Kituri, componente, module...
Marele Savant
  • Răspunsuri 94
  • Marele Savant
    34
  • PINTI
    11
  • grosu99
    11
  • Tanase Ion
    6
 Ce a mai ramas dintre cele vechi, plus citeva chestii noi:
1. Numarator, cu motor/reductor 1:200, alimentare 3-6Vac. Sint prea zgomotoase pentru gusturile mele! Pret 5 lei bucata.
https://imgur.com/QksUKWy
2.Placa Dezvoltare Raspberry RP2040, pret 24 lei bucata
https://imgur.com/G91St8X
4. Placa dezvoltare STM32
-STMF32F103C6T6, pret 18 lei bucata
-STMF32F103C8T6, pret 25 lei bucata
https://imgur.com/SSzltqZ
6. modul RTC DS1307, pret 8 lei bucata
https://imgur.com/aAl4JZp
https://imgur.com/gicZlLL
7. Sursa 24V, de foarte buna calitate, zgomot RF redus...pret 18 lei bucata
https://imgur.com/ld9OVwI
8. Placa electronica dintr-un casetofon, pret 8 lei
https://imgur.com/OcAJmme
9. Modul Micro SD Card, pentru Arduino, pret 12 lei
https://imgur.com/awb4gcV
11. Modul Micro SD card pentru Arduino,  pret 6 lei
https://imgur.com/6bzsTkl
12. Aparat fizioterapie. Pret 20 lei
-nu are electrozi
-are defecta panglica panoului frontal, dar poate fi uspor inlocuita cu un comutator cu 5 pozitii!
https://imgur.com/u9ou0Yz
https://imgur.com/NTzip9X
13. Modul SD card, pret 10 lei
https://imgur.com/bXYMEMr
14. Montaj pentru recuperat componente, contine doua placi fixate intre ele cu distantiere, pret 14 lei
https://imgur.com/amhKm3R
https://imgur.com/FSf3Lcc
16. Alt transformator, 16 lei
https://imgur.com/QpPo2KJ
19. Senzor Temperatura si Presiune, BMP280, pret 9 lei bucata
https://imgur.com/CqOhgt8
23.
Placa dezvoltare ESP32 WROOM, cu BT si WiFi, pret 42 lei bucata
https://imgur.com/3axfpyv
27. Laptop de generatie veche, Toshiba. Pentium Dual CPU, T2390, 1,86Ghz,
240 Gb SSD, nu are crapaturi sau probleme ascunse. Pret 240 lei
https://imgur.com/8ZDMmMA
https://imgur.com/O2BAweU
28. Alt laptop vechiut, Compaq Presario, AMD Sempron M100, 2.00 Ghz, 240 SSD, 4Gb RAM. Nu are probleme, crapaturi, etc.  pret 280 lei
https://imgur.com/1dpIcyI
https://imgur.com/zcrUyxo
https://imgur.com/cTcmBgN
Ambele imi apartin, unic proprietar cum se spune, cumparate de-alungul timpului din UK. SSD-urile sint noi, cu putine ore de functionare.
 Laptopurile au instalat Win 7, pentru ca am avut niste programatoare care nu mergeau pe Win 10. dar se poate instala si utiliza si cu Win 10, dar se misca mai incet.
29. Chromebook, 2011, nu mai primest update, dar se mai poate folosi pentru browsing, este usor, baterie cinca buna. Pret 30 lei
https://imgur.com/adwFwx9
https://imgur.com/sZAMTyh
Niciunul nu are pixeli morti. Deoarece la transport pot aparea probleme care ar duce la discutii neprincipiale, prefer doar cumparatori din Bucuresti. Sau din provincie, dar isi asuma riscurile inerente.
30. modul provenit dintr-o statie Storno, contine filtru 10.700Mha, oscilator 11.155 Mhz plus si mixer, deci la iesire vor fi 455Khz, pret 14 lei bucata.
https://imgur.com/e3bZBi1
33. Amp. operationale smd, lipite pe adaptoare DIP, noi:
-MAX4108 la 8,5 lei bucata
-OP297 la 8 lei bucata
https://imgur.com/RiyDoyR
36. cabluri semirigide de frecvente inalte, diferite lungimi, nu apar toate in foto. preturi 6-15 lei bucata.
https://imgur.com/nYVcDz2
Completam cu:
37. Ansamblu bobina pe calit, pret 28 lei!
https://imgur.com/2kZ0JgL
https://imgur.com/VuSGA6X
38. Ansamblu bobina in interiorul careia se roteste o alta mai mica, pret 22 lei.
https://imgur.com/fRxPIRO
39. RR ''de colectie'', OPTALIX model T0-100,  carcasa incompleta, se vede si in foto,  functioneaza OK, pret 22 lei
https://imgur.com/q1v84uC
40. Regulator temperatura cu termocupla. Foarte posibil sa fie in stare buna, pret 18 lei
https://imgur.com/XRLSCtW
https://imgur.com/5oMq2XO
 Urmeaza doua chestii cumparate aiurea de mine:
41. Mouse bengos, pentru gameri, nu am observat ca este cu fir, imi trebuia wireless. Modelul este Arctic M471, pretul 35 lei, mai putin de jumatate ca in magazin.
https://imgur.com/xnctW6v
si
42. doua surse de 24 volti. nu m-am prins la timp ca transformatoarele au primarul la 24 Vac!!! are doua secundare inseriate, dar nu le gasesc utilizare. pret 8 lei bucata.
https://imgur.com/UsMBR9T
plata prin banca, se adauga costul transportului prin curier.
  • 2 săptămâni mai târziu...
  cu scuze de rigoare, readuc in atentie acest anunt! nu mai fac nici un fel de ''rezervari'', le-am ametit si cu greu am descurcat anunturile, am avut ''rezervari'' facute si de acum 1-2-3 luni, dupa care solicitantii nu au mai dat nici un semn. Multe de la colegi care posteaza zi si noapte pe forum! Sigur, e dreptul lor, nici o suparare! Singura varianta este plata prin banca si le rezerv pentru 3 luni!!!
Transformatoarele respective au doua secundare de 16 volti fiecare, pentru 24 v in primar, inseriate.
Trimiteti si peste hotare?
Daca da, as lua urmatoarele (daca mai sunt disponibile toate, ca altfel nu merita):
La 01.10.2023 la 22:34, Marele Savant a spus:
si
Editat de franzm
Eu am scris pentru acele surse pe 9 octombrie, am dat si mesaj privat dupa care se pare ca ati sters mesajul...insa raspuns primesc abia azi...daca sunt valabile eu le vreau, asteptam doar sa vad daca mai puneti ceva, sa nu va incurc pt. 16 lei plus transport. Si nici curier nu e eficient sa platesc pt. atat...
Cred ca am colaborat de suficiente ori ca sa va asigurati ca nu renunt la cele solicitate, rezervate...dar faceti cum credeti.
1 oră în urmă, Tanase Ion a spus:
Buna seara, ramane valabila, il iau, cu stima si respect multumesc frumos.
mai aveti si: 31 la mine
Chiar acum, carageae a spus:
  Am toata increderea si sint disponibile. Am postat cuvintele respective pentru ca efectiv le-am incurcat destul. Am refuzat multi colegi pentru chestii ''rezervate'' de care nu a mai intrebat nimeni!
Acum 47 minute, franzm a spus:
Sursele nu, ati vazut ca au fost solicitate de alt coleg.
