Barbaro Postat Octombrie 25, 2024 Partajează Postat Octombrie 25, 2024 (editat) Buna ziua ! As dori , o bucata de la punctul 7 = flash drive , 3in 1 ; o bucata de la 57 receptor si telecomanda 433mhz si de la 67 ambele. Editat Octombrie 25, 2024 de Barbaro Link spre comentariu
Windows Postat Octombrie 25, 2024 Autor Partajează Postat Octombrie 25, 2024 Acum 24 minute, Barbaro a spus: Buna ziua ! As dori , o bucata de la punctul 7 = flash drive , 3in 1 ; o bucata de la 57 receptor si telecomanda 433mhz si de la 67 ambele. ok Link spre comentariu
vghesm Postat Octombrie 25, 2024 Partajează Postat Octombrie 25, 2024 Acum 2 ore, Windows a spus: 56. Adiwo UV black light spotlight, 100W LED UV black light lamp IP66 waterproof blacklight LED spotlight 395 nm UV party light with switch for bar party accessories stage lighting body painting 250mm x 130mm UV spre lumina alba, mai putin pronuntat https://ibb.co/YyqXrgn https://ibb.co/jHpM06L https://ibb.co/Wy3Dddj https://ibb.co/K5kgyjx https://ibb.co/MgXzLrc https://ibb.co/x74s3dL 30lei 57. This RC 433MHz RF radio remote control switch wireless 2 channels AC 220V 230V 240V wireless relay receiver with 2 transmitters for garage door roller shutters light and pumps https://ibb.co/Vp7dWcY https://ibb.co/FwBcLv5 https://ibb.co/d23mr8P 20 lei buc, disponibile 4 buc 58. Newgoal Zigbee Tuya Smart 4 Channel Smart Relay Module with 433RF Remote Control, USB 5V 7-32V Jog Lock Switch, Works with Alexa Google Home Requires ZigBee Hub https://ibb.co/R0QKjyc https://ibb.co/CnnK52m https://ibb.co/zRcyZcm https://ibb.co/zH46861 https://ibb.co/ykGNhfm 30 lei Bună. Astea le vreau eu. Vă trimit PM cu detaliile. Mulțumesc. Link spre comentariu
Windows Postat Octombrie 25, 2024 Autor Partajează Postat Octombrie 25, 2024 Acum 8 minute, vghesm a spus: Bună. Astea le vreau eu. Vă trimit PM cu detaliile. Mulțumesc. Sunt disponibile toate, mai putin un receptor cu 2 canale cerut de @Barbaro. Am si pungile. Link spre comentariu
Windows Postat Octombrie 27, 2024 Autor Partajează Postat Octombrie 27, 2024 Marfa este noua, posibil unele ambalaje deteriorate. Posibil si ceva marfa netestata, dar e specificat. Trimit doar prin Fancurier, daca aveti cont OLX coletul cu verificare costa undeva la 10 - 25 lei. Cu rosu bolduit intrari noi, cu portocaliu bolduit marfa trimisa/rezervata/discutii 1. Hailege USB Boost Converter Cable DC 5V to 9V 12V USB to DC 5.5x2.1mm USB Step-up Cable USB Power Supply Adapter UBS Power Voltage Boost Converter https://ibb.co/1TgwZJG https://ibb.co/wsBYsmn https://ibb.co/47yQdzv https://ibb.co/LY80Szy 10 lei 2. ECOTISH Women s Backpack in Soft Leather Casual School Daypack 2 in 1 as Backpack and Shoulder Bag, Women s Fashion Bag and Shoulder Backpack for School, Shopping, PLUS geanta de umar Rucsac piele ecologica si geanta de umar din piele naturala https://ibb.co/xmZz8tF https://ibb.co/HgD36q6 35 lei buc 3. Adaptor combinat M.2 NVME PCIE SSD la SFF-8654 NGFF SATA SATA la SATA 2 în 1 pentru placa de bază (NVME SSD la SATA nu funcționează pe acest adaptor) https://ibb.co/TRNf9Mg 20 lei 4. Newbealer Mini Travel Iron with Switchable Voltage-220V 120V, Compact Iron for Clothes No Steam , Ceramic Surface, 150 C Hot Press with Spray Bottle, Bag and Silicon Mini fier de calcat https://ibb.co/MGzRdVY https://ibb.co/LnvqxdL https://ibb.co/bQWZPwv https://ibb.co/GtkMyzv https://ibb.co/82JZ6JH https://ibb.co/FqbtC3r 40 lei 5. KOOTION 10 pieces USB sticks 16GB memory sticks set USB 2.0 10 pieces colorful data stick memory stick metal 16G thumb drive 10-pack flash drives 16 Gbyte flash stick https://ibb.co/pvccpk8 https://ibb.co/t24F40t 90 lei toate 6. SB Flash Drive, 3 in 1 256GB USB Flash Drive for Phone, USB Stick for Phone, Pad, USB C, Android Phone, PC, Tablet, Computer METALIC https://ibb.co/2gzXR0Y https://ibb.co/XF9y3dW https://ibb.co/vVv3JDm 55 lei 7. X-Sense CO detector with peak value memory, carbon monoxide detector, accurate sensor with 10 year battery LCD display https://ibb.co/gZ9qGNY https://ibb.co/XWhTZBP https://ibb.co/Zh0ZPWv https://ibb.co/Ms3RmtG https://ibb.co/1JX1L3m 25 lei , disponibile 2 buc 8. Memorii laptop SODIMM DDR4 DDR5 8GB/16GB https://ibb.co/m47d37r https://ibb.co/BPgMjFt https://ibb.co/CtvHgTf https://ibb.co/PQ9X9gZ https://ibb.co/7tGYnFT https://ibb.co/f4MDJnF https://ibb.co/FKr7zC8 https://ibb.co/QjfcMyP https://ibb.co/6Wk6dY4 preturi intre 70-190 lei 9. Sovol SV06 Plus SV04 Textured PEI Print Bed Printing Plate Magnetic 3D Printer Platform 310 x 320 mm for Ender 3 Max NEO CR-10 V2 CR-10 V3 CR-10S PRO V2 CR-X YOOPAI PEI Print Plate 310x320mm, Double-Sided Black Textured PEI Magnetic Spring Steel Print Bed for Creality CR10 CR10S 10S Pro V2 V3, Ender 3 Max, AnyCubic Mega X-5698794-4221764 Pat magnetic 310x320mm pentru imprimanta 3D 2 buc https://postimg.cc/gallery/Chb4qFW 40 lei bucata 10. Incarcatoare pentru orice tip de laptop mufa specifica fiecarului model, mufa Type C https://ibb.co/jGyxCSW https://ibb.co/m5S778B https://ibb.co/jZtMq8h https://ibb.co/mRDXJ4S https://ibb.co/0n7Pj42 https://ibb.co/16mtCrd https://ibb.co/QnrJZyG https://ibb.co/kDwvBGd https://ibb.co/TqPSgKn https://ibb.co/fSkBfBg https://ibb.co/9b6qBD4 https://ibb.co/z8R6kgK https://ibb.co/tP25LMr https://ibb.co/K5kCv9N https://ibb.co/PcN3Vjs 45 lei pana in 100W, 55 lei Type-C, Apple, 100 lei peste 100W 11. DVD CD Player for TV, Up-Convert to HD 1080p, All Region, Breakpoint Memory, Built-in PAL NTSC, USB 2.0 Mini DVD player cu telecomanda, iesiri rca si HDMI https://ibb.co/rwPjrTJ https://ibb.co/qRYp85p https://ibb.co/k0Z94qT https://ibb.co/sRJKzjp https://ibb.co/ss7zRZK https://ibb.co/Js2T0Gn https://ibb.co/pRZnM2L 40 lei 12. Treedix soldering iron set, 8W wireless soldering iron soldering set with adjustable temperature from 330 to 450 C, including USB cable, soldering wire, iron stand with sponge, 3 soldering tips for soldering Mini letcon cu incarcare type C https://ibb.co/5vr6wwB https://ibb.co/0sJHD36 90 lei 13. Soldering Iron Set - USB Soldering Iron with 3 Temperature Adjustable 300 -450 , 3 Soldering Tips, Soldering Iron Stand, Solder Wire, Solder Paste, KKMOL Soldering Set for Welding Repair - Blue https://ibb.co/jbbsjtP https://ibb.co/W0ncVrQ https://ibb.co/fqBsBhT https://ibb.co/R0QKjyc 80 lei 14. CD-uri printabile 700MB/80min cu ambalajul rupt, 100buc https://ibb.co/ZhnnwfM 20 lei 15. Baterii litiu-ion LIR2450 5 buc 3,7 V reîncărcabile cu încărcător tip monedă care înlocuiește cr2450 https://ibb.co/kHn7yfX https://ibb.co/ys46YKt https://ibb.co/8Y3CJNt https://ibb.co/Tb5PL4H https://ibb.co/QNWvxKc https://ibb.co/vYfbb0h https://ibb.co/GPQVtTz 45 lei 16. ANJANK Extremely Loud Wireless Vibrating Alarm Clock with Electric Shaker for No Hearing, Hard of Hearing, Deep Sleep, Dual Alarm, Battery Backup, USB Charger 2 Ceasuri cu afisaj foarte mare noi in cutie https://ibb.co/GnZsYp5 https://ibb.co/kMYpzRR https://ibb.co/f2ZGvXg https://ibb.co/8rjh502 https://ibb.co/bK1kmbC https://ibb.co/cNhtX6T https://ibb.co/r6nC67w https://ibb.co/51PKnvC https://ibb.co/0FwwsfD 35 lei buc 17. STK MP1584EN Step Down Buck Converter Adjustable DC-DC 4.5-28V to 0.8-20V Voltage Regulator Module 24V to 12V 9V 5V 3V Regulatoare step down https://ibb.co/k1wLKqv 30 lei 18. Koala Inkjet Photo Paper, Double Sided, Matt, A3, 230 g m , 100 Sheets. Suitable for printing photos, certificates, brochures, flyers, leaflets, greeting cards, calendars, art Hartie foto A3 inkjet, printabila pe ambele fete https://ibb.co/BsJLfFL https://ibb.co/jkWppmm 25 lei 19. TREKOLOGY Large Inflatable Pillow - ALUFT Ultra Camping Pillow for Beach and Camping, Inflatable Pillow for Outdoor Adventures Perna gonflabila https://ibb.co/4s48H5g https://ibb.co/THTVypr https://ibb.co/k6txtYS https://ibb.co/BVTryRN https://ibb.co/nnbx34S https://ibb.co/tD3PJxw 20 lei 20. SVNOOC 24V 4A Power Supply 96W Charger 100 240V AC to DC Converter LED Transformer with 5.5mmx 2.5mm Plug for CCTV Camera LCD Monitor DC Pump Fan CE Certificate EU Plug https://ibb.co/qJRXjK4 https://ibb.co/fCWN1Y4 https://ibb.co/tqYsTDg https://ibb.co/42k96G9 https://ibb.co/RTqHpNy 25 lei 21. Bzocio 1Din Car Radio CD DVD Player External Stereo Interface USB Port Navigation GPS Car Universal https://ibb.co/PZSh3gr https://ibb.co/rZWwnvB https://ibb.co/SXGG0jq https://ibb.co/W2JNRTS https://ibb.co/whJb8rq https://ibb.co/Tt4s1fx 20 lei 22. Magneti neodim 500 buc 5mmx5mmx2mm https://ibb.co/T41GmxC https://ibb.co/QKZGdJZ https://ibb.co/RBzXrvK 85 lei 23. FTDLCD 15.6 inch LCD Touch Screen Digitizer Display Screen Assembly for HP Pavilion x360 Convertible 15-dq0000ng 15-dq1433ng 15-dq1001ng 15-dq1002ng 15-dq1131ng 15-d-5355429-3969958 ansamblu display cu touch https://ibb.co/dB3FQn2 https://ibb.co/SRf5Qm4 https://ibb.co/r43tmvC 380 lei 24. Lumină LED pentru acvariu, 10W alb și albastru pentru acvariu de 40-60 cm, lampă pentru acvariu cu console extensibile, alimentator 12V, lumina reglabila ca intensitate, timer https://ibb.co/2PfKmS5 https://ibb.co/BnJxCN5 https://ibb.co/KLHCFqK https://ibb.co/G2rH3vJ https://ibb.co/h8Mt5dz https://ibb.co/pd00qvT https://ibb.co/MhDhfjk 40 lei 25. Digital Luxmeter Portable Photometer Exposure Meter Illuminance Light Meter with Range up to 200,000 Lux and LCD Display https://ibb.co/WfwjT0J https://ibb.co/hCwF0HZ https://ibb.co/3cXPZz0 https://ibb.co/wWwvdMG https://ibb.co/zn3JwdR https://ibb.co/prSd4hC https://ibb.co/FWHMdX0 70 lei 26. Cotiera Opel https://ibb.co/jLFQVs1 https://ibb.co/jhNqRQM https://ibb.co/wszVvtd https://ibb.co/c3CD6xJ https://ibb.co/RT8gxPK https://ibb.co/9ns028C 35 lei 27. Photo Album 10x15 300, Traditional Artificial Leather Slip-in Album for Landscape Format Photos Pictures Red Album foto deosebit 300 fotografii, 34cmx20cmx6cm aproximativ https://ibb.co/NKf2QFC https://ibb.co/VtvRQGD https://ibb.co/GHsLBbv https://ibb.co/vVwtfvJ 35 lei 29. Carcasă pentru hard disk extern de laptop SSD HDD de la SATA 2.5 la USB 3.2 Gen 1, suport UASP SATA III aluminiu negru, ambalaj deteriorat https://ibb.co/4PmVdr6 https://ibb.co/jGBq4pf https://ibb.co/7vbHPzT https://ibb.co/ThfSL8d 30 lei 30. Aparat contra tantarilor alimentare usb https://ibb.co/tDvZBGL https://ibb.co/H75q6cj https://ibb.co/0Q5gKLT https://ibb.co/pXmXBpr https://ibb.co/wywfDtx 15 lei ambele, unul fara ambalaj 31. Non-Contact Fever Thermometer for Babies and Adults, Digital Forehead Thermometer, Infrared Thermometer with Instant and Accurate Reading, Fever Alarm, Black Termometru IR https://postimg.cc/gallery/zqWVhg1 20 lei 32. Displayuri cu touch https://postimg.cc/gallery/3hHDX79 25 lei toate 33. RUIZHI 2x50W 100W 2.1 Channel Subwoofer Amplifier Board with Bluetooth Treble and Bass Control, Two TPA3116 Chips, DC 12-24V, Bluetooth and AUX Inputs, AMP Board for Wireless DIY Speakers https://ibb.co/sbXRtJ9 https://ibb.co/t824J1d https://ibb.co/vXFcbfG 75 lei 34. Disk Safe timed locker, phone locker with timer phone shutdown video games, social media, self-control timer locker container storage box for addiction management Cutie plastic cu cifru electronic, timer... https://ibb.co/0YvmPXx https://ibb.co/qyqyhVS https://ibb.co/y4TcCJg https://ibb.co/fC4m3XB https://ibb.co/3NL3hFh https://ibb.co/dGt90hJ https://ibb.co/G2J3TmQ 15 lei 35. OBD 2 MP69033, nu necesita laptop https://ibb.co/qpp63gt https://ibb.co/GHmXczz https://ibb.co/cLFyfys https://ibb.co/6Rx2NCh https://ibb.co/xYmYBcM https://ibb.co/2Ks1NYS https://ibb.co/whGdg7q https://ibb.co/yPJhBmh 75 lei, disponibile 4 buc 36. KKMOL Presentation Clicker, Presentation Remote Control, Powerpoint Remote Control, Pointer for Presentations, PPT Red Pointer, USB Presenter for PPT Windows XP 7 8 10 Mac OS Linux https://ibb.co/DWQg68N https://ibb.co/dQ04wGw 30 lei 37. KKMOL presentation remote control, Powerpoint remote control, pointer for presentations, PPT red pointer, USB 2.4 GHz presenter for PPT Windows XP 7 8 10 Mac OS Linux alim cu 2 baterii AAA, fara https://ibb.co/pKn3sCL https://ibb.co/0jG8VBf https://ibb.co/64550gL https://ibb.co/VH1KP5r 30 lei 38. Husa impermeabile - waterproof telefon Samsung A54 https://ibb.co/k6Bvwym https://ibb.co/7pyNMxx https://ibb.co/9TtMK94 10 lei 39. Dispozitiv pentru seringi cu flux printat 3D https://ibb.co/qyYz9pn 20 lei 40. Glostars 100W LED UV Blacklight Spotlight, Blacklight Lamp, IP66 Waterproof, 395-400nm UV Party Light with Switch for Bar, Party Accessories, Blacklight Decoration, Stage Lighting lampa UV 250mm x 130mm https://ibb.co/YyqXrgn https://ibb.co/jHpM06L https://ibb.co/Wy3Dddj https://ibb.co/K5kgyjx https://ibb.co/MgXzLrc https://ibb.co/x74s3dL 40lei buc disponibile 2 buc 41. OMPHOBBY 900mAh 3.7v Li-ion 18350 battery OSHM2344 https://ibb.co/rw8ZBbv https://ibb.co/37Y1JKv 25 lei 42. 3.7V 3000mAh NiMH rechargeable battery, POWO18B with NiMH battery protection box, NO 1818-666-888B battery, perfect for flashlight, camera, small fan, doorbell 4 bucati https://ibb.co/qmrc30z https://ibb.co/bNMs7Jr https://ibb.co/fkgJjSn https://ibb.co/jVxmtwY https://ibb.co/wLfCL4z https://ibb.co/ZSmqDcy 35 lei 43. Huse deosebite piele naturala vintage pentru telefon, etc de pus la curea https://ibb.co/dWhYbGr https://ibb.co/vPFbXsV https://ibb.co/27WHS1H https://ibb.co/gg2f6Kj https://ibb.co/5T119MF https://ibb.co/gg2f6Kj https://ibb.co/fnPbYfD 30 lei buc 44. Cotiere genunchiere copii pentru bicicleta/trotineta/etc marimea L https://ibb.co/FbfGmnF https://ibb.co/9pY4QzH https://ibb.co/9bDWpCv https://ibb.co/R7xxmDF https://ibb.co/Dwt3xSS 25 lei 45. Hanmatek Digital Oscilloscope 2 Channels 110MhZ Bandwidth 1GS/s Sampling Rate 5mV/Div 7-inch TFT Storage Desktop Oscilloscope https://ibb.co/g61jLFd https://ibb.co/Bt9shPS https://ibb.co/jZ6GzQx https://ibb.co/bd62cx9 https://ibb.co/bR9gSZR https://ibb.co/1KrDsny 800 lei 46. Trusa electronist , multimetru letcon 60W, temperatura reglabila 200-450 grade C https://ibb.co/hHq6MNC https://ibb.co/0n3mMFW https://ibb.co/Khsb3hX https://ibb.co/fx1t2Ns https://ibb.co/w0xdmds https://ibb.co/zhtbC9G https://ibb.co/60VBzk0 80 lei 47. Kuulaa Powerbank, 22.5W Fast Charging Function 10000mAh Power Bank Small But Strong, PD3.0 QC3.0 Powerbank USB C External Cell Phone Batteries Compatible with iPhone, Samsung, Huawei, iPad, AirPods and more https://ibb.co/v3RRQGv https://ibb.co/vk4Q7Zx https://ibb.co/KFbtkLz https://ibb.co/41cpJYG https://ibb.co/VVM5W9c 40 lei 48. Led Cold White 11W PLC G24d-3 Light Source Mains Bulb Lamp 6500K 1070 Lumen 5 lampi led, una desigilata, lungime 14cm https://ibb.co/XCFrYv5 https://ibb.co/pLW0dC6 https://ibb.co/bzXLsBK https://ibb.co/xHzJR4D https://ibb.co/4WZtmvp 30 lei toate 50. 9W 365nm UV Lamp 4 lampi UV, neprobate, nu stiu daca sunt direct la 230V https://ibb.co/JCQK03w https://ibb.co/4MdYBnC 10 lei toate Link spre comentariu
George Postat Octombrie 27, 2024 Partajează Postat Octombrie 27, 2024 Doresc eu toate cele 5 lampi de la punctul 48. Link spre comentariu
Windows Postat Octombrie 27, 2024 Autor Partajează Postat Octombrie 27, 2024 1 oră în urmă, George a spus: Doresc eu toate cele 5 lampi de la punctul 48. Ok, discutam pe MP. Link spre comentariu
Barbaro Postat Octombrie 27, 2024 Partajează Postat Octombrie 27, 2024 Va salut ! Rezervati va rog pentru mine amplificatorul 2+1 de la punctul 33 Link spre comentariu
Windows Postat Octombrie 27, 2024 Autor Partajează Postat Octombrie 27, 2024 Acum 2 ore, Barbaro a spus: Va salut ! Rezervati va rog pentru mine amplificatorul 2+1 de la punctul 33 ok Link spre comentariu
Windows Postat Octombrie 28, 2024 Autor Partajează Postat Octombrie 28, 2024 (editat) Marfa este noua, posibil unele ambalaje deteriorate. Posibil si ceva marfa netestata, dar e specificat. Trimit doar prin Fancurier, daca aveti cont OLX coletul cu verificare costa undeva la 10 - 25 lei. Cu rosu bolduit intrari noi, cu portocaliu bolduit marfa trimisa/rezervata/discutii 1. Hailege USB Boost Converter Cable DC 5V to 9V 12V USB to DC 5.5x2.1mm USB Step-up Cable USB Power Supply Adapter UBS Power Voltage Boost Converter https://ibb.co/1TgwZJG https://ibb.co/wsBYsmn https://ibb.co/47yQdzv https://ibb.co/LY80Szy 10 lei 2. ECOTISH Women s Backpack in Soft Leather Casual School Daypack 2 in 1 as Backpack and Shoulder Bag, Women s Fashion Bag and Shoulder Backpack for School, Shopping, PLUS geanta de umar Rucsac piele ecologica si geanta de umar din piele naturala https://ibb.co/xmZz8tF https://ibb.co/HgD36q6 35 lei buc 3. Adaptor combinat M.2 NVME PCIE SSD la SFF-8654 NGFF SATA SATA la SATA 2 în 1 pentru placa de bază (NVME SSD la SATA nu funcționează pe acest adaptor) https://ibb.co/TRNf9Mg 20 lei 4. Newbealer Mini Travel Iron with Switchable Voltage-220V 120V, Compact Iron for Clothes No Steam , Ceramic Surface, 150 C Hot Press with Spray Bottle, Bag and Silicon Mini fier de calcat https://ibb.co/MGzRdVY https://ibb.co/LnvqxdL https://ibb.co/bQWZPwv https://ibb.co/GtkMyzv https://ibb.co/82JZ6JH https://ibb.co/FqbtC3r 40 lei 5. KOOTION 10 pieces USB sticks 16GB memory sticks set USB 2.0 10 pieces colorful data stick memory stick metal 16G thumb drive 10-pack flash drives 16 Gbyte flash stick https://ibb.co/pvccpk8 https://ibb.co/t24F40t 90 lei toate 6. SB Flash Drive, 3 in 1 256GB USB Flash Drive for Phone, USB Stick for Phone, Pad, USB C, Android Phone, PC, Tablet, Computer METALIC https://ibb.co/2gzXR0Y https://ibb.co/XF9y3dW https://ibb.co/vVv3JDm 55 lei 7. X-Sense CO detector with peak value memory, carbon monoxide detector, accurate sensor with 10 year battery LCD display https://ibb.co/gZ9qGNY https://ibb.co/XWhTZBP https://ibb.co/Zh0ZPWv https://ibb.co/Ms3RmtG https://ibb.co/1JX1L3m 25 lei , disponibile 2 buc 8. Memorii laptop SODIMM DDR4 DDR5 8GB/16GB https://ibb.co/m47d37r https://ibb.co/BPgMjFt https://ibb.co/CtvHgTf https://ibb.co/PQ9X9gZ https://ibb.co/7tGYnFT https://ibb.co/f4MDJnF https://ibb.co/FKr7zC8 https://ibb.co/QjfcMyP https://ibb.co/6Wk6dY4 preturi intre 70-190 lei 9. Sovol SV06 Plus SV04 Textured PEI Print Bed Printing Plate Magnetic 3D Printer Platform 310 x 320 mm for Ender 3 Max NEO CR-10 V2 CR-10 V3 CR-10S PRO V2 CR-X YOOPAI PEI Print Plate 310x320mm, Double-Sided Black Textured PEI Magnetic Spring Steel Print Bed for Creality CR10 CR10S 10S Pro V2 V3, Ender 3 Max, AnyCubic Mega X-5698794-4221764 Pat magnetic 310x320mm pentru imprimanta 3D 2 buc https://postimg.cc/gallery/Chb4qFW 40 lei bucata 10. Incarcatoare pentru orice tip de laptop mufa specifica fiecarului model, mufa Type C https://ibb.co/jGyxCSW https://ibb.co/m5S778B https://ibb.co/jZtMq8h https://ibb.co/mRDXJ4S https://ibb.co/0n7Pj42 https://ibb.co/16mtCrd https://ibb.co/QnrJZyG https://ibb.co/kDwvBGd https://ibb.co/TqPSgKn https://ibb.co/fSkBfBg https://ibb.co/9b6qBD4 https://ibb.co/z8R6kgK https://ibb.co/tP25LMr https://ibb.co/K5kCv9N https://ibb.co/PcN3Vjs 45 lei pana in 100W, 55 lei Type-C, Apple, 100 lei peste 100W 11. DVD CD Player for TV, Up-Convert to HD 1080p, All Region, Breakpoint Memory, Built-in PAL NTSC, USB 2.0 Mini DVD player cu telecomanda, iesiri rca si HDMI https://ibb.co/rwPjrTJ https://ibb.co/qRYp85p https://ibb.co/k0Z94qT https://ibb.co/sRJKzjp https://ibb.co/ss7zRZK https://ibb.co/Js2T0Gn https://ibb.co/pRZnM2L 40 lei 12. Treedix soldering iron set, 8W wireless soldering iron soldering set with adjustable temperature from 330 to 450 C, including USB cable, soldering wire, iron stand with sponge, 3 soldering tips for soldering Mini letcon cu incarcare type C https://ibb.co/5vr6wwB https://ibb.co/0sJHD36 90 lei 13. Soldering Iron Set - USB Soldering Iron with 3 Temperature Adjustable 300 -450 , 3 Soldering Tips, Soldering Iron Stand, Solder Wire, Solder Paste, KKMOL Soldering Set for Welding Repair - Blue https://ibb.co/jbbsjtP https://ibb.co/W0ncVrQ https://ibb.co/fqBsBhT https://ibb.co/R0QKjyc 80 lei 14. CD-uri printabile 700MB/80min cu ambalajul rupt, 100buc https://ibb.co/ZhnnwfM 20 lei 15. Baterii litiu-ion LIR2450 5 buc 3,7 V reîncărcabile cu încărcător tip monedă care înlocuiește cr2450 https://ibb.co/kHn7yfX https://ibb.co/ys46YKt https://ibb.co/8Y3CJNt https://ibb.co/Tb5PL4H https://ibb.co/QNWvxKc https://ibb.co/vYfbb0h https://ibb.co/GPQVtTz 45 lei 16. ANJANK Extremely Loud Wireless Vibrating Alarm Clock with Electric Shaker for No Hearing, Hard of Hearing, Deep Sleep, Dual Alarm, Battery Backup, USB Charger 2 Ceasuri cu afisaj foarte mare noi in cutie https://ibb.co/GnZsYp5 https://ibb.co/kMYpzRR https://ibb.co/f2ZGvXg https://ibb.co/8rjh502 https://ibb.co/bK1kmbC https://ibb.co/cNhtX6T https://ibb.co/r6nC67w https://ibb.co/51PKnvC https://ibb.co/0FwwsfD 35 lei buc 17. STK MP1584EN Step Down Buck Converter Adjustable DC-DC 4.5-28V to 0.8-20V Voltage Regulator Module 24V to 12V 9V 5V 3V Regulatoare step down https://ibb.co/k1wLKqv 30 lei 18. Koala Inkjet Photo Paper, Double Sided, Matt, A3, 230 g m , 100 Sheets. Suitable for printing photos, certificates, brochures, flyers, leaflets, greeting cards, calendars, art Hartie foto A3 inkjet, printabila pe ambele fete https://ibb.co/BsJLfFL https://ibb.co/jkWppmm 25 lei 19. TREKOLOGY Large Inflatable Pillow - ALUFT Ultra Camping Pillow for Beach and Camping, Inflatable Pillow for Outdoor Adventures Perna gonflabila https://ibb.co/4s48H5g https://ibb.co/THTVypr https://ibb.co/k6txtYS https://ibb.co/BVTryRN https://ibb.co/nnbx34S https://ibb.co/tD3PJxw 20 lei 20. SVNOOC 24V 4A Power Supply 96W Charger 100 240V AC to DC Converter LED Transformer with 5.5mmx 2.5mm Plug for CCTV Camera LCD Monitor DC Pump Fan CE Certificate EU Plug https://ibb.co/qJRXjK4 https://ibb.co/fCWN1Y4 https://ibb.co/tqYsTDg https://ibb.co/42k96G9 https://ibb.co/RTqHpNy 25 lei 21. Bzocio 1Din Car Radio CD DVD Player External Stereo Interface USB Port Navigation GPS Car Universal https://ibb.co/PZSh3gr https://ibb.co/rZWwnvB https://ibb.co/SXGG0jq https://ibb.co/W2JNRTS https://ibb.co/whJb8rq https://ibb.co/Tt4s1fx 20 lei 22. Magneti neodim 500 buc 5mmx5mmx2mm https://ibb.co/T41GmxC https://ibb.co/QKZGdJZ https://ibb.co/RBzXrvK 85 lei 23. FTDLCD 15.6 inch LCD Touch Screen Digitizer Display Screen Assembly for HP Pavilion x360 Convertible 15-dq0000ng 15-dq1433ng 15-dq1001ng 15-dq1002ng 15-dq1131ng 15-d-5355429-3969958 ansamblu display cu touch https://ibb.co/dB3FQn2 https://ibb.co/SRf5Qm4 https://ibb.co/r43tmvC 380 lei 24. Lumină LED pentru acvariu, 10W alb și albastru pentru acvariu de 40-60 cm, lampă pentru acvariu cu console extensibile, alimentator 12V, lumina reglabila ca intensitate, timer https://ibb.co/2PfKmS5 https://ibb.co/BnJxCN5 https://ibb.co/KLHCFqK https://ibb.co/G2rH3vJ https://ibb.co/h8Mt5dz https://ibb.co/pd00qvT https://ibb.co/MhDhfjk 40 lei 25. Digital Luxmeter Portable Photometer Exposure Meter Illuminance Light Meter with Range up to 200,000 Lux and LCD Display https://ibb.co/WfwjT0J https://ibb.co/hCwF0HZ https://ibb.co/3cXPZz0 https://ibb.co/wWwvdMG https://ibb.co/zn3JwdR https://ibb.co/prSd4hC https://ibb.co/FWHMdX0 70 lei 26. Cotiera Opel https://ibb.co/jLFQVs1 https://ibb.co/jhNqRQM https://ibb.co/wszVvtd https://ibb.co/c3CD6xJ https://ibb.co/RT8gxPK https://ibb.co/9ns028C 35 lei 27. Photo Album 10x15 300, Traditional Artificial Leather Slip-in Album for Landscape Format Photos Pictures Red Album foto deosebit 300 fotografii, 34cmx20cmx6cm aproximativ https://ibb.co/NKf2QFC https://ibb.co/VtvRQGD https://ibb.co/GHsLBbv https://ibb.co/vVwtfvJ 35 lei 29. Carcasă pentru hard disk extern de laptop SSD HDD de la SATA 2.5 la USB 3.2 Gen 1, suport UASP SATA III aluminiu negru, ambalaj deteriorat https://ibb.co/4PmVdr6 https://ibb.co/jGBq4pf https://ibb.co/7vbHPzT https://ibb.co/ThfSL8d 30 lei 30. Aparat contra tantarilor alimentare usb https://ibb.co/tDvZBGL https://ibb.co/H75q6cj https://ibb.co/0Q5gKLT https://ibb.co/pXmXBpr https://ibb.co/wywfDtx 15 lei ambele, unul fara ambalaj 31. Non-Contact Fever Thermometer for Babies and Adults, Digital Forehead Thermometer, Infrared Thermometer with Instant and Accurate Reading, Fever Alarm, Black Termometru IR https://postimg.cc/gallery/zqWVhg1 20 lei 32. Displayuri cu touch https://postimg.cc/gallery/3hHDX79 25 lei toate 33. RUIZHI 2x50W 100W 2.1 Channel Subwoofer Amplifier Board with Bluetooth Treble and Bass Control, Two TPA3116 Chips, DC 12-24V, Bluetooth and AUX Inputs, AMP Board for Wireless DIY Speakers https://ibb.co/sbXRtJ9 https://ibb.co/t824J1d https://ibb.co/vXFcbfG 75 lei 34. Disk Safe timed locker, phone locker with timer phone shutdown video games, social media, self-control timer locker container storage box for addiction management Cutie plastic cu cifru electronic, timer... https://ibb.co/0YvmPXx https://ibb.co/qyqyhVS https://ibb.co/y4TcCJg https://ibb.co/fC4m3XB https://ibb.co/3NL3hFh https://ibb.co/dGt90hJ https://ibb.co/G2J3TmQ 15 lei 35. OBD 2 MP69033, nu necesita laptop https://ibb.co/qpp63gt https://ibb.co/GHmXczz https://ibb.co/cLFyfys https://ibb.co/6Rx2NCh https://ibb.co/xYmYBcM https://ibb.co/2Ks1NYS https://ibb.co/whGdg7q https://ibb.co/yPJhBmh 75 lei, disponibile 4 buc 36. KKMOL Presentation Clicker, Presentation Remote Control, Powerpoint Remote Control, Pointer for Presentations, PPT Red Pointer, USB Presenter for PPT Windows XP 7 8 10 Mac OS Linux https://ibb.co/DWQg68N https://ibb.co/dQ04wGw 30 lei 37. KKMOL presentation remote control, Powerpoint remote control, pointer for presentations, PPT red pointer, USB 2.4 GHz presenter for PPT Windows XP 7 8 10 Mac OS Linux alim cu 2 baterii AAA, fara https://ibb.co/pKn3sCL https://ibb.co/0jG8VBf https://ibb.co/64550gL https://ibb.co/VH1KP5r 30 lei 38. Husa impermeabile - waterproof telefon Samsung A54 https://ibb.co/k6Bvwym https://ibb.co/7pyNMxx https://ibb.co/9TtMK94 10 lei 39. Dispozitiv pentru seringi cu flux printat 3D https://ibb.co/qyYz9pn 20 lei 40. Glostars 100W LED UV Blacklight Spotlight, Blacklight Lamp, IP66 Waterproof, 395-400nm UV Party Light with Switch for Bar, Party Accessories, Blacklight Decoration, Stage Lighting lampa UV 250mm x 130mm https://ibb.co/YyqXrgn https://ibb.co/jHpM06L https://ibb.co/Wy3Dddj https://ibb.co/K5kgyjx https://ibb.co/MgXzLrc https://ibb.co/x74s3dL 40lei buc disponibile 2 buc 41. OMPHOBBY 900mAh 3.7v Li-ion 18350 battery OSHM2344 https://ibb.co/rw8ZBbv https://ibb.co/37Y1JKv 25 lei 42. 3.7V 3000mAh NiMH rechargeable battery, POWO18B with NiMH battery protection box, NO 1818-666-888B battery, perfect for flashlight, camera, small fan, doorbell 4 bucati https://ibb.co/qmrc30z https://ibb.co/bNMs7Jr https://ibb.co/fkgJjSn https://ibb.co/jVxmtwY https://ibb.co/wLfCL4z https://ibb.co/ZSmqDcy 35 lei 43. Huse deosebite piele naturala vintage pentru telefon, etc de pus la curea https://ibb.co/dWhYbGr https://ibb.co/vPFbXsV https://ibb.co/27WHS1H https://ibb.co/gg2f6Kj https://ibb.co/5T119MF https://ibb.co/gg2f6Kj https://ibb.co/fnPbYfD 30 lei buc 44. Cotiere genunchiere copii pentru bicicleta/trotineta/etc marimea L https://ibb.co/FbfGmnF https://ibb.co/9pY4QzH https://ibb.co/9bDWpCv https://ibb.co/R7xxmDF https://ibb.co/Dwt3xSS 25 lei 45. Hanmatek Digital Oscilloscope 2 Channels 110MhZ Bandwidth 1GS/s Sampling Rate 5mV/Div 7-inch TFT Storage Desktop Oscilloscope https://ibb.co/g61jLFd https://ibb.co/Bt9shPS https://ibb.co/jZ6GzQx https://ibb.co/bd62cx9 https://ibb.co/bR9gSZR https://ibb.co/1KrDsny 800 lei 46. Trusa electronist , multimetru letcon 60W, temperatura reglabila 200-450 grade C https://ibb.co/hHq6MNC https://ibb.co/0n3mMFW https://ibb.co/Khsb3hX https://ibb.co/fx1t2Ns https://ibb.co/w0xdmds https://ibb.co/zhtbC9G https://ibb.co/60VBzk0 80 lei 47. Kuulaa Powerbank, 22.5W Fast Charging Function 10000mAh Power Bank Small But Strong, PD3.0 QC3.0 Powerbank USB C External Cell Phone Batteries Compatible with iPhone, Samsung, Huawei, iPad, AirPods and more https://ibb.co/v3RRQGv https://ibb.co/vk4Q7Zx https://ibb.co/KFbtkLz https://ibb.co/41cpJYG https://ibb.co/VVM5W9c 40 lei 48. Weymic A-Series Professional Mixer for Recording DJ Stage, Karaoke Music Application with USB Drive for Computer Recording Input, XLR Microphone Port, 48V Power, RCA Output Defect, nu se aprinde afisajul, are o rezistenta arsa in zona lui, voi incerca sa-l dau jos, poate se vede ceva dedesubt ars. https://ibb.co/N2JgsNJ https://ibb.co/w4bTv31 https://ibb.co/wRq8Gct https://ibb.co/HVZ9rY5 80 lei 50. 9W 365nm UV Lamp 4 lampi UV, neprobate, nu stiu daca sunt direct la 230V https://ibb.co/JCQK03w https://ibb.co/4MdYBnC 10 lei toate 51. Incarcator 24V 2,5A https://ibb.co/2nzH9PV https://ibb.co/5BFNJGN https://ibb.co/nDQLBky 20 lei buc, disponibile 2 buc 52. Aideepen 3 x 3S 20A Li-ion Lithium Battery Charger Board PCB BMS 12.6V Cell Module Overcharge Overcurrent Short Circuit Protection https://ibb.co/mGbZXb3 https://ibb.co/b2fK1QM 10 lei buc, disponibile 3 buc 53. 400Ah Automatic Battery Desulfator Maintainer for reviving and regenerating Gel AGM SLA lead acid batteries https://ibb.co/BGs5w5k https://ibb.co/pXtLWCd https://ibb.co/nM5Sj88 55 lei 54. X-Sense SC07 Smoke and Carbon Monoxide Detector, Autonomous, 10 Years, with LCD Display and Test Button, 360 Degree Monitoring, Automatic Testing https://ibb.co/zsm9xvJ https://ibb.co/2Z4ncPf https://ibb.co/QHJ4ZsR 65 lei 55. UNI-T Sound Level Meter https://ibb.co/3mxXLsx https://ibb.co/k2XLxmC 55 lei 56. Pyrography station, Preciva burning iron set with 20-piece tips, pyrography set craft set soldering station soldering iron set temperature adjustable 250 - 750 , pyrography iron for wood, leather and cork Aparat pirogravura https://ibb.co/Nxtt7JZ https://ibb.co/TbtGZBH https://ibb.co/Wkdy78z https://ibb.co/vDJVMvk https://ibb.co/StRpPCK https://ibb.co/kGY4wJX https://ibb.co/rFg0CFt https://ibb.co/1mMYCsr https://ibb.co/9VhJBPR 120 lei 57. ORIGBELIE External DVD Drive USB 3.0 Type C, CD DVD -RW Burner with USB Ports and SD TF Card Reader, External CD Drive for Laptop Desktop MacBook Windows 11 10 8 7 XP Vista Linux Mac Livrate in huse de catifea neagra https://ibb.co/nbVhFZk https://ibb.co/Rz6MWD1 https://ibb.co/DrJprM0 45 lei/buc disponibile 4 buc Editat Octombrie 28, 2024 de Windows Link spre comentariu
Dj_Dog Postat Octombrie 28, 2024 Partajează Postat Octombrie 28, 2024 Rog rezervare pt punctul 48 Si daca mai apare un boost converter cum aveati in paginile anterioare sa imi rezervati si mie o bucata Multumesc! Link spre comentariu
Windows Postat Octombrie 28, 2024 Autor Partajează Postat Octombrie 28, 2024 Acum 18 minute, Dj_Dog a spus: Rog rezervare pt punctul 48 Si daca mai apare un boost converter cum aveati in paginile anterioare sa imi rezervati si mie o bucata Multumesc! Rezerv punct 48. cu o intrebare, continui eu investigatia placii sau trimit asa defecta? Link spre comentariu
Dj_Dog Postat Octombrie 29, 2024 Partajează Postat Octombrie 29, 2024 Nu ma deranjeaza daca il trimiteti asa cum este Link spre comentariu
Windows Postat Octombrie 29, 2024 Autor Partajează Postat Octombrie 29, 2024 1 oră în urmă, Dj_Dog a spus: Nu ma deranjeaza daca il trimiteti asa cum este ok Link spre comentariu
Windows Postat Octombrie 29, 2024 Autor Partajează Postat Octombrie 29, 2024 48. rezervat ...... 58. RUZIZAO laboratory power supply 30V 5A, laboratory power supply with 3-digit LED display, adjustable switching power supply upgrade encoder button, mini laboratory power supply adjustable Sursa alimentare 30V 5A , noua, disponibile 5 buc https://ibb.co/Pzqy9vJ https://ibb.co/6H7m4xC https://ibb.co/MCDw37z https://ibb.co/RgbMNbW https://ibb.co/cQByktt https://ibb.co/VL06YRX https://ibb.co/y46p4SG https://ibb.co/cyNmSsG https://ibb.co/C8R16mR https://ibb.co/gJfztPB 150 lei buc Link spre comentariu
