Vizitator Postat August 14, 2023 Partajează Postat August 14, 2023 (editat) Fara rezervari, ce se vinde ca defect nu are interventii interioare, adica nu s-a incercat depanarea aici in Romania. Rog fara negocieri, preturile sunt finale. Transport doar prin posta romana in sistem ramburs sau ridicare personala, exclus orice alta forma. 1. pick-up Wega (Sony), direct drive, doza si ac ok, functional, probleme usor reparabile la balamale, vezi poza spate. Pret 200 lei. https://imgur.com/2SSW0LX https://imgur.com/Q0Yywoh https://imgur.com/P3LhcZ3 https://imgur.com/ToI6R4z https://imgur.com/v2cpR5Z 2. pick-up Grundig, direct drive, brat tangential, perfect functional, doza si ac ok, 300 lei https://imgur.com/FcZ2akm https://imgur.com/VBBQIMf https://imgur.com/oO41aGS 3. minidisc Sony, defect, porneste doar daca si cand vrea el, 80 lei. https://imgur.com/KBgMS08 https://imgur.com/KBgMS08 https://imgur.com/9Zqp4vL 4. videorecorder Sony, porneste dar nu am caseta sa probez mai mult, se vinde ca defect 70 lei, cred ca am si telecomanda la el. https://imgur.com/8P0pIO7 https://imgur.com/wPt0DSx https://imgur.com/92CMrD0 5. amplificator Sony, functional, 150 lei https://imgur.com/nKw5GHT https://imgur.com/ycHRqf6 6. radio Philips functional pe toate gamele, o singura problema la tasta de display frecventa, inainte functiona, acuma vad ca nu. Pret 700 lei https://imgur.com/L8A89mh https://imgur.com/w0ldOft https://imgur.com/WPUkEGn 7. cd player Denon destul de hi-end, functional, necesita schimbare curea sertar, trebuie usor ajutat cu mana la inchidere. Pret 150 lei https://imgur.com/Ye6w7VE https://imgur.com/fT5maX5 https://imgur.com/BkNOZKr 8. preamplificator de microfoane functional lipsa cateva ornamente la butoane volum, 120 lei https://imgur.com/dsFfUHp https://imgur.com/yWDS24o Editat August 14, 2023 de fluffy37 Link spre comentariu
Tanase Ion Postat August 14, 2023 Partajează Postat August 14, 2023 Pct 1 il iau eu Link spre comentariu
Vizitator Postat August 15, 2023 Partajează Postat August 15, 2023 2. pick-up Grundig, direct drive, brat tangential, perfect functional, doza si ac ok, 300 lei https://imgur.com/FcZ2akm https://imgur.com/VBBQIMf https://imgur.com/oO41aGS 4. videorecorder Sony, porneste dar nu am caseta sa probez mai mult, se vinde ca defect 70 lei, cred ca am si telecomanda la el. https://imgur.com/8P0pIO7 https://imgur.com/wPt0DSx https://imgur.com/92CMrD0 5. amplificator Sony, functional, 150 lei https://imgur.com/nKw5GHT https://imgur.com/ycHRqf6 6. radio Philips functional pe toate gamele, o singura problema la tasta de display frecventa, inainte functiona, acuma vad ca nu. Pret 700 lei https://imgur.com/L8A89mh https://imgur.com/w0ldOft https://imgur.com/WPUkEGn 7. cd player Denon destul de hi-end, functional, necesita schimbare curea sertar, trebuie usor ajutat cu mana la inchidere. Pret 150 lei https://imgur.com/Ye6w7VE https://imgur.com/fT5maX5 https://imgur.com/BkNOZKr 8. preamplificator de microfoane functional lipsa cateva ornamente la butoane volum, 120 lei https://imgur.com/dsFfUHp https://imgur.com/yWDS24o adaug 9. deck Sony impecabil optic,laterale din lemn vumetre cu ace, functional, 250 lei https://imgur.com/hxQx6DI https://imgur.com/6WWiXa6 10. lot 4 radiouri neverificate numai impreuna 150 lei https://imgur.com/6yytvnA https://imgur.com/J43t2QP https://imgur.com/eQ0eGC2 11. amplificator Mars sunet bun, destul de greu, functional 100 lei https://imgur.com/7Khxu0l https://imgur.com/g7hdNHS 12. casetofon Blaupunkt de colectie, functional 50 lei https://imgur.com/unpSwWA https://imgur.com/kpgLVVS 13. casetofon Philips neverificat 30 lei https://imgur.com/nfkDrTQ 14. walkman Crown, neverificat 30 lei, ceva de frecventa in cutie, vad ca se aprinde un led si palpaie 25 lei https://imgur.com/PHojnj4 https://imgur.com/4BtUxqv Link spre comentariu
Simion Irinel Postat August 15, 2023 Partajează Postat August 15, 2023 14. walkman Crown, neverificat 30 lei, ceva de frecventa in cutie, vad ca se aprinde un led si palpaie 25 lei https://imgur.com/PHojnj4 https://imgur.com/4BtUxqv Doar casetofonul ma intereseaza. Link spre comentariu
Simion Irinel Postat August 15, 2023 Partajează Postat August 15, 2023 11. amplificator Mars sunet bun, destul de greu, functional 100 lei https://imgur.com/7Khxu0l https://imgur.com/g7hdNHS Link spre comentariu
Dj_Dog Postat August 15, 2023 Partajează Postat August 15, 2023 Salut! Amp Sony il vreau eu Link spre comentariu
vasile barsan Postat August 15, 2023 Partajează Postat August 15, 2023 "ceva de frecventa in cutie, vad ca se aprinde un led si palpaie 25 lei" - ESTE UN : Generator de câmp magnetic al sistemului de suprimare a interferențelor Magnethera Duo Star 2000 Dual System - este utilizat pentru aplicarea țintită a câmpurilor magnetice pulsate pe corpul uman - conform producătorului, terapia cu câmp magnetic poate promova puteri de autovindecare și accelera vindecarea - dispozitivul generează un câmp magnetic pulsant de o anumită frecvență și intensitate - frecvențele poate fi setat usor si precis. - controlat cu quartz - complet automat - optoelectronica - interval automat - Dimensiuni: unitate principala: 33x38x5 cm (lxpxh); Mini dispozitiv 33x23 cm (lxl) Aplicații posibile ale terapiei cu câmp magnetic - crește conținutul de oxigen din țesutul celular - crește aportul de nutrienți către celule - întărește sistemul imunitar - ameliorarea durerilor de cap, migrene, dureri nervoase, dureri la nervul sciatic și dureri cauzate de hernia de disc sau amputații Pacat ca nu este tot dispozitivul.. Dar succes! Link spre comentariu
yo9hrb Postat August 15, 2023 Partajează Postat August 15, 2023 Acum 3 ore, fluffy37 a spus: 13. casetofon Philips neverificat 30 lei https://imgur.com/nfkDrTQ Asta il vreau eu. Link spre comentariu
Vizitator Postat August 15, 2023 Partajează Postat August 15, 2023 (editat) 1 oră în urmă, vasile barsan a spus: "ceva de frecventa in cutie, vad ca se aprinde un led si palpaie 25 lei" - ESTE UN : Generator de câmp magnetic al sistemului de suprimare a interferențelor Magnethera Duo Star 2000 Dual System - este utilizat pentru aplicarea țintită a câmpurilor magnetice pulsate pe corpul uman - conform producătorului, terapia cu câmp magnetic poate promova puteri de autovindecare și accelera vindecarea - dispozitivul generează un câmp magnetic pulsant de o anumită frecvență și intensitate - frecvențele poate fi setat usor si precis. - controlat cu quartz - complet automat - optoelectronica - interval automat - Dimensiuni: unitate principala: 33x38x5 cm (lxpxh); Mini dispozitiv 33x23 cm (lxl) Aplicații posibile ale terapiei cu câmp magnetic - crește conținutul de oxigen din țesutul celular - crește aportul de nutrienți către celule - întărește sistemul imunitar - ameliorarea durerilor de cap, migrene, dureri nervoase, dureri la nervul sciatic și dureri cauzate de hernia de disc sau amputații Pacat ca nu este tot dispozitivul.. Dar succes! Multumesc. edit; maine trimit toate coletele. Editat August 15, 2023 de fluffy37 Link spre comentariu
Tanase Ion Postat August 15, 2023 Partajează Postat August 15, 2023 De la 14 vreau ceva de frecventa daca e disponibil Link spre comentariu
Tanase Ion Postat August 17, 2023 Partajează Postat August 17, 2023 Azi am ridicat coletul, pickupl Wega a ajuns cu bine, cu stima si respect multumesc frumos Link spre comentariu
Simion Irinel Postat August 18, 2023 Partajează Postat August 18, 2023 9. deck Sony impecabil optic,laterale din lemn vumetre cu ace, functional, 250 lei https://imgur.com/hxQx6DI https://imgur.com/6WWiXa6 Link spre comentariu
Simion Irinel Postat August 18, 2023 Partajează Postat August 18, 2023 Va salut,am ridicat coletul,va multumesc multa stima si respect, Link spre comentariu
Vizitator Postat August 18, 2023 Partajează Postat August 18, 2023 2. pick-up Grundig, direct drive, brat tangential, perfect functional, doza si ac ok, 300 lei https://imgur.com/FcZ2akm https://imgur.com/VBBQIMf https://imgur.com/oO41aGS 4. videorecorder Sony, porneste dar nu am caseta sa probez mai mult, se vinde ca defect 70 lei, cred ca am si telecomanda la el. https://imgur.com/8P0pIO7 https://imgur.com/wPt0DSx https://imgur.com/92CMrD0 6. radio Philips functional pe toate gamele, o singura problema la tasta de display frecventa, inainte functiona, acuma vad ca nu. Pret 700 lei https://imgur.com/L8A89mh https://imgur.com/w0ldOft https://imgur.com/WPUkEGn 7. cd player Denon destul de hi-end, functional, necesita schimbare curea sertar, trebuie usor ajutat cu mana la inchidere. Pret 150 lei https://imgur.com/Ye6w7VE https://imgur.com/fT5maX5 https://imgur.com/BkNOZKr 8. preamplificator de microfoane functional lipsa cateva ornamente la butoane volum, 120 lei https://imgur.com/dsFfUHp https://imgur.com/yWDS24o 10. lot 4 radiouri neverificate numai impreuna 150 lei https://imgur.com/6yytvnA https://imgur.com/J43t2QP https://imgur.com/eQ0eGC2 12. casetofon Blaupunkt de colectie, functional 50 lei https://imgur.com/unpSwWA https://imgur.com/kpgLVVS adaug 15. amplificator onkyo functional 150 lei (destul de greu) https://imgur.com/ya9bi16 https://imgur.com/s8RrHk0 16. boxe grundig functionale 80 lei https://imgur.com/ttMaZV3 https://imgur.com/2rRUKkG 17. boxe tento (kashtan) functionale aspect foarte bun, 170 lei https://imgur.com/PfgubKn https://imgur.com/DrTJk3p https://imgur.com/QOSTIfc https://imgur.com/x7ZCskW 18. mixer audio neverificat vad ca becurile se aprind 80 lei https://imgur.com/Svq3Xda https://imgur.com/M9TWBfD 19. sistem logitech functional 40 lei https://imgur.com/fQ2wKMm https://imgur.com/T0vBzHE 20. aparat greu din cate am vazut putin pe net are legatura cu dantura....nu stiu cum si daca functioneaza 200 lei, e complet are si pedala. Preturi pe net pe la 1000 euro.... https://imgur.com/VKkmRif https://imgur.com/KFAZ4Qa https://imgur.com/6MUyRmV https://imgur.com/K5v2DDe 21. amplif auto philips neverificat 30 lei https://imgur.com/NWPYGSr https://imgur.com/OUb0DfT https://imgur.com/R8OkYkz Link spre comentariu
