Solutie imbunatatire boxe facute acasa
Costa
Pt amatorii DIY si nu numai o sinteza de link-uri despre constructia de boxe,sper ca sa nu fie erori importante,a fost ceva munca.
ghid constructie boxe
merita citit primul-autor roman,lb romana
https://electrodb.ro/wp-content/uploads/2011/03/Proiectarea-Incintelor-Bas-Reflex-02.pdf
-Elforum-logare-home-audio-boxe si difuzoare si casuta de cautare
-exemple de subiecte interesante si muulte altele:
 Ranforsare boxe-(informatia mea,cu obturare max 30% )
https://www.elforum.info/topic/146314-ranforsare-boxe/
port bas reflex
https://www.elforum.info/topic/17420-nedumerire-port-bas-reflex/
Frecventa rezonanta incinta bass-reflex!
https://www.elforum.info/topic/713-frecventa-rezonanta-incinta-bass-reflex/
conteaza unde vine pus bas reflex-ul??
https://www.elforum.info/topic/4525-conteaza-unde-vine-pus-bas-reflex-ul/
putere difuzoare boxe 3 cai
https://www.elforum.info/topic/94508-cum-calculez-puterea-pe-incinta-cu-3-cai/#comment-1104957
alegere spl
https://www.elforum.info/topic/157295-sugestie-realizare-incinte-acustice/page/7/#comment-2149265
Sugestie realizare incinte acustice
https://www.elforum.info/topic/157295-sugestie-realizare-incinte-acustice/page/5/
filtre
https://www.elforum.info/topic/62802-calcul-filtre/
Buretele din boxe -antifonare boxe
https://www.elforum.info/topic/104143-buretele-din-boxe/
Material fonoabsorbant intr-o incinta inchisa
https://www.elforum.info/topic/115113-material-fonoabsorbant-intr-o-incinta-inchisa/
experienta si pasiune:
https://hifiromania.wordpress.com/2015/11/08/audiophile-hi-fi-romania/comment-page-1/?unapproved=136&moderation-hash=7d47af4f9c6d27e5d69ee974e0f7bf43#comment-136 -lb romana
https://radiofarafiltru.blogspot.com/2013/10/ghid-practic-pentru-construtii-de-boxe.html -link inactiv,am salvat fisier text
f multe date,aici doar un ex, prezentari pe YT,autor roman,lb engleza  :
https://audiojudgement.com/tag/box/
https://audiojudgement.com/bass-reflex-alignments-explained/
-are prezentare,tab de calcul free downl. iar pe  yt :
Ported subwoofer box explained-merita vazut,explicatii si grafica
https://www.youtube.com/watch?v=nLMDDlTyeLs
http://education.lenardaudio.com/en/  introducere in audio
https://diy-audio.ro/ce-sunt-parametrii-thiele-small/ lb romana
https://www.diyaudioandvideo.com/Guide/BuildSpeaker/
http://sound-au.com/articles/enclosures.htm#s21 -Rod Elliot
http://www.troelsgravesen.dk/vent_tuning.htm
https://www.linkwitzlab.com/frontiers_5.htm
https://www.instructables.com/How-to-Build-Custom-Speakers/
https://www.tehnium-azi.ro/forums/topic/321-fonoabsorbant-in-boxe/
https://www.t-linespeakers.org/design/index.html
cum se fac boxe
https://www.thespeakerproject.com/courses constructii boxe
Dimensiunea contează cu adevărat?:
https://ddaudio.com/size-really-matter/#:~:text=One of the most important,tuning frequency of the port
DIY Audio Speaker Building Ghid / FAQ
 Box dimensions(raportul de aur):
https://www.diyaudio.com/community/threads/box-dimensions.732/
Cabinet size vs. port displacement:
https://www.audioheritage.org/vbulletin/archive/index.php/t-2849.html
is reflex tube part of enclosure volume?
https://www.diyaudio.com/community/threads/is-reflex-tube-part-of-enclosure-volume.306776/
port location to reduce standing waves
https://www.diyaudio.com/community/threads/port-location-to-reduce-standing-waves.392120/
Port Placement in DIY Bass Reflex Cabinet
https://community.klipsch.com/index.php?/topic/19550-port-placement-in-diy-bass-reflex-cabinet/
How to Tune Bass Reflex Speakers (5 Steps)
https://itstillworks.com/neodymium-speakers-1844.html
Alegerea inaltelor in functie de filtru
http://www.forum.poweraudio.ro/viewtopic.php?f=21&t=80
Passive Time Alignm calc online
http://www.mh-audio.nl/Calculators/DelayNetwork.html
crossovers Time alignment
https://education.lenardaudio.com/en/06_x-over_4.html
Time alignment
http://www.troelsgravesen.dk/Time-Alignment.htm
Using Phase Shift Networks To Achieve Time Delay For Time Alignment
https://sound-au.com/articles/phase.htm
boxnotes soft:
https://www.subwoofer-builder.com/freesoft.htm
Calculate Enclosure Resonances
http://www.mh-audio.nl/Calculators/standingwaveinbox.html
How to remove internal standing waves from speaker cabinets?
https://www.tonestack.net/articles/speaker-building/standing-waves-sound-absorbers-in-speaker-boxes.html
carti-pdf
-eu am dar nu pun aici ,drepturi de autor ?!-
Loudspeaker-design-cookbook-pdf Vance Dickanson
Speaker and Enclosure- pdf DG Meyer
Difuzoare-si-incinte-acustice-pdf C.Posa
Proiectarea-incintelor-acustice pdf ing A Mateescu
Proiectarea-incintelor-acustice ing A Mateescu -Tehnium iunie 2002 si mai-iunie 2000
proiecte de boxe realizabile
HiFi-/Surround Kits
https://www.visaton.de/en/products/hifi-surround-kits
https://audiojudgement.com/diy-speaker-plans-2-way-bookshelf-kit/
STARLET
https://www.visaton.de/en/products/3-way-speakers/starlet/bauanleitung
Planuri de difuzoare DIY - Kit raft cu 2 căi
DIY Speaker Project – folosind doar 2 instrumente
https://audiojudgement.com/diy-speaker-project-using-just-2-tools/
http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
http://sound-au.com/sp-boxes.htm
-Fostex are in pdf dif si recomandari de boxe
proiectare boxe
-programul winISD http://www.linearteam.org/
https://www.youtube.com/watch?v=yZNeYBYGRKk    -tutorial pt winisd
https://midwestaudio.club/resources/winisd-a-beginners-tutorial/ pt winisd
calculatoare online
https://www.ajdesigner.com/
https://www.ajdesigner.com/fl_subwoofer/subwoofer.php  -calc vol
calculator volum boxa audio si dimensiuni dupa regula de aur:
https://www.ajdesigner.com/speaker/bcs.php vezi free downl wind
http://www.mh-audio.nl/Loudspeakers.html
https://www.the12volt.com/caraudio/boxcalcs.asp   calc online
https://subbox.pro/en/bass-box/
https://subbox.pro/en/design/ calc vol
https://www.diyaudioandvideo.com/Calculator/SpeakerBoxEnclosure/  calc vol
https://www.diyaudioandvideo.com/Calculator/SealedVsPortedSpeakerBox/
https://www.diyaudioandvideo.com/Calculator/SpeakerBoxVolume/
https://www.lautsprechershop.de/tools/zy1_t_box_closed_en.htm
SIMULATOR DE BOXA INCHISA-PERMITE MODIF DE VOL,DIMENS SI IZOLATIE SI ARATA  RASPUNSUL GRAFIC :
http://www.loudspeakerdatabase.com/Simulators/ClosedBox#tenv=22/phPa=1000/eg=2.83/rg=0/brand=VISATON/ref=W170S-8/re=5.9/le=1.2/bl=5.4/rms=1.2/cms=1610/mms=13/sd=129/pmax=80/xmax=4.3/tvc=22/ly=564/lx=314/lz=184/dx=175/dy=400/wt=18/lmz=0/lmrf=2000/vr=0.0/nm_max=14/tbox=22
https://www.diyaudioandvideo.com/  -Gasiti acolo Speaker Box Enclosure Designer.
Calculation of cabinets and ports:
http://www.troelsgravesen.dk/BOX-PORT-CALC.htm -vezi sus downl.
-simulatorul de aici: https://speakerboxlite.com/
Helmholtz Resonators calculator:
http://www.vk2zay.net/calculators/helmholtz.php
Wavelength Calculator
https://weteachfullstack.com/wavelength-calculator/
soft simulare filtre
-xsim-simulator crossover -necesita fisierele frd si zma pt fiecare dif
Crossover Design Software Xsim Tutorial for HiFi Speakers
https://www.youtube.com/watch?v=Ccqij1DZafs&t=621s
formule de calcul filtre
http://www.electroniq.net/scheme-electronice-audio/filtre-pasive-audio-calcul-exemple.html
filtre
Tehnium mart2002,sept2003,dec2003
Filtre variabile high-pass și low-pass
https://sound-au.com/project155.htm
intelegere filtre
https://jlaudio.zendesk.com/hc/en-us/articles/206556458-Understanding-Crossovers
calc online filtre-nu sunt recomandate,dar...
http://www.apicsllc.com/apics/Misc/filter2.html
http://www.diyaudioandvideo.com/Calculator/SpeakerCrossover/
http://www.diyaudioandvideo.com/Calculator/LPad/ calc online pt atenuator de putere
-Loudspeaker Crossover 12 dB Calculation
https://www.redcrab-software.com/en/Calculator/Loudspeaker-crossover-12dB
defazare
https://www.audiofrog.com/time-alignment-part-three-delays-and-crossovers-for-tweeters-and-mids/
https://www.reddit.com/r/diyaudio/comments/l69jsh/1st_order_crossover_hpf_phase_shift/
REW= este un software gratuit pentru măsurarea acustică a camerei, măsurarea difuzoarelor și măsurarea dispozitivelor audio
Room Acoustics Software=REW SOFT
https://www.roomeqwizard.com/
alegere dif
--Exista  o baza de date :
-branduri evidentiate in forum: visaton. seas  ,scan-speak ,fostex,TB
,audio nirvana , Perless
boxa br,acordaj,reglaje
-scurtare lungime calculata la  tub br=frecventa de acordaj creste
"acordaj"
1-orice tub BR de orice lungime va fi acordat la o anumita fr,fr de rezonanta a tubului
2-undele la fr de rezonanta a tubului care ies prin tub vor fi in faza cu undele sonore emise de difuzor intarindu-le
3-inseamna ca la o anumita fr si numai una sunetul va fi mai puternic
4-la celelate fr sunetul va fi mai slab pt ca se produce antifaza,adica undele vor iesi la 180gr fata de ce emite difuzorul in fata
5-fr de acordaj  trebuie sa fie peste fs difuzor  dar si armonicele ei sa fie diferite de cele critice?!
Testare boxe audio
-cu generaton de ton pt dif frecvente-aplicatie android
https://wooferbasstest.com/ro/sisteme-audio-de-verificare-canal-stânga-și-dreapta/efecte-sonore.html
https://wooferbasstest.com/ro/tweeter-speakers-test/subwoofer-test.html
https://playtech.ro/2017/cum-testezi-casti-boxe-melodii-relevante/ contine urmatoarele videoclipuri de pe youtube:
https://www.youtube.com/watch?v=fV0ujFgvApE
https://www.youtube.com/watch?v=hyb94O7OJcM
https://www.youtube.com/watch?v=f-wcMfGdMow&t=1s
https://www.youtube.com/watch?v=MbpMOEoLcLc
https://www.youtube.com/watch?v=IZlJ61N3wHI&t=2s
https://www.youtube.com/watch?v=yUi_S6YWjZw&t=2s
https://www.youtube.com/watch?v=6vImyP5EYc8
https://www.youtube.com/watch?v=-AORasS2Oxc&t=4s
https://www.youtube.com/watch?v=NAc83CF8Ejk&t=64s
https://www.youtube.com/watch?v=eXBBmJTFuYs&t=1s
https://www.youtube.com/watch?v=pBkHHoOIIn8&t=1s
https://www.youtube.com/watch?v=9TqUlGyWSEk&t=1s
https://www.youtube.com/watch?v=-1xmbfo8kSY&t=4s
http://www.eminent-tech.com/music/multimediatest.html contine teste de sunet pe dif frecvente
Time alignment
woofer vs subwoofer
Gama de frecvență: Un woofer reproduce de obicei frecvențe cuprinse între 40 Hz și 2 kHz, în timp ce un subwoofer reproduce frecvențe cuprinse între 20 Hz și 200 Hz. Aceasta înseamnă că subwooferele sunt proiectate pentru a gestiona cele mai joase frecvențe, în timp ce wooferele se ocupă de frecvențele medii-joase până la medii-înalte.
ce este W.A.F. in audio
Orice audiofil care a petrecut timp în forumuri AV sau comunități Hi-Fi sau grupuri Reddit pentru audiofili, iubitori de căști și iubitori de Hi-Fi, va fi familiarizat cu vizionarea termenului WAF. Mai frecvent văzut în cercurile Hi-Fi, WAF înseamnă pur și simplu factorul de acceptare a soției.
boxe
-boxa e calculata pt woofer si e doar despre woofer care e ajutat pt redare fr joase si medii joase iar dif de medii si tw pot functiona cu un spatiu minimal si trebuiesc protejate in cutii inchise de agresiunea wooferului
-rigidizarea boxei prin ranforsari
-la volumul calculat se adauga orice obict care poate micsora acest volum
-in functie de fr de taiere a filtrelor se alege raportul dintre puterile woofer/tweeter de ex
800hz=55/45 1800hz=70/30  2400hz=75/25 3000hz=80/20 etc
-difuzoare-banda largade calitate de 8" +tweeter
                  -sau woofer de 8"cu fs cat mai mic +tweeter cu fs de 1khz
 -calcul EBP=fs/Qes si pt val <50 boxa inchisa ,50-70 ambele, >70 bas reflex
-tweeter recomandat -cu calota textila-matase
-spl necesar pt apartament 88-91db
-acordajul boxei se face peste fs woofer sau full range de aceea e bine sa fie alese cu fs=35-45hz
-filtrele dupa estimarea de calcul se optimizeaza prin multe experimentari si auditii
-diferentele de spl dintre cele dou dif se rezolva prin utilizarea de L-paduri
-compensarea defazajului introdus de filtre si al delayului
-antifonarea ,captusirea interioara cu mat fonoabsorbant se face prin experimentari
Cum să configurați o cameră de ascultare:
https://realtraps.com/art_room-setup.htm
Speaker Placement Calculators:
http://noaudiophile.com/speakercalc/
sau:
https://www.cardas.com/system-setup
amplasare boxe in camera pt efectul stereo:
https://www.hifitech.ro/revista/recenzii/cum-obtinem-un-sunet-de-calitate-intr-o-camera-normala-scurt-ghid-acustic-r65/#:~:text=Boxele nu trebuie sa fie,pentru un efect stereo complet
Cum să vă poziționați perfect difuzoarele:
https://www.harman-audio.ro/cum-sa-va-pozitionati-perfect-difuzoarele/#:~:text=Dacă aveți suporturi pentru difuzoare,părțile strălucitoare ale muzicii ies
  • Răspunsuri 335
  • Costa
    104
  • Shambala
    61
  • sonic11
    43
  • sesebe
    39
Nu stiu daca o sa stea cineva sa citeasca complet toate acele linkuri adunate cu greu.  Ar fi bine.
Dar nu tot ce scrie in ele este adevarat sau corect !
Am citit vreo 4 sau 5 si deja am gasit mai multe afirmatii neadevarate. Sau doar partial adevarate - pt cate un caz particular.
Se putea si mai bine,se citeste greu,m-am grabit cu publicarea.
Cred ca sunt acolo si cateva informatii bune mai ales pt incepatori.
Numai sa mai fie constructori DIY interesati sa se informeze si dispusi la ceva munca.
  • 1 lună mai târziu...
Va rog sa nu va lasati impresionati de "calitatea boxei" si sa-mi spuneti o metoda simpla,empirica prin care sa aflu valoarea aproximativa pt Fb-frecventa boxa  avand la dispozitie DOAR generatorul de ton din imagine si...aplicatii android telefon,tableta .
(difuzor -subwoofer- no name -6.5inch,100w/8ohm, boxa 44x17x27cm cu vol net aprox 20litrii si tubul BR utilizat-diam 5cm/lungime 15cm)
Am gasit asta:
Cum testează boxele pentru BASS cu telefonul (frecventa de răspuns) - YouTube
Alte metode ?
Acum 40 minute, Costa a spus:
Am gasit asta:
Alte metode ?
Alta metoda ar fi sa descărcați REW și să faceți o măsurătoare cu microfonul incorporat din leptop, nu fa fi precis da va dă un punct de reper.
Puteți introduce cotele într-un soft dedicat gen bass box...
O varianta e sa cumparati un microfon dayton imm6 (s) care se cupleaza la telefon , descarcati un soft de calibrare , aplicatie ,cuplati generatorul de semnal la amplificator si folositi display-ul telefonului/tabletei; gasiti sugestii pe net.
Poate nu e cea mai precisa varianta dar functioneaza.
O varianta "babeasca", e sa folositi generatorul de semnal cuplat la un amplificator, variati frecventa generatorului lent crescator/descrescator, cum doriti dvs.; asezati in fata deschiderii tubului br o lumanare -la frecventa de rezonanta ,pe care o cititi pe displayul generatorului,din cauza curentului de aer, lumanarea va "palpai" mai tare.
Multumesc pt raspunsuri
@sonic11-am introdus cotele in bass-box ,ce pot sa obtin acolo este ca pt datele mele Fb=39.5hz-tot e ceva !
Pt "masurari" cu microfoane in REW calibrarea este o conditie fara de care nu se poate obtine nimic ori se poate si fara ?
Cred ca mai am o jucarie de microfon portabil primit la primul meu casetofon acum 50 de ani .
@ex.escu-am incercat cu foi de hartie(nu cu lumanarea) ,semnalul find sinusoidal miscarea hartiei e vibratorie,greu sa realizezi ceva.
Nu stiam ca exista microfoane ce se pot utiliza cu telefon,tableta .
DAYTON AUDIO IMM-6 -are un pret decent dar pt conectare e necesara acea mufa TRRS de 3,5 mm .
Eu am S10lite nu are jack si la Galaxy tab A7lite (SM-T225) cu jack clasic stereo .
Acum 44 minute, Costa a spus:
Nu trebuie musai calibrat, trebuie doar sa afi unde este acordată incinta.
Scoateți dif din incinta și măsurați parametri, veți obține un grafic, apoi repetați măsurătoarea cu dif in boxa și comparați cele două grafice.
O sa vedeți unde cutia "ajuta" wooferul, graficul generat este spl vs frecventa, sub fs incinta spl din grafic o sa aivă o cădere în spl.
In serie cu difuzorul conectati o rezistenta de putere 2-3w, catziva ohmi , ansamblul conectat la amplificator , acesta comandat la un nivel decent de generatorul de semnal ; in paralel pe resistenta conectati un voltmetru de c.a.- la rezonante veti avea un maxim pe voltmetru .Frecventa e cea de pe display.
Succes.
