Alimentatoare,Temporizatoare,alte Diverse
vasile barsan
Valabile inca:
1 -  PIK - UP / amplificator VOLNA stereo , portabil , rusesc ,an 1991 , alimentare cu baterii sau adaptor retea dedicat (inclus in pret), stare foarte buna , perfect functional , doza originala (veche dar inca buna), sunet puternic , un pic zgariat capacul spate(vizibil in poze), brosura utilizare , pentru colectie sau uz curent , pret = 120 lei - negociabil
https://i.postimg.cc/fbyzPfjM/PIK-UP-VOLNA-PLATAN.jpg
https://i.postimg.cc/ZYBHrWgg/PIK-UP-VOLNA-SPATE.jpg
https://i.postimg.cc/KjGZh6d3/PIK-UP-VOLNA-DES-1.jpg
https://i.postimg.cc/c1bjWyyq/PIK-UP-VOLNA-BAT.jpg
https://i.postimg.cc/ZYvkCKLY/manula-volna.jpg
https://i.postimg.cc/RZXpgjTb/ALIMENTATOR-VOLNA-1.jpg
2 - Sursa SMPS , 0-12V / 5A , home made , (echipata cu LM 317 + 2 xTIP 3055),pentru cine nu are timp/ posibilitati sa construiasca.. pret = 150 130lei - negociabil
https://i.postimg.cc/fyy98r6X/SURSA-12-V-FATA.jpg
https://i.postimg.cc/KjbZzk5Y/SURSA-12-V-FATA2.jpg
https://i.postimg.cc/0QWf5DvY/SURSA-12-V-INT-1.jpg
https://i.postimg.cc/1zLFvByY/SURSA-12-V-INT2.jpg
https://i.postimg.cc/q70V2V3m/SURSA-12-V-LAT.jpg
https://i.postimg.cc/FKRtTbTc/SURSA-12-V-SPATE.jpg
3 - Placa de baza PC , model G41T - M7 , echipata cum se vede in poze (procesor ;cooler ; memorii ),perfect functionala , pret = 75 lei , 50 lei
https://i.postimg.cc/zvhd3gMM/PLACA-DE-BAZA-1.jpg
https://i.postimg.cc/cLhFKZ9s/PLACA-BAZA-2.jpg
https://i.postimg.cc/66ZzrCjb/PLACA-BAZA-3.jpg
4 - SURSA ATX 450W , perfect functionala , pret = 25lei
https://i.postimg.cc/RZcPxs9L/SURSA-ATX-450-W-1.jpg
https://i.postimg.cc/rsB9vWPH/SURSA-ATX-450-W.jpg
5 - PLACA VIDEO MSI  V234 , pret  = 25lei  20 lei
https://i.postimg.cc/KjtR9MSQ/PLACA-VIDEO.jpg
Toate perfect functionale
6 - Cutie metalica (fosta sursa ATX transformata) , fata din AL  , echipata cu voltampermetru digital ,ventilator , cablu retea ,buton (fara retinere) , intrerupator retea ,borne.. gata pentru a primi un montaj de sursa , pret = 60 lei  45 lei
https://i.postimg.cc/zDM76b1s/CUTIE-SURSA-FATA.jpg
https://i.postimg.cc/wxJRx7N8/Cutie-sursa-baza.jpg
https://i.postimg.cc/0rRpQSkr/Cutie-sursa-lat.jpg
https://i.postimg.cc/kgyh0JsW/CUTIE-SURSA-spate.jpg
7 - RR SONATA 201 ,anii "70 un radio colectibil , perfect functional , alimentare baterie 9V ( sau 2x baterii 4,5v patrate / alimentator cc 9v dedicat ) UM; US ,la carcasa  am mai umblat eu deoarece manerul era desprins ,lipsa capacul bateriilor ,ultimul element al antenei , detaliile se vad in poze , tija butonului UM este rupta(pare ca sta tot timpul apasata dar este ok -schimba gamele) ,  nu influenteza buna functionare, pentru colectionari ,componentele sunt originale  , construit pe sasiu metalic, destul de rar , pret = 60 lei  50 lei
https://i.postimg.cc/2SJ2DyBZ/RR-SONATA-BAZA.jpg
https://i.postimg.cc/GpGJnQCW/RR-SONATA-DET.jpg
https://i.postimg.cc/SRsMRLBN/RR-SONATA-FATA.jpg
https://i.postimg.cc/LX0sycW2/RR-sonata-LAT.jpg
https://i.postimg.cc/MT4W0ycG/RR-SONATA-SPATE.jpg
Mai multe poze exista in paginile de mai sus
8 -  RR  "NOSTALGIC" , un aparat rar ,colectibil , UM ; UUS 1 - UUS 2 , carcasa tip "cathedral" , construit de Electronica (probabil / sigur  pentru export), carcasa din lemn  perfecta (fara zgarieturi , crapaturi ,pete - arata mai bine ca in poze), functional ,sunet perfect , in UUS nu are receptie -doar fassul specific ,(il am de tare multa vreme -suspectam filtrul ceramic ,insa nu am intervenit pentru reparatie datorita comoditatii.. si lipsei unei scheme dedicate.. ),absolut complet / componente originale, pentru cunoscatori  pretul = 200 180 lei ar fi in regula (livrare cu posta / suma in cont)
https://i.postimg.cc/rFSPgJLk/RR-NOSTALGIC-1.jpg
https://i.postimg.cc/vTSHKsn4/RR-NOSTALGIC-2.jpg
https://i.postimg.cc/rsdLKtdp/RR-NOSTALGIC-3.jpg
https://i.postimg.cc/9XvfyWck/RR-NOSTALGIC-BAZA.jpg
https://i.postimg.cc/1R6ShDZW/RR-NOSTALGIC-PCB-1.jpg
https://i.postimg.cc/tgY0rx5N/RR-NOSTALGIC-SPATE.jpg
9 -  Difuzor subwofer , 8 ohm / 75W , diam. = 170 cm , h = 8cm ,stare f.buna , pret = 45 lei  40 lei
https://i.postimg.cc/ZR21z326/dif-bass-1.jpg
https://i.postimg.cc/y6RGSD2r/dif-bass-h-8.jpg
https://i.postimg.cc/TPHsngRB/dif-bass-75-w-8ohm.jpg
10 - SENZOR PIR ,12v , nefolosit  , PRET = 15 lei
https://i.postimg.cc/rmT21xyr/senzor-pir-12v-lateral.jpg
11 - STROBOSCOP AUTO , profesional , se folosea la reglarea aprinderii / distributiei , la auto cu motor cu aprindere prin scanteie , pentru nostalgici sau pasionati , alte aplicatii , pret = 15 lei
https://i.postimg.cc/QtGTKHtF/STROBOSCOP-AUTO.jpg
https://i.postimg.cc/d1Jktqs5/MANERE-DIVERSE.jpg
12 - TASTATURA ALARMA , in cutie zdravana ,metalica + SENZOR ZGOMOT(de ex. GEAM SPART) , PRET = 15 lei ambele
https://i.postimg.cc/13XnF0bm/tastatura-int.jpg
13 -  COMBINA  audio monobloc RECOR , stereo , telecomanda - [ON ; OFF ; VOL] ,stare perfecta optic(fara zgarieturi , sparturi ,etc) functional : radio ; pik-up ; dublu cass .
RADIO analog AM FM , selectiv, sensibil ; PIK-UP , doza perfecta , platan 33 - 45 rpm , CASS dublu , mecanica autorevers (una din parti) ,posibilitate inregistrare rapida , curele schimbate recent , EQ 5 cai . Fara boxe /difuzoare . Combina este made in China ,PRET = 100 lei
https://i.postimg.cc/Fs6dzfhC/RECOR-FATA.jpg
https://i.postimg.cc/Z5y9dTRb/RECOR-LAT-1.jpg
https://i.postimg.cc/wv93ZLkM/RECOR-LAT-2.jpg
https://i.postimg.cc/3rSWfy0r/RECOR-SPATE.jpg
14 - Letcon 100W (URSS made) ,rezistenta lipsa , in schimb carcasa foarte buna, din bachelita , fara crapaturi ,pret = 15 lei
https://i.postimg.cc/Qd93ssLM/LETCON-URSS-2.jpg
https://i.postimg.cc/fy2GnqBX/LETCON-URSS-3.jpg
15 - Motorase stepper (2 buc) +  1buc "normal" , recuperate dintr-o imprimanta HP , detalii in poze ,pret = 35 lei toate
https://i.postimg.cc/TYgJkSsY/IMG-20240128-151302.jpg
https://i.postimg.cc/5Ns2M9TP/IMG-20240128-151439.jpg
https://i.postimg.cc/MKCrHVCX/IMG-20240128-152044-Copy.jpg
https://i.postimg.cc/HkTvbdLC/IMG-20240128-152055-Copy.jpg
https://i.postimg.cc/nrcMvXND/IMG-20240128-152125-Copy.jpg
17 - Amplificator home made 2x20 w (chinezesti) ,4-8 Ohm  ,carcasa AL , telecomanda functii multiple , corector ton inalte / joase ,  intrari : aux ; usb ; micro SD ; bluetooth , radioFM  incorporat.Un proiect didactic (abandonat - l-am construit in joaca si asa a ramas..) care poate fi modificat ,imbunatatit , transformat , etc..  pret = 120 lei -(pretul componentelor) -   negociabil.
https://i.postimg.cc/CMPWH0qV/AMPLI-TELEC.jpg
https://i.postimg.cc/v8VN9nb5/AMPLI-INT-2.jpg
https://i.postimg.cc/L5DffvXH/AMPLI-SPATE.jpg
https://i.postimg.cc/431JX0FN/AMPLI-BAZA.jpg
18 - Alimentator Radioprogres , 3-15v , probabil functional , gasit  prin cutiile mele , carcasa ok , completa , traf , cablaj , vad ca lipseste led-ul ,butonul reset si bornele.. pentru colectie sau reconditionare , pret = 35 lei
https://i.postimg.cc/xjRnnV4V/ALIM-RADIOPROGRES-FATA.jpg
https://i.postimg.cc/T3nkvftr/ALIM-RADIOPROGRES-INT.jpg
https://i.postimg.cc/BZVsXB4m/ALIM-RADIOPROGRES-SUS.jpg
https://i.postimg.cc/ZnFMFmXP/ALIMENTATOR-RADIOPROGRE-CABLAJ.jpg
https://i.postimg.cc/0yJ7Ln2F/ALIMENTATOR-RADIOPROGRES-CAB.jpg
https://i.postimg.cc/F1Xh1h3j/ALIMENTATOR-RADIOPROGRES-3.jpg
19 - SET Discuri taietoare , pret = 15 lei  ; Magnet cu tija telescopica ,extensibila pana la 60cm ,(ptr. recuperat suruburi din locuri greu accesibile .de ex.), pret = 15lei
https://i.postimg.cc/W4MB2x7k/IMG-20240426-140325.jpg
https://i.postimg.cc/wvn4LVFp/IMG-20240426-140141.jpg
  • Răspunsuri 312
  • vasile barsan
    205
  • Tanase Ion
    16
  • carageae
    10
  • grosu99
    9
Se adauga la cele de mai sus:
Voltampermetru digital  100V / 10A , 2buc , pret = 20lei / buc
Voltmetru digital 100V , afisor mare , pret = 15lei
https://i.postimg.cc/vH3cfLG6/Voltmetru-100-V.jpg
https://i.postimg.cc/zfpt1QNG/Voltmetru-100-V.jpg
Conectori cablaj - cablu ,  2 / 3 / 4 pini ,miniatur , sunt cate 10 buc din fiecare , pret = 20 lei toate
https://i.postimg.cc/BvrnCm8M/conectori-cablu-2.jpg
Voltamperimetrele le vreau eu
Si cu ce mai rezervasem se pot trimite. Cu stima si respect multumesc frumos.
Editat de Tanase Ion
Am macat o litera, scuze de greseala
Le vreau eu .
Acum 53 minute, Tanase Ion a spus:
In regula , le trimit saptamana viitoare
Acum 52 minute, nostromo a spus:
Le vreau eu .
Ok , le pun deoparte pentru dvs..
Multumesc , daca mai apar si voltampermetre m-ar interesa si pe mine 1-2 buc.
Editat de nostromo
Au ramas valabile (actualizare):
1 -  PIK - UP / amplificator VOLNA stereo,portabil , rusesc ,an 1991 , alimentare cu baterii sau adaptor retea dedicat (inclus in pret), stare foarte buna , perfect functional , doza originala (veche dar inca buna), sunet puternic , un pic zgariat capacul spate(vizibil in poze), brosura utilizare , pentru colectie sau uz curent , pret = 120 lei - negociabil
2 - Sursa SMPS , 0-12V / 5A , home made , (echipata cu LM 317 + 2 xTIP 3055),pentru cine nu are timp/ posibilitati sa construiasca.. pret = 130lei - negociabil
3 - Placa de baza PC , model G41T - M7 , echipata cum se vede in poze (procesor ;cooler ; memorii ),perfect functionala , pret =  50 lei
5 - RR SONATA 201 ,anii "70 un radio colectibil , perfect functional , alimentare baterie 9V ( sau 2x baterii 4,5v patrate / alimentator cc 9v dedicat ) UM; US ,la carcasa  am mai umblat eu deoarece manerul era desprins ,lipsa capacul bateriilor ,ultimul element al antenei , detaliile se vad in poze , tija butonului UM este rupta(pare ca sta tot timpul apasata dar este ok -schimba gamele) ,  nu influenteza buna functionare, pentru colectionari ,componentele sunt originale  , construit pe sasiu metalic, destul de rar , pret = 60 lei  50 lei
6 -  RR  "NOSTALGIC" , un aparat rar ,colectibil , UM ; UUS 1 - UUS 2 , carcasa tip "cathedral" , construit de Electronica (probabil / sigur  pentru export), carcasa din lemn  perfecta (fara zgarieturi , crapaturi ,pete - arata mai bine ca in poze), functional ,sunet perfect , in UUS nu are receptie -doar fassul specific ,(il am de tare multa vreme -suspectam filtrul ceramic ,insa nu am intervenit pentru reparatie datorita comoditatii.. si lipsei unei scheme dedicate.. ),absolut complet / componente originale, pentru cunoscatori  pretul = 200 180 lei ar fi in regula (livrare cu posta / suma in cont)
7 -  Difuzor subwofer , 8 ohm / 75W , diam. = 170 cm , h = 8cm ,stare f.buna , pret =  40 lei
8 - SENZOR PIR ,12v , nefolosit  , PRET = 10 lei
9 - STROBOSCOP AUTO , profesional , se folosea la reglarea aprinderii / distributiei , la auto cu motor cu aprindere prin scanteie , pentru nostalgici sau pasionati , alte aplicatii , pret = 15 lei
10 - TASTATURA ALARMA , in cutie zdravana ,metalica + SENZOR ZGOMOT(de ex. GEAM SPART) , PRET = 15 lei ambele
11 -  COMBINA  audio monobloc RECOR , stereo , telecomanda - [ON ; OFF ; VOL] ,stare perfecta optic(fara zgarieturi , sparturi ,etc) functional : radio ; pik-up ; dublu cass .
12 - Motorase stepper (2 buc) +  1buc "normal" , recuperate dintr-o imprimanta HP , detalii in poze ,pret = 25 lei toate
13 - Amplificator home made 2x20 w (chinezesti) ,4-8 Ohm  ,carcasa AL , telecomanda functii multiple , corector ton inalte / joase ,  intrari : aux ; usb ; micro SD ; bluetooth , radioFM  incorporat.Un proiect didactic (abandonat - l-am construit in joaca si asa a ramas..) care poate fi modificat ,imbunatatit , transformat , etc..  pret = 120 lei -(pretul componentelor) -   negociabil.
14 - Alimentator Radioprogres , 3-15v , probabil functional , gasit  prin cutiile mele , carcasa ok , completa , traf , cablaj , vad ca lipseste led-ul ,butonul reset si bornele.. pentru colectie sau reconditionare , pret = 30 lei
15 - Voltmetru digital 100V , afisor mare , pret = 15lei
Se adauda la cele de mai sus:
16 - Modul (kit amplificator) LM 386 ,mono , 1W , alimentare 5-12v , sunt 3buc , pret = 8lei/buc
https://i.postimg.cc/cLdTjy7t/AMPLIF-386-1.jpg
https://i.postimg.cc/sgwFHJWy/LM-386-AMPLI.jpg
17 - motor mag. MAJAK ,
17 - motor mag. MAJAK ,perfect functional , pret =15 lei
Acum 1 minut, vasile barsan a spus:
https://i.postimg.cc/mZ3t2t1q/motor-MAJAK-1.jpg
Se adauga nu se adauda😖
Actualizare - adaugare produse in ultimul post :
18 - traf si alte componente cuptor microunde (rezultate din dezmembrare) , perfect functionale
https://i.postimg.cc/fkn0dD37/cuptor-1.jpg
https://i.postimg.cc/TYgt4Pc6/cuptor-farfurie.jpg
Motivul dezmembrarii :
https://i.postimg.cc/wjk09bP4/cuptor-int.jpg
Pret:  trafo = 25 lei ; motor farfurie = 8lei ; condensator +diode = 15lei ; ventilator = 12 lei ; filtru retea+microintrerupatoare = 8 lei ; temporizator = 5 lei ; farfurie = 10 lei , magnetron = 10 lei  sau toate = 65lei
Puneti va rog deoparte piesele pt. microunde, va spun maine seara sau cel tarziu marti daca cu traf sau fara...am unul de reparat si inca nu stiu ce are....mai aveti si siguranta?
Acum 12 ore, carageae a spus:
Sigur, nicio problema ! se vede in poze si siguranta termica(nu am mentionat in anunt)
