Marele Savant Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 De vinzare cele de mai jos. Livrare preferabil prin curier si plata prin banca! in Bucuresti ne putem intilni. deoarece este posibil ca peste 2-4 saptamini sa plec pentru o perioada din tara, nu mai fac ''rezervari'' pe termen nedeterminat! 1. Hdd laptop SATA 120 Gb, pret 12 lei https://imgur.com/F2Yrejj 2. Hdd laptop SATA 250 Gb, pret 24 lei https://imgur.com/uKeKoVt 3. HDD extern IDE, conectare prin USB, sint de fapt niste media playere, dar nu au telecomenzi si nici softul original instalat. Se pot folosi deci doar pentru stocare de date. Pret 40 lei bucata, disponibile doua bucati! https://imgur.com/lSSzZ5q 4.modul calit, cu diverse componente fata/spate , nou. pret 5 lei https://imgur.com/XrRuMvw 5. Potentiometre rusesti, 680K, 10k si 220K, noi, pret 3 lei bucata https://imgur.com/Vv3CiLI 6. Potentiometre bobinate 1, pret 4 lei bucata https://imgur.com/iKQJdzT 7.Ampermetru, clasa 0.5, 20 lei https://imgur.com/IYbJws6 8. Rezistente neinductive, 47 ohm/5 watt, pret 6 lei bucata https://imgur.com/Flbc6hJ 9. doua filtre 10,7 mhz, noi, pret 6 lei bucata https://imgur.com/Jxro27F 10. unitate Iomega Zip, 750 mb, pret 25 lei https://imgur.com/hong8AJ 11. placa pentru recuperat componente 1, pret 8 lei https://imgur.com/Iu7uluw 12. Point manager, pret 50 lei, mai multe info aici: https://www.embeddeddatasystems.com/Point-Manager_p_60.html https://imgur.com/n9P9h2G 13. Voltmetru clasa 0.5, 20 lei https://imgur.com/1DbRE4M 14. Max6350 (referinte tensiune 5V) si MAX7400 (smd), pret 12 lei bucata https://imgur.com/dpBUHyo 15. Butoane actionare pot. multitur, 5 lei bucata! https://imgur.com/r8XbdkL 16. Modul convertizor tensiune, defect, pret 5 lei https://imgur.com/aR4t4gQ https://imgur.com/n1hmlQY 17. relee RES15, pret 3 lei bucata https://imgur.com/7G6YNs1 18. Comutator calit, nou, 2x11 pozitii, pret 25 lei https://imgur.com/5zOZoQk 19. ''Izolator'' antena, plus cablu cu doua mufe sertizate, pret 15 lei https://imgur.com/sO5isjz 20. Releu bengos, capsulat, nou, comanda 24v, pret 8 lei https://imgur.com/GT1NSk3 21. Modul pentru recuperat carcasa si componente, pret 10 lei https://imgur.com/ROxw0Io 22. potentiometri bobinati 2, pret 5 lei bucata https://imgur.com/QtCRtHZ 23. Condensatori tensiuni mari, pret 75 lei toti! https://imgur.com/QtCRtHZ 24. Comutator calit, 3x2 pozitii, pret 6 lei https://imgur.com/DH8pmyz 25. Cutie cu montaj electronic in interior, calitate militara, pret 15 lei! https://imgur.com/7uiBlLg 26. Alte rezistente de volum, neinductive, pret 3 lei bucata https://imgur.com/OfpaZsG 27. Doua difuzoare Panasonic, 8 ohm/7watt, pret 15 lei ambele https://imgur.com/SDteG4v 28. Sonda de masura RF cu bucla! pret 12 lei https://imgur.com/06TcwCy 29. Condensator 470pF/20Kv, pret 8 lei https://imgur.com/0zXR1n7 30. Termostat cu fir, dar cu multe facilitati! pret 30 lei. https://imgur.com/nAlOKCH 31.Cristale 9 Mhz, pret 1,4 lei bucata! https://imgur.com/PmCSFjg 32. 4 buc. tranz. C2539, doua lipite pentru masuratori, pret excelent, 80 de lei toate! sau 50 lei perechea nelipita si 30 cea cu urme de lipituri!!! https://imgur.com/byTfLGp 33. ''Detector'' de pisici! 15 lei bucata! https://imgur.com/9oeHSAo 34. Pastile scule aschiatoare, 2 lei bucata! https://imgur.com/pDfUAJ8 35. Media convertor, intrare optica, iesire coax. 75 ohm, pret 50 lei https://imgur.com/AAxHWRh 36.PCB+integrate+releu (SH) pentru sursa K7200, rezistentele din emitoarele tranz. de putere nu sint pe placa, sint lipite direct la terminalul respectiv. pret 34 lei https://imgur.com/G4REklu 37. Module preamplificator (doza magnetica cred), nu am schema, dar nu ar trebui sa puna probleme identificarea pinilor, pret 16 lei doua bucati! https://imgur.com/Dlo3ngl 38.CI tip TAA765, inca prezente in diverse automatizari industriale, greu de gasit, pret 2,5 lei bucata pentru 10 bucati!!! https://imgur.com/jf9vwzo 39. PCB plus microcontroler progamat pentru GOESR (capacimetru+ESR), pret 38 lei. Suplimentar, cred ca mai am si restul integratelor! https://imgur.com/qj02rub 40. PCB pentru 6 filtre trece banda, inclusiv atenuator si preamplificatoare pentru Rx si Tx. pret 14 lei, doar PCB-ul!!! https://imgur.com/YqkRxwu ULTIMA BUCATA! 41. PCB pentru testerul pentru FBT, deflexii, etc. 10 lei sau 40 lei complet! https://imgur.com/eToabj8 https://www.flippers.com/fbt-main.html 42. placa dintr-un UPS functional, pret 15 lei https://imgur.com/4e4Beo5 43. Cuarturi 4Khz pret 15 lei bucata https://imgur.com/kfMv9Zy 44. Comutator cu pedala, calitate medicala, NOU, pret 24 lei bucata https://imgur.com/vuakYbv 45.Modul FI-MF, demodulator, AAF, nou, 10 lei https://imgur.com/ICsxhy8 46. Google Chromecast TV, 4K, HDMI, Bluetooth, Wi-Fi, Alb, absolut nou, pret 220 lei!!! https://imgur.com/LMe9L6W 47. casete video profesionale Betamax SONY, absolut noi, 10 lei bucata!!! https://imgur.com/CzftMjD 48.cablu Home Cinema, lungime 5 metri, pret 30 lei! NOU https://imgur.com/IUmGi3B https://imgur.com/mFdMiiK 49.Cablu DVI-I la DVI-I, lungime 5 metri, pret 35 lei NOU https://imgur.com/z1Y0ebr Toate cablurile sint noi, sigilate, productie Franta, calitate profesionala!!! 50.Transformator dintr-un UPS de 600VA, pret 20 lei https://imgur.com/JjIdQuo 51.IOMEGA ZIP, de 10 M, noi, sigilate 10 lei bucata!!! https://imgur.com/O0Xe5QQ 52.Mixer activ, AD831APZ, 15 lei bucata! https://imgur.com/vCqJXwc 53.Tuburi 6N3P-EV, dubla trioda, long life, calitate militara, excelente in audio, 8 lei bucata! Disponibile 8 bucati! https://imgur.com/dxVSNHG 54. Tuburi 6K1P, noi, pret 4,5 lei bucata!!! https://imgur.com/t9jUKXu 55. Tuburi 6N2P, noi, 4 lei bucata https://imgur.com/Ucsh7gO 56. Tub 6F1P, pret 5 lei https://imgur.com/bPDQPcd 57. Rezonatoare quartz, 30khz, noi, pret 6 lei bucata! https://imgur.com/kHGqKFd 58. Tuburi 6N1P, noi, pret 8 lei bucata!!! https://imgur.com/73jgOy8 59. Dubla dioda ruseasca, pret 4 lei bucata https://imgur.com/xL25quE mai urmeaza! Link spre comentariu
dann_262003 Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 salutare.potentiometrele de la pct 5 sunt stereo? Link spre comentariu
imre1968 Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 15. Butoane actionare pot. multitur, 5 lei bucata! = 6 buc Link spre comentariu
imreberes Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 (editat) Doresc pct 4,16,21, 25 si 53 toate ! Editat Mai 17, 2023 de imreberes Link spre comentariu
imre1968 Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 18. Comutator calit, nou, 2x11 pozitii, pret 25 lei 24. Comutator calit, 3x2 pozitii, pret 6 lei Link spre comentariu
imre1968 Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 Acum 15 minute, imreberes a spus: 53 toate ! putem sa le impartim (macar 2 buc pt. celelat Imre) ? Link spre comentariu
ndor Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 Salut Ma interesaza pct.15 . Discutam in PM daca nu sunt deja arvunite. Multumesc Link spre comentariu
PavelR Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 6. Potentiometre bobinate 1, pret 4 lei bucata -toate 3 36.PCB+integrate+releu (SH) pentru sursa K7200, rezistentele din emitoarele tranz. de putere nu sint pe placa, sint lipite direct la terminalul respectiv. pret 34 lei 22. potentiometri bobinati 2, pret 5 lei bucata -ambele 14. Max6350 (referinte tensiune 5V) pret 12 lei bucata 1 bucata 58. Tuburi 6N1P, noi, pret 8 lei bucata!!! -toate Link spre comentariu
imreberes Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 OK, renunt la 2 buc 6N3P-EV, in favoarea lui celalalt Imre, adica pt @imre1968! Link spre comentariu
PavelR Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 5. Potentiometre rusesti, 10k noi, pret 3 lei bucata - 7 bucati Link spre comentariu
imre1968 Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 Acum 5 minute, imreberes a spus: OK, renunt la 2 buc 6N3P-EV, in favoarea lui celalalt Imre, adica pt @imre1968! Multumesc Link spre comentariu
grosu99 Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 PCT 19,28 ,40, 14 2buc MAX6350 Link spre comentariu
dan-a2 Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 Punctul 3 ,1buc. aveti pm. Link spre comentariu
sonic11 Postat Mai 17, 2023 Partajează Postat Mai 17, 2023 (editat) Dacă mai este ceva din punctul 15 vreau si eu și 13 Editat Mai 17, 2023 de sonic11 Link spre comentariu
Marele Savant Postat Mai 17, 2023 Autor Partajează Postat Mai 17, 2023 Acum 2 ore, dann_262003 a spus: salutare.potentiometrele de la pct 5 sunt stereo? NU! Link spre comentariu
