PKP98 Postat Aprilie 2, 2023 Partajează Postat Aprilie 2, 2023 (editat) Se vand urmatoarele componente: 1. Conectori D-Sub 15P, tata, în unghi 90° - 4 lei/buc 2. Telecomanda sistem audio Genius SW-HF 5005 (perfect functionala, estetic 9.9 din 10) - 30 lei 3. Cablaj sursa Conex 0-30V 0-3A (la ultimul test a functionat, are nevoie doar de alimentare si de cele doua potentiometre, au fost utilizate doar componente de calitate si originale, condensatorul cel mare este de 63V 10000uF) - 100 lei 4. Cablaj AVR doctor, necesita microcontroller - 15 lei 5. Panou LED P10-16x32 RGB (noua) - 50 lei 6. Descărcător ETI M T2 PV 1100/20 (nou) - 150 lei 7. Diode si punti redresoare (utile pentru cei care mai repara diferite aparate, pretul depinde de model si cantitate) - pret informativ 1leu/buc Name Description Package Quantity D3SBA60 SILICON BRIDGE RECTIFIER - 600V - 4A THT 3 PBL405 SILICON BRIDGE RECTIFIER - 600V - 4A THT 3 GBI25M SILICON BRIDGE RECTIFIER - 1000V - 25A THT 1 D5SB60 SILICON BRIDGE RECTIFIER - 600V - 6A THT 1 SF20SC4 Schottky Rectifiers (SBD) - 40V - 20A THT: TO220F15 1 YG885C02R SCHOTTKY BARRIER DIODE - 20V - 30A THT: TO220F15 1 BYV29F Rectifier diodes ultrafast - 400V - 9A THT: SOD100 1 BYW29E100 Rectifier diodes ultrafast, rugged - 100V - 8A THT: TO220 3 RHRP8120 Hyperfast Diode - 1200V - 8A THT: TO220 4 SBL2040CT SCHOTTKY BARRIER RECTIFIER - 40V - 20A THT: TO220 2 C82-004 SCHOTTKY BARRIER RECTIFIER - 45V - 15A THT: TO220 2 F10U150S High voltage and high reliability - 1500V - 10A THT: TO220F15 1 STTH8R06D TURBO 2 ULTRAFAST HIGH VOLTAGE RECTIFIER - 600V - 8A THT: TO220 1 F12C20 Dual Fast Recovery Power Rectifiers - 200V - 12A THT: TO220 1 MBR760 Schottky Rectifiers - 60V - 7.5A THT: TO220 1 U860 ULTRAFAST RECTIFIERS - 600V - 8A THT: TO220 1 BY359X-1500 Damper diode fast, high-voltage - 1500V - 15.7A THT: TO220F15 1 5JLZ47 High Efficiency Rectifier - 600V- 5A THT: TO220F15 1 SF5LC20U Super Fast Recovery Rectifiers - 200V - 5A THT: TO220F15 1 FCL20A01 Schottky Rectifiers - 15V - 20A THT: TO220F15 1 FCQ06A04 Diode - 40V - 6A THT: TO220F15 1 BYQ28-200 Rectifier diodes ultrafast - 200V - 10A THT: TO220 1 STPS3045 POWER SCHOTTKY RECTIFIER - 45V - 15A THT: TO220 1 SB3045ST SCHOTTKY BARRIER RECTIFIERS - 45V - 30A THT: TO-247 1 STPS30L40 LOW DROP POWER SCHOTTKY RECTIFIER - 40V - 15A THT: TO-247 1 MBR3045PT Dual Common Cathode Schottky Rectifier - 45V - 30A THT: TO-247 1 S30SC4M Dual Common Cathode Schottky Rectifier - 40V - 30A THT: TO-247 1 KCH30A10 Dual Diodes – Cathode Common - 40V - 30A THT: TO-247 1 D4SB80 SILICON BRIDGE RECTIFIER - 800V - 4A THT 1 GBU6J Glass Passivated Single-Phase Bridge Rectifier - 600V - 6A THT 1 KBJ408 SILICON BRIDGE RECTIFIER - 800V - 4A THT 1 KBL408 SILICON BRIDGE RECTIFIER - 800V - 4A THT 1 B380C1500 SILICON BRIDGE RECTIFIER - 1000V - 1.5A THT 1 STPS2045 POWER SCHOTTKY RECTIFIER - 45V - 10A THT: TO220 2 SB2040 SCHOTTKY BARRIER RECTIFIERS - 45V - 30A THT: TO220 1 GBU6K Glass Passivated Single-Phase Bridge Rectifier - 800V - 6A THT 1 GBU605 Single Phase Glass Passivated Bridge Rectifier - 600V - 6A THT 1 RS808 SINGLE-PHASE SILICON BRIDGE - 800V - 8A THT 1 TS4B05 Single Phase Glass Passivated Bridge Rectifiers - 600V - 4A THT 1 2KBP06M Bridge Rectifiers - 600V - 2A THT 1 8. Regulatoare de tensiune si surse separatoare (utile pentru cei care mai repara diferite aparate, pretul depinde de model si cantitate) - pret informativ 2lei/buc Name Description Package Quantity LM723 Voltage Regulator THT: DIP14 4 EC4AB11H 5-6 WATT 2:1 INPUT RANGE DC-DC CONVERTERS THT: DIP24 1 FKC08-24S05W 8 WATT DC-DC CONVERTERS THT: DIP24 2 RFM-0505 1W converter 1kVDC isolation THT: SIP4 5 NME0505 Isolated 1W Single Output DC-DC Converters THT: DIP8 1 KIA78R12PI 1A Low Dropout Voltage Regulator With ON/OFF Control THT:TO-220F-4 3 PQ30RV21 Variable Output Low Power-Loss Voltage Regulators THT:TO-220F-4 1 PQ15RW11 Variable Output Low Power-Loss Voltage Regulator THT:TO-220F-4 1 LM7805 3-Terminal 1 A Positive Voltage Regulator THT: TO220 15 LM78M05 3-Terminal 500-mA Positive Voltage Regulator THT: TO220 1 LM317 3-Terminal Adjustable Regulator THT: TO220 8 LM7812 3-Terminal 1 A Positive Voltage Regulator THT: TO220 5 LM7808 3-Terminal 1 A Positive Voltage Regulator THT: TO220 3 LM78M08 3-Terminal 500-mA Positive Voltage Regulator THT: TO220 1 78L05 3-Terminal 100-mA Positive Voltage Regulator THT: TO92 6 TL431 Precision Programmable Reference THT: TO92 13 KA78R33 1A Low Dropout Voltage Regulator With ON/OFF Control THT:TO-220F-4 1 378R12 3A/12V Output Low Dropout Voltage Regulator THT:TO-220F-4 1 LM7806 3-TERMINAL POSITIVE VOLTAGE REGULATOR, 6V THT: TO220 1 LM7912 Series 3-Terminal Negative Regulators, -12V THT: TO220 3 LM2576-ADJ Series SIMPLE SWITCHER® 3-A Step-Down Voltage Regulator THT: TO220-5 1 78L15 3-Terminal 100-mA Positive Voltage Regulator THT: TO92 2 LM2937-12 500-mA Low Dropout Regulator THT: TO220 1 LM7915 Series 3-Terminal Negative Regulators, -15V THT: TO220 1 LM7815 3-Terminal 1 A Positive Voltage Regulator THT: TO220 1 KIA378R33 3A Low Dropout Voltage Regulator With ON/OFF Control THT:TO-220F-4 1 KIA278R05 2A Low Dropout Voltage Regulator With ON/OFF Control THT:TO-220F-4 1 MA7805 3-Terminal 1 A Positive Voltage Regulator THT: TO3 1 MA7824 3-Terminal 1 A Positive Voltage Regulator THT: TO3 1 TMA0515D Traco Power DC/DC, 1 Watt, ±15V OUT 5v IN THT:SIP5 1 9. Tranzistori bipolari, MOSFET, IGBT, etc (utile pentru cei care mai repara diferite aparate, pretul depinde de model si cantitate) - pret informativ 2lei/buc Name Description Package Quantity STB70NF3LL N-Channel 30V - 0.0075Ω - 70A SMD: TO263 2 SUB45N03 N-Channel 30V - 0.013Ω - 45A SMD: TO263 2 STB45NF3LL N-Channel 30V - 0.014Ω - 45A SMD: TO263 2 SPD30N03 N-Channel 30V - 0.015Ω - 30A SMD: P-TO252 3 SUD50N03 N-Channel 30V - 0.0120Ω - 17.5A SMD: P-TO252 2 PHD45N03 N-Channel 25V - 0.0175Ω - 40A SMD: TO263 1 TIP36C High-Power Transistors - PNP - 25A - 100V - 125W THT: TO218 4 IRF740 N-Channel 400V - 0.55Ω - 10A THT: TO220 8 IRL540 N-Channel 100V - 0.077Ω - 28A THT: TO220 4 IRLB4132 N-Channel 30V - 0.0035Ω - 150A THT: TO220 4 11N80C3 N-Channel 800V - 0.45Ω - 11A THT: TO247 6 MJE340 0.5A POWER TRANSISTOR NPN SILICON 300V, 20W THT: TO225 4 MJE350 0.5A POWER TRANSISTOR PNP SILICON 300V, 20W THT: TO225 5 IRF1010 N-Channel 60V - 0.012Ω - 84A THT: TO220 3 NDP603 N-Channel 30V - 0.022Ω - 25A THT: TO220 2 MCR100-6 Silicon Planar PNPN Thyristor ITRMS: 0.8A VDRM: 400V THT: TO92 2 IRF630 N-Channel 200V - 0.29Ω - 9A THT: TO220 3 IRLZ14 N-Channel 60V - 0.20Ω - 10A THT: TO220 1 IRF634 N-Channel 250V - 0.45Ω - 8.1A THT: TO220 1 P6N60 N-Channel 650V - 1.2Ω - 4.5A THT: TO220 1 SSP2N60B N-Channel 600V - 5.0Ω - 2.0A THT: TO220 2 BDX33C Power Darlington NPN - 10A - 100V - 70W THT: TO220 1 FS12UM N-Channel 250V - 0.40Ω - 12A THT: TO220 1 P60NF03 N-Channel 30V - 0.008Ω - 60A THT: TO220 1 IRFZ44 N-Channel 60V - 0.028Ω - 50A THT: TO220 1 TIP29C Epitaxial Silicon - NPN - 1A - 100V - 30W THT: TO220 1 TIP30C Epitaxial Silicon - PNP - 1A - 100V - 30W THT: TO220 1 P9NC60 N-Channel 600V - 0.6Ω - 9A THT: TO220 1 SFP9634 P-Channel -250V - 1.3Ω - -5A THT: TO220 1 K2761 N-Channel 600V - 1Ω - 10A THT: TO220F15 1 4N20 N-Channel 200V - 1.4Ω - 2.8A THT: TO220F15 1 10N20 N-Channel 200V - 0.36Ω - 10A THT: TO220F15 5 E13007-2 High Voltage Power Transistor - 400V - 8A - 80W THT: TO220 4 TIP115 Medium-Power Complementary Silicon - 60V - 2A - 50W THT: TO220 1 TIP117 Medium-Power Complementary Silicon - 100V - 2A - 50W THT: TO220 1 K1117 N-Channel 600V - 0.95Ω - 6A THT: TO220 1 2SK2608 N-Channel 900V - 3.73Ω - 3A THT: TO220 1 KD607S Power Transistors - NPN - 10A - 80V - 70W THT: TO-3 4 2N3055 Power Transistors - NPN - 15A - 60V - 115W THT: TO-3 10 FJL6820 Triple Diffused Planar Silicon - NPN - 20A - 750V - 200W THT: TO-264 0 W13009 High voltage fast-switching NPN - 12A - 400V - 125W THT: TO-247 2 IRFP450 N-Channel 500V - 0.4Ω - 14A THT: TO-247 3 K2837 N-Channel 500V - 0.21Ω - 20A THT: TO-247 1 2SK2765 N-Channel 800V - 2Ω - 7A THT: TO-247 1 K2485 N-Channel 900V - 2.8Ω - 6A THT: TO-247 1 C5148 Silicon Power Transistors - NPN - 8A - 600V - 50W THT: TO-3P 1 C4769 Silicon Power Transistors - NPN - 7A - 800V - 60W THT: TO-3P 1 D1710 Silicon Power Transistors - NPN - 5A - 800V - 50W THT: TO-3P 1 J6916 Silicon Power Transistors - NPN - 16A - 800V - 60W THT: TO-3P 1 BU2520 Silicon Power Transistors - NPN - 10A - 800V - 45W THT: TO-3PF 1 BU508 Silicon Power Transistors - NPN - 8A - 700V - 125W THT: TO-247 2 KT872 Silicon Power Transistors - NPN - 8A - 700V - 100W THT: TO218 2 D1391 Silicon Power Transistors - NPN - 5A - 700V - 100W THT: TO-3P 1 BD442 Epitaxial Silicon Transistor - PNP - -4A - -80V - 36W THT: TO-126 1 B649 Epitaxial Silicon Transistor - PNP - -3A - -160V - 20W THT: TO-126 4 BD679 Epitaxial Silicon Transistor - NPN - 4A - 80V - 40W THT: TO-126 1 D1609 Epitaxial Silicon Transistor - NPN - 0.1A - 160V - 1.25W THT: TO-126 3 D669 Epitaxial Silicon Transistor - NPN - 1.5A - 160V - 20W THT: TO-126 4 B632 Epitaxial Silicon Transistor - PNP - -2A - -35V - 10W THT: TO-126 1 BD135 Epitaxial Silicon Transistor - NPN - 1.5A - 45V - 12.5W THT: TO-126 8 BD139 Epitaxial Silicon Transistor - NPN - 1.5A - 80V - 12.5W THT: TO-126 4 BF458 Epitaxial Silicon Transistor - NPN - 0.1A - 250V - 6W THT: TO-126 2 BD236 Epitaxial Silicon Transistor - PNP - -2A - -60V - 25W THT: TO-126 4 BD136 Epitaxial Silicon Transistor - PNP - -1.5A - -45V - 12.5W THT: TO-126 2 BD140 Epitaxial Silicon Transistor - PNP - -1.5A - -80V - 12.5W THT: TO-126 1 VN2410L Small Signal MOSFET N-Channel 240V - 10Ω - 0.2A THT: TO92 2 C3467 Epitaxial Silicon Transistor - NPN - 0.1A - 200V - 1W THT: SC-51 2 A1370 Epitaxial Silicon Transistor - PNP - -0.1A - -200V - 1W THT: SC-51 3 B647 Epitaxial Silicon Transistor - PNP - -1A - -80V - 0.9W THT: SC-51 5 D667 Epitaxial Silicon Transistor - NPN - 1A - 80V - 0.9W THT: SC-51 3 BFQ235 VIdeo Transistor - NPN - 0.3A - 110V - 3W THT: TO-202 3 40N03 N-Channel 25V - 0.012Ω - 45A THT: TO220 1 VS4604 N-Channel 40V - 0.0026Ω - 150A THT: TO220 1 SVF18N50 N-Channel 500V - 0.26Ω - 18A THT: TO220F 4 BD911 Silicon Power Transistors - NPN - 15A - 100V - 90W THT: TO220 3 BUX98A Silicon Power Transistors - NPN - 24A - 1000V - 200W THT: TO218 2 IRFB4710 N-Channel 100V - 0.014Ω - 75A THT: TO220 16 IKW40T120 IGBT 1200V - 1.7V - 40A THT: TO247 4 G20N60 IGBT 600V - 2.4V - 40A THT: TO247 2 G4PC40U IGBT 600V - 1.72V - 20A THT: TO247 2 GW30NC120HD IGBT 1200V - 2.75V - 30A THT: TO247 2 IRFPG50 N-Channel 1000V - 2Ω - 6.1A THT: TO247 2 10. Diferite circuite integrate (utile pentru cei care mai repara diferite aparate, pretul depinde de model si cantitate) - pret informativ 3lei/buc Name Description Package Quantity MAX202 5-V Dual RS-232 Line Driver and Receiver SMD: SO16 7 MAX483 RS-485/RS-422 Transceivers SMD: SO8 3 TL074 JFET-Input Operational Amplifiers SMD: SO14 2 IS7421 Low-Power Dual-Channel Digital Isolators SMD: SO8 4 VP11 3.3-V RS-485 TRANSCEIVERS SMD: SO8 16 L297 STEPPER MOTOR CONTROLLERS SMD: SO20 3 LM75 Digital Temperature Sensor I2C SMD: SO8 8 PCF8563 Real-time clock/calendar I2C SMD: SO8 6 PCF85176 40 x 4 universal LCD driver SMD: TQFP64 4 MAX232 Dual EIA-232 Drivers/Receivers SMD: SO16 3 PCF8574A Remote 8-bit I/O expander for I2C SMD: SO16 3 PCA9546A 4-channel I2C-bus switch SMD: SO16 3 24LC64 64K I2C, Serial EEPROM SMD: SO8 4 ULN2003 Seven Darlington arrays SMD: SO16 4 ULN2803 8 Darlington Transistor Arrays SMD: SO18 1 MAX485 RS-485/RS-422 Transceivers THT: DIP8 8 IXDP630 3-Phase PWM Controls THT: DIP18 3 LM331 Precision Voltage-to-Frequency Converters THT: DIP8 2 ULN2004 Seven Darlington arrays THT: DIP16 3 HCNW3120 2.5 Amp Output Current IGBT Gate Drive Optocoupler SMD: Gull wing 8 18 OP177 Ultraprecision Operational Amplifier THT: DIP8 2 OP07 Ultralow Offset Voltage Operational Amplifier THT: DIP8 2 NE555 Precision Timers THT: DIP8 2 H11D1 Transistor Output Optocouplers SMD: Gull wing 6 10 LM324 Low-Power, Quad-Operational Amplifiers THT: DIP14 5 UC3843 High Performance Current Mode Controllers THT: DIP8 4 ULN2003 Seven Darlington arrays THT: DIP16 6 MC144110 Digital-to-Analog Converters with Serial Interface THT: DIP18 2 UAA2022 16 SEGMENT LED DRIVER THT: DIP24 1 TC7660 Charge Pump DC-to-DC Voltage Converter THT: DIP8 1 LM358 Low-Power, Dual-Operational Amplifiers THT: DIP8 2 TL494 Pulse-Width-Modulation Control Circuits THT: DIP16 1 PCF8563 Real-time clock/calendar I2C THT: DIP8 2 TDA2614 6 W hi-fi audio power amplifier THT: SOT110 1 uPC1242 7 W AF power amplifier THT: 8 SIL 1 uPC1241 7 W AF power amplifier THT: 8 SIL 1 KIA7280 5.8W Dual Audio Power Amplifier 22W BTL Audio Power THT: HZIP12-P 1 LM567 Tone Decoder, Precision oscillator THT: DIP8 1 UAA170 LED Driver For Light Spot Displays THT: DIP16 1 SN29764 4 bit Binary 7 Segment Decoder/Driver THT: DIP16 1 TDA7057 2 × 8 W stereo audio output amplifier, DC volume control THT: SOT141-6 2 TDA8943 6 W mono Bridge Tied Load (BTL) audio amplifier THT: SOT110 1 TDA2005 20 W bridge/stereo amplifier for car radio THT: Multiwatt11 1 TDA7262 20+20W STEREO AMPLIFIER WITH STAND-BY THT: Multiwatt11 1 TA8223 Low Frequency Power Amplifier THT: HSIP15-P 1 UTC2003 10W Car Radio Audio Amplifier THT: TO220B 3 C1316 Dual Audio Power Amplifier THT: DIP14 TAB 1 B1403 5 DOT Red/Green LED Level Meter THT: SIL9 1 LM324 Low-Power, Quad-Operational Amplifiers SMD: SO14 1 UC3845 High Performance Current Mode Controllers THT: DIP8 2 UC3842 High Performance Current Mode Controllers THT: DIP8 2 FOD8316 2.5 A Output Current, IGBT Drive Optocoupler SMD: SO16 16 MCP23017 16-Bit I/O Expander with Serial Interface THT: DIP28 4 SG3525 Pulse Width Modulator Control Circuit THT: DIP16 3 FPAM30LH60 PFC SPM 2 Series for 2-Phase Interleaved PFC THT: S32EA-032 2 TPD4124K The TPD4124K is a DC brush less motor driver THT: HDIP26-P 1 PS219A4-ASTX 600V/15A low-loss IGBT inverter bridge for three phase THT: DPH-7897e 1 PC814 AC Input Photocoupler THT: DIP4 20 De preferat sa le vand in Bucuresti, pentru colete suma minima este de 50 lei (fara transport). Pentru mai multe detalii ma puteti contacta la numarul de telefon: 0761813130 (telefonic sau pe WhatsApp) sau in mesageria privata. Editat Aprilie 2, 2023 de PKP98 Link spre comentariu
floob Postat Aprilie 2, 2023 Partajează Postat Aprilie 2, 2023 Vreau să-mi rezervați: IRF740 N-Channel 400V - 0.55Ω - 10A THT: TO220 2buc. IRL540 N-Channel 100V - 0.077Ω - 28A THT: TO220 2buc. IRFZ44 N-Channel 60V - 0.028Ω - 50A THT: TO220 1buc. BD911 Silicon Power Transistors - NPN - 15A - 100V - 90W THT: TO220 2buc. OP177 Ultraprecision Operational Amplifier THT: DIP8 2buc. OP07 Ultralow Offset Voltage Operational Amplifier THT: DIP8 2buc. TL494 Pulse-Width-Modulation Control Circuits THT: DIP16 1buc. Mulțumesc Link spre comentariu
imre1968 Postat Aprilie 2, 2023 Partajează Postat Aprilie 2, 2023 (editat) OP177 si OP07 cate mai aveti ? m-ar interesa minim 5+5 buc. Editat Aprilie 2, 2023 de imre1968 Link spre comentariu
antonvasileeee Postat Aprilie 3, 2023 Partajează Postat Aprilie 3, 2023 Cablaj avr doctor rezervati pentru mine . Studiez lista si completez pana la suma minima . Link spre comentariu
PKP98 Postat Aprilie 3, 2023 Autor Partajează Postat Aprilie 3, 2023 Acum 20 ore, floob a spus: Vreau să-mi rezervați: IRF740 N-Channel 400V - 0.55Ω - 10A THT: TO220 2buc. IRL540 N-Channel 100V - 0.077Ω - 28A THT: TO220 2buc. IRFZ44 N-Channel 60V - 0.028Ω - 50A THT: TO220 1buc. BD911 Silicon Power Transistors - NPN - 15A - 100V - 90W THT: TO220 2buc. OP177 Ultraprecision Operational Amplifier THT: DIP8 2buc. OP07 Ultralow Offset Voltage Operational Amplifier THT: DIP8 2buc. TL494 Pulse-Width-Modulation Control Circuits THT: DIP16 1buc. Mulțumesc In regula! Acum 16 ore, imre1968 a spus: OP177 si OP07 cate mai aveti ? m-ar interesa minim 5+5 buc. Sunt reservate toate, nu mai am altele. Acum 3 ore, antonvasileeee a spus: Cablaj avr doctor rezervati pentru mine . Studiez lista si completez pana la suma minima . Sigur! Link spre comentariu
antonvasileeee Postat Aprilie 14, 2023 Partajează Postat Aprilie 14, 2023 La 03.04.2023 la 12:06, PKP98 a spus: Cablaj avr doctor rezervati pentru mine . Studiez lista si completez pana la suma minima . Cred ca o sa renunt ,nu am mai gasit nimic necesar . Link spre comentariu
floob Postat Aprilie 19, 2023 Partajează Postat Aprilie 19, 2023 Pe când trimiteți cele rezervate? Link spre comentariu
PKP98 Postat Aprilie 21, 2023 Autor Partajează Postat Aprilie 21, 2023 (editat) Se vand urmatoarele componente: 1. Conectori D-Sub 15P, tata, în unghi 90° - 4 lei/buc 2. Telecomanda sistem audio Genius SW-HF 5005 (perfect functionala, estetic 9.9 din 10) - 30 lei 3. Cablaj AVR doctor, necesita microcontroller - 15 lei 4. Panou LED P10-16x32 RGB (noua) - 50 lei 5. Diode si punti redresoare (utile pentru cei care mai repara diferite aparate, pretul depinde de model si cantitate) - pret informativ 1leu/buc Name Description Package Quantity D3SBA60 SILICON BRIDGE RECTIFIER - 600V - 4A THT 3 PBL405 SILICON BRIDGE RECTIFIER - 600V - 4A THT 3 GBI25M SILICON BRIDGE RECTIFIER - 1000V - 25A THT 1 D5SB60 SILICON BRIDGE RECTIFIER - 600V - 6A THT 1 SF20SC4 Schottky Rectifiers (SBD) - 40V - 20A THT: TO220F15 1 YG885C02R SCHOTTKY BARRIER DIODE - 20V - 30A THT: TO220F15 1 BYV29F Rectifier diodes ultrafast - 400V - 9A THT: SOD100 1 BYW29E100 Rectifier diodes ultrafast, rugged - 100V - 8A THT: TO220 3 RHRP8120 Hyperfast Diode - 1200V - 8A THT: TO220 4 SBL2040CT SCHOTTKY BARRIER RECTIFIER - 40V - 20A THT: TO220 2 C82-004 SCHOTTKY BARRIER RECTIFIER - 45V - 15A THT: TO220 2 F10U150S High voltage and high reliability - 1500V - 10A THT: TO220F15 1 STTH8R06D TURBO 2 ULTRAFAST HIGH VOLTAGE RECTIFIER - 600V - 8A THT: TO220 1 F12C20 Dual Fast Recovery Power Rectifiers - 200V - 12A THT: TO220 1 MBR760 Schottky Rectifiers - 60V - 7.5A THT: TO220 1 U860 ULTRAFAST RECTIFIERS - 600V - 8A THT: TO220 1 BY359X-1500 Damper diode fast, high-voltage - 1500V - 15.7A THT: TO220F15 1 5JLZ47 High Efficiency Rectifier - 600V- 5A THT: TO220F15 1 SF5LC20U Super Fast Recovery Rectifiers - 200V - 5A THT: TO220F15 1 FCL20A01 Schottky Rectifiers - 15V - 20A THT: TO220F15 1 FCQ06A04 Diode - 40V - 6A THT: TO220F15 1 BYQ28-200 Rectifier diodes ultrafast - 200V - 10A THT: TO220 1 STPS3045 POWER SCHOTTKY RECTIFIER - 45V - 15A THT: TO220 1 SB3045ST SCHOTTKY BARRIER RECTIFIERS - 45V - 30A THT: TO-247 1 STPS30L40 LOW DROP POWER SCHOTTKY RECTIFIER - 40V - 15A THT: TO-247 1 MBR3045PT Dual Common Cathode Schottky Rectifier - 45V - 30A THT: TO-247 1 S30SC4M Dual Common Cathode Schottky Rectifier - 40V - 30A THT: TO-247 1 KCH30A10 Dual Diodes – Cathode Common - 40V - 30A THT: TO-247 1 D4SB80 SILICON BRIDGE RECTIFIER - 800V - 4A THT 1 GBU6J Glass Passivated Single-Phase Bridge Rectifier - 600V - 6A THT 1 KBJ408 SILICON BRIDGE RECTIFIER - 800V - 4A THT 1 KBL408 SILICON BRIDGE RECTIFIER - 800V - 4A THT 1 B380C1500 SILICON BRIDGE RECTIFIER - 1000V - 1.5A THT 1 STPS2045 POWER SCHOTTKY RECTIFIER - 45V - 10A THT: TO220 2 SB2040 SCHOTTKY BARRIER RECTIFIERS - 45V - 30A THT: TO220 1 GBU6K Glass Passivated Single-Phase Bridge Rectifier - 800V - 6A THT 1 GBU605 Single Phase Glass Passivated Bridge Rectifier - 600V - 6A THT 1 RS808 SINGLE-PHASE SILICON BRIDGE - 800V - 8A THT 1 TS4B05 Single Phase Glass Passivated Bridge Rectifiers - 600V - 4A THT 1 2KBP06M Bridge Rectifiers - 600V - 2A THT 1 6. Regulatoare de tensiune si surse separatoare (utile pentru cei care mai repara diferite aparate, pretul depinde de model si cantitate) - pret informativ 2lei/buc Name Description Package Quantity LM723 Voltage Regulator THT: DIP14 4 EC4AB11H 5-6 WATT 2:1 INPUT RANGE DC-DC CONVERTERS THT: DIP24 1 FKC08-24S05W 8 WATT DC-DC CONVERTERS THT: DIP24 2 RFM-0505 1W converter 1kVDC isolation THT: SIP4 5 NME0505 Isolated 1W Single Output DC-DC Converters THT: DIP8 1 KIA78R12PI 1A Low Dropout Voltage Regulator With ON/OFF Control THT:TO-220F-4 3 PQ30RV21 Variable Output Low Power-Loss Voltage Regulators THT:TO-220F-4 1 PQ15RW11 Variable Output Low Power-Loss Voltage Regulator THT:TO-220F-4 1 LM7805 3-Terminal 1 A Positive Voltage Regulator THT: TO220 15 LM78M05 3-Terminal 500-mA Positive Voltage Regulator THT: TO220 1 LM317 3-Terminal Adjustable Regulator THT: TO220 8 LM7812 3-Terminal 1 A Positive Voltage Regulator THT: TO220 5 LM7808 3-Terminal 1 A Positive Voltage Regulator THT: TO220 3 LM78M08 3-Terminal 500-mA Positive Voltage Regulator THT: TO220 1 78L05 3-Terminal 100-mA Positive Voltage Regulator THT: TO92 6 TL431 Precision Programmable Reference THT: TO92 13 KA78R33 1A Low Dropout Voltage Regulator With ON/OFF Control THT:TO-220F-4 1 378R12 3A/12V Output Low Dropout Voltage Regulator THT:TO-220F-4 1 LM7806 3-TERMINAL POSITIVE VOLTAGE REGULATOR, 6V THT: TO220 1 LM7912 Series 3-Terminal Negative Regulators, -12V THT: TO220 3 LM2576-ADJ Series SIMPLE SWITCHER® 3-A Step-Down Voltage Regulator THT: TO220-5 1 78L15 3-Terminal 100-mA Positive Voltage Regulator THT: TO92 2 LM2937-12 500-mA Low Dropout Regulator THT: TO220 1 LM7915 Series 3-Terminal Negative Regulators, -15V THT: TO220 1 LM7815 3-Terminal 1 A Positive Voltage Regulator THT: TO220 1 KIA378R33 3A Low Dropout Voltage Regulator With ON/OFF Control THT:TO-220F-4 1 KIA278R05 2A Low Dropout Voltage Regulator With ON/OFF Control THT:TO-220F-4 1 MA7805 3-Terminal 1 A Positive Voltage Regulator THT: TO3 1 MA7824 3-Terminal 1 A Positive Voltage Regulator THT: TO3 1 TMA0515D Traco Power DC/DC, 1 Watt, ±15V OUT 5v IN THT:SIP5 1 7. Tranzistori bipolari, MOSFET, IGBT, etc (utile pentru cei care mai repara diferite aparate, pretul depinde de model si cantitate) - pret informativ 2lei/buc Name Description Package Quantity STB70NF3LL N-Channel 30V - 0.0075Ω - 70A SMD: TO263 2 SUB45N03 N-Channel 30V - 0.013Ω - 45A SMD: TO263 2 STB45NF3LL N-Channel 30V - 0.014Ω - 45A SMD: TO263 2 SPD30N03 N-Channel 30V - 0.015Ω - 30A SMD: P-TO252 3 SUD50N03 N-Channel 30V - 0.0120Ω - 17.5A SMD: P-TO252 2 PHD45N03 N-Channel 25V - 0.0175Ω - 40A SMD: TO263 1 TIP36C High-Power Transistors - PNP - 25A - 100V - 125W THT: TO218 4 IRF740 N-Channel 400V - 0.55Ω - 10A THT: TO220 8 IRL540 N-Channel 100V - 0.077Ω - 28A THT: TO220 4 IRLB4132 N-Channel 30V - 0.0035Ω - 150A THT: TO220 4 11N80C3 N-Channel 800V - 0.45Ω - 11A THT: TO247 6 MJE340 0.5A POWER TRANSISTOR NPN SILICON 300V, 20W THT: TO225 4 MJE350 0.5A POWER TRANSISTOR PNP SILICON 300V, 20W THT: TO225 5 IRF1010 N-Channel 60V - 0.012Ω - 84A THT: TO220 3 NDP603 N-Channel 30V - 0.022Ω - 25A THT: TO220 2 MCR100-6 Silicon Planar PNPN Thyristor ITRMS: 0.8A VDRM: 400V THT: TO92 2 IRF630 N-Channel 200V - 0.29Ω - 9A THT: TO220 3 IRLZ14 N-Channel 60V - 0.20Ω - 10A THT: TO220 1 IRF634 N-Channel 250V - 0.45Ω - 8.1A THT: TO220 1 P6N60 N-Channel 650V - 1.2Ω - 4.5A THT: TO220 1 SSP2N60B N-Channel 600V - 5.0Ω - 2.0A THT: TO220 2 BDX33C Power Darlington NPN - 10A - 100V - 70W THT: TO220 1 FS12UM N-Channel 250V - 0.40Ω - 12A THT: TO220 1 P60NF03 N-Channel 30V - 0.008Ω - 60A THT: TO220 1 IRFZ44 N-Channel 60V - 0.028Ω - 50A THT: TO220 1 TIP29C Epitaxial Silicon - NPN - 1A - 100V - 30W THT: TO220 1 TIP30C Epitaxial Silicon - PNP - 1A - 100V - 30W THT: TO220 1 P9NC60 N-Channel 600V - 0.6Ω - 9A THT: TO220 1 SFP9634 P-Channel -250V - 1.3Ω - -5A THT: TO220 1 K2761 N-Channel 600V - 1Ω - 10A THT: TO220F15 1 4N20 N-Channel 200V - 1.4Ω - 2.8A THT: TO220F15 1 10N20 N-Channel 200V - 0.36Ω - 10A THT: TO220F15 5 E13007-2 High Voltage Power Transistor - 400V - 8A - 80W THT: TO220 4 TIP115 Medium-Power Complementary Silicon - 60V - 2A - 50W THT: TO220 1 TIP117 Medium-Power Complementary Silicon - 100V - 2A - 50W THT: TO220 1 K1117 N-Channel 600V - 0.95Ω - 6A THT: TO220 1 2SK2608 N-Channel 900V - 3.73Ω - 3A THT: TO220 1 KD607S Power Transistors - NPN - 10A - 80V - 70W THT: TO-3 4 2N3055 Power Transistors - NPN - 15A - 60V - 115W THT: TO-3 10 FJL6820 Triple Diffused Planar Silicon - NPN - 20A - 750V - 200W THT: TO-264 0 W13009 High voltage fast-switching NPN - 12A - 400V - 125W THT: TO-247 2 IRFP450 N-Channel 500V - 0.4Ω - 14A THT: TO-247 3 K2837 N-Channel 500V - 0.21Ω - 20A THT: TO-247 1 2SK2765 N-Channel 800V - 2Ω - 7A THT: TO-247 1 K2485 N-Channel 900V - 2.8Ω - 6A THT: TO-247 1 C5148 Silicon Power Transistors - NPN - 8A - 600V - 50W THT: TO-3P 1 C4769 Silicon Power Transistors - NPN - 7A - 800V - 60W THT: TO-3P 1 D1710 Silicon Power Transistors - NPN - 5A - 800V - 50W THT: TO-3P 1 J6916 Silicon Power Transistors - NPN - 16A - 800V - 60W THT: TO-3P 1 BU2520 Silicon Power Transistors - NPN - 10A - 800V - 45W THT: TO-3PF 1 BU508 Silicon Power Transistors - NPN - 8A - 700V - 125W THT: TO-247 2 KT872 Silicon Power Transistors - NPN - 8A - 700V - 100W THT: TO218 2 D1391 Silicon Power Transistors - NPN - 5A - 700V - 100W THT: TO-3P 1 BD442 Epitaxial Silicon Transistor - PNP - -4A - -80V - 36W THT: TO-126 1 B649 Epitaxial Silicon Transistor - PNP - -3A - -160V - 20W THT: TO-126 4 BD679 Epitaxial Silicon Transistor - NPN - 4A - 80V - 40W THT: TO-126 1 D1609 Epitaxial Silicon Transistor - NPN - 0.1A - 160V - 1.25W THT: TO-126 3 D669 Epitaxial Silicon Transistor - NPN - 1.5A - 160V - 20W THT: TO-126 4 B632 Epitaxial Silicon Transistor - PNP - -2A - -35V - 10W THT: TO-126 1 BD135 Epitaxial Silicon Transistor - NPN - 1.5A - 45V - 12.5W THT: TO-126 8 BD139 Epitaxial Silicon Transistor - NPN - 1.5A - 80V - 12.5W THT: TO-126 4 BF458 Epitaxial Silicon Transistor - NPN - 0.1A - 250V - 6W THT: TO-126 2 BD236 Epitaxial Silicon Transistor - PNP - -2A - -60V - 25W THT: TO-126 4 BD136 Epitaxial Silicon Transistor - PNP - -1.5A - -45V - 12.5W THT: TO-126 2 BD140 Epitaxial Silicon Transistor - PNP - -1.5A - -80V - 12.5W THT: TO-126 1 VN2410L Small Signal MOSFET N-Channel 240V - 10Ω - 0.2A THT: TO92 2 C3467 Epitaxial Silicon Transistor - NPN - 0.1A - 200V - 1W THT: SC-51 2 A1370 Epitaxial Silicon Transistor - PNP - -0.1A - -200V - 1W THT: SC-51 3 B647 Epitaxial Silicon Transistor - PNP - -1A - -80V - 0.9W THT: SC-51 5 D667 Epitaxial Silicon Transistor - NPN - 1A - 80V - 0.9W THT: SC-51 3 BFQ235 VIdeo Transistor - NPN - 0.3A - 110V - 3W THT: TO-202 3 40N03 N-Channel 25V - 0.012Ω - 45A THT: TO220 1 VS4604 N-Channel 40V - 0.0026Ω - 150A THT: TO220 1 SVF18N50 N-Channel 500V - 0.26Ω - 18A THT: TO220F 4 BD911 Silicon Power Transistors - NPN - 15A - 100V - 90W THT: TO220 3 BUX98A Silicon Power Transistors - NPN - 24A - 1000V - 200W THT: TO218 2 IRFB4710 N-Channel 100V - 0.014Ω - 75A THT: TO220 16 IKW40T120 IGBT 1200V - 1.7V - 40A THT: TO247 4 G20N60 IGBT 600V - 2.4V - 40A THT: TO247 2 G4PC40U IGBT 600V - 1.72V - 20A THT: TO247 2 GW30NC120HD IGBT 1200V - 2.75V - 30A THT: TO247 2 IRFPG50 N-Channel 1000V - 2Ω - 6.1A THT: TO247 2 8. Diferite circuite integrate (utile pentru cei care mai repara diferite aparate, pretul depinde de model si cantitate) - pret informativ 3lei/buc Name Description Package Quantity MAX202 5-V Dual RS-232 Line Driver and Receiver SMD: SO16 7 MAX483 RS-485/RS-422 Transceivers SMD: SO8 3 TL074 JFET-Input Operational Amplifiers SMD: SO14 2 IS7421 Low-Power Dual-Channel Digital Isolators SMD: SO8 4 VP11 3.3-V RS-485 TRANSCEIVERS SMD: SO8 16 L297 STEPPER MOTOR CONTROLLERS SMD: SO20 3 LM75 Digital Temperature Sensor I2C SMD: SO8 8 PCF8563 Real-time clock/calendar I2C SMD: SO8 6 PCF85176 40 x 4 universal LCD driver SMD: TQFP64 4 MAX232 Dual EIA-232 Drivers/Receivers SMD: SO16 3 PCF8574A Remote 8-bit I/O expander for I2C SMD: SO16 3 PCA9546A 4-channel I2C-bus switch SMD: SO16 3 24LC64 64K I2C, Serial EEPROM SMD: SO8 4 ULN2003 Seven Darlington arrays SMD: SO16 4 ULN2803 8 Darlington Transistor Arrays SMD: SO18 1 MAX485 RS-485/RS-422 Transceivers THT: DIP8 8 IXDP630 3-Phase PWM Controls THT: DIP18 3 LM331 Precision Voltage-to-Frequency Converters THT: DIP8 2 ULN2004 Seven Darlington arrays THT: DIP16 3 HCNW3120 2.5 Amp Output Current IGBT Gate Drive Optocoupler SMD: Gull wing 8 18 OP177 Ultraprecision Operational Amplifier THT: DIP8 2 OP07 Ultralow Offset Voltage Operational Amplifier THT: DIP8 2 NE555 Precision Timers THT: DIP8 2 H11D1 Transistor Output Optocouplers SMD: Gull wing 6 10 LM324 Low-Power, Quad-Operational Amplifiers THT: DIP14 5 UC3843 High Performance Current Mode Controllers THT: DIP8 4 ULN2003 Seven Darlington arrays THT: DIP16 6 MC144110 Digital-to-Analog Converters with Serial Interface THT: DIP18 2 UAA2022 16 SEGMENT LED DRIVER THT: DIP24 1 TC7660 Charge Pump DC-to-DC Voltage Converter THT: DIP8 1 LM358 Low-Power, Dual-Operational Amplifiers THT: DIP8 2 TL494 Pulse-Width-Modulation Control Circuits THT: DIP16 1 PCF8563 Real-time clock/calendar I2C THT: DIP8 2 TDA2614 6 W hi-fi audio power amplifier THT: SOT110 1 uPC1242 7 W AF power amplifier THT: 8 SIL 1 uPC1241 7 W AF power amplifier THT: 8 SIL 1 KIA7280 5.8W Dual Audio Power Amplifier 22W BTL Audio Power THT: HZIP12-P 1 LM567 Tone Decoder, Precision oscillator THT: DIP8 1 UAA170 LED Driver For Light Spot Displays THT: DIP16 1 SN29764 4 bit Binary 7 Segment Decoder/Driver THT: DIP16 1 TDA7057 2 × 8 W stereo audio output amplifier, DC volume control THT: SOT141-6 2 TDA8943 6 W mono Bridge Tied Load (BTL) audio amplifier THT: SOT110 1 TDA2005 20 W bridge/stereo amplifier for car radio THT: Multiwatt11 1 TDA7262 20+20W STEREO AMPLIFIER WITH STAND-BY THT: Multiwatt11 1 TA8223 Low Frequency Power Amplifier THT: HSIP15-P 1 UTC2003 10W Car Radio Audio Amplifier THT: TO220B 3 C1316 Dual Audio Power Amplifier THT: DIP14 TAB 1 B1403 5 DOT Red/Green LED Level Meter THT: SIL9 1 LM324 Low-Power, Quad-Operational Amplifiers SMD: SO14 1 UC3845 High Performance Current Mode Controllers THT: DIP8 2 UC3842 High Performance Current Mode Controllers THT: DIP8 2 FOD8316 2.5 A Output Current, IGBT Drive Optocoupler SMD: SO16 16 MCP23017 16-Bit I/O Expander with Serial Interface THT: DIP28 4 SG3525 Pulse Width Modulator Control Circuit THT: DIP16 3 FPAM30LH60 PFC SPM 2 Series for 2-Phase Interleaved PFC THT: S32EA-032 2 TPD4124K The TPD4124K is a DC brush less motor driver THT: HDIP26-P 1 PS219A4-ASTX 600V/15A low-loss IGBT inverter bridge for three phase THT: DPH-7897e 1 PC814 AC Input Photocoupler THT: DIP4 20 9. Boxe HI FI SM 80 K - 200 lei https://postimg.cc/gallery/CF9BZ5T Boxele se afla in perfectă stare de funcționare, iar estetic sunt de nota 9.5. Sunt deja colantate și gata de pus in funcțiune. Fără nici o intervenție pe partea de difuzoare sau filtre, totul este original. Putere reală: 50W Putere muzicala: 80 W Impedanța: 8 ohmi Dimensiuni: 430x253x207 mm Le dau doar cu predare personala și testare la fata locului. Imi cer scuze pentru raspunsul intarziat, dar timpul fuge de mine. La 19.04.2023 la 12:53, floob a spus: Pe când trimiteți cele rezervate? Nu am avut efectiv timp sa merg la posta, am incercat intr-o zi, dar coada era interminabila. Din acest motiv nu o sa mai trimit colete, produsele se vand doar cu predare personala. Am trimis un colet la un coleg de pe forum si nu l-a mai ridicat (nu dau nume ca nu asta este important), dar din acest motiv renunt la a mai trimite colete. Va multumesc pentru intelegere! Pentru mai multe detalii ma puteti contacta la numarul de telefon: 0761813130 (telefonic sau pe WhatsApp) sau in mesageria privata. Editat Aprilie 21, 2023 de PKP98 Adaugarea punctului 9 Link spre comentariu
RJK Postat Aprilie 21, 2023 Partajează Postat Aprilie 21, 2023 Acum 4 ore, PKP98 a spus: Am trimis un colet la un coleg de pe forum si nu l-a mai ridicat (nu dau nume ca nu asta este important), dar din acest motiv renunt la a mai trimite colete. Cereti plata in cont, in avans, si puteti trimite fara probleme. Succes! Link spre comentariu
adydep Postat Aprilie 22, 2023 Partajează Postat Aprilie 22, 2023 Colegului @floob i-am trimis în decursul timpului 3 colete,toate cu ramburs,ridicate fără nici o problemă.Om serios. Link spre comentariu
PKP98 Postat Aprilie 22, 2023 Autor Partajează Postat Aprilie 22, 2023 A zis cineva ceva de colegul @floob ? Problema este ca nu mai am timpul necesar sa trimit colete. Eu inteleg foarte bine ca experienta mea negativa nu trebuie generalizata, dar am specificat clar ca nu mai timpul necesar sa il pierd pe la cozi ca apoi sa se mai intample sa nici nu fie ridicat de catre cumparator. Produsele se vand doar in Bucuresti cu predare personala si chiar testare la fata locului pentru cine doreste. Imi place sa stiu ca omul este multumit de ceea ce cumpara si ca amandoi ne bucuram de targul realizat. In trecut am mai fost acuzat ca am trimis niste difuzoare nefunctionale, desii am specificat clar in anunt ca nu stiu stare lor, erau la gramada. Sunt doar niste exemple si nu acuz pe nimeni de nimic, vreau doar ca ambele parti sa fie multumite. Multumesc! Link spre comentariu
floob Postat Aprilie 22, 2023 Partajează Postat Aprilie 22, 2023 Am citit ce a-ți postat în legătură cu trimiterea coletelor prin poștă. Părerea mea că v-ați descurajat prea repede când ați ajuns la poștă. Acum se fac numeroase plăți la ghișee cu acele carduri subvenționate de guvern. Poate că ar fi și soluția de a trimite prin curier, bineînțeles cu plata înainte prin cont să nu aveți surprize neplăcute. Oricum, nu e plăcut deloc să-i spui cuiva după două săptămâni de așteptare că nu-i mai trimiți că nu ai timp de poștă... Link spre comentariu
