Componente TV, Audio, diverse electronice
gogu firescu
Vand Placa de baza BN41-01587E din Samsung 46UE6510WS, am achizitionat-o cu 300lei pentru un TV luat din targ, insa dupa montare am descoperit ca ecranul este defect.
Pretul este acelasi, 300lei, pentru 450 lei ofer toate componentele din TV, mainboard, tcon, sursa, modul WI-FI, cabluri, ochelari 3D ...
https://imgur.com/taziSsL
https://imgur.com/TX4TzBm
https://imgur.com/1fruqZw
mainboard 715G8709-MOE-B00-005N - pret 200 lei
t-con 6870C-0535B - pret 80lei
sursa: 715G8672-P02-000-002H - 150 lei
Componente TV Led TOSHIBA 50L2456D cu ecran spart
sursa FSP108-3FS01, PK101W0800I 140 lei
mainboard SR0500 VTV-L50005 140 lei
Editat de gogu firescu
  • Răspunsuri 18
  • gogu firescu
    16
  • razzvann
  • iuliantv
1.Vand Placa de baza BN41-01587E din Samsung 46UE6510WS, am achizitionat-o cu 300lei pentru un TV luat din targ, insa dupa montare am descoperit ca ecranul este defect.
2. mainboard 715G8709-MOE-B00-005N - pret 200 lei
3.Componente TV Led TOSHIBA 50L2456D cu ecran spart
4. Multimetru digital, ecran tactil Mustool MT111 6000,AC/DC/DC, RMS, Negru - 200lei
    Este nou, doar testat
  Display mode: triple display LCD; main display, sub display, analog bar;
   Maximum display: 5999 (5 5/6) bit automatic polarity display;
   Measurement method: double integral A/D conversion;
   Sampling rate: about 3 times per second;
   Over range display: The highest position shows “OL”;
   Continuous power operation function;
   Low voltage display
   Power: AAA 2* 1.5V battery;
   Volume (size): 139×68×18mm (L×W×H);
   Weight:about 175g;
  5. Soundbar Sandstrøm   SSBDA13E  - 200lei
                https://imgur.com/DsqpZz4
                https://imgur.com/fjhlWXk
      - nu am  telecomanda
              Intrari: AUX , DAB , MP3 LINK ,OPTICAL1
              Tuner:                     FM: 87.5 – 108 MHz
                                             DAB: 174 –240 MHz
              Power Supply AC 220-240V~50/60Hz
              ECO Standby Power Consumption < 0.5W
              Speaker Output Power 30W x 2
              Net Weight 2.0kg
              Dimensions 1068mm (W) x 51mm (D) x 83mm (H
  • 2 săptămâni mai târziu...
2.Componente Philips 55PUS6272
    tabla panel cu  6 barete formate din cate 2 barete care se imbina, fiecare cu cate 5 leduri - pret 150 lei
   Low voltage display
   Weight:about 175g;
      - nu am  telecomanda
                                             DAB: 174 –240 MHz
              Net Weight 2.0kg
  • 3 săptămâni mai târziu...
4. Soundbar Sandstrøm   SSBDA13E  - 200lei
      - nu am  telecomanda
                                             DAB: 174 –240 MHz
              Net Weight 2.0kg
              Dimensions 1068mm (W) x 51mm (D) x 83mm (H)
Multimetrul vandut, multumiri domnului razzvann
Restul valabile
1.Vand Placa de baza BN41-01587E din Samsung 46UE6510WS  250lei
Pentru 375 lei ofer toate componentele din TV, mainboard, tcon, sursa, modul WI-FI, cabluri, ochelari 3D ...
    mainboard 715G8709-MOE-B00-005N - pret 170 lei
    t-con 6870C-0535B - pret 75lei
    sursa: 715G8672-P02-000-002H - 130 lei
    tabla panel cu  6 barete formate din cate 2 barete care se imbina, fiecare cu cate 5 leduri - pret 130 lei
  • 2 luni mai târziu...
1.Vand Placa de baza BN41-01587E din Samsung UE46D6510WS , UE40D6510 - 250lei
    sursa: 715G8672-P02-000-002H - vandut la stefank , multumesc
Acum 13 minute, gogu firescu a spus:
modelul tv e trecut gresit,trebuie sa fie ceva ue46D6510WS ,nu e repros din partea mea,doar ca e pacat ,ca e o placa cautata,si unii se pierd in detalii,daca nu e modelul de tv ca si al lor,cred ca nu e ceea ce trebuie
cosiderati.l un up din partea mea
