nexus Postat Iulie 15, 2023 Autor Partajează Postat Iulie 15, 2023 Up! Valabile. Link spre comentariu
nexus Postat Iulie 18, 2023 Autor Partajează Postat Iulie 18, 2023 Up! Ultima lista valabila. Link spre comentariu
nexus Postat Iulie 24, 2023 Autor Partajează Postat Iulie 24, 2023 Valabile reperele din lista de mai jos: 1. DVD-RW LG 4167RBB 16x/8x/48x/24x/16x, negru, bulk, IDE - pret: 4lei. https://postimg.cc/nXKLDscy 3. LCD panel laptop, Samsung, LTN154X3-L01, 15.4", 1280x800, wxga, LVDS (1 ch, 6-bit) , 30 pins; pret: 18lei. https://postimg.cc/bDrYW3HP 4. Diverse motorase; pret: 9lei toate https://postimg.cc/68bTz2Xr 6. Lot placi pentru recuperare componente; pret: 14lei. https://postimg.cc/f3T0SMPH 7. Display TFT recuperat dintr-o imprimanta, TD024THEB5, 2.4", 480×240; pret: 4lei. detalii aici: http://www.gotolcd.com/panel/201401/TD024THEB5_14219.html https://postimg.cc/sQbz8ygP 9. Afisaje led, Kingbright Electronic, SC23-11SRWA, 1 digit, 56.9mm(2.3"), rosu, 88-190mcd, catod comun, disponibile 4buc.; pret: 4lei/buc. https://postimg.cc/PC1cK7ty https://postimg.cc/4mDq6GTn 13. Cooler laptop Cooler-Master NotePal X2, negru, pentru laptopuri cu dimensiuni de pana la 15.4 inch; controlul vitezei nu mai merge; functioneaza doar pe turatie maxima; pret: 5lei. https://postimg.cc/zLL5FK1D https://postimg.cc/9DgC91KN https://postimg.cc/gx2Gr1SZ 16. Memorie RAM, 2GB, Kingmax KLCE88F-B8KU5, DDR2, PC2-667 - pret: 9lei Memorie RAM, 1GB, Kingmax KLCD48F-B8MO5, DDR2, PC2-667 - pret: 4lei https://postimg.cc/3yGt3SS6 19. HDD, 160GB, Maxtor, DiamondMax 17, 3.5", model: 6G160P0, ATA / 133, 7200 RPM - pret: 9lei detalii: https://www.hdsentinel.com/storageinfo_results.php?model=Maxtor+6G160P0&capacity=over+128+GB&connection=IDE&lang=en https://postimg.cc/9RKgdD84 https://postimg.cc/4HcLBXqW https://postimg.cc/0MbHKYfR https://postimg.cc/t1RcpQng https://postimg.cc/xks4dxL3 20. HDD, 160GB, Western Digital, Caviar Blue, 3.5", model: WD16 00AAJS-00M0A, SATA-II 3.0Gb/s, 7200 RPM - pret: 14lei detalii: https://www.hdsentinel.com/storageinfo_details.php?lang=en&model=WDC WD1600AAJS https://postimg.cc/kRy8nZbn https://postimg.cc/pyM6LFF7 https://postimg.cc/G9PS8mPp 22. Procesor AMD Athlon(tm) 64 X2 Dual Core Processor 5000+, 2.6GHz, AM2 - pret: 19lei Se vinde impreuna cu stock cooler si back-plate. detalii: https://www.cpubenchmark.net/cpu.php?cpu=AMD+Athlon+64+X2+Dual+Core+5000%2B&id=83 https://postimg.cc/RNNKrP0z https://postimg.cc/N5STQ1y2 https://postimg.cc/bGjttp9z https://postimg.cc/75zzhf7s https://postimg.cc/7bPS9P8h https://postimg.cc/hhCT5Fcr 23. LCD panel laptop, Samsung, LTN150XB-L01, 15.0", RGB 1024x768, xga, LVDS (1 ch, 6-bit) , 30 pins; pret: 19lei. Panelul se vinde fara cablul LVDS. https://postimg.cc/rDCqgjV5 https://postimg.cc/QK9XbrCM https://postimg.cc/K4wcY4p3 https://postimg.cc/c6r4ZfhN 24. doua difuzoare 8ohm/1W + grilele si ramele aferente - 4lei si un difuzor 8ohm/5W - 2lei https://postimg.cc/xX1cKGWj 25. set de 3 perii de dimensiuni diferite, pentru curatare cablaje, componente, ESD - 12lei No.7#: 11.5cm x 2.5cm x 3.1cm No.8#: 11.5cm x 2.5cm x 4.5cm No.9#: 14.5cm x 2.5cm x 5.5cm https://postimg.cc/R6pgj3W7 26. 4 cabluri de silicon de test cu conector banana standard 4mm, conectabile in stiva(stackable), 1m, 20A, pentru multimetru, sursa - 8lei/buc. https://postimg.cc/SJMgvxk9 28. Mufa alimentare PC mama - 2buc. pret: 1.5lei/buc https://postimg.cc/949pr0yy https://postimg.cc/tswkqWnX 29. Buton PBS-11, 1A/250V~, cu revenire, diam. prindere 12mm, diam. rama 18mm, lungime 33.75mm - 2buc. pret: 1.5lei/buc https://postimg.cc/fJkYVkNk 30. Buton push, SPST(NO), montare panou(Ø7mm), metal, rosu, 1A/250V~, 20mΩ - 3buc. - pret: 1.5lei/buc https://postimg.cc/Cd5RNt6Q 31. Spliter RJ45, 8P8C mama - 2x8P8C mama(2 x porturi RJ45) - pret: 2lei https://postimg.cc/qtrL60wY 32. Conector mama GX16-5(Aviation plug) pentru letcon, 5 pini, pentru cablu, Ø16mm, 5pini - pret: 2lei https://postimg.cc/7fdDkt9b 33. Comutator basculant; KNX-2; Poz: 2; DPDT; ON-ON; 3A/250VAC, 20mΩ, orif. prindere Ø6mm, inaltime maneta 11mm, corp metalic cu dim. 12.5x11.5x9.5mm, nr. actionari 20000 cicluri - 5buc., pret: 2.5lei/buc. https://postimg.cc/tnsfvyLk 34. Comutator culisant, dublu pol, 3 poz.., 2A/250VAC, L x l x h: 28x13x15(maneta 5mm), pin pitch = 6mm - 2 buc. - 1leu/buc. https://postimg.cc/mcx9v3hC 35. Comutatoare din uscatoare de par, 3pini x 3pozitii, unul fara retinere(NO) si celalalt OFF-(one)ON-(both)ON, 10A/250VAC - 2buc; pret: 1.5lei/buc. https://postimg.cc/LJ7d25Mz 36. Mufa alimentare mama(jack), cu montare pe fir, 2.1x5.5mm, DC - 8buc.; pret: 0.5lei/buc. https://postimg.cc/fJT1dmzc 37. Mufa alimentare tata, DC, 2.1x5.5mm, cu montare pe panou (Ø12.8mm) - 8buc.; pret: 0.5lei/buc https://postimg.cc/zbQHknmy 38. Mufa alimentare tata, DC, 2.1x5.5mm, cu montare pe PCB, THT, 3A, 12VDC - 8buc.; pret: 0.5lei/buc https://postimg.cc/xqkz1FHM Comanda minima este 30lei + transport cu Posta Romana. Link spre comentariu
nexus Postat Iulie 28, 2023 Autor Partajează Postat Iulie 28, 2023 Up! Valabile! Link spre comentariu
nexus Postat August 10, 2023 Autor Partajează Postat August 10, 2023 Punctele 25. si 26. s-au dat. Celelalte puncte in continuare valabile. Link spre comentariu
nexus Postat August 17, 2023 Autor Partajează Postat August 17, 2023 Ultima lista actualizata: 1. DVD-RW LG 4167RBB 16x/8x/48x/24x/16x, negru, bulk, IDE - pret: 4lei. https://postimg.cc/nXKLDscy 3. LCD panel laptop, Samsung, LTN154X3-L01, 15.4", 1280x800, wxga, LVDS (1 ch, 6-bit) , 30 pins; pret: 18lei. https://postimg.cc/bDrYW3HP 4. Diverse motorase; pret: 9lei toate https://postimg.cc/68bTz2Xr 6. Lot placi pentru recuperare componente; pret: 14lei. https://postimg.cc/f3T0SMPH 7. Display TFT recuperat dintr-o imprimanta, TD024THEB5, 2.4", 480×240; pret: 4lei. detalii aici: http://www.gotolcd.com/panel/201401/TD024THEB5_14219.html https://postimg.cc/sQbz8ygP 9. Afisaje led, Kingbright Electronic, SC23-11SRWA, 1 digit, 56.9mm(2.3"), rosu, 88-190mcd, catod comun, disponibile 4buc.; pret: 4lei/buc. https://postimg.cc/PC1cK7ty https://postimg.cc/4mDq6GTn 13. Cooler laptop Cooler-Master NotePal X2, negru, pentru laptopuri cu dimensiuni de pana la 15.4 inch; controlul vitezei nu mai merge; functioneaza doar pe turatie maxima; pret: 5lei. https://postimg.cc/zLL5FK1D https://postimg.cc/9DgC91KN https://postimg.cc/gx2Gr1SZ 16. Memorie RAM, 2GB, Kingmax KLCE88F-B8KU5, DDR2, PC2-667 - pret: 9lei Memorie RAM, 1GB, Kingmax KLCD48F-B8MO5, DDR2, PC2-667 - pret: 4lei https://postimg.cc/3yGt3SS6 19. HDD, 160GB, Maxtor, DiamondMax 17, 3.5", model: 6G160P0, ATA / 133, 7200 RPM - pret: 9lei detalii: https://www.hdsentinel.com/storageinfo_results.php?model=Maxtor+6G160P0&capacity=over+128+GB&connection=IDE&lang=en https://postimg.cc/9RKgdD84 https://postimg.cc/4HcLBXqW https://postimg.cc/0MbHKYfR https://postimg.cc/t1RcpQng https://postimg.cc/xks4dxL3 20. HDD, 160GB, Western Digital, Caviar Blue, 3.5", model: WD16 00AAJS-00M0A, SATA-II 3.0Gb/s, 7200 RPM - pret: 14lei detalii: https://www.hdsentinel.com/storageinfo_details.php?lang=en&model=WDC WD1600AAJS https://postimg.cc/kRy8nZbn https://postimg.cc/pyM6LFF7 https://postimg.cc/G9PS8mPp 22. Procesor AMD Athlon(tm) 64 X2 Dual Core Processor 5000+, 2.6GHz, AM2 - pret: 19lei Se vinde impreuna cu stock cooler si back-plate. detalii: https://www.cpubenchmark.net/cpu.php?cpu=AMD+Athlon+64+X2+Dual+Core+5000%2B&id=83 https://postimg.cc/RNNKrP0z https://postimg.cc/N5STQ1y2 https://postimg.cc/bGjttp9z https://postimg.cc/75zzhf7s https://postimg.cc/7bPS9P8h https://postimg.cc/hhCT5Fcr 23. LCD panel laptop, Samsung, LTN150XB-L01, 15.0", RGB 1024x768, xga, LVDS (1 ch, 6-bit) , 30 pins; pret: 19lei. Panelul se vinde fara cablul LVDS. https://postimg.cc/rDCqgjV5 https://postimg.cc/QK9XbrCM https://postimg.cc/K4wcY4p3 https://postimg.cc/c6r4ZfhN 24. doua difuzoare 8ohm/1W + grilele si ramele aferente - 4lei si un difuzor 8ohm/5W - 2lei https://postimg.cc/xX1cKGWj 28. Mufa alimentare PC mama - 2buc. pret: 1.5lei/buc https://postimg.cc/949pr0yy https://postimg.cc/tswkqWnX 29. Buton PBS-11, 1A/250V~, cu revenire, diam. prindere 12mm, diam. rama 18mm, lungime 33.75mm - 2buc. pret: 1.5lei/buc https://postimg.cc/fJkYVkNk 30. Buton push, SPST(NO), montare panou(Ø7mm), metal, rosu, 1A/250V~, 20mΩ - 3buc. - pret: 1.5lei/buc https://postimg.cc/Cd5RNt6Q 31. Spliter RJ45, 8P8C mama - 2x8P8C mama(2 x porturi RJ45) - pret: 2lei https://postimg.cc/qtrL60wY 32. Conector mama GX16-5(Aviation plug) pentru letcon, 5 pini, pentru cablu, Ø16mm, 5pini - pret: 2lei https://postimg.cc/7fdDkt9b 33. Comutator basculant; KNX-2; Poz: 2; DPDT; ON-ON; 3A/250VAC, 20mΩ, orif. prindere Ø6mm, inaltime maneta 11mm, corp metalic cu dim. 12.5x11.5x9.5mm, nr. actionari 20000 cicluri - 5buc., pret: 2.5lei/buc. https://postimg.cc/tnsfvyLk 34. Comutator culisant, dublu pol, 3 poz.., 2A/250VAC, L x l x h: 28x13x15(maneta 5mm), pin pitch = 6mm - 2 buc. - 1leu/buc. https://postimg.cc/mcx9v3hC 35. Comutatoare din uscatoare de par, 3pini x 3pozitii, unul fara retinere(NO) si celalalt OFF-(one)ON-(both)ON, 10A/250VAC - 2buc; pret: 1.5lei/buc. https://postimg.cc/LJ7d25Mz 36. Mufa alimentare mama(jack), cu montare pe fir, 2.1x5.5mm, DC - 8buc.; pret: 0.5lei/buc. https://postimg.cc/fJT1dmzc 37. Mufa alimentare tata, DC, 2.1x5.5mm, cu montare pe panou (Ø12.8mm) - 8buc.; pret: 0.5lei/buc https://postimg.cc/zbQHknmy 38. Mufa alimentare tata, DC, 2.1x5.5mm, cu montare pe PCB, THT, 3A, 12VDC - 8buc.; pret: 0.5lei/buc https://postimg.cc/xqkz1FHM Link spre comentariu
BRANCA Postat August 21, 2023 Partajează Postat August 21, 2023 nexus.Succes la vânzări,da' vezi că poz 36-38 le-ai botezat.Ce e "mama" e "tata" şi invers...Totdeauna ce intră e tată,iar în ce intră e mamă. Link spre comentariu
nexus Postat August 22, 2023 Autor Partajează Postat August 22, 2023 Da, Branca ai dreptate le-am încurcat; voi corecta la o postare viitoare. Oricum se vedeau în poze. Mersi Link spre comentariu
