cozmalau Postat August 6, 2024 Partajează Postat August 6, 2024 (editat) Se vand urmatoarele: 1) Boxa pasiva Behringer B215 in stare foarte buna. 300 lei 2) Slefuitor cu vibratii Black Decker KA2000-QS in stare buna 100 lei 3) Stativ de aluminiu neo tools pentru laser 40 lei - Inaltime reglabila pana la 150 cm - Picioare telescopice care se blocheza cu cleme - Filet stativ 1/4" - Cap reglabil - Structura usoara din aluminiu - Nivela cu o bula pentru punerea pe orizontala a capului 4) Kit amplificator audio 350W in 4 ohm (IRFP 240/IRFP 9240), tensiune alimentare +/-65v 250 lei 5) Ciocan rotopercutor Berner in stare buna, se vinde cu tot cu cutie (acumulator trecut de la NiCd la Li-ion , are capacitate 8A tensiune de 25.2V, s-au folosit 12 celule 21700 Samsung 40T) 300 lei 6) Amplificator 5.1 Sony STR-D611 in stare de functionare, sunet impecabil la varsta lui. 200 lei Tuning range: FM, MW Power output: 75 watts per channel into 8Ω (stereo) Surround output: 80W (front), 20W (center), 20W (rear) Frequency response: 10Hz to 50kHz Total harmonic distortion: 0.8% Input sensitivity: 2.5mV (MM), 200mV (line) Signal to noise ratio: 74dB (MM), 95dB (line) Output: 200mV (line) Speaker load impedance: 8Ω (minimum) Video Connections: composite Dimensions: 430 x 135 x 295mm Weight: 6.4kg Accessories: RM-U232 remote control Year: 1993 7) Amplificator Akai AA-5210 Power output: 15 watts per channel into 8Ω (stereo) Frequency response: 20Hz to 50kHz Total harmonic distortion: 0.5% Input sensitivity: 2.75mV (mic), 2.75mV (MM), 155mV (DIN), 155mV (line) Signal to noise ratio: 37dB (mic), 37dB (MM), 47dB (DIN), 47dB (line) Channel separation: 50dB (line) Output: 140mV (line), 27mV (DIN) Dimensions: 450 x 108 x 290mm Weight: 7.2kg Amplificator Pioneer SX-205RDS Tuning range: FM, MW Power output: 40 watts per channel into 8Ω (stereo) Frequency response: 5Hz to 100kHz Total harmonic distortion: 0.09% Input sensitivity: 2.5mV (MM), 200mV (line) Signal to noise ratio: 67dB (MM), 82dB (line) Output: 200mV (line) Dimensions: 420 x 140 x 313mm Weight: 5.4kg Accessories: remote control Year: 1996 Ambele se vand la 300 lei Editat August 6, 2024 de cozmalau Link spre comentariu
deo Postat August 6, 2024 Partajează Postat August 6, 2024 Boxa behringer o iau eu daca nu sa dat. Link spre comentariu
cozmalau Postat August 6, 2024 Autor Partajează Postat August 6, 2024 Acum 1 oră, deo a spus: Boxa behringer o iau eu daca nu sa dat. Inca e valabil. Link spre comentariu
cozmalau Postat August 6, 2024 Autor Partajează Postat August 6, 2024 Pozitia 1 s-a vandut. Link spre comentariu
cozmalau Postat August 6, 2024 Autor Partajează Postat August 6, 2024 Se adauga in continuare: 8 ) Autofiletanta de mana chinezeasca , noua 50 lei. 9) Autofiletanta cu percutie , are afisaj procent baterie si nivela. Necesita acumulatori noi, cei vechi sunt obositi. Pret 50 lei. Am si bms 13s 30A pentru cine vrea sa treaca pe li-ion. 100 lei buc 10) Aspiratoare de mana 140 lei amandoua. Necesita schimbati acumulatorii, ambele au celule li-ion de fabrica. Aspiratorul Silvercrest Lithium Power SHSS 12 C2 75w tensiune 12.6v cu 3 celule li-ion Aspiratorul Bono HVC-150.580.57R 150W tensiune 25.2v cu 6 celule li-ion Link spre comentariu
deo Postat August 7, 2024 Partajează Postat August 7, 2024 Sa inteleg ca a-ti vandut pozitia 1 ? Link spre comentariu
cozmalau Postat August 7, 2024 Autor Partajează Postat August 7, 2024 Acum 1 oră, deo a spus: Sa inteleg ca a-ti vandut pozitia 1 ? Buna seara, s-a vandut pana ati intrat dv sa imi dati raspuns. Link spre comentariu
marius_amp Postat August 7, 2024 Partajează Postat August 7, 2024 La 06.08.2024 la 17:16, deo a spus: Boxa behringer o iau eu daca nu sa dat. @cozmalau ce raspuns mai vroiati? Deo a spus clar ca vrea sa o cumpere in citatul de mai sus. A fost primul care si-a exprimat intentia de a o cumpara. Nu e trecut in regulamentul bazarului ce ati facut, dar nu e deloc corect ce ati facut. Rușinică!!!!!! Link spre comentariu
deo Postat August 7, 2024 Partajează Postat August 7, 2024 O seama mai si lucreaza,nu e corect dar asta e.Sanatate, Link spre comentariu
cozmalau Postat August 7, 2024 Autor Partajează Postat August 7, 2024 (editat) Acum 52 minute, marius_amp a spus: @cozmalau ce raspuns mai vroiati? Deo a spus clar ca vrea sa o cumpere in citatul de mai sus. A fost primul care si-a exprimat intentia de a o cumpara. Nu e trecut in regulamentul bazarului ce ati facut, dar nu e deloc corect ce ati facut. Rușinică!!!!!! Cumperi ceva? Te rog sa parasesti pe usa daca nu iti convine. Primul care cumpara cu bani e primu servit, fapte nu vorbe. Te bagi si tu ca chilotu.... Acum 30 minute, deo a spus: O seama mai si lucreaza,nu e corect dar asta e.Sanatate, Imi pare rau domnule, nu am toata ziua la dispozitie sa astept dupa fiecare, aici nu se da pe caiet. Eu nu am vina ca dv intrati rar.... ar insemna sa stau cu marfa pe stoc dupa dv... ee Editat August 7, 2024 de cozmalau Link spre comentariu
Marian Postat August 7, 2024 Partajează Postat August 7, 2024 23 minutes ago, cozmalau said: Te bagi si tu ca chilotu.... Doar pentru ca-i anuntul tau nu inseamna ca poti spune ce vrei, ca poti insulta pe aia incomozi, deci ia o pauza: Link spre comentariu
cozmalau Postat August 14, 2024 Autor Partajează Postat August 14, 2024 (editat) Pozitia 1;5;8 s-au vandut! Se dau toate pozitiile valabile la 900 lei. Editat August 14, 2024 de cozmalau Link spre comentariu
