ph3e4r Postat Ianuarie 15, 2008 Partajează Postat Ianuarie 15, 2008 Am incercat sa configurez un server de pppoe, si ceva nu merge poate aveti vreo idee. options lockmru 1492mtu 1492proxyarppppoe-server-options require-paploginlcp-echo-interval 10lcp-echo-failure 2pap-secrets # Secrets for authentication using PAP# client server secret IP addresses* * "" *log Jan 16 16:41:40 localhost pppoe-server[3688]: Session 1 created for client 00:e0:18:be:a2:a5 (192.168.0.10) on eth1 using Service-Name 'PPPoE7'Jan 16 16:41:40 localhost pppd[3688]: pppd 2.4.4 started by root, uid 0Jan 16 16:41:40 localhost pppd[3688]: Using interface ppp0Jan 16 16:41:40 localhost pppd[3688]: Connect: ppp0 <--> /dev/pts/2Jan 16 16:42:11 localhost pppd[3688]: LCP: timeout sending Config-RequestsJan 16 16:42:11 localhost pppd[3688]: Connection terminated.Jan 16 16:42:11 localhost pppd[3688]: Modem hangupJan 16 16:42:16 localhost pppd[3688]: Exit. ifconfig eth1 eth1 Link encap:Ethernet HWaddr 00:06:5B:6B:3B:E3 inet6 addr: fe80::206:5bff:fe6b:3be3/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:228389 errors:0 dropped:0 overruns:1 frame:0 TX packets:56 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:19746457 (18.8 MiB) TX bytes:3756 (3.6 KiB) Interrupt:11 Base address:0xa800uname -r [root@localhost ppp]# uname -r2.6.23.9-85.fc8 La conectare primesc error 619. Ma puteti ajuta sa deslusesc problema? Va multumesc. Link spre comentariu
Blind Postat Ianuarie 15, 2008 Partajează Postat Ianuarie 15, 2008 Dupa cate minte google, fie portul pe care te conectezi e ocupat de altceva, fie datorita clientului VPN facut de microsoft (asta e mentionata mai des pe net). Link spre comentariu
MifTy Postat Ianuarie 17, 2008 Partajează Postat Ianuarie 17, 2008 în slackware zice c? placa de re?ea pe care faci PPPoE trebuie s? fie pornit?, dar NU configurat?!!!!?i ?la e clientul PPPoE pur, nemodificat, cu readme-ul neatins, scos de Roaring Penguin... Link spre comentariu
ph3e4r Postat Ianuarie 17, 2008 Autor Partajează Postat Ianuarie 17, 2008 am rezolvat Link spre comentariu
ph3e4r Postat Ianuarie 18, 2008 Autor Partajează Postat Ianuarie 18, 2008 pe fedora core 8 problema era ca intra in conflict cu syslogd si cu klogd inca nu am stat sa vad daca e din cauza la os sau la pachetul nou. Imi poti lasa te rog un mp cu id-ul tau ca vreau sa vorbesc ceva cu tine Link spre comentariu
luciann Postat Februarie 21, 2008 Partajează Postat Februarie 21, 2008 Am si io o intrebare legata de PPPoE, cum configurez PPPoE in fedora? Link spre comentariu
MifTy Postat Aprilie 10, 2008 Partajează Postat Aprilie 10, 2008 scrii intr-un terminal root "pppoeconf", si urmezi sfaturile de pe ecran...asta daca vine cu rpppoe preinstalat. daca nu... poate ai noroc, si e un pachet instalabil pe vre-unul din cd-uri. sau dvd-uri...din motive obiective, am instalat kubuntu, ca doar asta incape pe harduletzu meu de 3 gigei, celelalte 2 sunt pline pana la refuz de date...ma capiaza ca nush de ce naiba da eroare la boot pppoe-ul... tre sa-l pornesc manual din terminal de vre-o doua ori cu "pon dsl-provider"da' lasa, ca nu mai e mult, si golesc macar jumate, adica o partitie de 40 de gigi, si bag gentoo :P Link spre comentariu
yo9hnf Postat Aprilie 10, 2008 Partajează Postat Aprilie 10, 2008 comanda PPPOECONF sau defapt SUDO PPPOECONF mie mi-a mers perfect pe UBUNTU ( in mod de consola, adica cu o interfata grafica de consola ), si pe Kubuntu (cred ultima versiune) mi-a mers tot super, doar ca la configurare, interfata era complet grafica.Nu mai stiu sigur, dar cred ca mi-a mers si pe PcOS. Link spre comentariu
MifTy Postat Aprilie 10, 2008 Partajează Postat Aprilie 10, 2008 problema e ca in ubuntu/kubuntu si posibil si in alte distroaie, desi se ofera sa ti-l bage in startup, nu stiu de ce naiba da eroare, si conexiunea moare!!!asa ca tre pornit manual, dintr-o consola root, cu pon dsl-provider!!!pe slackware nu mi-a facut figura asta, nush de ce...offtopic:slackul mi se pare cel mai usor de configurat, dar habar n-are de dependinte tgz-ul ala!!!si daca nu esti un ubergeek care stie si sculat din somn ce dependinte are fiecare pachet, si mai ales, in ce ordine, dreq te-a luat incercand sa le rezolvi manual!!!!debianul are un suport de dependinte nemaipomenit, fapt dovedit si de imensitatea repourilor cu soft precompilat disponibile online!!! insa interfata de instalare nu e foarte noob-friendly, asa ca daca n-ai cateva instalari usor ratate la activ, dureaza ceva pana il instalezi ok...din motivele de mai sus, e plin de distributii debian-based, care au mai degraba rolul de installer simplu si usor!!!iar BSD... cred ca sistemul ala al lui de partitionare a fost inventat de un klingonian, ca ma uit ca vaca la schema aia, si ma pierd instant!!!!(da, skaarj, iti dau voie sa razi!!!! de fapt, poti sa razi si fara sa-ti dau eu voie!!! :smt019 ) Link spre comentariu
ratza Postat Aprilie 10, 2008 Partajează Postat Aprilie 10, 2008 La mine porne?te odat? cu startup. Link spre comentariu
