Kituri, componente, module...
Marele Savant
  • Răspunsuri 94
  • Marele Savant
    34
  • PINTI
    11
  • grosu99
    11
  • Tanase Ion
    6
Ce a mai ramas dintre cele vechi, am mai inviorat unele preturi, plus citeva chestii noi:
1. Rezistente neinductive, 50 ohmi/150W, pret 30 lei bucata
https://imgur.com/YwMCIQS
2.Placa Dezvoltare Raspberry RP2040, pret 20 lei bucata
https://imgur.com/G91St8X
4. Placa dezvoltare STM32
-STMF32F103C6T6, pret 15 lei bucata
-STMF32F103C8T6, pret 22 lei bucata
https://imgur.com/SSzltqZ
6. modul RTC DS1307, pret 8 lei bucata
https://imgur.com/aAl4JZp
https://imgur.com/gicZlLL
7. Sursa 24V, de foarte buna calitate, zgomot RF redus...pret 18 lei bucata
https://imgur.com/ld9OVwI
8. Placa electronica dintr-un casetofon, pret 8 lei
https://imgur.com/OcAJmme
9. Modul Micro SD Card, pentru Arduino, pret 12 lei
https://imgur.com/awb4gcV
11. Modul Micro SD card pentru Arduino,  pret 6 lei
https://imgur.com/6bzsTkl
12. Aparat fizioterapie. Pret 15 lei
-nu are electrozi
-are defecta panglica panoului frontal, dar poate fi uspor inlocuita cu un comutator cu 5 pozitii!
https://imgur.com/u9ou0Yz
https://imgur.com/NTzip9X
13. Modul SD card, pret 10 lei
https://imgur.com/bXYMEMr
14. Montaj pentru recuperat componente, contine doua placi fixate intre ele cu distantiere, pret 14 lei
https://imgur.com/amhKm3R
https://imgur.com/FSf3Lcc
16. Alt transformator, 16 lei
https://imgur.com/QpPo2KJ
19. Senzor Temperatura si Presiune, BMP280, pret 9 lei bucata
https://imgur.com/CqOhgt8
23.
Placa dezvoltare ESP32 WROOM, cu BT si WiFi, pret 35 lei bucata
https://imgur.com/3axfpyv
27. Laptop de generatie veche, Toshiba. Pentium Dual CPU, T2390, 1,86Ghz,
240 Gb SSD, nu are crapaturi sau probleme ascunse. Pret 200 lei
https://imgur.com/8ZDMmMA
https://imgur.com/O2BAweU
28. Alt laptop vechiut, Compaq Presario, AMD Sempron M100, 2.00 Ghz, 240 SSD, 4Gb RAM. Nu are probleme, crapaturi, etc.  pret 240 lei
https://imgur.com/1dpIcyI
https://imgur.com/zcrUyxo
https://imgur.com/cTcmBgN
Ambele imi apartin, unic proprietar cum se spune, cumparate de-alungul timpului din UK. SSD-urile sint noi, cu putine ore de functionare.
 Laptopurile au instalat Win 7, pentru ca am avut niste programatoare care nu mergeau pe Win 10. dar se poate instala si utiliza si cu Win 10, dar se misca mai incet.
29. Chromebook, 2011, nu mai primest update, dar se mai poate folosi pentru browsing, este usor, baterie inca buna. Pret 20 lei
https://imgur.com/adwFwx9
https://imgur.com/sZAMTyh
Niciunul nu are pixeli morti. Deoarece la transport pot aparea probleme care ar duce la discutii neprincipiale, prefer doar cumparatori din Bucuresti. Sau din provincie, dar isi asuma riscurile inerente.
30. modul provenit dintr-o statie Storno, contine filtru 10.700Mha, oscilator 11.155 Mhz plus si mixer, deci la iesire vor fi 455Khz, pret 14 lei bucata.
https://imgur.com/e3bZBi1
33. Amp. operationale smd, lipite pe adaptoare DIP, noi:
-MAX4108 la 8,5 lei bucata
-OP297 la 8 lei bucata
https://imgur.com/RiyDoyR
36. cabluri semirigide de frecvente inalte, diferite lungimi, nu apar toate in foto. preturi 6-15 lei bucata.
https://imgur.com/nYVcDz2
Completam cu:
37. Ansamblu bobina pe calit, pret 25 lei!
https://imgur.com/2kZ0JgL
https://imgur.com/VuSGA6X
38. Ansamblu bobina in interiorul careia se roteste o alta mai mica, pret 22 lei.
https://imgur.com/fRxPIRO
39. RR ''de colectie'', OPTALIX model T0-100,  carcasa incompleta, se vede si in foto,  functioneaza OK, pret 22 lei
https://imgur.com/q1v84uC
40. Regulator temperatura cu termocupla. Foarte posibil sa fie in stare buna, pret 14 lei
https://imgur.com/XRLSCtW
https://imgur.com/5oMq2XO
41. Mouse bengos, pentru gameri, nu am observat ca este cu fir, imi trebuia wireless. Modelul este Arctic M471, pretul 30 lei, mai putin de jumatate ca in magazin.
https://imgur.com/xnctW6v
42. module cu componente RF, pret 8 lei bucata
https://imgur.com/t1hHUbZ
43. Diskete noi, pret 7 lei bucata
https://imgur.com/8VXKD36
https://imgur.com/lsRYYJC
44. Difuzoare noi, 14 lei bucata!
https://imgur.com/krl2hGQ
45. 4 tuburi, pret 42 lei toate
https://imgur.com/y5s0Qy7
46. Rezonator 4Khz, pret 14 lei
https://imgur.com/QzrA0Ek
47. Conectori BNC, pret 3 lei bucata
https://imgur.com/nWqfI9t
48. cabluri cu mufe BNC, fabricatie industriala, pret 8 lei bucata
49. sursa alimentare, 41Vcc, contine un tr. toroidal de 36v/100VA
carcasa are si capac, nu am mai pus foto completa. Pret 18 lei
https://imgur.com/Ma0VIgP
https://imgur.com/OqHaRGT
50. ansamblu motor-reductor, de la un aparat de desfacut conserve, 12 lei
https://imgur.com/oy6TAnY
https://imgur.com/q7oTpzY
51. Sursa de alimentare cu mai multe tensiuni fixe, CC si AC plus una reglabila. A fost inlocuit potentiometrul sursei reglabile cu unul multitur. Nu mai are suportii originali pentru sigurante, au fost inlocuite cu altele pe cablaj. pret 180 lei
este cu tr. de retea baban, destul de grea, deci preferabil cu predare personala in bucuresti!
https://imgur.com/JNwRE78
plata prin banca, se adauga costul transportului prin curier.
Disponibile citeva bucati tuburi 6E2, echivalente EM84, EM87.
Noi, testate individual, pret 30 lei bucata plus transport prin curier. plata prin banca.
-nu are electrozi
23.
Completam cu:
Pret 160 lei
52. Trusa Arduino, nu cred ca lipseste ceva din ea, nu a fost folosita, chiar are cite ceva in plus. pret 140 lei
https://imgur.com/wQMak0Y
https://imgur.com/GhxgLdY
53. Router nou, 15 lei
https://imgur.com/9TFBlCi
54. OCT, pret 14 lei
https://imgur.com/HEg885q
55. Pompa aer? pret 8 lei
https://imgur.com/u5Hw2t5
56. doua potentiometre bobinate, pret 14 lei ambele
https://imgur.com/01nnwjV
57. Placa centrala termica Wiessmann, aproape sigur buna, a fost supravoltata si a pocnit un varistor si siguranta, dar s-a prefersat o placa noua! Pret 25 lei
   niste pistoale de lipit pe care m-a rugat un prieten mai in virsata sa le postez. Nu arata grozav, dar functioneaza bine primele doua, la ultimul am masurat doar infasurarea sa nu fie intrerupta.
58. Pistol de lipit 1, pret 50 lei
https://imgur.com/nYipq7g
59. pistol de lipit 2, pret 40 lei
https://imgur.com/ZoI1mSl
60. transformator pistol lipit, pret 15 lei
https://imgur.com/Vs0O5n2
61. set capace pistol lipit romanesc, noi,  pret 20 lei
