sorinas Postat Mai 1, 2023 Partajează Postat Mai 1, 2023 Amplificatorul este in perfecta stare de functionare. Specificatii : Output Power, 1000 Hz, THD+N at 1%, Both Channels Driven: Stereo mode: 8 Ohm: 2x 600 Watt RMS 4 Ohm: 2x 900 Watt RMS 2 Ohm: Not Allowed Bridge mode: 8 Ohm: 1800 Watt RMS 4 Ohm: Not Allowed Frequency Response: 20 - 45,000 Hz, -1 dB THD+N: < 0.05% Intermodulation Distortion: < 0.01% Damping Factor at 8 Ohm: > 300 Slew Rate: > 40 V/µS Input CMRR: > 60 dB Crosstalk 20 - 20,000 Hz: > 60 dB Signal to Noise Ratio: > 105 dB A-weighted Input Sensitivity: 1 V~, +2.2 dBu Max. Input Voltage: +22 dBu Input Impedance: 20 kOhm Balanced 10k Ohm Unbalanced Protection: Clip Limiter (Fixed) Short Circuit Input Overload Output Overload DC Voltage High Temperature Soft Start Output Modes (Select.): Stereo / Parallel / Bridge Cooling: Dual Speed Fan Airflow: Front to Back Input / Link Connector: XLR / Jack Output Connector: 2x Speakon, 2 Pair Bindings Posts Groundlift Switch: Yes Dimensions (LxWxH): 483 x 430 x 89 mm Net Weight: 18,96 kg Power Supply: 200 - 240 V~, 50 Hz Main Fuse: 12AT, 5 x 20 mm Power Consump. (2 x 4 Ohm): 2440 Watt Pret - 1100 lei. Pentru cei interesati tel. 0749141684 sau mesaj pe forum. Link spre comentariu
sorinas Postat Mai 11, 2023 Autor Partajează Postat Mai 11, 2023 Up. Negociabil. Link spre comentariu
sorinas Postat August 4, 2023 Autor Partajează Postat August 4, 2023 Hai cu puterea Link spre comentariu
sorinas Postat Ianuarie 16, 2024 Autor Partajează Postat Ianuarie 16, 2024 900 lei Link spre comentariu
