Module, cablaje, componente audio si RF III
  • Răspunsuri 94
Astazi nimic nou, am pregatit pachete si am sters ce s-a mai dat!
1.  Hdd laptop SATA 120 Gb, pret 12 lei
https://imgur.com/F2Yrejj
2. Hdd laptop SATA 250 Gb, pret 24 lei
https://imgur.com/uKeKoVt
3. HDD extern IDE, conectare prin USB, sint de fapt niste media playere, dar nu au telecomenzi si nici softul original instalat.
Se pot folosi deci doar pentru stocare de date. Pret 40 lei
https://imgur.com/lSSzZ5q
5.  Potentiometre rusesti, 680K, 10k si 220K, noi, pret 3 lei bucata
https://imgur.com/Vv3CiLI
8. Rezistente neinductive, 47 ohm/5 watt, pret 6 lei bucata
https://imgur.com/Flbc6hJ
9. doua filtre 10,7 mhz, noi, pret 6 lei bucata
https://imgur.com/Jxro27F
10. unitate Iomega Zip, 750 mb, pret 25 lei
https://imgur.com/hong8AJ
12. Point manager, pret 50 lei, mai multe info aici: https://www.embeddeddatasystems.com/Point-Manager_p_60.html
https://imgur.com/n9P9h2G
14. Max6350 (referinte tensiune 5V) si MAX7400 (smd), pret 12 lei bucata
https://imgur.com/dpBUHyo
20. Releu bengos, capsulat, nou, comanda 24v, pret 8 lei
https://imgur.com/GT1NSk3
23. Condensatori tensiuni mari, pret 75 lei toti!
https://imgur.com/QtCRtHZ
26.  Alte rezistente de volum, neinductive, pret 3 lei bucata
https://imgur.com/OfpaZsG
27. Doua difuzoare Panasonic, 8 ohm/7watt, pret 15 lei ambele
https://imgur.com/SDteG4v
29. Condensator 470pF/20Kv, pret 8 lei
https://imgur.com/0zXR1n7
30.  Termostat cu fir, dar cu multe facilitati! pret 30 lei.
https://imgur.com/nAlOKCH
31.Cristale 9 Mhz, pret 1,4 lei bucata!
https://imgur.com/PmCSFjg
32. 4 buc. tranz. C2539, doua lipite pentru masuratori, pret excelent, 80 de lei toate! sau 50 lei perechea nelipita si 30 cea cu urme de lipituri!!!
https://imgur.com/byTfLGp
33. ''Detector'' de pisici! 15 lei bucata!
https://imgur.com/9oeHSAo
34. Pastile scule aschiatoare, 2 lei bucata!
https://imgur.com/pDfUAJ8
35. Media convertor, intrare optica, iesire coax. 75 ohm, pret 50 lei
https://imgur.com/AAxHWRh
36.PCB+integrate+releu (SH) pentru sursa K7200, rezistentele din emitoarele tranz. de putere nu sint pe placa, sint lipite direct la terminalul respectiv. pret 34 lei
https://imgur.com/G4REklu
37. Module preamplificator (doza magnetica cred), nu am schema, dar nu ar trebui sa puna probleme identificarea pinilor, pret 16 lei doua bucati!
https://imgur.com/Dlo3ngl
38.CI tip TAA765, inca prezente in diverse automatizari industriale, greu de gasit,  pret 2,5 lei bucata pentru 10 bucati!!!
https://imgur.com/jf9vwzo
39. PCB plus microcontroler progamat pentru GOESR (capacimetru+ESR), pret 38 lei. Suplimentar, cred ca mai am si restul integratelor!
https://imgur.com/qj02rub
41. PCB pentru testerul pentru FBT, deflexii, etc. 10 lei sau 40 lei complet!
https://imgur.com/eToabj8
https://www.flippers.com/fbt-main.html
42. placa dintr-un UPS functional, pret 15 lei
https://imgur.com/4e4Beo5
43.  Cuarturi 4Khz  pret 15 lei bucata
https://imgur.com/kfMv9Zy
44. Comutator cu pedala, calitate medicala, NOU, pret 24 lei bucata
https://imgur.com/vuakYbv
45.Modul FI-MF, demodulator,   AAF, nou, 10 lei
https://imgur.com/ICsxhy8
46. Google Chromecast TV, 4K, HDMI, Bluetooth, Wi-Fi, Alb, absolut nou, pret 220 lei!!!
https://imgur.com/LMe9L6W
47. casete video profesionale Betamax SONY, absolut noi, 10 lei bucata!!!
https://imgur.com/CzftMjD
48.cablu Home Cinema, lungime 5 metri, pret 30 lei!  NOU
https://imgur.com/IUmGi3B
https://imgur.com/mFdMiiK
49.Cablu DVI-I la DVI-I, lungime 5 metri, pret 35 lei  NOU
https://imgur.com/z1Y0ebr
     Toate cablurile sint noi, sigilate, productie Franta, calitate profesionala!!!
50.Transformator dintr-un UPS de 600VA, pret 20 lei
https://imgur.com/JjIdQuo
51.IOMEGA ZIP, de 10 M, noi, sigilate 10 lei bucata!!!
https://imgur.com/O0Xe5QQ
52.Mixer activ, AD831APZ, 15 lei bucata!
https://imgur.com/vCqJXwc
54. Tuburi 6K1P, noi, pret 4,5 lei bucata!!!
https://imgur.com/t9jUKXu
55. Tuburi 6H2P, noi, 4 lei bucata
https://imgur.com/xL25quE
56. Tub 6F1P, pret 5 lei
https://imgur.com/bPDQPcd
57. Rezonatoare quartz, 30khz, noi, pret 6 lei bucata!
https://imgur.com/kHGqKFd
continuare:
60. 6E6P-E (6Э6П-Е) o bucata, 15 lei!!!
https://imgur.com/E1LioZV
62. PCF802 si PCF80
https://imgur.com/zBumKZi
63.EF184, 5 lei bucata
https://imgur.com/CNUGmSm
65.6J2P-EV, 6 lei bucata!!!
https://imgur.com/ROqYpGV
66.EF183, 4 lei bucata
https://imgur.com/nNzDOsN
67. 6J9P, 5 lei bucata!!!
https://imgur.com/0urmamQ
70.Tub EF80, pret 8 lei bucata!!!
https://imgur.com/DpWzw8L
73.Tub 6J20P, 4 lei bucata
https://imgur.com/LhFfMgd
75. Alt set de la un echipament militar, pret 15 lei
https://imgur.com/zNnNZ4r
76. 2 socluri LOCTAL, pret 12 lei bucata
https://imgur.com/k4BI7GO
78. 4 socluri LOCTAL, 20 lei bucata
https://imgur.com/3GrZf5W
80. radiator cu 4 tranzistoare, medie putere, Ge
pret 15 lei toate
https://imgur.com/fC0gTFB
https://imgur.com/Nm9htva
81. Quartzuri dintr-o statie militara, 12 lei toate
https://imgur.com/kAztkNu
82. Soua statii radio, functioneaza, dar nu au antene,
acumulatori defecti, 25 lei ambele
https://imgur.com/SsId3gY
83.Socuri anodice, din echipament militar, 6 lei bucata
https://imgur.com/9RQZU7K
84. Alte socuri anodice, pret 20 lei ambele
https://imgur.com/wntwOrc
90. Ansamblu doua transformatoare cu montare pe sina,
pret 18 lei
https://imgur.com/2KsfvKm
 Acumulatori ramasi in urma unei idei proaste, dar abandonata la timp, sint absolut noi
iar preturile sint mult sub cele de achizitie!!!
91. Acumulator LiPo 3,7V/4400 mA, testat la curent de descarcare de 1A,
s-au consumat din el 4600 mA. protejat la scc, supraincarcare sau descrcare,
pret 100 lei, a costat peste 200!!!
https://imgur.com/4iYOZ1c
https://imgur.com/BRX3pdn
92. Acumulatori de la IKEA, 1900 mA, pret 28 lei/set
https://imgur.com/K2Kplsf
93. Acumulatori de la IKEA, 2450 mA, pret35 lei/set
https://imgur.com/GkhdLvI
94. 3 placi pentru folosit sau recuperat componente, pret 15 lei toate 3.
https://imgur.com/ZhbP62I
95. alt cablu cu mufe, RP-TNC cred ca se numesc, 10 lei
https://imgur.com/wiC3uAs
96. doua relee de timp, pret 18 lei ambele
https://imgur.com/thwejly
98. Parca un temporizator, cindva am gasit documentatie pe net despre el, 14 lei
https://imgur.com/WrsdrFZ
99. cleme de cablaj, 1 leu sirul de 10 bucati
https://imgur.com/GjGnOxj
100. radio cu ceas, SONY de la mama lui, 35 lei
https://imgur.com/zftsN2i
Dacă mai sînt valabile, vă rog adăugați la pachetul meu și :
50.Transformator dintr-un UPS de 600VA, preț 20 lei, https://imgur.com/JjIdQuo
75. Alt set de la un echipament militar, preț 15 lei, https://imgur.com/zNnNZ4r
90. Ansamblu doua transformatoare cu montare pe șina, preț 18 lei, https://imgur.com/2KsfvKm
96. doua relee de timp, preț 18 lei ambele, https://imgur.com/thwejly
98. Parca un temporizator, cîndva am găsit documentație pe net despre el, 14 lei, https://imgur.com/WrsdrFZ
Detalii prin MP. Mulțumesc !
Le-am pus bine pt. dv.
am mai adugat citeva fleacuri si am sters ce nu mai este disponibil.
Am sters ce s-a dat si am mai adaugat altele noi:
continuare:
62. PCF802 si PCF80
pret 15 lei toate
101. incarcator acumulatori, vindut mai demult la Penny,
este bun, dar nu se impaca cu acumulatorii dubiosi, 15 lei
https://imgur.com/8ygFaEV
102. Surse 5V/3A, de foarte buna calitate, Taiwan, pret 10 lei bucata
https://imgur.com/LWO4x1I
103. Tuburi PL500. Arata dubias, dar testate intrun amplificator audio,
cu 250V anodic nu au facut nazuri. pret 15 lei toate 4.
https://imgur.com/torGqj8
104. DC/DC 12V/2,5A pret 8 lei
https://imgur.com/QMAAILr
105. 2 boxe blue tech, 150Wrms/8 ohmi.
Garantez ca au fost foarte putin folosite si la puteri mici.
 pret 250 lei ambele. Doar ridicare personala!
https://imgur.com/AT4zNpz
106. GAL16V8D, pret 3 lei bucata
https://imgur.com/rQULZgz
107. Placa RR Milcov, functioneaza bine pe UM, nu merge OL pe lungi,
are comutatorul de game nou, pret 18 lei
https://imgur.com/YBmiLaO
108. 20 relee reed, 20 de lei toate!
https://imgur.com/kh7PIdn
109. filtre retea provenite din tehnica de calcul RDR, pret 8 lei bucata
https://imgur.com/ccqf4eM
110. modul alimentare din ceva audio romanesc, pret 10 lei
https://imgur.com/ENZUIzV
111. intreruptoare, pret 10 lei cele monofazate si 20 lei cele trifazate.
multi 9 este un brand Schneider!
https://imgur.com/TIkl0ty
112. doua difuzoare, pret 8 lei ambele
https://imgur.com/Ius1aMf
113. IGBT-uri de la mama lor, recuperate, pret 5 lei bucata
https://imgur.com/AuUSNtd
114. 3 PCB-uri pentru recuperat potentiometri de calitate, pret 12 lei toate trei!
https://imgur.com/idRdksn
115. Butoane metalice noi, produse de IEI, stringere cu penseta,
pret 3 lei bucata/10 lei toate 4.
https://imgur.com/df9wiUC
116. Binecunoscuta sursa 12V/30A, utilizabila la transceiverele pentru radioamatori!
pret 60 lei
https://imgur.com/QvRE8Ya
117. doua mufe BNC noi, pret 5 lei ambele
https://imgur.com/ywE6yCO
118. Amplificator casti, integratul smd este pe spate, 10 lei
https://imgur.com/M4vQQSf
119. Surse 3,3v, pret 6 lei bucata
https://imgur.com/G1zLtZy
120. Amplificator receptie satelit, include alimentarea, pret 10 lei
https://imgur.com/NlzNpis
121. carcasa alimentator mica putere, are montajul complet, inclusiv tr. regulator,
fara transformator, are si capac, nu este prea vizibil in poza, pret 10 lei
https://imgur.com/Oy7JKjT
122. Alt filtru de retea, pret 10 lei
https://imgur.com/Voxsg7Q
123. miez tr. ferita, pret 6 lei
https://imgur.com/D38hRBl
124. 47 micro la 250V, pret 1,5 lei bucata
https://imgur.com/1QsY2Dz
125. diode redresoare inalta tensiune, pret 18 lei toate
https://imgur.com/SJB20j3
126. difuzoare 16 ohmi, pret 12 lei ambele
https://imgur.com/mZWBGi2
https://imgur.com/2zkPpIq
127. filtre receptie din radiotelefoane de banda 4, pret 8 lei bucata
https://imgur.com/zY8o9zA
128. amplificatoare hibride CATV, noi majoritatea, functionare perfect liniara,
pentru canale tv sau pentru calea inversa, pret 8 lei bucata!!!
https://imgur.com/XFogxxH
129. comutatoare, inclusiv butoanele cu stringere pe penseta, pret 5 lei bucata!
https://imgur.com/gbqvR8g
130. set butoane echipament militar, noi, nu au suruburile de fixare pe ax,
pret 10 lei toate 5
https://imgur.com/QUaEf4s
131. minicombina audio, CD, FM, DAB, semidefecta, se opreste dupa 10 minute,
am inteles ca se rezolva soft!? pret 15 lei
https://imgur.com/XRBb902
132. doua ventilatoare sanatoase, pret 25 lei bucata.
pot functiona neoprite cu lunile.
https://imgur.com/dRqb1Ud
133. modul DC/DC, pret 8 lei
https://imgur.com/DopyrSS
134. surse excelente, reglabile in jurul valorii de 30 volti
(24,5-35,5), pret 15 lei bucata. la una a fost taiat o bucata
de cablaj in zona conectorului de intrare, e inestetic
dar nu afecteaza functionarea. Produse in japonia!
https://imgur.com/3nlwMQ8
mai urmeaza!
