Vand placa de sunet profesionala RME Fireface 800
danipasc
Vand placa de sunet profesionala RME Fireface 800.
Placa a fost folosita in regim home studio.
Pret: 2100 lei usor negociabil.
Technical Specifications
Input AD: 8 x 1/4" TRS, 4 x XLR Mic, 4 x 1/4" TRS Line, all servo-balanced. 1 x 1/4" TS unbalanced
Output DA: 8 x 1/4" TRS, servo-balanced, DC-coupled signal path. 1 x 1/4" TRS unbalanced
Input Digital: 2 x ADAT optical or SPDIF optical, SPDIF coaxial (AES/EBU compatible)
Output Digital: 2 x ADAT optical or SPDIF optical, SPDIF coaxial (AES/EBU compatible)
MIDI: 1 x MIDI I/O via 5-pin DIN jacks, for 16 channels low jitter hi-speed MIDI
Dynamic range AD: 109 dB RMS unweighted, 112 dBA
THD AD: -110 dB ( 0.00032 %)
THD+N AD: -104 dB ( 0.00063 %)
Crosstalk AD: > 110 dB
Dynamic range DA: 116 dB RMS unweighted, 119 dBA (unmuted)
THD DA: -103 dB ( 0.0007 %)
THD+N DA: -100 dB ( 0.001 %)
Crosstalk DA: > 110 dB
Input/Output level for 0 dBFS Hi Gain: +19 dBu
Input/Output level for 0 dBFS +4 dBu: +13 dBu
Input/Output level for 0 dBFS -10 dBV: +2 dBV
Sample rate internally: 32, 44.1, 48, 64, 88.2 kHz, 96 kHz, 128, 176.4, 192 kHz
Sample rate externally: 28 kHz - 200 kHz
Frequency response AD/DA: -0.1 dB: 5 Hz - 21.5 kHz (sf 48 kHz)
Frequency response AD/DA: -0.5 dB: 5 Hz - 43.5 kHz (sf 96 kHz)
Frequency response AD/DA: -1 dB: 5 Hz - 70 kHz (sf 192 kHz)
  • Răspunsuri 8
  • danipasc
    9
  • 2 săptămâni mai târziu...
  • 4 săptămâni mai târziu...
  • 2 luni mai târziu...
  • 1 lună mai târziu...
