vasile barsan Postat Octombrie 8 Autor Partajează Postat Octombrie 8 Inca valabile cele de mai sus.. Link spre comentariu
vasile barsan Postat Octombrie 11 Autor Partajează Postat Octombrie 11 - exponometru SIXTOMAT , piesa de colectie , perfect functional , pret = 80lei https://i.postimg.cc/8CCftJhF/EXPONOMETRU-SIXTOMAT2.jpg - aparat foto ZORKI 4 , sovietic , colectibil , perfect functional , pret = 120 lei ,negociabil https://i.postimg.cc/K8W3pcQJ/ZORKI4.jpg https://i.postimg.cc/1zTTzFBw/ZORKI-4.jpg - alimentator Radioprogres , nu are borne , in rest complet ,neverificat , pret =30 lei https://i.postimg.cc/bvhMSn2t/ALIM-RADIOPROGRES-SUS.jpg https://i.postimg.cc/5NHNnhKm/ALIM-RADIOPROGRES-INT.jpg https://i.postimg.cc/25CxQ7jn/ALIMENTATOR-RADIOPROGRE-CABLAJ.jpg https://i.postimg.cc/WbH36N28/ALIMENTATOR-RADIOPROGRES-CAB.jpg - motor Bosch + modul comanda , recuperat dintr-un storcator de fructe putin folosit, pret = 40 lei https://i.postimg.cc/8cnyWp93/motor-Bosh.jpg https://i.postimg.cc/j2WHpz3g/motor-bosch-1.jpg https://i.postimg.cc/rydYXW42/motor-bosch-2.jpg - 2 buc. modul filtre(crossover) ,80W , inalte / joase , noi , pret= 20lei/buc https://i.postimg.cc/TPFj78M4/FILTRE-BOXA-1.jpg https://i.postimg.cc/Qt7Qv6jx/FILTRE-BOXA-2.jpg - sistem 2.1 Logitech , model S - 00154 , lipsa dif-ul subwoofer , in rest perfect functional , optic 10/10 , pret = 45 lei https://i.postimg.cc/y85SBFQJ/LOGITECH-FATA.jpg https://i.postimg.cc/1zqVzf2v/LOGITECH-1.jpg https://i.postimg.cc/G2PBk6cY/LOGITECH-2.jpg https://i.postimg.cc/2yz1TT6t/LOGITECH-3.jpg - Difuzor (recuperat) Tonsil (Pioneer license) , impecabil , 4W / 8 Ohm , dimensiuni 16x10 cm , pret = 15 lei https://i.postimg.cc/j2b50n1f/dif-TONSIL-1.jpg https://i.postimg.cc/zX3BmNt0/DIF-TONSIL-2.jpg - Modul (recuperat din RCass Unitra Eltra)) radio FM (65,5 - 73 MHz) , echipat cu CI - TA 8164 (Toshiba) , pret = 7 lei https://i.postimg.cc/13Bs4Yjf/modul-radio-FM-1.jpg https://i.postimg.cc/1XhLvpjk/MODUL-RADIO-FM-2.jpg ,- Boxa center sistem Genius , contine 2 buc difuzoare 15W / 4 Ohm inseriate , carcasa in stare foarte buna . dimensiuni 33x16x14 cm , pret = 35 lei https://i.postimg.cc/2SZ9Kq4m/BOXA-GENIUS-2.jpg https://i.postimg.cc/gkfN8Y17/BOXA-GENIUS-1.jpg https://i.postimg.cc/FKvpCTrg/BOXA-GENIUS-3.jpg - Placa radio AM / FM , stereo , echipata cu CI ; LA1201 ; BA1320 , CV , bara ferita , comutator game , completa ,componente originale , nu mai stiu provenienta , pret = 20 lei https://i.postimg.cc/02JC8Tr0/placa-radio1.jpg https://i.postimg.cc/bvq09dgm/placa-radio-2.jpg - Mecanica Rcass Unitra Eltra , curata ,fara motor , claviatura , capete redare/inregistrare ; stergere/premagnetizare , tamburi , role complete , etc, pentru piese de schimb , pret = 8 lei https://i.postimg.cc/hPy6QW0z/MECANICA-1.jpg https://i.postimg.cc/TPm4syvg/MECANICA-2.jpg - sasiu Rcass National Panasonic model RQ-432DS , perfect functional , radio MW ( 525 - 1605 Khz) , SW 1 -( 2,3 - 7 MHZ) ; SW 2 - ( 7 - 22 MHZ) ,extrem de sensibil / selectiv , componente originale , fara interventii , parte electronica / mecanica casetofon impecabila , carcasa se ofera bonus deoarece lipseste geamul scalei ,are lipsa capacul bateriilor si o parte din partea superioara + crapaturi.. ( are manerul si antena originale), pret = 40 lei https://i.postimg.cc/3xwhGwV8/national-panasonic-cablaj.jpg https://i.postimg.cc/kMhvCYCT/national-panasonic-mecanica.jpg https://i.postimg.cc/Y25K93fx/afisor-1.jpg - modul redresare, filtrare si stabilizare preamplificator din dezmembrare amplificator ROTEL RA-500 Pret = 22 Lei https://i.postimg.cc/vmxqnRv2/preamplif-sursa-ROTEL.jpg - Trafo retea recuperat dintr-un PA , tensiuni secundar ; 2 x 27,8V ; 2 x 17,8V ; 3V , dimensiuni tole 90x 70 x 45 mm, complet silentios , ecranat , pret = 40 lei https://i.postimg.cc/gJ0gBL3r/trafo.jpg https://i.postimg.cc/gcxWxn1Y/trafo-2.jpg https://i.postimg.cc/0NVTQsfM/trafo-3.jpg - PCB probe 9x7cm , 6 buc , pret = 4 lei/buc https://i.postimg.cc/hPwbK3TD/cablaje.jpg - Converter HDMI - AV , nou ,nefolosit (imi trebuia de fapt optic fiber / AV) , pret = 35 lei https://i.postimg.cc/VLb0Ws0w/converter-hdmi-1.jpg https://i.postimg.cc/0rgQBmKs/converter-hdmi-2.jpg - Sursa tensiuni multiple : 3,3V ; 5V ; 23V ; 30V , pret = 10 lei https://i.postimg.cc/PqGqf1Sv/SURSA-MULTIPLA.jpg - Sursa reglabila SMPS , 0-12V / 5A , home made , (echipata cu LM 317 + 2 xTIP 3055), pret = 130lei - negociabil https://i.postimg.cc/xTwQLnMW/sursa3.jpg https://i.postimg.cc/v81HnPCx/SURSA-12-V-FATA2.jpg https://i.postimg.cc/3NLgztCv/SURSA-12-V-LAT.jpg https://i.postimg.cc/MG8j3k2L/SURSA-12-V-INT-1.jpg - Placa de baza PC , model G41T - M7 , echipata cum se vede in poze (procesor ;cooler ; memorii ),perfect functionala , pret = 30 lei https://i.postimg.cc/zvhd3gMM/PLACA-DE-BAZA-1.jpg https://i.postimg.cc/cLhFKZ9s/PLACA-BAZA-2.jpg https://i.postimg.cc/66ZzrCjb/PLACA-BAZA-3.jpg - SURSA ATX 450W , perfect functionala , pret = 20lei https://i.postimg.cc/RZcPxs9L/SURSA-ATX-450-W-1.jpg https://i.postimg.cc/rsB9vWPH/SURSA-ATX-450-W.jpg Link spre comentariu
vasile barsan Postat Octombrie 13 Autor Partajează Postat Octombrie 13 Au ramas valabile: - exponometru SIXTOMAT , piesa de colectie , perfect functional , pret = 80lei - negociabil https://i.postimg.cc/8CCftJhF/EXPONOMETRU-SIXTOMAT2.jpg - aparat foto ZORKI 4 , sovietic , colectibil , perfect functional , pret = 120 lei ,negociabil https://i.postimg.cc/K8W3pcQJ/ZORKI4.jpg https://i.postimg.cc/1zTTzFBw/ZORKI-4.jpg - motor Bosch + modul comanda , recuperat dintr-un storcator de fructe putin folosit, pret = 40 lei https://i.postimg.cc/8cnyWp93/motor-Bosh.jpg https://i.postimg.cc/j2WHpz3g/motor-bosch-1.jpg https://i.postimg.cc/rydYXW42/motor-bosch-2.jpg - Modul (recuperat din RCass Unitra Eltra)) radio FM (65,5 - 73 MHz) , echipat cu CI - TA 8164 (Toshiba) , pret = 7 lei https://i.postimg.cc/13Bs4Yjf/modul-radio-FM-1.jpg https://i.postimg.cc/1XhLvpjk/MODUL-RADIO-FM-2.jpg - Placa radio AM / FM , stereo , echipata cu CI ; LA1201 ; BA1320 , CV , bara ferita , comutator game , completa ,componente originale , nu mai stiu provenienta , pret = 20 lei https://i.postimg.cc/02JC8Tr0/placa-radio1.jpg https://i.postimg.cc/bvq09dgm/placa-radio-2.jpg - Mecanica Rcass Unitra Eltra , curata ,fara motor , claviatura , capete redare/inregistrare ; stergere/premagnetizare , tamburi , role complete , etc, pentru piese de schimb , pret = 8 lei https://i.postimg.cc/hPy6QW0z/MECANICA-1.jpg https://i.postimg.cc/TPm4syvg/MECANICA-2.jpg - modul redresare, filtrare si stabilizare preamplificator din dezmembrare amplificator ROTEL RA-500 Pret = 22 Lei https://i.postimg.cc/vmxqnRv2/preamplif-sursa-ROTEL.jpg - Trafo retea recuperat dintr-un PA , tensiuni secundar ; 2 x 27,8V ; 2 x 17,8V ; 3V , dimensiuni tole 90x 70 x 45 mm, complet silentios , ecranat , pret = 40 lei https://i.postimg.cc/gJ0gBL3r/trafo.jpg https://i.postimg.cc/gcxWxn1Y/trafo-2.jpg - Sursa reglabila SMPS , 0-12V / 5A , home made , (echipata cu LM 317 + 2 xTIP 3055), pret = 130lei - negociabil https://i.postimg.cc/xTwQLnMW/sursa3.jpg https://i.postimg.cc/v81HnPCx/SURSA-12-V-FATA2.jpg https://i.postimg.cc/3NLgztCv/SURSA-12-V-LAT.jpg https://i.postimg.cc/MG8j3k2L/SURSA-12-V-INT-1.jpg Link spre comentariu
vasile barsan Postat Octombrie 18 Autor Partajează Postat Octombrie 18 Se adauga: Amplificator stereo echipat cu CI BA 5406 , 2x5W , include corector ton , volum , parte alimentare , pret = 35 lei , fara carcasa .. https://i.postimg.cc/Hkxp3N31/amplif-5406.jpg https://i.postimg.cc/tgpNLhZb/amplif5406-1.jpg https://i.postimg.cc/3xnyq0P4/amplif-5406-2.jpg Difuzoare nos 10W / 4Ohm , 2 buc. , pret = 8 lei / buc. https://i.postimg.cc/vmKtpNpV/difuzoare-10-W-4-Ohm.jpg Valabile si cele de mai jos: - exponometru SIXTOMAT , piesa de colectie , perfect functional , pret = 80lei - negociabil https://i.postimg.cc/8CCftJhF/EXPONOMETRU-SIXTOMAT2.jpg - aparat foto ZORKI 4 , sovietic , colectibil , perfect functional , pret = 120 lei ,negociabil https://i.postimg.cc/K8W3pcQJ/ZORKI4.jpg https://i.postimg.cc/1zTTzFBw/ZORKI-4.jpg - motor Bosch + modul comanda , recuperat dintr-un storcator de fructe putin folosit, pret = 40 lei https://i.postimg.cc/8cnyWp93/motor-Bosh.jpg https://i.postimg.cc/j2WHpz3g/motor-bosch-1.jpg https://i.postimg.cc/rydYXW42/motor-bosch-2.jpg - Modul (recuperat din RCass Unitra Eltra)) radio FM (65,5 - 73 MHz) , echipat cu CI - TA 8164 (Toshiba) , pret = 7 lei https://i.postimg.cc/13Bs4Yjf/modul-radio-FM-1.jpg https://i.postimg.cc/1XhLvpjk/MODUL-RADIO-FM-2.jpg - Placa radio AM / FM , stereo , echipata cu CI ; LA1201 ; BA1320 , CV , bara ferita , comutator game , completa ,componente originale , nu mai stiu provenienta , pret = 20 lei https://i.postimg.cc/02JC8Tr0/placa-radio1.jpg https://i.postimg.cc/bvq09dgm/placa-radio-2.jpg - Mecanica Rcass Unitra Eltra , curata ,fara motor , claviatura , capete redare/inregistrare ; stergere/premagnetizare , tamburi , role complete , etc, pentru piese de schimb , pret = 8 lei https://i.postimg.cc/hPy6QW0z/MECANICA-1.jpg https://i.postimg.cc/TPm4syvg/MECANICA-2.jpg - modul redresare, filtrare si stabilizare preamplificator din dezmembrare amplificator ROTEL RA-500 Pret = 22 Lei https://i.postimg.cc/vmxqnRv2/preamplif-sursa-ROTEL.jpg - Trafo retea recuperat dintr-un PA , tensiuni secundar ; 2 x 27,8V ; 2 x 17,8V ; 3V , dimensiuni tole 90x 70 x 45 mm, complet silentios , ecranat , pret = 40 lei https://i.postimg.cc/gJ0gBL3r/trafo.jpg https://i.postimg.cc/gcxWxn1Y/trafo-2.jpg - Sursa reglabila SMPS , 0-12V / 5A , home made , (echipata cu LM 317 + 2 xTIP 3055), pret = 130lei - negociabil https://i.postimg.cc/xTwQLnMW/sursa3.jpg https://i.postimg.cc/v81HnPCx/SURSA-12-V-FATA2.jpg https://i.postimg.cc/3NLgztCv/SURSA-12-V-LAT.jpg https://i.postimg.cc/MG8j3k2L/SURSA-12-V-INT-1.jpg Link spre comentariu
hamatdumitru Postat Octombrie 18 Partajează Postat Octombrie 18 Rog eu: Amplificator stereo echipat cu CI BA 5406 , 2x5W , include corector ton , volum , parte alimentare , pret = 35 lei , fara carcasa .. https://i.postimg.cc/Hkxp3N31/amplif-5406.jpg https://i.postimg.cc/tgpNLhZb/amplif5406-1.jpg https://i.postimg.cc/3xnyq0P4/amplif-5406-2.jpg Difuzoare nos 10W / 4Ohm , 2 buc. , pret = 8 lei / buc. https://i.postimg.cc/vmKtpNpV/difuzoare-10-W-4-Ohm.jpg Link spre comentariu
vasile barsan Postat Octombrie 18 Autor Partajează Postat Octombrie 18 Acum 2 ore, hamatdumitru a spus: Rog eu: Amplificator stereo echipat cu CI BA 5406 , 2x5W , include corector ton , volum , parte alimentare , pret = 35 lei , fara carcasa .. https://i.postimg.cc/Hkxp3N31/amplif-5406.jpg https://i.postimg.cc/tgpNLhZb/amplif5406-1.jpg https://i.postimg.cc/3xnyq0P4/amplif-5406-2.jpg Difuzoare nos 10W / 4Ohm , 2 buc. , pret = 8 lei / buc. https://i.postimg.cc/vmKtpNpV/difuzoare-10-W-4-Ohm.jpg OK , le pun deoparte pentru dvs. Link spre comentariu
vasile barsan Postat Octombrie 20 Autor Partajează Postat Octombrie 20 Se adauga: DIGITAL LC-ESR metru , la mine aduna praful ,am masurat 2 condensatori in 4 ani.. pret decent = 110 lei ( m-a costat mult mai mult din cate imi amintesc..) https://i.imgur.com/JudvwCC.jpeg https://i.imgur.com/G01LWUH.jpeg https://i.imgur.com/snYWJnB.jpeg https://i.imgur.com/zU7TPJt.jpeg - SIRENA piezo , in carcasa AL , impreuna cu un montaj functional (alarma auto) , extrem de zgomotoasa .. pret = 25 lei (macar pentru piese..) https://i.imgur.com/UZRdLEO.jpeg https://i.imgur.com/WmF7sj3.jpeg Valabile si cele de mai jos: - exponometru SIXTOMAT , piesa de colectie , perfect functional , pret = 80lei - negociabil https://i.postimg.cc/8CCftJhF/EXPONOMETRU-SIXTOMAT2.jpg - aparat foto ZORKI 4 , sovietic , colectibil , perfect functional , pret = 120 lei ,negociabil https://i.postimg.cc/K8W3pcQJ/ZORKI4.jpg https://i.postimg.cc/1zTTzFBw/ZORKI-4.jpg - motor Bosch + modul comanda , recuperat dintr-un storcator de fructe putin folosit, pret = 40 lei https://i.postimg.cc/8cnyWp93/motor-Bosh.jpg https://i.postimg.cc/j2WHpz3g/motor-bosch-1.jpg https://i.postimg.cc/rydYXW42/motor-bosch-2.jpg - Modul (recuperat din RCass Unitra Eltra)) radio FM (65,5 - 73 MHz) , echipat cu CI - TA 8164 (Toshiba) , pret = 7 lei https://i.postimg.cc/13Bs4Yjf/modul-radio-FM-1.jpg https://i.postimg.cc/1XhLvpjk/MODUL-RADIO-FM-2.jpg - Placa radio AM / FM , stereo , echipata cu CI ; LA1201 ; BA1320 , CV , bara ferita , comutator game , completa ,componente originale , nu mai stiu provenienta , pret = 20 lei https://i.postimg.cc/02JC8Tr0/placa-radio1.jpg https://i.postimg.cc/bvq09dgm/placa-radio-2.jpg - Mecanica Rcass Unitra Eltra , curata ,fara motor , claviatura , capete redare/inregistrare ; stergere/premagnetizare , tamburi , role complete , etc, pentru piese de schimb , pret = 8 lei https://i.postimg.cc/hPy6QW0z/MECANICA-1.jpg https://i.postimg.cc/TPm4syvg/MECANICA-2.jpg - modul redresare, filtrare si stabilizare preamplificator din dezmembrare amplificator ROTEL RA-500 Pret = 22 Lei https://i.postimg.cc/vmxqnRv2/preamplif-sursa-ROTEL.jpg - Trafo retea recuperat dintr-un PA , tensiuni secundar ; 2 x 27,8V ; 2 x 17,8V ; 3V , dimensiuni tole 90x 70 x 45 mm, complet silentios , ecranat , pret = 40 lei https://i.postimg.cc/gJ0gBL3r/trafo.jpg https://i.postimg.cc/gcxWxn1Y/trafo-2.jpg - Sursa reglabila SMPS , 0-12V / 5A , home made , (echipata cu LM 317 + 2 xTIP 3055), pret = 130lei - negociabil https://i.postimg.cc/xTwQLnMW/sursa3.jpg https://i.postimg.cc/v81HnPCx/SURSA-12-V-FATA2.jpg https://i.postimg.cc/3NLgztCv/SURSA-12-V-LAT.jpg https://i.postimg.cc/MG8j3k2L/SURSA-12-V-INT-1.jpg Link spre comentariu
sonic11 Postat Octombrie 20 Partajează Postat Octombrie 20 (editat) lc esr-merru îl vreau eu Editat Octombrie 20 de sonic11 Link spre comentariu
vasile barsan Postat Octombrie 20 Autor Partajează Postat Octombrie 20 Acum 16 minute, sonic11 a spus: lc esr-merru îl vreau eu OK , rezervat , vorbim in privat. Link spre comentariu
vasile barsan Postat Octombrie 21 Autor Partajează Postat Octombrie 21 Se adauga astazi: - Statie lipit ZD 98 , folosita , perfect functionala , pret = 55lei https://i.postimg.cc/L63vJ0G5/statie-LIPIT-ZD98.jpg https://i.postimg.cc/2S4YLmrv/statie-lipit2.jpg https://i.postimg.cc/sXBsXWXf/statie-lipit3.jpg - Pistol lipit , 100W , folosit(aproape deloc) , perfect functional , pret = 65 lei https://i.postimg.cc/vHCqFVRL/pistol-lipit1.jpg https://i.postimg.cc/BtfKNsyD/pistol-lipit2.jpg Valabile si cele de mai jos: - SIRENA piezo , in carcasa AL , impreuna cu un montaj functional (alarma auto) , extrem de zgomotoasa .. pret = 25 lei (macar pentru piese..) https://i.imgur.com/kbn0LyP.jpeg https://i.imgur.com/UZRdLEO.jpeg - exponometru SIXTOMAT , piesa de colectie , perfect functional , pret = 80lei - negociabil https://i.postimg.cc/8CCftJhF/EXPONOMETRU-SIXTOMAT2.jpg - aparat foto ZORKI 4 , sovietic , colectibil , perfect functional , pret = 120 lei ,negociabil https://i.postimg.cc/K8W3pcQJ/ZORKI4.jpg https://i.postimg.cc/1zTTzFBw/ZORKI-4.jpg - motor Bosch + modul comanda , recuperat dintr-un storcator de fructe putin folosit, pret = 40 lei https://i.postimg.cc/8cnyWp93/motor-Bosh.jpg https://i.postimg.cc/j2WHpz3g/motor-bosch-1.jpg https://i.postimg.cc/rydYXW42/motor-bosch-2.jpg - Modul (recuperat din RCass Unitra Eltra)) radio FM (65,5 - 73 MHz) , echipat cu CI - TA 8164 (Toshiba) , pret = 7 lei https://i.postimg.cc/13Bs4Yjf/modul-radio-FM-1.jpg https://i.postimg.cc/1XhLvpjk/MODUL-RADIO-FM-2.jpg - Placa radio AM / FM , stereo , echipata cu CI ; LA1201 ; BA1320 , CV , bara ferita , comutator game , completa ,componente originale , nu mai stiu provenienta , pret = 20 lei https://i.postimg.cc/02JC8Tr0/placa-radio1.jpg https://i.postimg.cc/bvq09dgm/placa-radio-2.jpg - Mecanica Rcass Unitra Eltra , curata ,fara motor , claviatura , capete redare/inregistrare ; stergere/premagnetizare , tamburi , role complete , etc, pentru piese de schimb , pret = 8 lei https://i.postimg.cc/hPy6QW0z/MECANICA-1.jpg https://i.postimg.cc/TPm4syvg/MECANICA-2.jpg - modul redresare, filtrare si stabilizare preamplificator din dezmembrare amplificator ROTEL RA-500 Pret = 22 Lei https://i.postimg.cc/vmxqnRv2/preamplif-sursa-ROTEL.jpg - Trafo retea recuperat dintr-un PA , tensiuni secundar ; 2 x 27,8V ; 2 x 17,8V ; 3V , dimensiuni tole 90x 70 x 45 mm, complet silentios , ecranat , pret = 40 lei https://i.postimg.cc/gJ0gBL3r/trafo.jpg https://i.postimg.cc/gcxWxn1Y/trafo-2.jpg - Sursa reglabila SMPS , 0-12V / 5A , home made , (echipata cu LM 317 + 2 xTIP 3055), pret = 130lei - negociabil https://i.postimg.cc/xTwQLnMW/sursa3.jpg https://i.postimg.cc/v81HnPCx/SURSA-12-V-FATA2.jpg https://i.postimg.cc/3NLgztCv/SURSA-12-V-LAT.jpg https://i.postimg.cc/MG8j3k2L/SURSA-12-V-INT-1.jpg Link spre comentariu
vasile barsan Postat Octombrie 22 Autor Partajează Postat Octombrie 22 Se adauga: - Difuzor subwofer , 8 ohm / 75W , diam. = 17 cm , h = 8cm ,stare f.buna , pret = 30 lei - Difuzor subwofer , 8 ohm , diam = 12 cm , stare foarte buna , pret = 18 https://i.postimg.cc/mrRQQ51r/dif-bas-1.jpg https://i.postimg.cc/g2BKPDxc/dif-bas-2.jpg https://i.postimg.cc/W3rRZzBr/dif-bas-3.jpg - Difuri piezo tip horn , noi , nefolosite , 8 ohm , 91 db , 2 buc. , pret = 15lei / buc https://i.postimg.cc/7hwzzBsk/dif-piezo-1.jpg https://i.postimg.cc/CK0wSWzS/dif-piezo-2.jpg - Difuzoare nos 10W / 4Ohm , 2 buc. , pret = 8 lei / buc. Valabile si cele de mai jos: - Sursa reglabila SMPS , 0-12V / 5A , home made , (echipata cu LM 317 + 2 xTIP 3055), pret = 130lei - negociabil https://i.postimg.cc/xTwQLnMW/sursa3.jpg https://i.postimg.cc/v81HnPCx/SURSA-12-V-FATA2.jpg https://i.postimg.cc/3NLgztCv/SURSA-12-V-LAT.jpg https://i.postimg.cc/MG8j3k2L/SURSA-12-V-INT-1.jpg - Statie lipit ZD 98 , folosita , perfect functionala , pret = 55lei https://i.postimg.cc/L63vJ0G5/statie-LIPIT-ZD98.jpg https://i.postimg.cc/2S4YLmrv/statie-lipit2.jpg https://i.postimg.cc/sXBsXWXf/statie-lipit3.jpg - Pistol lipit , 100W , folosit(aproape deloc) , perfect functional , pret = 65 lei https://i.postimg.cc/vHCqFVRL/pistol-lipit1.jpg https://i.postimg.cc/BtfKNsyD/pistol-lipit2.jpg - SIRENA piezo , in carcasa AL , impreuna cu un montaj functional (alarma auto) , extrem de zgomotoasa .. pret = 25 lei (macar pentru piese..) https://i.imgur.com/kbn0LyP.jpeg https://i.imgur.com/UZRdLEO.jpeg https://i.postimg.cc/nhwxyCqb/SIRENA4.jpg - exponometru SIXTOMAT , piesa de colectie , perfect functional , pret = 80lei - negociabil https://i.postimg.cc/8CCftJhF/EXPONOMETRU-SIXTOMAT2.jpg - aparat foto ZORKI 4 , sovietic , colectibil , perfect functional , pret = 120 lei ,negociabil https://i.postimg.cc/K8W3pcQJ/ZORKI4.jpg https://i.postimg.cc/1zTTzFBw/ZORKI-4.jpg - motor Bosch + modul comanda , recuperat dintr-un storcator de fructe putin folosit, pret = 40 lei https://i.postimg.cc/8cnyWp93/motor-Bosh.jpg https://i.postimg.cc/j2WHpz3g/motor-bosch-1.jpg https://i.postimg.cc/rydYXW42/motor-bosch-2.jpg - Modul (recuperat din RCass Unitra Eltra)) radio FM (65,5 - 73 MHz) , echipat cu CI - TA 8164 (Toshiba) , pret = 7 lei https://i.postimg.cc/13Bs4Yjf/modul-radio-FM-1.jpg https://i.postimg.cc/1XhLvpjk/MODUL-RADIO-FM-2.jpg - Placa radio AM / FM , stereo , echipata cu CI ; LA1201 ; BA1320 , CV , bara ferita , comutator game , completa ,componente originale , nu mai stiu provenienta , pret = 20 lei https://i.postimg.cc/02JC8Tr0/placa-radio1.jpg https://i.postimg.cc/bvq09dgm/placa-radio-2.jpg - Mecanica Rcass Unitra Eltra , curata ,fara motor , claviatura , capete redare/inregistrare ; stergere/premagnetizare , tamburi , role complete , etc, pentru piese de schimb , pret = 8 lei https://i.postimg.cc/hPy6QW0z/MECANICA-1.jpg https://i.postimg.cc/TPm4syvg/MECANICA-2.jpg - modul redresare, filtrare si stabilizare preamplificator din dezmembrare amplificator ROTEL RA-500 Pret = 22 Lei https://i.postimg.cc/vmxqnRv2/preamplif-sursa-ROTEL.jpg - Trafo retea recuperat dintr-un PA , tensiuni secundar ; 2 x 27,8V ; 2 x 17,8V ; 3V , dimensiuni tole 90x 70 x 45 mm, complet silentios , ecranat , pret = 40 lei https://i.postimg.cc/gJ0gBL3r/trafo.jpg https://i.postimg.cc/gcxWxn1Y/trafo-2.jpg Link spre comentariu
hamatdumitru Postat Octombrie 22 Partajează Postat Octombrie 22 Rog eu: - Difuzor subwofer , 8 ohm / 75W , diam. = 17 cm , h = 8cm ,stare f.buna , pret = 30 lei - Difuri piezo tip horn , noi , nefolosite , 8 ohm , 91 db , 2 buc. , pret = 15lei / buc Ambele https://i.postimg.cc/7hwzzBsk/dif-piezo-1.jpg https://i.postimg.cc/CK0wSWzS/dif-piezo-2.jpg Link spre comentariu
vasile barsan Postat Octombrie 22 Autor Partajează Postat Octombrie 22 Acum 7 minute, hamatdumitru a spus: Rog eu: - Difuzor subwofer , 8 ohm / 75W , diam. = 17 cm , h = 8cm ,stare f.buna , pret = 30 lei - Difuri piezo tip horn , noi , nefolosite , 8 ohm , 91 db , 2 buc. , pret = 15lei / buc Ambele https://i.postimg.cc/7hwzzBsk/dif-piezo-1.jpg https://i.postimg.cc/CK0wSWzS/dif-piezo-2.jpg OK , le trimit impreuna cu ampliful Link spre comentariu
hamatdumitru Postat Octombrie 23 Partajează Postat Octombrie 23 Rog eu: - SIRENA piezo , in carcasa AL , impreuna cu un montaj functional (alarma auto) , extrem de zgomotoasa .. pret = 25 lei (macar pentru piese..) https://i.imgur.com/kbn0LyP.jpeg https://i.imgur.com/UZRdLEO.jpeg https://i.postimg.cc/nhwxyCqb/SIRENA4.jpg Link spre comentariu
vasile barsan Postat Octombrie 23 Autor Partajează Postat Octombrie 23 1 oră în urmă, hamatdumitru a spus: Rog eu: - SIRENA piezo , in carcasa AL , impreuna cu un montaj functional (alarma auto) , extrem de zgomotoasa .. pret = 25 lei (macar pentru piese..) https://i.imgur.com/kbn0LyP.jpeg https://i.imgur.com/UZRdLEO.jpeg https://i.postimg.cc/nhwxyCqb/SIRENA4.jpg OK, rezervat pentru dvs. Link spre comentariu
