibb.co/S58v4q9 https://ibb.co/sqsQrD6 https://ibb.co/gZCHTjb https://ibb.co/rFX8BZ4 https://ibb.co/6rRgHKw https://ibb.co/8D455Vj https://ibb.co/rxDw09Q 50 lei 60. Lanpn Photo Album 10x15 400 foto, Linen Insert Album for Portrait Format Photos Pictures Gray album foto mare https://ibb.co/GQTDxw0 https://ibb.co/WKfq4fG 30 lei 61. Smoke detector networked, AEGISLINK set of 6 wireless smoke detectors with replaceable battery, fire alarm with transmission range of over 250 m, test mute button, auto-check function, S-RF220 detectoare de fum, bulk, fara baterii https://ibb.co/Qc3xmdX https://ibb.co/09fjw7J https://ibb.co/TvVSCfR https://ibb.co/bNghb3g https://ibb.co/vz68mwx https://ibb.co/ZVf68nH https://ibb.co/J5tFxZq https://ibb.co/ZHT72Bh https://ibb.co/QNK1byZ 20 lei buc, 5 buc 62. Networkable combined smoke and carbon monoxide detector, AEGISLINK smoke detector networked, 2 IN-1 CO detector with replaceable battery and 250 m transmission range, SC-RF220, set of 3 detectoare monoxid carbon si fum bulk, fara baterii https://ibb.co/1qFw7Bn https://ibb.co/bspvw3q https://ibb.co/qxG3d1H https://ibb.co/G30BHPs https://ibb.co/WgS597C https://ibb.co/nDgnh3N https://ibb.co/q0M4JLY https://ibb.co/hX6GkgJ 25 lei buc, 3 buc 63.Pancellent PH meter, PH TDS EC and temperature 4 in 1 set, water quality tester ATC for drinking water swimming pool aquarium pools, conductivity meter with high accuracy and LCD display blue 13 seturi testeter PH si calitate apa potabila, acvarii, piecine, etc https://ibb.co/WDFBDBH https://ibb.co/y0zS8tg https://ibb.co/B22z1B7 https://ibb.co/QpP1yx1 https://ibb.co/gJC28fS https://ibb.co/GTYWCXk https://ibb.co/XCtbBQx https://ibb.co/NmFrRNw 20 lei setul 64. YYSG Vacuum Bags 6 Pack 60x40cm, Vacuum Bags for Clothes, 80 More Storage Space, Reusable Travel Space Saving, Vacuum Storage Bags for Clothes Duvets Bedding Pillows Blankets 6 pungi vacuum set sigilat https://ibb.co/wz5Wb5Y https://ibb.co/3N9jym8 20 lei 65. Awootsv Priză temporizatoare electrică digitală cu afișaj LCD 10 funcții aleatorii configurabile antiefracție Conectare interioară întrerupător temporizator electric pentru lumini și aparate de uz casnic, 3680W 2 pachete https://ibb.co/nbG9W3N https://ibb.co/pLHxhF1 https://ibb.co/mJWg4YY https://ibb.co/KKRMXG4 https://ibb.co/k5hysNm https://ibb.co/c2QC7Ky https://ibb.co/GkcHBZB 30 lei ambele 66. Elitech STC-1000HX Controler digital de temperatură Termostat cu termostat de alarmă LED inteligent -50 99 cu senzor AC10 V-220 V https://ibb.co/0r626Rn https://ibb.co/GVQ68qS https://ibb.co/RSxVqXr https://ibb.co/tZw3XVK https://ibb.co/02J5fWj https://ibb.co/qgkDVZ6 40 lei 67. 18 x Brand New Samsung Galaxy A71A Case, Flexible Material, TPU Material, Scratch-Resistant, Maximum Protection, Black carcase silicon Samsung A71 https://ibb.co/309z3GG https://ibb.co/q91DNS4 2,5 lei buc 68. Incarcator de baterii EBL cu baterie AA 2800mAh 8 bucati - incarcator de baterii cu 2 porturi USB pentru baterii AA, AAA, NI-MH si dispozitive USB, multi-protecție, afișaj LED pentru baterii https://ibb.co/pyK6B3C https://ibb.co/SVSXptH https://ibb.co/XbR6V9V https://ibb.co/Pgj1J3N https://ibb.co/nLxDNh4 https://ibb.co/nkmJ0ph https://ibb.co/wcZVd4j https://ibb.co/HBf4vtn https://ibb.co/cY4BTWf 90 lei 69. 70. 71. 72. Link spre comentariu
hamatdumitru Postat Noiembrie 20, 2024 Partajează Postat Noiembrie 20, 2024 Rog eu: 59. Tuner DVB -T / DVB- C, telecomada, receptor wireless pe USB cu antena( merge si la laptop/PC ), micut https://ibb.co/S58v4q9 https://ibb.co/sqsQrD6 https://ibb.co/gZCHTjb https://ibb.co/rFX8BZ4 https://ibb.co/6rRgHKw https://ibb.co/8D455Vj https://ibb.co/rxDw09Q 50 lei Link spre comentariu
