Kituri, componente, module...
Marele Savant
  • Răspunsuri 94
  • Marele Savant
    34
  • PINTI
    11
  • grosu99
    11
  • Tanase Ion
    6
Cele vechi, plus câteva noutăți!
1. Numarator, cu motor/reductor 1:200, alimentare 3-6Vac. Sint prea zgomotoase pentru gusturile mele! Pret 5 lei bucata.
https://imgur.com/QksUKWy
2.Placa Dezvoltare Raspberry RP2040, pret 24 lei bucata
https://imgur.com/G91St8X
4. Placa dezvoltare STM32
-STMF32F103C6T6, pret 18 lei bucata
-STMF32F103C8T6, pret 25 lei bucata
https://imgur.com/SSzltqZ
6. modul RTC DS1307, pret 8 lei bucata
https://imgur.com/aAl4JZp
https://imgur.com/gicZlLL
7. Sursa 24V, de foarte buna calitate, zgomot RF redus...pret 14 lei bucata
https://imgur.com/ld9OVwI
8. Placa electronica dintr-un casetofon, pret 8 lei
https://imgur.com/OcAJmme
9. Modul Micro SD Card, pentru Arduino, pret 12 lei
https://imgur.com/awb4gcV
11. Modul Micro SD card pentru Arduino,  pret 6 lei
https://imgur.com/6bzsTkl
12. Aparat fizioterapie. Pret 20 lei
-nu are electrozi
-are defecta panglica panoului frontal, dar poate fi uspor inlocuita cu un comutator cu 5 pozitii!
https://imgur.com/u9ou0Yz
https://imgur.com/NTzip9X
13. Modul SD card, pret 10 lei
https://imgur.com/bXYMEMr
14. Montaj pentru recuperat componente, contine doua placi fixate intre ele cu distantiere, pret 14 lei
https://imgur.com/amhKm3R
https://imgur.com/FSf3Lcc
16. Alt transformator, 16 lei
https://imgur.com/QpPo2KJ
17. VU-metru recuperat, pret 14 lei
https://imgur.com/VXOkaFV
19. Senzor Temperatura si Presiune, BMP280, pret 9 lei bucata
https://imgur.com/CqOhgt8
20. Modul RTC, DS1302, pret 5 lei bucata, fara baterie
https://imgur.com/QMlW8uB
22. Comutatoare calit, in stare foarte buna, pret 50 lei toate!
https://imgur.com/cYEquDE
23.
Placa dezvoltare ESP32 WROOM, cu BT si WiFi, pret 42 lei bucata
https://imgur.com/3axfpyv
24. Robinete calorifer cu cap termostatat, comandate de doua ori din greseala, absolut noi, 4 bucati, 15 lei bucata
https://imgur.com/tUN6zIM
25. Telefon mobil Samsung A7 Duos, 64/4 Gb, stare foarte buna, unic proprietar, pret 380 lei
Baterie in stare buna, unic proprietar.
https://imgur.com/Lh3tQBz
26.
25. Telefon mobil Huawei P Smart Z, 64/4 Gb, stare foarte buna, unic proprietar, pret 380 lei
https://imgur.com/3JQG7Xw
27. Laptop de generatie veche, Toshiba. Pentium Dual CPU, T2390, 1,86Ghz,
240 Gb SSD, nu are crapaturi sau probleme ascunse. Pret 240 lei
https://imgur.com/8ZDMmMA
https://imgur.com/O2BAweU
28. Alt laptop vechiut, Compaq Presario, AMD Sempron M100, 2.00 Ghz, 240 SSD, 4Gb RAM. Nu are probleme, crapaturi, etc.  pret 280 lei
https://imgur.com/1dpIcyI
https://imgur.com/zcrUyxo
https://imgur.com/cTcmBgN
Ambele imi apartin, unic proprietar cum se spune, cumparate de-alungul timpului din UK.
 Laptopurile au instalat Win 7, pentru ca am avut niste programatoare care nu mergeau pe Win 10. dar se poate instala si utiliza si cu Win 10, dar se misca mai incet.
29. Chromebook, 2011, nu mai primest update, dar se mai poate folosi pentru browsing, este usor, baterie cinca buna. Pret 30 lei
https://imgur.com/adwFwx9
https://imgur.com/sZAMTyh
Niciunul nu are pixeli morti. Deoarece la transport pot aparea probleme care ar duce la discutii neprincipiale, prefer doar cumparatori din Bucuresti. Sau din provincie, dar isi asuma riscurile inerente.
Acum 14 ore, yo9hrb a spus:
1 (2 buc) si 22 le doresc eu.
Bune si asa. Sa-mi dat un pret cu transport, cu rugamintea sa ajunga intre miercuri si joi - saptamana viitoare, evident - la Ploiesti. Vineri ma intorc din delegatie si trec sa-l iau.
  O rugaminte mare: nu imi mai trimiteti SMS-uri! le citesc doar accidental, nu le vad rostul atita timp cit avem servicii de voce cu milioane de quatralioane de minute, si email!
   Referitor la anunturi, contact MP sau direct in topic, mail sau telefon. Stiu ca eu sint cel vinovat, SMS-urile nu au nici o vina, dar asta e!
La 12.09.2023 la 22:04, humulin a spus:
Vreau eu:
Sigur, va astept sa le luati!
La 13.09.2023 la 2:55, sonic11 a spus:
13, doua bucăți.
 Va asteapta!
7. Sursa 24V, de foarte buna calitate, zgomot RF redus...pret 18 lei bucata
-nu are electrozi
23.
Editat de Marele Savant
 Ce a mai ramas dintre cele vechi, plus citeva chestii noi:
-nu are electrozi
23.
Ambele imi apartin, unic proprietar cum se spune, cumparate de-alungul timpului din UK. SSD-urile sint noi, cu putine ore de functionare.
Ae mai adauga:
30. modul provenit dintr-o statie Storno, contine filtru 10.700Mha, oscilator 11.155 Mhz plus si mixer, deci la iesire vor fi 455Khz, pret 14 lei bucata.
https://imgur.com/e3bZBi1
31. Modul amplificator stereo, clasa D desigur, cu Bluetooth, alimentare dintr-un singur element 18650. Pret 22 lei
https://imgur.com/6TvkuQp
32. Cablu serial CISCO, poate fi folosit ca atare sau recuperate doua cabluri de cite 3 metri fiecare cu mufe BNC, pret 25 lei.
  https://imgur.com/Jeqo99T
33. Amp. operationale smd, lipite pe adaptoare DIP, noi:
-MAX4108 la 8,5 lei bucata
-OP297 la 8 lei bucata
https://imgur.com/RiyDoyR
33. Generator audio, max. 200 Khz, absolut nefolosit. Are urmatoarele probleme:
-nu se aprinde LED-ul de pornire, dar fiind LED de ICCE, era de mirare daca se aprindea!
-nu functioneaza pe domeniul IV, aparatul are sigiliul original, nu a fost desfacut. Este un oscilator Wienn, deci nu ar trebui sa aiba probleme deosebite. Pret  145 lei
https://imgur.com/S9qSpH7
34. Doua module cu componente. Presupun ca sint prescalere de IF, se pot recupera cite 17 tranzistoare 2N2369 din fiecare. Pret 16 lei bucata
https://imgur.com/T95bGCv
35. detector de radiatii de uz didactic. Este nefolosit,  boxa in care ar trebui sa se auda pocnetele nu stiu daca este cea originala. Sertarul negru care contine receptorul poate fi extrasa din aparat, fiind conectata printr-un cablu ecranat. Amplificatorul de audio functioneaza si se aude cite un pocnet din cind in cind, nu am nimic ce ar putea fi folosit la teste. Pret 95 lei
https://imgur.com/B8FoxvZ
36. cabluri semirigide de frecvente inalte, diferite lungimi, nu apar toate in foto. preturi 6-15 lei bucata.
https://imgur.com/nYVcDz2
