Aparate , module , diverse electronice
vasile barsan
Livrare : Posta Romana ; curier ; livrare personala in Buftea IF.
Conditii de plata : direct in cont bancar ; ramburs ; personal in cazul ridicarii din Buftea
 taxele de expediere / transport sunt suportate de cumparator
Pentru discutii sau alte lamuriri va rog sa  folosim MP sau tel. 0720999779 (de regula raspund prompt)
Se vand urmatoarele (actualizare in ultimul post):
- Kit radio AM  , nemontat , made in China , pret = 35 lei
https://i.postimg.cc/QM78KVF9/radio-KIT-1.jpg
https://i.postimg.cc/ryj8rBwJ/RADIO-KIT-2.jpg
- Trafo retea recuperat dintr-un PA , tensiuni secundar ; 2 x 27,8V  ; 2 x 17,8V  ; 3V , dimensiuni tole 90x 70 x 45 mm, complet silentios , ecranat , pret = 40 lei
https://i.postimg.cc/gJ0gBL3r/trafo.jpg
https://i.postimg.cc/gcxWxn1Y/trafo-2.jpg
https://i.postimg.cc/0NVTQsfM/trafo-3.jpg
- Radiator masiv AL , dimensiuni generoase ,L=150 , l= 90 , aripioare =45 mm , grosime talpa15mm , pret = 28lei
https://i.postimg.cc/02mrJth2/RADIATOR-1.jpg
https://i.postimg.cc/B6kQjDgK/RADIATOR-2.jpg
https://i.postimg.cc/TYrYPKWK/RADIATOR-3.jpg
- PCB probe 9x7cm , 6 buc , pret = 5 lei/buc
- Extractor (gheara) componente electronice , pret = 15 lei
- Magnet puternic cu tija telescopica (extensie max. 60cm) , pret = 15 lei
https://i.postimg.cc/hPwbK3TD/cablaje.jpg
- Converter HDMI - AV , nefolosit (imi trebuia de fapt optic fiber / AV) , pret = 35 lei
https://i.postimg.cc/VLb0Ws0w/converter-hdmi-1.jpg
https://i.postimg.cc/0rgQBmKs/converter-hdmi-2.jpg
- Modul (kit amplificator) LM 386 ,mono , 1W , alimentare 5-12v , 2 buc , pret = 8lei /buc
https://i.postimg.cc/Gt3twrqM/AMPLIF-386-1.jpg
 - Sursa tensiuni multiple : 3,3V  ;  5V ; 23V ; 30V , pret = 15lei
https://i.postimg.cc/PqGqf1Sv/SURSA-MULTIPLA.jpg
- Sursa reglabila SMPS , 0-12V / 5A , home made , (echipata cu LM 317 + 2 xTIP 3055), pret = 130lei - negociabil
https://i.postimg.cc/xTwQLnMW/sursa3.jpg
https://i.postimg.cc/v81HnPCx/SURSA-12-V-FATA2.jpg
https://i.postimg.cc/3NLgztCv/SURSA-12-V-LAT.jpg
https://i.postimg.cc/MG8j3k2L/SURSA-12-V-INT-1.jpg
- Placa de baza PC , model G41T - M7 , echipata cum se vede in poze (procesor ;cooler ; memorii ),perfect functionala , pret =  45 lei
https://i.postimg.cc/zvhd3gMM/PLACA-DE-BAZA-1.jpg
https://i.postimg.cc/cLhFKZ9s/PLACA-BAZA-2.jpg
https://i.postimg.cc/66ZzrCjb/PLACA-BAZA-3.jpg
- SURSA ATX 450W , perfect functionala , pret = 25lei
https://i.postimg.cc/RZcPxs9L/SURSA-ATX-450-W-1.jpg
https://i.postimg.cc/rsB9vWPH/SURSA-ATX-450-W.jpg
  • Răspunsuri 108
  • vasile barsan
    74
  • sonic11
    7
  • Tanase Ion
    7
  • deneinvins
    5
si acestea
Acum 12 ore, Tanase Ion a spus:
Kit radio va rog sa-l.rezervati ptr mine
Si cele 2buc kit 1w cu LM386
si acestea
OK , le pun deoparte
Se adauga astazi, diverse  din proiecte abandonate :
-modul preamplificator doza pickup magnetica,cu integrate Hitachi HA12017 Low Noise Preamp, functional, din dezmembrare amplificator ROTEL RA-500
Pret = 20 lei
- modul redresare, filtrare si stabilizare din dezmembrare amplificator ROTEL RA-500
Pret = 22 Lei
ofer si schema celor doua module
https://i.postimg.cc/vmxqnRv2/preamplif-sursa-ROTEL.jpg
- modul VU meter stereo ,echipat cu BA 6124(x2) , 7 led/canal , probat ,nu mai stiu provenienta , pret = 20 lei
 https://i.postimg.cc/15C1cQpy/VU-meter-1.jpg
https://i.postimg.cc/pVs63ByZ/VU-meter-2.jpg
- modul preamplif. ( Technics , daca imi amintesc bine), pret = 15 lei
https://i.postimg.cc/Hxq9CVDT/Preamplif-TEC-1.jpg
https://i.postimg.cc/wTHDcK94/preamplif-TECHNICS.jpg
- sasiu Rcass   National Panasonic  model RQ-432DS , perfect functional , radio MW ( 525 - 1605 Khz) , SW 1 -( 2,3 - 7 MHZ) ; SW 2 - ( 7 - 22 MHZ) ,extrem de sensibil / selectiv ,  componente originale , fara interventii , parte electronica / mecanica casetofon  impecabila , carcasa se ofera bonus deoarece lipseste geamul scalei ,are lipsa capacul bateriilor si o  parte din partea superioara + crapaturi..  ( are manerul si antena originale), pret = 40 lei
https://i.postimg.cc/3xwhGwV8/national-panasonic-cablaj.jpg
https://i.postimg.cc/kMhvCYCT/national-panasonic-mecanica.jpg
https://i.postimg.cc/Y25K93fx/afisor-1.jpg
- CARCASA  metalica GRUNDING , recuperata , dimensiuni : L= 35 cm ; l = 27 cm  ; h =5 cm , pret = 20 lei
https://i.postimg.cc/kg74p9Hz/CUTIE-1.jpg
https://i.postimg.cc/fyZyQNLV/CUTIE-2.jpg
https://i.postimg.cc/NF1sdPkQ/CUTIE-3.jpg
https://i.postimg.cc/SsLQrvrk/CUTIE-4.jpg
-modul  afisor recuperat , pret = 5 lei
https://i.postimg.cc/bNxMvjvz/afisor.jpg
 Exact pentru modulul preamplif  de mai sus
Pret = 22 Lei
Vumetru il vreau eu
Si modulul preamp hitachi de doza magnetica
Si carcasa de Grundig
Vă rog pentru mine:
Mulțumesc
..colegul George a fost mai rapid…
Acum 1 oră, Tanase Ion a spus:
Vumetru il vreau eu
In regula , le pun alaturi de celelalte rezervate de dvs..
Acum 1 oră, George a spus:
Modul preamplif. Technics, pret = 15 lei il vreau eu.
Il pun deoparte  pentru dvs..
Buna seara, se pot trimite cand puteti si aveti timp, nu e graba, cu stima multumesc frumos.
 Se adauga astazi:
 - Difuzor (recuperat) Tonsil (Pioneer license) , impecabil , 4W / 8 Ohm , dimensiuni 16x10 cm , pret = 15 lei
https://i.postimg.cc/j2b50n1f/dif-TONSIL-1.jpg
https://i.postimg.cc/zX3BmNt0/DIF-TONSIL-2.jpg
- Modul (recuperat din RCass Unitra Eltra)) radio FM (65,5 - 73 MHz) , echipat cu CI - TA 8164 (Toshiba) , pret = 7 lei
https://i.postimg.cc/13Bs4Yjf/modul-radio-FM-1.jpg
https://i.postimg.cc/1XhLvpjk/MODUL-RADIO-FM-2.jpg
,- Boxa center sistem Genius , contine 2 buc difuzoare 15W / 4 Ohm inseriate , carcasa in stare foarte buna . dimensiuni 33x16x14 cm , pret = 35 lei
https://i.postimg.cc/2SZ9Kq4m/BOXA-GENIUS-2.jpg
https://i.postimg.cc/gkfN8Y17/BOXA-GENIUS-1.jpg
https://i.postimg.cc/FKvpCTrg/BOXA-GENIUS-3.jpg
 - Placa radio AM / FM , stereo , echipata cu CI ;  LA1201  ; BA1320 , CV , bara ferita , comutator game , completa ,componente originale , nu mai stiu provenienta , pret = 20 lei
https://i.postimg.cc/02JC8Tr0/placa-radio1.jpg
https://i.postimg.cc/bvq09dgm/placa-radio-2.jpg
 - Placa AF  RCass UNITRA ELTRA , echipata cu CI ; UL1497 , mufe si ce se mai vede in poze , pret = 10lei
https://i.postimg.cc/FKnZFNbG/PLACA-AMPLIF-UNITRA.jpg
https://i.postimg.cc/1tnKf2JS/PLACA-AMPLIF-UNITRA1.jpg
https://i.postimg.cc/PrzQpmzC/PLACA-AMPLIF-UNITRA-2.jpg
https://i.postimg.cc/K807QxWF/MUFE-PLACA-UNITRA.jpg
 - Mecanica Rcass Unitra Eltra , curata ,fara motor , claviatura , capete redare/inregistrare ; stergere/premagnetizare , tamburi , role complete , etc, pentru piese de schimb , pret = 10 lei
https://i.postimg.cc/hPy6QW0z/MECANICA-1.jpg
https://i.postimg.cc/TPm4syvg/MECANICA-2.jpg
 - Partea de alimentare , redresare/stabilizare (transformator ecranat , silentios)din acelasi RCass Unitra  , pret = 20 lei
https://i.postimg.cc/htnsG2kz/ALIMENTATOR-UNITRA-1.jpg
https://i.postimg.cc/mr577j5S/ALIMENTATOR-UNITRA-2.jpg
Raman valabile:
 - modul  afisor recuperat , pret = 5 lei
Pret = 22 Lei
- Sursa tensiuni multiple : 3,3V  ;  5V ; 23V ; 30V , pret = 15lei  10 lei
- Placa de baza PC , model G41T - M7 , echipata cum se vede in poze (procesor ;cooler ; memorii ),perfect functionala , pret =  45 lei  30 lei
Dacă mai sînt valabile, vă rog să rezervați următoarele :
Detalii prin MP. Mulțumesc !
Acum 15 minute, deneinvins a spus:
In regula , rezervate pentru dvs ,multumesc si eu!
Acum 3 minute, deneinvins a spus:
În imaginea alăturată, se văd două module. Cel din stînga, mai este valabil ?
Dacă da, vă rog să-l rezervați. Dacă nu, asta e. Cel din dreapta nu mă interesează.
- modul redresare, filtrare si stabilizare din dezmembrare amplificator ROTEL RA-500, Pret = 22 Lei
Cel din stanga este preamplificatorul revendicat deja .Cel din dreapta este modulul de alimentare (+16v)-GND- (-16v) al preamplifului - valabil inca..
