gigione01 Postat Ianuarie 18, 2024 Partajează Postat Ianuarie 18, 2024 Vand acest swich nou impreuna cu manualul de folosire. Pretul este de 1500 lei negociabil. Pretul de magazin se vede in ultima poza. Trimit prin curier. PLANET IGS-4215-16T2S. De tip Switch: Gestionate, Strat Switch: L2/L4. Tip de porturi Ethernet Basic switching RJ-45: Gigabit Ethernet (10/100/1000), Număr de porturi Ethernet Basic switching RJ-45: 16, Port consolă: RJ-45. Duplex complet. Mărimea tabelei de adresare: 8000 intrari, Capacitatea de comutare: 36 Gbit/s. Reţea standard: IEEE 802.1D, IEEE 802.1Q, IEEE 802.1ab, IEEE 802.1p, IEEE 802.1s, IEEE 802.1w, IEEE 802.1x, IEEE.... Tensiune intrare CC: 12 - 48 V. Hardware SpecificationsCopper Ports16 10/100/1000BASE-T RJ45 auto-MDI/MDI-X portsGigabit SFP Slots2 100/1000BASE-SX/LX/BX SFP interfacesConsoleIGS-4215-16T2S:1 RJ45 serial port (115200,8, N, 1) IGS-4215-16T2S-U:1 Micro-USB female port (115200,8, N, 1)RAM128MbytesFlash Memory16MbytesReset Button< 5 sec: System reboot > 5 sec: Factory defaultConnectorRemovable 6-pin terminal block for power input Pin 1/2 for Power 1 Pin 3/4 for fault alarm Pin 5/6 for Power 2AlarmOne relay output for power failure. Alarm relay current carry ability: 1A @ 24V DCPower RequirementsIGS-4215-16T2S: Dual 12~48V DC 24V AC IGS-4215-16T2S-U: Dual 9~48V DC 24V ACPower ConsumptionIGS-4215-16T2S: DC input: Max. 3.4 watts/11.6BTU (System on) Max. 12.5 watts/42.7BTU (Full loading) AC input: Max. 6 watts/20.5BTU (System on) Max. 15 watts/51.2BTU (Full loading) IGS-4215-16T2S-U: DC input: Max. 3.31 watts/11.3BTU (System on) Max.10.41 watts/35.5BTU (Full loading) AC input: Max. 3 watts/10.2BTU (System on) Max. 10 watts/34.1BTU (Full loading)Dimensions (W x D x H)66 x 107 x 152 mmWeightIGS-4215-16T2S:813g IGS-4215-16T2S-U:829gEnclosureIP30 metal caseInstallationDIN-rail kit and wall-mount earESD Protection6KV DCLEDSystem Green: Power 1 Green: Power 2 Red: Power Fault Per 10/100/1000T RJ45 Ports Green: 1000 LNK/ACT Orange: 10/100 LNK/ACT Per SFP Interface Green: 1000 LNK/ACT Orange: 100 LNK/ACTSwitching SpecificationsSwitch ArchitectureStore-and-ForwardSwitch Fabric36Gbps (non-blocking)Switch Throughput@64 bytes26.79Mpps@ 64 bytesMAC Address Table8K entriesShared Data Buffer4.1MbitsFlow ControlIEEE 802.3x pause frame for full duplex Back pressure for half duplexJumbo Frame10 KbytesLayer 2 FunctionsPort MirroringTX/RX/Both Many-to-1 monitor Up to 4 sessionsVLAN802.1Q tagged-based VLAN Up to 256 VLAN groups, out of 4094 VLAN IDs 802.1ad Q-in-Q tunneling (VLAN stacking) Voice VLAN Protocol VLAN Private VLAN (Protected port) GVRPLink AggregationIEEE 802.3ad LACP and static trunk Cisco ether-channel (Static Trunk) Up to 8 trunk groups Up to 8 ports per trunk group with 16Gbps bandwidthSpanning Tree ProtocolIEEE 802.1D Spanning Tree Protocol (STP) IEEE 802.1w Rapid Spanning Tree Protocol (RSTP) IEEE 802.1s Multiple Spanning Tree Protocol (MSTP) STP BPDU Guard, BPDU Filtering and BPDU ForwardingIGMP SnoopingIPv4 IGMP snooping v1, v2, v3 IGMP querier Up to 256 multicast groupsMLD SnoopingIPv6 MLD snooping v1, v2, up to 256 multicast groupsQoSIngress/Egress Rate Limit per port bandwidth control 8-level priority for switching Port number 802.1p priority DSCP/IP precedence of IPv4/IPv6 packets Typical network application DSCP remarkingRingSupports ERPS, and complies with ITU-T G.8032 Recovery time < 450msSecurity FunctionsAccess Control ListIPv4/IPv6 IP-based ACL/MAC-based ACL IPv4/IPv6 IP-based ACE/MAC-based ACE Max. 256 ACL entriesPort SecurityIEEE 802.1X – Port-based authentication Built-in RADIUS client to co-operate with RADIUS server RADIUS/TACACS+ user access authenticationMAC SecurityIP-MAC port binding MAC filter Static MAC address, max. 256 static MAC entriesEnhanced SecurityDHCP Snooping and DHCP Option82 STP BPDU guard, BPDU filtering and BPDU forwarding DoS attack prevention ARP inspection IP source guardManagement FunctionsBasic Management InterfacesConsole; Telnet; Web browser; SNMP v1, v2cSecure Management InterfacesSSHv2, TLS v1.2, SNMP v3System ManagementFirmware upgrade by HTTP protocol through Ethernet network Configuration upload/download through HTTP Remote Syslog System log LLDP protocol SNTP PLANET Smart Discovery Utility PLANET NMS System/CloudViewer appEvent ManagementRemote/Local Syslog System logSNMP MIBsRFC 1213 MIB-II RFC 1493 Bridge MIB RFC 1643 Ethernet MIB RFC 2863 Interface MIB RFC 2665 Ether-Like MIB RFC 2819 RMON MIB (Groups 1, 2, 3 and 9) RFC 2737 Entity MIB RFC 2618 RADIUS Client MIB RFC 2863 IF-MIB RFC 2933 IGMP-STD-MIB RFC 3411 SNMP-Frameworks-MIB RFC 4292 IP Forward MIB RFC 4293 IP MIB RFC 4836 MAU-MIB IEEE 802.1X PAE LLDP MAU-MIBStandards ConformanceRegulatory ComplianceFCC Part 15 Class A EN 55032 EN 55035 ICES-003 issue 7CertificationEN50121-4Stability TestingIEC 60068-2-32 (free fall) IEC 60068-2-27 (shock) IEC 60068-2-6 (vibration)Standards ComplianceIEEE 802.3 10BASE-T IEEE 802.3u 100BASE-TX/100BASE-FX IEEE 802.3z Gigabit SX/LX IEEE 802.3ab Gigabit 1000T IEEE 802.3x flow control and back pressure IEEE 802.3ad port trunk with LACP IEEE 802.1D Spanning Tree Protocol IEEE 802.1w Rapid Spanning Tree Protocol IEEE 802.1s Multiple Spanning Tree Protocol IEEE 802.1p Class of Service IEEE 802.1Q VLAN tagging IEEE 802.1x Port Authentication Network Control IEEE 802.1ab LLDP IEEE 802.3az for Energy-Efficient Ethernet RFC 768 UDP RFC 783 TFTP RFC 791 IP RFC 792 ICMP RFC 2068 HTTP RFC 1112 IGMP v1 RFC 2236 IGMP v2 RFC 3376 IGMP v3 RFC 2710 MLD v1 FRC 3810 MLD v2 ITU G.8032 ERPS RingEnvironmentOperating Temperature-40 ~ 75 degrees CStorage Temperature-40 ~ 85 degrees CHumidity5 ~ 95% (non-condensing) Link spre comentariu
gigione01 Postat Ianuarie 27, 2024 Autor Partajează Postat Ianuarie 27, 2024 Valabil si negociabil! Am mai multe bucati! Link spre comentariu
gigione01 Postat Februarie 15, 2024 Autor Partajează Postat Februarie 15, 2024 Pentru primul aparat vandut la pretul cerut mai sus,adaug in pret PLANET MGB-TSX2 modul de emisie-recepție pentru rețele Fibră optică 1000 Mbit/s mini-GBIC 1310 nm PERFORMANȚĂ Tip aparat emisie-recepție SFP Fibră optică Rată maximă transfer de date 1000 Mbit/s Tipul de interfaţă mini-GBIC Fibră mod unic (SMF) suportat Nu Fibră multi-mod (MMF) suportat Da Conector cu fibră optică LC Standard transceiver SFP SX Maximă de transfer de la distanţă 2000 m De lungimi de undă 1310 nm Indicator detectare semnal TTL Da Monitorizare diagnostice digitale (DDM) Da Porturile canal Fibre 2 Link spre comentariu
gigione01 Postat Februarie 27, 2024 Autor Partajează Postat Februarie 27, 2024 Pret nou 1250 lei pentru tot. Transport curier sau posta inclus. Link spre comentariu
