Condensatoare, lampi, tranzistoare, IC si altele
Ned George
O lista cu surplus de componente.
Comanda minim 100 lei si minim 5 lei dintr-o pozitie, functie de comanda si stoc unele preturi se pot negocia.
Poze in galerie https://postimg.cc/gallery/PYBbNT2
inv denumire valoare tip brand pret RON
    CONDENSATORI THT RADIAL
E28 Condensator 2,2nF/500/760/1500VDC CERAMIC VISHAY 0,2
E46 Condensator 4,7nF/500/760/1500VDC CERAMIC VISHAY 0,3
E103 Condensator 22nF/350/1000VDC MKP VISHAY 0,5
E11 Condensator 100nF/630VDC/305VAC X2 MKP EPCOS 0,7
E102 Condensator 560nF/630VDC/305VAC X2 MKP EPCOS? 0,8
E81 Condensator 10uF/63V Electrolitic NIPPON-CHEMICON 0,33
E16 Condensator 10uF/450V Electrolitic RUBYCON 0,7
E21 Condensator 22uF/450V Electrolitic RUBYCON 1,5
E15 Condensator 47uF/35V Electrolitic RUBYCON 0,4
E17 Condensator 47uF/400V Electrolitic NIPPON-CHEMICON 2,5
E18 Condensator 47uF/400V Electrolitic JIANGHAI 1,8
E19 Condensator 100uF/25V Electrolitic NICHICON 0,4
E14 Condensator 1000uF/25V Electrolitic SANWA KOREA 1,1
E26 Condensator 1000uF/25V Electrolitic RUBYCON 1,2
E22 Condensator 2200uF/6,3V Electrolitic TEAPO 1,1
E56 Condensator 5600uF/6,3V Electrolitic PANASONIC 1,5
E12 Condensator 12000uF = 12mF/25V Electrolitic NIPPON-CHEMICON 2,5
    CONDENSATORI SMD
E49 Condensator 220pF/25V CERAMIC pe REEL 0,05
E48 Condensator 10nF/25V CERAMIC pe REEL 0,05
    INDUCTOR THT
E29 Șoc retea 2x 47mH/0,3A/2,6ohm 7446120047 WE-LF Wurth Electronic 5
E42 General 1mH/0,3A/1,84ohm 744772102 Wurth Electronic 1,5
E83 Șoc retea 2x 47mH 0,25A 250V 2,4 ohm B82791H2251N20Z99 EPCOS 3
E112 General 150uH 175mA axial   0,2
    INDUCTOR SMD
E67 General 10μH 1910mA 49mΩ A921CY-100M=P3 Murata 0,3
E104 General 330μH 650mA 1Ω SMTDR75-331M 3Lcoil 0,3
E71 General 1mH 0.2A  3,3 ohm OWI75-102K-T1 OLE WOLFF 0,25
    DIODE THT
E43 440V 1500W bi 1.5KE440A bi TRANSIENT SUPPRESSOR EICsemi 0,5
E44 IR emitting  L-53F3BT blue 5mm 940nm Kingbright 0,1
E45 rect GP02-35 250mA 3,5KV VISHAY 0,4
    DIODE SMD
E30 Prot. ESD PESD5V0L1UB bi ESD protection SOD323 Nexperia 0,15
E50 Schottky  BAS85-GS08 30V 0,2A 5ns 200mW SOD80 VISHAY 0,05
E51 zener BZX84C9V1LT1G 9,1V 250mW SOT 23 Onsemi 0,15
E65 rectifier E52G - E3/5BT 2A 400V DO214AA VISHAY 0,1
E77 rectifier S1M-13-F 1A 1000V 1.8uS SMA-2 DIODES Inc. 0,2
E82 Genpurp, sw LL4150GS08 50V; 0,6A; 4ns; SOD80 VISHAY 0,15
E61 Schottky rect. STPS1L40U 1A, 40V, lowVf, DO-214AA STM 0,3
E105 rectifier GS2Y-LPT 1,5A 1,6KV DO-214AC MCC 0,25
E106 30V 400W bi P4SMA30CA  DO-214AC bi TRANSIENT SUPPRESSOR Littelfuse 0,5
    REZISTENTE THT
E96   2R2 0,5W 5%   VISHAY 0,06
E94   9R31 0,6W 1%   VISHAY 0,05
E93 WP4S-10RJA1 10R 4W 5% vertical THT RM5   0,7
E85   15R 3w 5%     0,5
E89   27R 7W 5%     0,8
E88 Mox 100R 2W 5%     0,5
E92   100R 3W 5% FUSIBLE WIREWOUND VISHAY 0,5
E97   200R 4W 5%     0,6
E95   470R 0,6W 1%   VISHAY 0,2
E91   2K7 0,5W 5%   VISHAY 0,05
E90   120K 2W 5%     0,5
    REZISTENTE SMD
E54 thick film 470R 5% CRCW0603470RJNEA VISHAY 0,05
E52 MELF resistor 100K 1% 0,25W 50ppm SMM02040C1003FB300 VISHAY 0,1
E53 MELF resistor 120K 1% 0,25W 50ppm MMA02040C1203FB300 VISHAY 0,1
    IC THT SI SMD
E63 8 bit contrioller PIC16C64A-10I/L PLCC-44 MICROCHIP 10
E64 32 bit MCU ARM STM32F030CCT6TR 48-LQFP STM 7
E40 voltage ref. LM4041C12ILPR  TO-92, 1.225V TEXAS INSTRUMENTS 0,7
E33 optocuplor ISP621-2GB 2 ch DIP-8 ISOCOM 1,5
E60 optocuplor 6N137STA1-V-H 1 ch DIP-8 LITEON 0,3
E68 DC-DC converter MC34063EBD-TR SOP-8 STM 2
E69 optocuplor IS181DTR-ND 1 ch SMD-4 ISOCOM 0,25
E70 optocuplor VO615A-4X009T 1 ch DIP-4 VISHAY 0,15
E84 tranzistor BCX70H NPN 45V 0.1A 0.3W SOT23 Nexperia 0,05
E76 optocuplor IS2701-1 1 ch SOP-4 ISOCOM 0,5
E78 optocuplor SFH6156-2T 1 ch SMD-4 VISHAY 0,3
E79 fototranzistor LPT3333A THT 5mm transparent   0,05
    DIVERSE
E23 releu bistabil 725DR-R1A-B020-009/R180 250V 100A 12V shunt 180 uohm GRUNER 65
E59 releu bistabil HFE62/9 - 1HDST - L2 380V 8A coil 9V Hongfa 4
E13 releu   DM05-3021-35-S003 1NO SPST coil 3V 5-10A/1250W DURAKOOL 2
E31 terminal block TL308V-9000-02P 2 poli PCB 5mm 320V 15A surub 0,2-1,5mmp   0,15
E27 terminal block 6 poles tension spring 24A PCB 5mm  18-24 awg Hartmann 0,6
E32 terminal block 600V / 30A 2 poli PCB 10AWG pitch 9.52mm SAURO 0,5
E37 microswitch DM1-01P-30-3 short lever 1A/125V   0,3
E38   miniantena GSM SMA tata 3,5 cm   15
E58 varistor  V510LA40AP diam. 14mm 510V Littelfuse 0,35
E55 varistor  TMOV14RP510E diam. 14mm 510V Littelfuse 0,35
E57 cristal cuart 12.8 Mhz HC49/US 30ppm  30 pF THT   0,5
E107 cuart ceas 32768Hz 5ppm 12,5pF CFS-20632768HZFB CITIZEN 0,5
E47 cristal cuart 8Mhz 16pF 50ppm SMT 13X4,8X4,5mm   0,5
E125 filtru cuart MCF10,7-15E filtru 5 celule 10,7Mhz banda +/-7,5khz Bulgaria 25
E62 push switch KSC401J50SHLFS CK IP67 SMT 32V 50mA C&K 1,4
E39 cablu antena 10cm coax 2mm, 2 conectori     3,5
E66 switch detector SPVE110900 slider 4,8mm SMD ALPS 0,25
E108 baterie litiu CR 2032 SC PCBD PCB THT P/N 004749 REV.407 VARTA 1
E109 baterie litiu CR 2032HT PCB THT 3V  EVE 1
E110 baterie litiu XL-050F 3,6V XENOENERGY KOREA   2,5
E111 baterie litiu EL29 4V     3
E159 tranzistor RF 2N4933 Romania, anii 80   10
E160 tranzistor 2N3442 recuperati, verificati SESCOSEM 7
E161 tranzistor BUX80 TO-3 PHILIPS 10
E162 tranzistor RF BLX14   PHILIPS 20
E163 tranzistor KU607 TO-3 TESLA 5
E164 stab. Tens MA7824 voltage regulator 24V TO-3 TESLA 5
E165 tranzistor AC180   IPRS 2,5
E166 tranzistor AC185   IPRS 2,5
E167 tranzistor 2N3055 TO-3 IPRS 5
    TUBURI ELECTRONICE
E150 DUBLA TRIODA 6N1P Voshod, anii 70 CCCP 15
E151 DUBLA TRIODA 6N3P Reflector, anii 80 CCCP 10
E152 DUBLA TRIODA 6N3P-E Reflector, anii 80 CCCP 12,5
E153 DUBLA TRIODA 6N3P-EV Reflector, anii 80 CCCP 15
E154 DUBLA TRIODA 6N6P NEVZ, anii 70 CCCP 20
E155 DUBLA TRIODA 6N8S NEVZ, anii 70 CCCP 20
E156 VOLT REGUL. SG1P   CCCP 6
E157 pentoda 12J1L Reflector, anii 80 CCCP 6
E158 pentoda DHT 2J27L Reflector, anii 80 CCCP 7
E168 VOLT REGUL. SG2S fara cutiile albe CCCP 10
  • Răspunsuri 21
  • Ned George
    9
  • arossiro
  • terciziu
  • darius_bv
2 hours ago, grosu99 said:
Poate ar trebui sa reduceti valoarea minima la 50 de lei.Cred ca ar cumpara mai multi ....
E limita ce mi-a parut rezonabila atat pentru mine cat si pentru un potential doritor.
  • 2 săptămâni mai târziu...
On 2/10/2024 at 10:46 AM, terciziu said:
Va salut,
Va rog E48 si E49 cate 1000 buc din fiecare si E62 100 buc.
 (pot sa achit cu mandat postal online, bine o sa fie asa?...sau?)
Multumesc
Rezolvat. Totul ok?
La 22.02.2024 la 22:01, Ned George a spus:
Rezolvat. Totul ok?
Da, in regula totul, multumesc frumos.
(multumesc frumos si pentru ceea ce ati in plus...consistent)
5 hours ago, arossiro said:
Pozitia E155 aveti 10 buc
Am chiar si cutie de fabrica sigilata cu 100 bucati deci 10 bucati binenteles ca am, garantez ca sunt nefolosite (NOS) si functionale. Verificate si fisa de test pentru fiecare tub costa 7 lei in plus/tub. Ce se vede in poze este exact stocul actual, nu sunt poze de pe net
Pretul e pentru 6n8s NEVZ luate la rand din cutie. Am si FOTON din 67, selectii perechi / quaduri dar la alte ptreturi.
In foto cum arata o fisa de test, tubul respectiv e o raritate, perfect balansat.
Un exemplu de selectie pentru audiofili pretentiosi 6n8s pereche matched FOTON 1967 export cu datasheet in engleza.
Pretull este 150 lei pentru selectie +/-5% si 200 lei pentru +/-2,5%.
15 hours ago, arossiro said:
As dori E155 - 10 buc si E153-6 buc.Se poate transport prin Posta Romana, cu rambursul si transportul platit de mine?
Lampi am, se poate prin posta dar exclus rambursul. Dati-mi mesaj privat cu nr. de tel si va sun sa stabilim.
