codrut Postat Septembrie 1, 2023 Partajează Postat Septembrie 1, 2023 Model : TX-L37U3B Acest tv este adus din Anglia,și nu are sunet. Se poate face ceva din meniul service pentru a funcționa? Sau ii recomand un reciver. Mulțumesc! sasiu:TNP8EA114 Link spre comentariu
iuliantv Postat Septembrie 1, 2023 Partajează Postat Septembrie 1, 2023 (editat) un reset din menu ,sau o reinstalare,si cand cere tara daca apare si irlanda,e posibil sa intre si sunet,cel putin la mine mergea in norma BG ,dar nu scana decat in uif eu personal nu am intalnit panasonic lcd ,ce e facut pentru UK sa poata fi facut cu rescriere soft,pe usb sau cu programator,am vazut destule idei de ce si cum se face,dar nimic bun la o plasma ce avea hotel mod activ,dar nu era de uk .a mers metoda de mai jos Factory Reset Panasonic TV Without A Remote You will need someone else to help you out with a factory reset without a remote because it can be difficult to perform it alone, especially if the electric socket is far away. You need to turn off the Panasonic TV for a factory reset as well, but not by holding down the power button. For a factory reset, you need to unplug the AC power cord of your Panasonic TV. The TV will be turned off. Now, you will have to press and hold the “POWER BUTTON” and the “VOLUME DOWN” buttons simultaneously. While holding both buttons, ask your helper to plug the AC power cord back into the electric socket. Keep holding the buttons, even after the Panasonic TV is turned on. You need to hold them and wait until the “Erasing Screen” shows up on the screen. Once the erasing screen shows up, you can simply use the buttons present on your TV’s hardware to select what to keep and what not to keep before pressing OK for the factory reset. Editat Septembrie 1, 2023 de iuliantv Link spre comentariu
AlpHs00 Postat Septembrie 1, 2023 Partajează Postat Septembrie 1, 2023 Am si eu o problema cu panasonic tx-40ex700b. Televizorul mi la facut o ruda din Spania cadou dar banuiesc ca a fost facut pt piata din UK, dupa un reset imi apare doar zona UK sau Irlanda Pe internet sau alte dracii merge fara probleme, in schimb pe TV, pe partea analog prinde doar cateva posturi, habar n-am in ce banda. Pe digital nu prinde nimic. Am pierdut o gramada de timp umbland prin meniu, la final tot ca curca-n lemne ma uit la el Orice sfat, idee este binevenite. Va multumesc. Link spre comentariu
iuliantv Postat Septembrie 2, 2023 Partajează Postat Septembrie 2, 2023 dupa experianta mea cu ele,nu ai ce.i face,doar sa gasesti mainboard pentru eu,sau ce.l mai accesibil daca aveti digital de la distribuitorul de cablu ,cereti un receiver,decodor....sau cumparati unul 100-150lei Link spre comentariu
AlpHs00 Postat Septembrie 3, 2023 Partajează Postat Septembrie 3, 2023 Cred ca va ramane pe post de youtube pt. juniori, nu ma omor prea tare dupa posturile TV. Va multumesc pt. timpul acordat. Stima! Link spre comentariu
bobo123 Postat Septembrie 4, 2023 Partajează Postat Septembrie 4, 2023 (editat) La 02.09.2023 la 0:06, AlpHs00 a spus: Am si eu o problema cu panasonic tx-40ex700b. Televizorul mi la facut o ruda din Spania cadou dar banuiesc ca a fost facut pt piata din UK, dupa un reset imi apare doar zona UK sau Irlanda Pe internet sau alte dracii merge fara probleme, in schimb pe TV, pe partea analog prinde doar cateva posturi, habar n-am in ce banda. Pe digital nu prinde nimic. Am pierdut o gramada de timp umbland prin meniu, la final tot ca curca-n lemne ma uit la el Orice sfat, idee este binevenite. Va multumesc. Eu am adus unul de 47" din Anglia. Cele cu terminatia B sunt facute pt UK si Irlanda, iar cele cu terminatie E sunt pt Europa( restul tarilor). Se pot importa profile pe un stick dintr un tv identic cu terminatia E, asa am procedat eu si am extins de la 14 programe la 43, cateva fara sunet. Prindea doar analog pe Uif. In cele din urma am pus un receiver si prind si digital si am rezolvat definitiv. Editat Septembrie 4, 2023 de bobo123 Link spre comentariu
iuliantv Postat Septembrie 4, 2023 Partajează Postat Septembrie 4, 2023 Acum 1 oră, bobo123 a spus: Eu am adus unul de 47" din Anglia. Cele cu terminatia B sunt facute pt UK si Irlanda, iar cele cu terminatie E sunt pt Europa( restul tarilor). Se pot importa profile pe un stick dintr un tv identic cu terminatia E, asa am procedat eu si am extins de la 14 programe la 43, cateva fara sunet. Prindea doar analog pe Uif. In cele din urma am pus un receiver si prind si digital si am rezolvat definitiv. poate vorbiti de panasonic vestel? Link spre comentariu
bobo123 Postat Septembrie 5, 2023 Partajează Postat Septembrie 5, 2023 Acum 16 ore, iuliantv a spus: poate vorbiti de panasonic vestel? Nu Vestel. Sasiu TPN parca, cand ajung acasa va pot spune exact sasiul. Link spre comentariu
