Ajutor pt proiectarea primului cablaj cu Autodesk Eagle 9.6.2 free
Costa
  • Răspunsuri 63
  • Costa
    35
  • sesebe
    13
  • ratza
  • Dxxx
Am impresia ca oricat de mult bunavointa am avea noi, dumneata nu vrei sa fii ajutat. De ce am impresia ca nu ai avut rabdare sa te uiti la cele 2 - 3 ore de tutorial la care ti am dat link ?
Scuze,am folosit gresit top si bottom in ceea ce am scris.
In soft nu am ales nimic,am lucrat pe setarile existente.
Ma intorc la citit...poate si unul dintre voi...
Multumesc
Cu stima Costa
D-le djvas gresiti, stiam despre acel material.
Am sa pun mai jos link-urile si cautarile mele poate ajuta si alti incepatori..
       Eagle link
Eagle Tutorial-Marius Stanciu:@mars01 Author Posted December 26, 2017
                    https://www.elforum.info/topic/126226-eagle-tutorial/#comment-1575712
#partea 1 : https://www.youtube.com/watch?v=lG51U8Br9pA&feature=youtu.be
#partea 2 : https://www.youtube.com/watch?v=9Q_FC1wdiuw&feature=youtu.be
#partea 3 : https://www.youtube.com/watch?v=RmtNO3O8Pw8&feature=youtu.be
#partea 4 : https://www.youtube.com/watch?v=6Gg-wM7iNGA&feature=youtu.be
#partea 5 : https://www.youtube.com/watch?v=NrGQbeO0ZYU&feature=youtu.be
#partea 6 : https://www.youtube.com/watch?v=2-4T1TEs85s&feature=youtu.be
#partea 7 : https://www.youtube.com/watch?v=mHKsOZg7CBg&feature=youtu.be
#partea 8 : https://www.youtube.com/watch?v=lCsE7RKQ7Rk&feature=youtu.be
#Partea 9 : https://youtu.be/MJr8Ya0y4os
                    https://www.youtube.com/watch?v=MJr8Ya0y4os&feature=youtu.be
Traseele de masa in Eagle
https://www.elforum.info/topic/950-trasee-de-masa-in-eagle/
Librarie eagle.
https://www.elforum.info/topic/129978-librarie-eagle/
Ajutor Autoroute Eagle
https://www.elforum.info/topic/873-ajutor-autoroute-eagle/
Un ajutor ptr. programul Eagle:
https://www.elforum.info/topic/94-un-ajutor-ptr-programul-eagle/
Cum se face un cablaj in eagle pas cu pas cu imagini
http://tehniq.uv.ro/cablaj0/cablaj0.htm
Tutorial Eagle in Limba Romana Partea I-Schema electronica [RO]
https://www.youtube.com/watch?v=F5Ai4lAIzoU
EAGLE Tutorial: Library Part Creation Part 1 - Creating Packages
https://community.element14.com/members-area/personalblogs/b/rachael-s-blog/posts/eagle-tutorial-library-part-creation-part-1---creating-packages
 Exporting Gerber files from EAGLE, ce poate fi descarcat de aici:
http://docdro.id/FkYnsGH
Using EAGLE: Schematic
https://learn.sparkfun.com/tutorials/using-eagle-schematic/all
Intrebari pt google sau youtube:
how to switch between layers on eagle
how to disable a layer on eagle
eagle pcb layout guidelines
eagle for beginners
getting started with eagle
Informatii f multe trebuie timp pt intelegere si aprofundare.
Sunt f utile mai ales pt profesionisti ceea ce nu este cazul meu !
Cu toate erorile posibile am listat de proba traseele pe hartie normala si este in regula.
Mai am de facut modificari apoi sa studiez cum pot obtine pe hartie lucioasa printarea la rezolutia maxima buna pt realizarea cablajului.
Multumesc
Cu stima Costa
Tot de pe forum adunate,poate sunt utile si pt altii asa adunate.
-Intotdeauna si in orice soft vederea este de sus prin pcb adica spre tine este fata cu componentele.
Se poate rasturna la printare/ export.
Cateva tips-uri:
- Stai pe GRID de 100 mil cu alternativa de 50 MIL. Plasarea componentelor sa fie SNAP on GRID. Atat componentele cat si traseele le pozitionezi pe GRID si dimensiuni imperiale. MEtric faci doar partea mecanica ( Dimensiuni, gauri de fixare, etc )
- DRC trebuie sa fie cel mai bun prieten al tau. Cel standard nu e OK pentru toner. Cauta un fisier DRC facut special pentru asha ceva ca sigur gasesti. Eu nu pot recomanda ca nu folosesc aceasta metoda.
- Atentie ca PAD-uri din librariele standard EAGLE nu prea sunt ok pentru toner. Sunt MULLLLT prea mici si sigur nu ies ok. Eu am componente editate chiar si pentru cablaje de fabrica.
- In EAGLE nu poti face NIMIC pe PCB fara concordanta cu schema. NU incerca sub nici o forma ca o sa primesti eroare ca nu sunt consistente si nu o sa mai stii ce sa le faci.
-Stie cineva sub ce denumire gasesc in eagle un terminal tata 6.3mm pentru cablaj?=papuc auto
-Vezi în librăria con-faston, PIN2
-stergere dimensiuni board -click pe group-selectare zona -delete-gata
-ce pot utiliza pt realizarea conexiunii "IN"=intrare semnal audio (gaura in cablaj si scris numele),   idem pt. "OUT"=iesire pt difuzor si   idem pt "V+", "V-" SI "GND"=alimentarile de la sursa
-In libraria de componente cautati 'through-hole pad'. Veti gasi mai multe, gata definite, cu diverse marimi/forme ale pad-ului, respectiv diam. gaurii. Eu cu astea am defilat sau le modificam dupa nevoi. Traseul intre asemenea 'componente' il desenam pe layer-ul 'tNames' pt. a aparea  pe silkscreen. Intrucat am gasit folosite mult asemenea 'jumpere' prin aparate din anii '80-'90, mi-am creat si io in libraria Eagle, cu lungimi de 5 si 10 mm (distanta intre gaurile pad-urlor).
-Sint deja definite in biblioteca jump-ere din fire de diferite lungimi (5, 7, 10, 12, 20, 25, 30mm). Se gasesc in biblioteca Jumper, sublibraria J ->bridge.
-ce reprezinta culorile rosu si albastru pe care le face la cablaj?
-Roşu e traseul de top, albastru - traseul de bottom. Cînd dai autoroute (deşi ar trebui să fugi de opţiunea aia cît vezi cu ochii), selectează N/A la top.
-Am si eu o intrebare, please! Cum fac sa-mi apara in schema pinii de alimentare (VCC, GND) de la un CI (un CDB400, apr eample)?
-Edit-Invoke si selecteaza componenta.
-exista vre-o setare prin care se poat mari " insulele de Cu rotunde/gaurile unde vin montate piesele?
-Acelea sunt "Pad"-urile, si nu pot fi modificate decat prin editarea componentei in librarie, dar peste ele pot fi adaugate "Via" la care poti selecta ce forma doresti ( octogonal, rotund sau oval ), sau ce dimensiune doresti, putand ajusta diametrul gaurii cat si diametrul extern.
-Am observat ca peste unele pad-uri pot fi adaugate "Via" iar peste unele nu. M-am descurcat cumva
-Copiezi lbr-ul din zip peste cel original (eagle-x.y.z/lbr), din control panel dai clic dreapta pe Libraries -> Use all, apoi în schematic Library -> Update all. Are exact numele din datasheet: LTW-3030DZLxx.
-cum pot obtine o gaura pentru surub
-Pui un VIA normal şi-i măreşti dimensiunile la diametru şi la annular ring (Change Drill, Change Diameter).
-pt o sursa de alimentare diferentiala de +/- 15V si 5A (tensiune reglabila), "firele" din cablaj de ce dimensiune tre' sa fie? (latime, caci grosimea e cea de pe placa...
-cu 3mm latimea traseului de 35µm esti la limita celor 5A din secundar, iti recomand un traseu de minim 4mm cu un strat generos de fludor. Evita sa folosesti trasee lungi pentru partea de "putere". Pentru fire poti pune 1,5mm sectiune si nu o sa ai probleme.
-De unde setez grosimea traseelor? Se poate seta distanta minima dintre ele?
R:  setarea care se modifica e WIDTH (e in inchi)
-Exista "aranjeaza piesele a.i. routarea sa fie cat mai simpla"?
-Eu intotdeauna asez piesele manual si p-orma ii dau sa routeze.
- De unde setez dimensiunea boardului? Eu vad ca pot trage cu mouse-ul de patratul ala alb dar vreau sa-i scriu de la tastatura ce dimensiune sa aiba.
-cel mai bine folosesti functia GRID care se acceseaza de la VIEW, alegi ca DISPLAY sa fie ON si dai dimensiunile care le vrei
-Traseul pleaca de langa pin, iar cand dau switch to board legaturile electrice practic nu sunt efectuate. Ce gresesc?
-Cred că au folosit alt grid. Încearcă cu 0.01 inch, conectază pinii, apoi treci înapoi pe default.
-Stie cineva daca este vreo modalitate de a ii spune autorouter-ului din Eagle sa faca traseele mai groase. Ca stau 15 ani pana fac toate traseele klumea...De exemplu la o sursa de curent imi trebuie trasee de 1 mm minim ca am si rezistente mai mari si sunt alti curenti. El se incapataneaza si face cu 0.2 mm. Si apoi chin sa nu se suprapuna daca le fac de 1 mm si modificari, stergeri.
-Grupeaza conexiunile in Schematic (cind desenezi schema) in clase, veziin meniu Edit/Net classes... si cind trasezi conexiunea (Net) selectezi dindreapta sus clasa dorita.Succes!
-Bibliotecile Element14 sunt cu mii si mii de componente active. Totusi nu prezinta o consecventa in desen. Probabil sunt facute de studenti in stagiu.
-Dar stie cineva cum se foloseste "copy" in Eagle? :d Am facut un pcb si vreau sa mai am unul identic la 5mm distanta. Folosind "copy" imi copiaza doar cate un segment sau cate o componenta; io vreu sa-l iau pe tot si sa-l pun alaturi.
-Selectezi ce vrei cu unealta "Group", apoi apesi "Cut", click dreapta pe board, apoi "Paste".E cam ciudat asa-i, Cut de fapt e copy pentru grupuri.
-Cum sa inserez un text intr-o portiune placata (un poligon, de ex) a pcb-ului?
-Doua optiuni: prima importati o imagine cu ce va trebuie (textul facut ca un bmp) cu import-bmp.ulp, va jucati cu setarile acolo pina va iese cum vreti, atentie la alegerea sratului unde sa fie importata, sau daca folositi mai departe fisierele Gerber pentru produs placa modificati acolo cu o scula potrivita.
-Am nevoie de un tutorial in format electronic (preferabil pdf, nu video) in care sa se explice cum se realizeaza corect un layout. Adica ma intereseaza regulile care trebuie urmate si eventual, exemple.
-Scrie in Google: "pcb layout guidelines" si o sa gasesti PDF-uri pentru toate aplicatiile.
-Cred ca este bine sa stie toata lumea sa ne usuram munca:
In eagle ai facut cablajul.
1. Apesi pe DRC :
a.apesi pe CLEARANCE si pui si tu de ex 30 la toate,asta este izolatia dintre trasee,pad,etc si poligonul care ai sa-l faci
b.apesi pe restring si alegi dimensiunile de 20mil/90%/30 la primele trei ca sa-ti fie pad-urile mai mari un pic dar sa nu se atinga intre ele
2. Apesi pe POLYGON (o zona mica hasurata asa arata butonul) apoi te duci cu mouse-ul si incadrezi cablajul
3. Apesi pe butonul RECT este chiar langa POLYGON si te duci din nou si incadrezi montajul peste linia facuta de POLYGON
4.Acum te duci si dai o pagina inapoi(sageata aia de dat inapoi ,de sus de langa lupe)
5.RASTNES apesi si gata ( butonul asta este crucea aia verde cu bilute in capat)
-Sa presupunem ca incepti o schema in Eagle (la inceput aveti un grid default in inch sa zicem), puneti piesele din librarii pe foaia de lucru si dupa aia va trece un pitic prin cap sa modificati gridul la 1 mm sa zicem (ca da mai bine la ochi si va ajuta la asezat in pagina).... MARE GRESEALA! nu o sa mai puteti sa uniti piesele intre ele ( indiferent cu wire sau cu net)
Ce e de facut (in afara de trimis colegii pe Google) ?
Pai primul ajutor vine de pe pagina ofciala a programului si va citez mai jos pasajul legat de problema mea
-Prima data setezi gridul la 0.1 inch, dupa care tii CTRL apasat si iei piesa si o muti de 2 ori pe foaie si vine originea pe noul grid.
Si ca invatatura de mine (cel putin pentru mine) nu mai schimba gridul in mijlocul proiectului.
-Nu vă mai chinuiţi. Grid default, 0.05 inch.
-nu reusesc sa fac traseele de masa. Vreau sa am masa pe toata suprafata placii cu o distanta de 1mm intre celelalte trasee si paduri.
-Desenezi un poligon pe conturul placii si il denumesti GND.Distantele le stabilesti in DRC, Clearance si Distance.
-Am incercat si asa dar se pastreaza distanta si fata de masa pe care am desenat-o anterior.
-Asta se intimpla daca poligonul si GND nu au acelasi nume.Crede-ma ca functioneaza.
selectezi din bara din stanga butonul NAME si ii dai un nume la poligon ,apoi apesi iar pe NAME si dai acelasi nume la traseul de masa al tau
-Am reusit. Va multumesc.
-umplerea unui cablaj cu un desen de fond ( acel poligon ) care acopera o mare parte din placa si se poate seta ca sa devina circuitul de masa, astfel incat sa ramana cat mai putin cupru de corodat, poligonul imi iese si se separa de celelalte circuite insa nu reusesc sa il asociez cu circuitul de masa, dau click pe info si selectez net class ca fiind gnd asa cum se specifica in tutorial, ma asigur ca si circuitul de masa propriu zis este setat tot pe gnd si dau ratsnest, se umple placa insa fondul aparut se separa de toate circuitele, inclusiv de cel de masa, iata un circuit de test cat se poate de simplu spre a exemplifica ceea ce nu reusesc eu, sper sa gasiti greseala ( banuiesc ca eu gresesc undeva ) si astfel sa ma pot corecta
-Trebuie sa dai acelasi nume la poligon cu circuitul de masa.De exemplu GND trebuie sa se numeasca si circuitul de masa si poligonul. Circuitul de masa trebuie sa fie conectat la GND,acesta il alegi din librarie impreuna cu tensiunile de alimentare(supply)!
-nu reusesc sa fac astfel incat conductorul de pe cablaj notat cu X sa fie unit cu poligonul desenat pe cablaj. Intre ele apare o delimitare asa cum se vede si in poza. Prima data am tras traseul cu route dupa care unde am considerat am vrut sa le unesc cu poligon.
-Trebuie să redenumeşti poligonul cu comanda "Name", astfel încît să aibe acelaşi nume cu traseul cu care va fi comun.
- Am vazut in realitate la unele cablaje ca: in cazul in care 2 trasee s-ar intersecta, se foloseste o sarma pe deasupra cablajului (ca o piese normala doar ca e sarma obijnuita). Eagle stie de asa ceva? Are un buton "use si sarme pe deasupra"?
R: exista libraria JUMPER si ai mai multe modele, functie de lungimi, etc.
-Cum pot face strap in Eagle?
- tragi traseele pe top pentru strapuri.
-Cum pot face "legatura" intre 2 trasee sau 2 insule diferite practic un strap. In modul in care este realizata mai jos.
-Eu folosesc top layer. Dacă vrei să faci mai multe conexiuni peste un anumit traseu, foloseşti Route cu Ctrl+clic.
-Asa foloseam si eu top layer, o sa incerc si varianta Route cu Ctrl+clic.
-eu stiam ca un mil este a mia parte dintr-un inch adica 1 mil = 0.0254 mm dar poate gresesc.de ce nu lucrezi direct in mm? eagle permite acest lucru.4mm = 157mil deci 4000mil = 101 mm
-Un mil este a mia parte dintr-un inch si asta fara discutie! In zona anglo-saxona se mai numeste si "thou" (de la "thousand"). In acest sens, distanta dintre doi pini adiacenti ai unui integrat pe o capsula DIL (DIP) uzuala este de 100 mils (sau 2.54 mm). In Romania am mai auzit si denumirea 100 / 50 pitch (tot in sensul a 100 / 50 mils) sau chiar exprimarea "la un modul / la jumatate de modul" (echivalenta tot cu 100 mils / 50 mils).
-atunci cand comut pe BOARD.. la fel ramane... intepenit in stanga jos... si nu pot sa-l mut dea acolo....
-La layers este posibil să nu ai selectat origins si din această cauza nu poţi mută componentele. Ştiu pentru că m.am lovit si eu de chestia asta. Sper să ajute. Tot de acolo selectezi si ce informaţii să îţi apară pe placă . Ai pe toolbar din stânga o iconita din mai multe dreptunghiuri suprapuse
-selectarea layer-elor.
-Fara sa deschizi fereastra de print, apesi pe butonul display-show/hide layers,plasat sus in stanga, deasupra tuturor butoanelor din bara de butoane.Simbolizeaza cateva dreptunghiuri suprapuse divers colorate.
-Din fereastra aparuta,dai click in stanga fiecarui nume,care reprezinta un layer(strat).Mai exact ,click pe numarul din fata numelui.
-Cele albastre sunt active(vizibile),cele albe,nu.
Care si cum ..le vezi tu pana la urma ... trebuie sa le dichisesti....le iei pe rand oricum...vezi ce dispare..ce apare.
-In cazul in care vreau sa printez, selectez - stratul care ma interesează bottom, pads si dimension. Pentru a nu irosi foaia mai pot face cumva sa pot printa pe ea, spre ex daca circuitul ocupa doar partea de sus a foii?
-in situatia in care nu am inteles eu gresit ceea ce vrei sa zici atunci in momentul cand scoti fisierul pdf in eagle, selectezi alinierea desenului in foaie, de exemplu top center care va pune desenul in partea de sus in mijlocul foii, apoi poti selecta center, va pune desenul fix in jumatatea foii, apoi bottom center care evident pune dcesenul in partea de jos in mijloc, etc...
-la listare atentie la scale factor sa fie 1:1 !
-Adevarata problema este ca nu se pastreaza dimensiunea circuitului, si trebuie sa faci f. multe ajustari practice cu printare pt. stabilirea dimensiunilor.
- Salvand in format *.bmp apar 'difuzii' de culoare si nu este pastrata integritatea,mai ales salvand la rezolutie mica.
-Solutia cea mai convenabila este urmatoarea:
- trebuie sa ai instalat pe sistem 'FinePDFFactory'(printer virtual, realizeaza 'printarea' documentelor intr-un fisier format *.pdf)
- printezi circuitul intr-un fisier format *.pdf
- deschizi fishierul cu AdobePhotoShop, i-l importii la rezolutie de minim 300 px.!
- inserezi 1 Layer backround negru,apoi comanda Lyers-> arrange -> arrange down, pt. a-l pozitiona layerul in spatele layerului ce contine circuitul.
- pe Layer-ul ce contine circuitul aplici comanda 'Invert' (i-l transforma in negativ)
- eventual se aplica comada 'Merge Layers' pt. comasarea layerelor intr-un singur layer.
- dai printare  asta-i tot.
-Imi poate spune si mie cineva cum pot imprima doar cablajul, nu si componentele?
-view / display/hide layers iar de acolo deselectezi 21 si 22 ,cam asta ar fii
-Dar negativul unui cablaj cum il pot printa direct din Eagle ?
-Cu un Pdf Factory.Instalezi programul asta te duci la "Print" in Eagle si se deschide programul mai sus amintit
-O solutie pentru imprimarea negativului: se foloseste procesorul CAM cu "Inverted_PS" selectat la Device, rezulta un fisier postscript .ps care poate fi deschis/tiparit cu ghostscript/gsview sau asemenea.
-cum fac export din eagle doar la partea botom care contine doar traseele? Deci ma intereseaza partea care o printez pentru a realiza un cablaj prin metoda (printare pe hattie foto).
- înainte să printezi selectezi:- stratul care te interesează (top sau bottom);- pads;- dimension.
-Tot incerc de cateva ore sa export un pdf din Eagle
-din Eagle dai Print si selectezi convertorul ca imprimanta.
-Daca te referi la cablaj care tre sa iasa 1:1, din cam processor poti lista postscript care se poate dupa aia converti in pdf
-Treaba e super simpla
-Selectezi layerele care te intereseaza...apoi dai print...si ai jos buton "pdf"...dai nume.. locatie... si gata
Daca incalc regulile forumului cu aceste sinteze,rog sa fie sterse.
Printarea cablajului meu are ceva deficiente.
Latimea traseelor prea mica,cercurile de cupru (pad-uri?) prea mici si felul "pixelat"in care arata traseele.
Pozitiv ar fi ca am gasit posibila rezolvare pt marire pad-uri
How to increase pad size in eagle
https://www.youtube.com/watch?v=T3qcVwHIw5w&t=38s
Latimea traseelor o pot rezolva ,am descoperit si butoanele
"VIA si HOLE",mai ramane sa sper ca densitatea obtinuta pe imprimanta va fi cea buna.
Cu stima Costa
Buna ziua
Daca tot am deschis acest subiect am sa continui pt alti incepatori .
Am reusit sa finalizez proiectarea cablajului si cand credeam ca am muncit fara folos am gasit pt listare in format pdf :
How to export from Eagle to pdf.
https://www.youtube.com/watch?v=UMDO0Ptbn38
La mine a functionat.
Din Eagle-File-Open-Board-deschidem circuitul realizat.
Intai trebuie selectat tabelul cu  layerele active cu butonul din  stanga sus langa Grid.
Eu mi-am notat ce layere erau bifate ca masura de precautie .
Apoi urmarind ce schimbari apar pe circuitul proiectat  prin incercari am pastrat bifate doar layerele necesare apoi OK.
In principal eu am fost interesat sa obtin separat intai traseele plus pad-urile si separat desenul cu piesele .
In caz de greseala cu butonul "Undo" se poate revenii in pasi repetati la situatia anterioara dorita.
Urmeaza salvare in format  pdf cu metoda File,Print ( la printer am ales"Microsoft Print to PDF",la options doar "black" si  la scale factor=1.15 apoi OK ,in fereastra urmatoare denumire fisier Save si gata.
Cu fierul de calcat am cam supraincalzit cablajul...data viitoare ...
Am facut cateva corectii cu markerul si apoi corodarea.
Nu a iesit de nota 10 dar fiind prima incercare sunt multumit ca am dus la capat primul meu proiect cu Eagle.
Avand PDF-urile si dimensiunile cablajului se poate apela la un profesionist pt executie cablaj.
Proiectul nr.2-un mic cablaj pt o sursa de alimentare de 5v a mers muult mai usor.
Multumesc
Cu stima Costa
PS Am sa-i rog pe cei cu experienta care nu au uitat cum a fost ca incepator sa corecteze,completeze...si nu dati cu pietre eu in continuare sunt doar un amator.
Printarea trebuie făcută direct din Eagle pt ca păstrează corect dimensiunile. Pt realizare industriala se generează gerberele care sint universale ca forma (nu depind de programul în care s-a făcut layout-ul) și se trimit la fabrica.
Crearea de fișiere intermediare pdf nu înseamnă decit sa te scarpini în urechea stingă cu mina drepta, și să-ți creiezi potențiale probleme.
Modului de printare din Eagle îți permite să printezi și la scala și în oglinda și cam tot ce ai avea nevoie.
Editat de sesebe
Amplificatorul pt care am experimentat proiectarea cu Eagle este cel calculat de d-l Marian in subiectul "Teorie si generalitati in audio".
Am finalizat primul modul si a pornit din prima incercare (cu ceva ezitari de incepator)
Multumiri pe aceasta cale autorului pt munca impresionanata depusa mai ales in folosul incepatorilor si nu numai.
Sunt bucuros ca am reusit ceea ce mi-am propus.
Cu tot respectul as vrea sa-i rog pe colegii care cu timpul sau plictisit ori au uitat cum este sa ajuti sa se mai gandeasca.
Pana la proba contrarie fiecare merita o sansa si uneori prima impresie poate sa fie gresita.
Cu stima Costa
  • 2 luni mai târziu...
Dupa ceva timp am capatat un pic de experienta in Eagle suficienta pt micile mele proiecte casnice.
Una dintre probleme :-care e latimea minima pt un traseu.
Am citit printre altele si acest subiect
densitati de curent PCB - Sectiunea incepatorilor - ELFORUM - Forumul electronistilor
Utilizand calc online am pus pt mine in tabelul de mai jos corelatia dintre latime trasee Eagle(mil=0.001inch=0.0254mm)-latimea in mm-curentul suportat pt dif de temp de 1grC pt cablaj de 0.035mm ,observatiile,corectiile voastre?
Cred ca o crestere a temperaturii de 5-10 grade este acceptabila, oricum pe un pcb doar cateva trasee sunt de curent mai mare, majoritatea sunt de curent mic. Traseul minim il scazi la 0.15mm numai daca e absolut necesar si il faci la fabrica, altfel foloseste minim 0.2-0.25mm
Nu cunosc normative dar posibil sa fie prea mult o crestere de 10 grade.
Cu un soft de simulare pot aproxima curentii  apoi cu datele prezentate pot alege latimea traseelor.
Eu n-am sa aleg niciodata ceva sub 1mm -ochelarist,dificultate de realizare cablaj.
Pt 2,3 cablaje prefer sa-mi fac singur toata treaba mai ales ca pretentiile sunt f mici.
