Electronice, mecanice, diverse
Dxxx
01. Stand metalic + bormasina cu reductor, pentru lucrari fine (dimensiuni sub 25cm, cursa 3 cm). Alimentarea trebuie asigurata extern, DC 6-18V, 40A in varfuri, 350 lei.
https://i.postimg.cc/Dfsb9g1d/bohrmch-2.jpg
https://i.postimg.cc/13WgGYZP/bohrmch-ambele.jpg
https://i.postimg.cc/cHt8472W/bohrmch-1.jpg
02. Mini-masina gaurit 6-12V, 25 lei.
https://i.postimg.cc/8zkJrg9t/bohrmch-small.jpg
https://drive.google.com/file/d/1z7JXSjekboqwHG8Is7KFAx5FQLQ3-PCy/view?usp=drive_link
03. Dremel3000 + mandrina4486=270 lei; transmisie flexibila225=60 lei; stand220=230 lei. Pret impreuna 500lei, toate sunt noi. Mai ieftin vedeti la punctul urmator.
https://i.postimg.cc/wTqTwc2B/dremel-1.jpg
https://i.postimg.cc/FsTF8dCV/dremel-2.jpg
https://i.postimg.cc/6pT6XWDJ/dremel-3.jpg
https://i.postimg.cc/KYMZ19G0/dremel-4.jpg
https://i.postimg.cc/50WfLwjb/dremel-5.jpg
https://i.postimg.cc/zGMzXmrL/dremel-6.jpg
04. Numai ca ansamblu: stand Dremel220 echipat cu freza Dexter / plus mandrina imperecheata /plus transmisie flexibila (deci exact aceleasi functii ca mai sus) pret 340 lei.
https://i.postimg.cc/0jcvTFny/dremel-no-name-1.jpg
https://i.postimg.cc/4yJZFsz0/dremel-no-name-2.jpg
05. Vandut
Carote diamantate diametre: 6,10,12,18,22,27,28,30,40,50mm, 85 lei, toate.
https://i.postimg.cc/fRgLttxR/carote-diamantate-set.jpg
06. Rezervat
Transmisie elastica pentru bormasini normale, cu rulment, 50 lei.
https://i.postimg.cc/6pDKxdrn/flexi1.jpg
https://i.postimg.cc/DwWhNCX7/flexi2.jpg
07. Rezervat
PCB incarcare bormasina cu baterii - 18V ni-cd, 5 lei
https://i.postimg.cc/jSBLK0P3/37.jpg
08. Diode putere, 4 bucati, dintre care cele mici sunt KU1490s (90A,1400V). Erau intr-o instalatie care putea porni camioane (sunt ale altei persoane). Totul din poze 125 lei.
https://i.postimg.cc/4dpNSWjY/diode1.jpg
https://i.postimg.cc/Pfz5bFmc/diode2.jpg
https://i.postimg.cc/sxcfVvjy/diode3.jpg
09. Casti, 5 lei bucata
https://i.postimg.cc/jjwjzxXQ/casti-1.jpg
https://i.postimg.cc/N03jD3Ch/casti-2.jpg
10. Gamepad, 5 lei
https://i.postimg.cc/vmfsYchj/gamepad.jpg
11. Instalatii brad.
Prima are 4m si 30 leduri, lipseste o stea, clipesc bicolor rosu+verde si rosu+albastru.
A doua: 10m si 250 leduri, functioneaza numai una din trei catene (alb), nu exista ceva aparent defect. Fiecare 20 lei.
https://i.postimg.cc/Ss4pJktK/ghirlanda-1.jpg
https://i.postimg.cc/76Nrzdpn/ghirlanda-2.jpg
12. Reflector halogen tub, nou, 10 lei
https://i.postimg.cc/J7PWzw31/proiector.jpg
13. Radio, functional, cu defect la piesa de transmisie mecanica pentru lungimi de unda si pornire, si fara cordon retea - 25 lei.
https://i.postimg.cc/nhQ82Cyz/radio-panou-frontal-1.jpg
https://i.postimg.cc/Jhwf2R8Q/radio-panou-frontal-2.jpg
https://i.postimg.cc/26rPCTVb/radio_-_panou_spate_1.jpg
https://i.postimg.cc/hG9kFNPR/radio_-_panou_spate_2.jpg
14. Vandut
Testere AVO, noi, set 30 lei.
https://i.postimg.cc/59PZMB1y/testere.jpg
15. Trafo x2. 50W 15 lei si 25 lei.
https://i.postimg.cc/KvRCc1vN/trafo_2.jpg
https://i.postimg.cc/1XYTcQMw/trafo1.jpg
16. Acumulatoare Varta 4 buc/blister sigilat. 25 lei/blister.
https://i.postimg.cc/HxpGf6Xn/varta.jpg
17. Acumulatori noi R3/AAA LiFePO4 set pentru doua avometre de 3V (2 baterii + 2 carcase scurt-circuit), 40 lei.
https://i.postimg.cc/BvC5L0Mn/11.jpg
https://i.postimg.cc/htT1nxmx/10.jpg
18. Adaptor VGA+audio la HDMI, carcasa metal, alimentator, nou 40 lei.
https://i.postimg.cc/HkWjc6Np/40.jpg
https://i.postimg.cc/9Qx0GG3y/41.jpg
19. Vandut
Cablu HDMI -> VGA, 15 lei
https://i.postimg.cc/SRNFfV4F/hdmi-vga-1.jpg
https://i.postimg.cc/8PcgFywL/hdmi-vga-2.jpg
20. Surse curent constant LED/COB de la retea 100-250V~ toate sunt noi. Posibile si schimburi.
40W        125 lei        0,91 eficienta       PF>96        dimming        25-58V / 0,7A          IP67       ALS4070-IP
40W        160 lei        0,89 eff             PF>95        dimming        29-48V / 0,84A         -          HCP-40H-48
45W        110 lei        0,84 eff             PF>92        dimming        26-43V / 1,05A         -          IDPC-45A-1050
50W        130 lei        0,86 eff             PF>95        dimming        20-55V / 1,25A         IP67       OT-50-1A2-2DIMLT2-P
85W        180 lei        0,91 eff             PF>95        dimming        95-189V / 0,45A        IP67       EUC-085S045DV
250W       180 lei        0,92eff              PF>95        -              180-357V / 0,7A        IP67       OT-250-120...277-700-P5
https://i.postimg.cc/zBGK5cVS/smps-a.jpg
https://i.postimg.cc/HxqbFkL3/17.jpg
21. Reflectoare de aluminiu pentru COB / LED  (nu sunt plastic metalizat), diametru ~11cm, noi, 10 lei /bucata.
https://i.postimg.cc/TP9wfJjy/21.jpg
https://i.postimg.cc/9fVM6n95/22.jpg
22. Diverse alte reflectoare si dispersoare, noi, pret incepand de la 2 lei.
https://i.postimg.cc/c1c1hqqL/reflectoare.jpg
23. Sursa MeanWell PT45B, noua, scoate 3 tensiuni: +5V/3A, +12V/2A -12v/0,3A, 35lei
https://i.postimg.cc/MZtHHj1Q/35.jpg
24. Voltmetre de panou, noi, muta virgula automat X,XX si XX,X, 10 lei bucata
Mai este unul singur.
https://i.postimg.cc/xCGnRcbH/dvm1.jpg
https://i.postimg.cc/660B44Kx/dvm2.jpg
https://i.postimg.cc/ZK548YYB/dvm3.jpg
https://i.postimg.cc/289m2p3H/dvm4.jpg
25. Clampmetru, nou, citire maxima 6000, 80 lei
https://i.postimg.cc/HnG8Jc1y/avo-1.jpg
https://i.postimg.cc/020KQyWz/avo-2.jpg
26. Vandut
Multitester / identificare componebte 2 si 3 pini, masoara ESR - varianta pentru baterie li-ion, include baterie de 700mAh, 90 lei
https://i.postimg.cc/m2nf7Q6J/multi-tester.jpg
https://drive.google.com/file/d/1_kHVZ_ayvXzATTRVx5TxaHLC-9EPYXSt/view?usp=drive_link
27. PCB adaptor de la DIL 8,  la MSOP8 (pe o fata) sau la SOIC8 (pe partea opusa), deci din SMD la THT, noi, 1 leu bucata
https://i.postimg.cc/c4S80nmq/adaptor-PCB.jpg
https://drive.google.com/file/d/1CtbC3Al541Ji6yyKX6nLCA_EZfQEmr5g/view?usp=drive_link
28. Sursa chinezeasca, noua, 24V-4A, (6A intermitent) 40 lei.
https://i.postimg.cc/fT2V20LN/38.jpg
29. Mufa GX16 - 5 pini mama/pe fir, noi, 1 leu bucata.
https://i.postimg.cc/d3S9zK6y/borne-5-cont-1.jpg
https://i.postimg.cc/HxkqpNxT/mufa5.jpg
30. Epuizat
PCB pentru power-bank, contine toate functiile intrare/iesire, borne, si ecran LED sau LCD - mai multe modele 15 lei/bucata.
https://i.postimg.cc/HnKQ69W0/Pcb-afisor-power-bank-20-b.jpg
https://i.postimg.cc/bYFHYp0G/Pcb-fisor-power-bank-20.jpg
31. Retras de la vanzare
Modul step-down (convertor DC/DC buck) 15A / XL4015, nou, 12 lei.
https://i.postimg.cc/vZnvSkV4/buck-XL4015-32-V-5-A-14.jpg
32. cabluri, 5 lei bucata sau setul:
https://i.postimg.cc/1trtp8Tb/33.jpg
https://i.postimg.cc/FzPHB2hZ/42.jpg plus https://i.postimg.cc/GmptmJTf/cablu-9.jpg 2 cabluri per set
https://i.postimg.cc/Nfz07qJG/43.jpg plus https://i.postimg.cc/3J1WhbNp/cablu-8.jpg
https://i.postimg.cc/HLGsR01f/44.jpg plus https://i.postimg.cc/Ghd9Z1Ld/cablu-7.jpg plus https://i.postimg.cc/FRS7Qrks/cablu-4.jpg
https://i.postimg.cc/5N64tKxh/46.jpg plus https://i.postimg.cc/C5jBbhw6/brackets.jpg
33. cabluri, 15 lei bucata:
https://i.postimg.cc/CKjLgZFd/47.jpg plus https://i.postimg.cc/BZxXYvGm/cablu-3.jpg
https://i.postimg.cc/3NwKmn2D/48.jpg plus https://i.postimg.cc/s2qv8QXN/cablu-1.jpg
https://i.postimg.cc/Twf2YRw0/49.jpg plus https://i.postimg.cc/Hn4nV6tq/cablu-6.jpg plus https://i.postimg.cc/SRpjSBcL/cablu-5.jpg
https://i.postimg.cc/Jnxrs9HL/50.jpg plus https://i.postimg.cc/PqPC2ztD/cablu-2.jpg, este lung
34. antistres cablu retea/~220V, noi, 2 lei bucata.
https://i.postimg.cc/wxkyNrY3/31.jpg
35. borne alimentare retea recuperate 1 leu bucata.
https://i.postimg.cc/zv5XZn10/conector-2.jpg
36. carcase SMPS: 5 lei/buc cele clipsabile, 10 lei bucata cele cu suruburi.
https://i.postimg.cc/tTjJZ3rh/32.jpg
37. Variator 1500W, 15 lei
https://i.postimg.cc/8P997T7V/variator.jpg
38. Vandut
Difuzoare inalte, 8 ohmi, dintr-un sistem coaxial Siarre, 10 lei/pereche
https://i.postimg.cc/y8DkwYgS/36.jpg
39. Majak 205 3 butoane metalice 20 lei
https://i.postimg.cc/k5KkP6bB/71.jpg
40. Vandut
Majak 205 trafo, 40 lei
https://i.postimg.cc/Y9sKZbkH/90.jpg
41. Vandut
VU Unitra,  pereche = 20 lei
https://i.postimg.cc/SRTPfcwt/73.jpg
42. huse/protectii Galaxy S5 / S6, iPhone 5, noi - 5 lei/buc
https://i.postimg.cc/jjL5vLKm/39.jpg
43. filtru laptop, nou, privacy filter pentru 12,5 si pentru 14 inch, 20 lei/buc.
https://i.postimg.cc/XYPqsDqk/25.jpg
https://i.postimg.cc/0NJQFdJR/26.jpg
44. placa audio externa (pe fir) cu intrare USB, 10 lei.
https://i.postimg.cc/T3QLCzbL/34.jpg
https://i.postimg.cc/pXX9JBPC/34.jpg
45. router Gigabit, 35 lei
https://i.postimg.cc/nVSkGnZs/4.jpg
https://i.postimg.cc/V6DFT8CV/5.jpg
https://i.postimg.cc/t4qjPQgD/6.jpg
46. router, il vand ca defect... cateodata intrerupe WiFi, 25 lei
https://i.postimg.cc/j2By0ddZ/14.jpg
https://i.postimg.cc/MZL7jtbV/15.jpg
47. ODD laptop DVD-RW diverse variante SATA / PATA 15 lei +/-
https://i.postimg.cc/g0RzNzfG/dvd.jpg
48. piese laptop HP DV6: cooler cu ventilator, PCB accesori, caddy, LVDS, cablu HDD, telecomanda - 30 lei, toate.
https://i.postimg.cc/5yG9sXNN/hp-dv6.jpg
49. piese laptop Lenovo Y560: tastatura in stare foarte buna, LVDS, cablu alimentare cu conector - 30 lei, toate.
https://i.postimg.cc/Gt9hPFR5/lenovo-Y560.jpg
50. unitati WiFi si buetooth pret pachet 25 lei.
https://postimg.cc/Xr7nptKr
51. placa laptop (MoBo) defecte, 30 lei/bucata sau 4 pentru 100 lei (Toshiba L500-128, Acer E1-532, Lenovo G550, HP DV6)
https://i.postimg.cc/XY1kyDN2/MoB0.jpg
52. procesoare laptop, 50 lei tot pachetul.
https://i.postimg.cc/G2CcN0CG/CPU.jpg
53. Subansamble mecanic + optic DVD-RW (laptop) recuperate- 5 lei bucata
https://i.postimg.cc/0yGqZj83/28.jpg
Bonusuri / donatii:
- cabluri UTP(rj45/lan) si de telefon, molex, USB, alte cabluri
- CD sau DVD blank
- walkman.
- mouse wireless defect.
- telecomanda AC WhiteWestinghouse cu ecran LCD
- telefoane fixe cordless Panasonic/ Alcatel cu defecte.
- difuzoare TomTec incomplete.
- tastaturi laptop.
- spoturi incorporabile in plafon fals, pentru becuri cu dulie E27
- tranzistoare si IC:
CDB - 403, 411, 416
betaM - 324
MMC 4066
TDA 85521
UL1203
NXP7555
Note:
- nu ma deranjeaza nici o propunere, insa ramane sa decid eu ce si unde se poate negocia.
- imi rezerv dreptul de a acorda prioritate cumparatorilor care imi convin.
Livrare, contact, expeditie:
- expediere prin curier, cu plata prin banca in avans si plata transportului la destinatar.
- predare personala in Bucuresti, in limita posibilitatilor prefer sa testam totul.
  • Răspunsuri 49
  • Dxxx
    34
  • nostromo
  • deneinvins
  • grosu99
Da, am vazut si eu, este serviciul de gazduire.
Ca solutie voi copia pozele pe Gooo-drive si o sa trebuiasca sa schimb toate linkurile... deci va rog un pic de rabdare (asta in cazul ca nu isi revine Postimg)
Scuze de deranj,
Dacă mai este valabil, vă rog să rezervați :
05. Carote diamantate diametre: 6,10,12,18,22,27,28,30,40,50mm, 85 lei, toate.
Toate carotele.
27. PCB adaptor de la DIL 8,  la MSOP8 (pe o fata) sau la SOIC8 (pe partea opusa), deci din SMD la THT, 1 leu bucata
De aici vreau 15 bucăți.
Și din lista de jos, dacă sînt, vreau SU160U, SU169, betaM 324 - cîte 2 sau 3 bucăți din fiecare.
Editat de deneinvins
Incepusem sa pun linkuri pe Gooo-drive, drept care la cateva pozitii apar si acestea, insa pentru ca si-a revenit nu are rost sa persist cu efortul.
@deneinvins din pacate pozitia 41 merge la colegul @flomar60 care a fost mai rapid, oricum nu aveam decat cele doua bucati.
Sunt interesat de punctul 26, dar as dori inainte sa intreb in ce zona din Bucuresti trebuie sa ajung ?
Multumesc
26. Multitester / identificare componebte 2 si 3 pini, masoara ESR - varianta pentru baterie li-ion, include baterie de 700mAh, 90 lei
Buna dimineata !
 Daca mai sant disponibile as dori urmatoarele articole din lista dumneavoastra :
30 - pcb pentru power bank adaptor : 2 buc.
27 -  pcb adaptor … :15 buc.
24 - voltmetru de panou  : 4 buc.
19 - cablu adaptor hdmi la vga : 1 buc
 as dori de asemenea de pe celalalt topic un varf tip 4C si un varf  3,2D de la gordak.
continuam pe mp .
Editat de Barbaro
Evident ca nu exista discriminare in functie de zona de resedinta a clientului - se pot trimite cele solicitate.
Diferenta este numai dpdv costuri, pentru Bucuresti fiind ~zero, iar pentru alte destinatii oricum mai mult... ceea ce evident ca face nejustificata achizitia daca costul componentei este mai mic decat cel al transportului...
Acum 57 minute, Dxxx a spus:
Tocmai de asta am renuntat , vroiam pct 38 parca cu cele doua tweetere in valoare de 10 Lei.
