Coduri pentru radiocasetofoane și radio-cd auto
goznerg
1 hour ago, Dex said:
salut! ma poate ajuta  vreun coleg care se pricepe la media nav Dacia?
unitatea in cauza este LAN5200WR1
HW VER 1.6.2
SW VER 2.0.9
problema consta in restart la fiecare 50 secunde
apare logo ul apoi o ia de la capat.
am incercat cu un fisier nk file dar banuiesc ca nu este pentru versiunea mea pentru ca nu il vede,
in acelas timp am incercat usb debugging cu un serial adapter la 115200 baudrate si unitatea imi afiseaza asta (atasez la final )  am vazut ceva pe niste forumuri cum ca s- ar pune un sdhc card in locul memoriei interne dar banuiesc ca tot o sa am nevoie sa intru in windows.
daca e vreun coleg pe aici care ar putea sa ma ajute, as fi recunoscator!
LGE ULC Bootloader (23:21:42 Nov 11 2014)
ULC AutoBoot, Revision Micron_0.0.4
Car type is 0
Select boot sequence.
        1: nK.bin -> nA.bin -> nB.bin
        2: nA.bin -> nB.bin
        3: nB.bin
        E: nC.bin
first files : nk.bin
files: 9FCFAB00, address: 9FCFAB18, jump: 0
........................................................................................................................                ..............................High Capacity = 1
CID MID Version 0x45 , Sd_info_MID 0x45
CSD Version 3
CSD MMC spec version 4
sd_init: bus width 4
Card Status : 0x900, CardLock:0x0
FAT Info:
     OEMName: 'MSWIN4.1'
  filesystem: FAT32
  sectorSize: 512
 sectorCount: 1444662
 clusterSize: 4096
  clusterCnt: 180402
 BPB_NumFATs: 1
     fatSize: 1411
 numRootDirE: 0
 dirEPerSect: 16
 sectorsRoot: 0
 ReservedCnt: 32
  fstDataSec: 1443
 sectPerClus: 8
 rootSector: 62
    diskSize: 722331K
Loading Image: nk.bin       (Format = CE-BIN)
Image Info:
 Address: 0x80100000
  Length: 16951196 bytes
Image Loaded Successfully.
Boot from eSD/eMMC mass storage
Program Entry Point: 80100004
Executing Application
OS is booting 0
Windows CE Kernel for MIPS Built on Mar  8 2013 at 17:06:06
+OEMInit
Address OEMTlbMissHandler 801043D8
LGE ULC
Cold Boot
+OEMInterruptInit
+OEMInterruptInit Disable All...
+OEMInterruptInit Parsing Platform GPINT Configuration table...
DONE
-OEMInterruptInit
Using RTCTICK tick source
Au13xx AA (PRId 800C8001) @ 660MHZ
-OEMInit
[SF][OAL] loader pool:8388608, file pool:10485760
[SF][OAL] no OEMIdle
pBootArgs->BootVer: 1042014
Initializing PSC3 for SMBUS operation
Initializing PSC2 for I2S operation
SetADCSampleRate : 48000 ***********
SetDACSampleRate : 48000 -------------
Initializing PSC0 for I2S2 operation
MEMPOOL: Built on Nov 28 2014.11:54:44
MEMPOOL: Found      MAE Memory Region(0). Phys:0x01D00000 Virt:0xD05D0000 Size:0x00100000
MEMPOOL: Found      ITE Memory Region(1). Phys:0x0D200000 Virt:0xD06F0000 Size:0x00500000
MEMPOOL: Found      LCD Memory Region(2). Phys:0x0D700000 Virt:0xD0BF0000 Size:0x00600000
BSA: Driver, v1.2 Sep 26 2011.23:43:31
ITE: Driver, v1.0 Sep 26 2011.23:43:31
MPE: Driver, v1.2 Sep 26 2011.23:43:32
[DRVMGR] BT reset
[DRVMGR] Driver Manager is initialized. (Nov 28 2014 at 11:54:57)
SDIOInitializeSlot:: Slot:0x0
SDIOSDSlotOptionHandler - called - SetSlotInterface : Clock Setting: 100000
SDIOSDSlotOptionHandler - called - SetSlotInterface : setting for 1 bit mode
 ManufactuerID: 0x45
SDIOSDSlotOptionHandler - called - SetSlotInterface : Clock Setting: 20000000
SDIOSDSlotOptionHandler - called - SetSlotInterface : setting for 4 bit mode
 ManufactuerID: 0x45
 ManufactuerID: 0x45
USBware::DllMain: Attach called - Current Process: 0x00000042, ID: 0x00400002
USBware::DllMain: Detach called - Current Process: 0x00000042, ID: 0x00400002
USBware::DllMain: Started hModule 0x8A0D5F30, dwReason 1
USBware::UDD_Init: Starting pContext 0xD030EB88
UDD_Init:RegQueryValueEx(EnableStack) failed
bsp_pre_init: h/w init type 2012
USBware::UWD_Init: Starting pContext 0xD030EB88
USBware version 3.5.14.82
ehci_local0: EHCI version 1.0, with 2 ports
ehci_local0: companion controllers, 1 port each
ehci_local0: USB revision 2.0
ehci_local0: new device, port=0 depth=0 speed=high
ehci_local0: - Jungo Generic Root Hub, class 9/0, rev 0.20/af.00, addr 1
uhub0: 2 ports with 2 removable, self powered
ohci_local0: OHCI version 1.0, legacy support
ohci_local0: USB revision 1.0
ohci_local0: new device, port=0 depth=0 speed=full
ohci_local0: - Jungo Generic Root Hub, class 9/0, rev 0.11/af.00, addr 1
uhub1: 1 port with 1 removable, self powered
+MAL_PowerUp
-MAL_PowerUp
Mali200/GP2.
                   Compiled: Jun 16 2010, time: 17:11:08.
                    Variant: mali200-maligp2-udd-windowsce-gles11-gles20-vg-mmu-r0p4-drawmerge
      MALI_MEMORY_IS_CACHED: 1
                MEMCPY_FAST: 1
  __PLATFORM_MAX_DR_BUFFERS: 4
[SF][PHYMGR] PHYMGR Driver is initialized. (Jun  2 2014 at 20:23:57)
Window(0)              Desktop Config. Pipe:1 Priority:0
Window(1)                  MAE Config. Pipe:0 Priority:3
Window(2)            OpenGL/3d Config. Pipe:0 Priority:1
Window(3)           DirectDraw Config. Pipe:0 Priority:2
Using panel 11 Innonux 800x480 BPP:16
fbsize: 2863104, 002bb000
AllocPhysMem(): p=0D700000 v=D18A0000
-OEMInterruptConnectTimer() = 25(i::1)
[LAUNCHER] ULC launcher started. (Nov 27 2014 at 15:50:14)
[DRVMGR] enable USB phy
[LAUNCHER] Searching Startup...........................................................................................................................................................................................................[LAUNCHER] Launching startup.
Car type is 0
        2: nA.bin -> nB.bin
        3: nB.bin
        E: nC.bin
......................................................................................................................................................High Capacity = 1
CSD Version 3
FAT Info:
     OEMName: 'MSWIN4.1'
  filesystem: FAT32
  sectorSize: 512
 clusterSize: 4096
  clusterCnt: 180402
 BPB_NumFATs: 1
     fatSize: 1411
 numRootDirE: 0
 dirEPerSect: 16
 sectorsRoot: 0
 ReservedCnt: 32
  fstDataSec: 1443
 sectPerClus: 8
 rootSector: 62
    diskSize: 722331K
Image Info:
 Address: 0x80100000
Aapare Renault by LG ?
Acum 12 minute, maxim_sedilec a spus:
buna ziua, \caut si eu un cod pentru un "radio"  BMW e39 530d
e marca ALPINE serial No AL 3910 6 10 38638A
Ai 02 index 18 kw 43/06
multumesc
Buna
Incercati ....42278.......
Seara faina
Acum 3 minute, eos a spus:
Buna ziua. La aparatul de mai jos se poate afla codul din seria lui ?
Se poate si dupa serie dar sunt costuri!
Acum 4 minute, eos a spus:
Si alta metoda mai ieftina care credeti ca ar fi, se poate citi din memorie cevva ?Multumesc
Cititi eeprom 95640 si postati dump aici!!!!
Buna ziua
Va mai deranjez cu o intrebare. LA modelul de aparat in poza de mai jos cum se poate citui procesoru nec ?
Am inteles ca jumate din cod este in memoria 95128 si cealalta jumate e in nec. Va rog sa imi dati ceva detalii cum pot si cu se se poate citi.
