Shambala Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 Ok, multumim. Link spre comentariu
Vizitator Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 (editat) Comanda minima 30 lei doar aici in topic fara editari. Rezervari pana in 05.03. 1. vumetre cu ace, 50 lei cele de jos, 30 lei cele de sus, unul de sus necesita un mic reglaj de aducere in 0 dar toate sunt functionale. https://ibb.co/tJCbmKN 2. vumetre cu ace functionale cu preturi dupa cum urmeaza; nr.1 =20 lei, nr. 2,3,4=30 lei perechea https://ibb.co/FhCc3xW 3. filtraje mari 15 lei perechea https://ibb.co/G77Zn1b 4. finali sony mn2488/mp1620, 5 perechi, una nu am pozat-o, 10 lei perechea https://ibb.co/M72ky8X 5. finali motorola MJ3001/MJ2501 2 perechi 20 lei perechea https://ibb.co/cxFgvkg 6. finali motorola BD311/BD312 2 perechi la 20 lei perechea https://ibb.co/C1mnXPG 7. finali nec 2sd586/2sb616 35 lei perechea https://ibb.co/6FpBfB8 8. radiatoare rusesti (capsule to-3), 25 lei https://ibb.co/ZzQbTPk https://ibb.co/7tkkC1z 9. filtre audio din boxe nemtesti 40 lei https://ibb.co/MZs5LHM https://ibb.co/Vxm4ZPh 10. traf toroidal din final rusesc dimensiuni D=12 H=5, 40 lei, nu stiu cat scoate https://ibb.co/dgM63vH https://ibb.co/yQ6zS11 11. difuzoare inalte nemtesti, unul bun, unul intrerupt 30 lei https://ibb.co/gr31nfZ https://ibb.co/m8VL6ys 12. difuzoare bune din pickup supraphon 30 lei https://ibb.co/QNTNhtx https://ibb.co/48hMrsy 13. lot butoane 50 lei https://ibb.co/ctw4xNC 14. lot butoane 30 lei https://ibb.co/sJX3wk1 15. placa kenwood, stk neverificate 25 lei https://ibb.co/64xBf2s 16. placa deck philips 20 lei https://ibb.co/1dQHWK6 17. corector ton 10 lei https://ibb.co/9GPMRbz 18. placa amplif, stk neverificat 20 lei https://ibb.co/0yYPdpz 19. modul redresare philips 10 lei https://ibb.co/zhJt9wH 20. module amplificare pickup akkord 50 lei https://ibb.co/b6v7FsB 21. placa amplificator 15 lei https://ibb.co/VMqQR66 https://ibb.co/VwcnB2L 22. modul tuner 10 lei https://ibb.co/tXp5cbW 23. 2 radiatoare aluminiu, 10 lei bucata https://ibb.co/gWqnPty https://ibb.co/6BXdqqN 24. placa amplif sony 15 lei https://ibb.co/7Qjy9MS https://ibb.co/crgN0SD 25. vumetre cu ace si becuri grundig 35 lei toate https://ibb.co/T8y8FBH 26. placa amplif 5 lei https://ibb.co/CbFQytm 27. placa deck 20 lei https://ibb.co/923kNsS 28. potentiometru volum cu priza loudness 10 lei https://ibb.co/dJ67Yph 29. placa mare cu radio si corector itt 30 lei https://ibb.co/G9nzS1w 30. volum cu loudness si corector 15 lei https://ibb.co/n6YXspV 31. vumetru stereo cu leduri 20 lei https://ibb.co/djLHkL1 32. decodor stereo cu tca 290a 20 lei https://ibb.co/QjbDLRG 33. placa amplif sony 30 lei https://ibb.co/DYnZ5MT 34. filtraje rusesti dintr-un final 15 lei toti https://ibb.co/PgbY5w2 35. difuzoare bas 25cm impecabile si functionale date tehnice in poza 2, 120 lei https://ibb.co/QFmrfQr https://ibb.co/Jnmg50n 36. filtru boxa, am doar unul 15 lei https://ibb.co/d5S1hsj 37. traf onkyo 2x37v 25 lei https://ibb.co/DbGtMKJ Editat Februarie 27, 2023 de fluffy37 Link spre comentariu
cristi7521 Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 Punctul 37 il iau eu. Link spre comentariu
okean Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 24. placa amplif sony 15 lei https://ibb.co/7Qjy9MS https://ibb.co/crgN0SD Link spre comentariu
paul_ral Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 Ce valoare are potentiometrul de la nr.28? Daca e 250kohm il vreau eu Link spre comentariu
okean Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 (editat) 27. placa deck 20 lei https://ibb.co/923kNsS 21. placa amplificator 15 lei https://ibb.co/VMqQR66 https://ibb.co/VwcnB2L Editat Februarie 27, 2023 de okean Link spre comentariu
Barbaro Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 Va salut. Punctele 30 și 35 la mine vă rog. Link spre comentariu
ionroata Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 25 la mine Link spre comentariu
hamatdumitru Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 34. filtraje rusesti dintr-un final 15 lei toti https://ibb.co/PgbY5w2 Link spre comentariu
Vizitator Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 Acum 47 minute, paul_ral a spus: Ce valoare are potentiometrul de la nr.28? Daca e 250kohm il vreau eu Ati ghicit bine, vi l-am pus deoparte. Link spre comentariu
paul_ral Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 Mulțumesc. Astept sa mai apara ceva piese de interes Link spre comentariu
sonic11 Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 33. la mine Link spre comentariu
hamatdumitru Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 36. filtru boxa, am doar unul 15 lei https://ibb.co/d5S1hsj Link spre comentariu
nostromo Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 Daca nu i-a luat nimeni ii vreau eu pe toti . 50 Lei 4. finali sony mn2488/mp1620, 5 perechi, una nu am pozat-o, 10 lei perechea https://ibb.co/M72ky8X Link spre comentariu
Vittorino Postat Februarie 27, 2023 Partajează Postat Februarie 27, 2023 (editat) Va salut! Daca nu au fost inca rezervate... as vrea eu: 20. module amplificare pickup akkord 50 lei https://ibb.co/b6v7FsB 22. modul tuner 10 lei https://ibb.co/tXp5cbW 29. placa mare cu radio si corector itt 30 lei https://ibb.co/G9nzS1w 31. vumetru stereo cu leduri 20 lei https://ibb.co/djLHkL1 32. decodor stereo cu tca 290a 20 lei https://ibb.co/QjbDLRG Si lasam deschis poate mai apare ceva ;) Multumesc mult. Editat Februarie 27, 2023 de Vittorino Corectorul automat setat pe EN... Link spre comentariu
