Vand diverse electronice
nexus
  • Răspunsuri 95
  • nexus
    83
  • BRANCA
  • nostromo
  • rosmarin
Lista actualizata:
1. DVD-RW LG 4167RBB 16x/8x/48x/24x/16x, negru, bulk, IDE - pret: 5lei.
    https://postimg.cc/nXKLDscy
3. LCD panel laptop, Samsung, LTN154X3-L01, 15.4", 1280x800, wxga, LVDS (1 ch, 6-bit) , 30 pins; pret: 20lei.
    https://postimg.cc/bDrYW3HP
4. Diverse motorase; pret: 10lei toate
    https://postimg.cc/68bTz2Xr
5.   Variator dintr-un aspirator Philips, cu HT46C47 si BTB12-600BW, conductori silicon; pret: 5lei.
      https://postimg.cc/N5qYkgVB
6.   Lot placi pentru recuperare componente; pret: 15lei.
      https://postimg.cc/w7V1y44b
7.   Display TFT recuperat dintr-o imprimanta, TD024THEB5, 2.4", 480×240; pret: 5lei.
      detalii aici: http://www.gotolcd.com/panel/201401/TD024THEB5_14219.html
      https://postimg.cc/sQbz8ygP
9.   Afisaje led, Kingbright Electronic, SC23-11SRWA,  1 digit, 56.9mm(2.3"), rosu, 88-190mcd,
      catod comun, disponibile 4buc.; pret: 5lei/buc.
      https://postimg.cc/PC1cK7ty
      https://postimg.cc/4mDq6GTn
13. Cooler laptop Cooler-Master NotePal X2, negru, pentru laptopuri cu dimensiuni de pana la 15.4 inch;
      controlul vitezei nu mai merge; functioneaza doar pe turatie maxima; pret: 8lei.
      https://postimg.cc/zLL5FK1D
      https://postimg.cc/9DgC91KN
      https://postimg.cc/gx2Gr1SZ
14. Circuite integrate, microcontrolere si regulatoare diverse, noi si recuperate:
Name                    Q'ty    Package    State              Description        lei/buc.
HCF4050               2       SO-16         nou               HEX BUFFER/CONVERTER (NON INVERTING)                1
LM311P                  2       DIP8            nou               Single, Strobed Differential Comparator with Open
        Collector and Emitter Outputs                                          1
74HC04D               2       SO-14          nou              Hex inverter        1
HCF4069U             1       SO-14          nou              HEX INVERTER        1
CD4011BE              3       DIP14           nou             CMOS Quad 2-Input NAND Gate                                      1
CD4001BE             2       DIP14            nou             CMOS Quad 2-Input NOR Gate                                         1
TP8452AP             1       DIP14            recuperat   PS/2 2D 3key mouse controller.                                         1
CD4052BE             5      DIP16            nou             High Speed CMOS Differential 4-Channel Analog        Multiplexer/Demultiplexer                                                   1
LM358                   7       DIP8             nou              Dual General-Purpose Operational Amplifier                     1
LM833N                3       DIP-8           nou               Dual Audio Operational Amplifier                                       3
LA6515                  1       SIP10           recuperat     0.5A Power Operational Amplifier                                      1
MC33171               5       SO-8            nou               Low Power, Single Supply Operational Amplifiers             2
MOC3041              2       DIP6             nou               6-Pin DIP 400V Zero Crossing Triac Driver Output
        Optocoupler        2
MCP41100-I/SN    1       SO-8            montat          Single/Dual Digital Potentiometer with SPI™ Interface      6
                                                            pe
                                                            adaptor
                                                            DIP8
LD1117AV3.3         30    SOT-223       nou               3.3V, 800mA LOW DROPOUT VOLTAGE REGULATOR       0.5
FSDH321               4       DIP8            nou               Green Mode Fairchild Power Switch (FPSTM)                     1.5
78L05A                 3       SO-8            nou               3-Terminal 0.1A Positive Voltage Regulator                         1
MAX1674               1       uMAX8         nou               High-Efficiency, Low-Supply-Current, Compact,
        Step-Up DC-DC Converters"                                               3
TL431C                 40    TO-92           nou               Adjustable precision shunt regulators                                  0.5
34063AP1             10    DIP8             nou                DC-TO-DC CONVERTER CONTROL CIRCUITS                   1
MC34063A            5     SO-8             nou               1.5 A, Step-Up/Down/Inverting Switching Regulators         1
STR-F6654            1     TO-3P           recuperat     OFF-LINE QUASI-RESONANT FLYBACK SWITCHING
        REGULATORS        2
LM317T                  10    TO-220        nou                1.2V TO 37V VOLTAGE REGULATOR                                    1
TEA5767                 1      LQFP40       nou -              single-chip FM stereo radio                                                 5
                                                            montat
                                                            pe
                                                           adaptor
                                                           DIP10
KA22471                  1     DIP16          recuperat        FM IF/AF TUNER SYSTEM                                                     1
TDA7000                 1     DIP18          recuperat        FM radio circuit        1
TBA120U(A223D)    1     DIP14          recuperat        FM IF amplifier        1
K174YP1(TBA120U) 1     DIP14          recuperat        FM IF amplifier        1
DS3231SN               1     SO-16W      nou                  Extremely Accurate I2C-Integrated RTC/TXO/Crystal         5
TEA2025B                5    DIP16          nou                  audio amp        2
K174YH7                   1    DIP12          recuperat        audio amp        1
(TBA810/A210)
HCF4541BE              1     DIP14         recuperat       PROGRAMMABLE TIMER                                                          2
PIC18F452 - I/P        1    DIP40         nou                 High-Performance, Enhanced Flash Microcontrollers
        with 10-Bit A/D        14
PIC16F84-04/P        1     DIP16         nou                 18-pin Flash/EEPROM 8-Bit Microcontrollers                          9
PIC12F629-I/SN       4    SO-8           nou                 8-Pin, Flash-Based 8-Bit CMOS Microcontrollers                   4
PIC12F675-I/P          2    DIP8            nou                8-Pin, Flash-Based 8-Bit CMOS Microcontrollers                    4
PIC16F628-20/P       1    DIP18          nou                Flash-Based, 8-Bit CMOS
        Microcontrollers with nanoWatt Technology                           11
PIC16F648A-I/P        1    DIP18          nou                Flash-Based, 8-Bit CMOS
        Microcontrollers with nanoWatt Technology                            9
PIC16F628-04/SO    1    SO-18         recuperat       Flash-Based, 8-Bit CMOS
        Microcontrollers with nanoWatt Technology                            8
TDA6108JF               2    DBS9MPF    recuperat      Triple video output amplifier                                                     1
STV9556                   1  11 PIN-          recuperat      12 ns TRIPLE-CHANNEL HIGH VOLTAGE VIDEO AMPLIFIER    1
                                       CLIPWATT
TDA8358J                 1    DBS13P       recuperat       Full bridge vertical deflection output circuit in LVDMOS
        with east-west amplifier                                                            1
A241D                        1    DIP16           recuperat       IF-amplifier circuit        1
K224YP3                   2    SIL9              recuperat       Video frequency amp.                                                              1
15. Placa video ATI Radeon HD4550, 512MB, 64-Bit, DDR3, PCIe x16, DVI, Display Port - rezervat
      https://postimg.cc/564qDkqp
      https://postimg.cc/Hj49ZC5V
      https://postimg.cc/vDdvtm4J
16. Memorie RAM, 2GB, Kingmax KLCE88F-B8KU5, DDR2, PC2-667 - pret: 10lei
       Memorie RAM, 1GB, Kingmax KLCD48F-B8MO5, DDR2, PC2-667 - pret: 5lei
      https://postimg.cc/3yGt3SS6
17. Placa retea pentru laptop Wifi BCM943228HMB, 2.4G/5G Dual Band, 802.11a/b/g/n, Bluetooth 4.0, Mini PCI-E - rezervat
       Adaptorul de la mini PCI-E la PCI-E 1X permite folosirea placii pe orice PC si este inclus in pret.
      https://postimg.cc/nsQnpxtJ
      https://postimg.cc/cvzdpH2h
      https://postimg.cc/XGS4vPVy
19. HDD, 160GB, Maxtor, DiamondMax 17, 3.5", model: 6G160P0, ATA / 133, 7200 RPM - pret: 10lei
       detalii: https://www.hdsentinel.com/storageinfo_results.php?model=Maxtor+6G160P0&capacity=over+128+GB&connection=IDE&lang=en
      https://postimg.cc/9RKgdD84
      https://postimg.cc/4HcLBXqW
      https://postimg.cc/0MbHKYfR
      https://postimg.cc/t1RcpQng
      https://postimg.cc/xks4dxL3
20. HDD, 160GB, Western Digital, Caviar Blue, 3.5", model: WD16 00AAJS-00M0A,
      SATA-II 3.0Gb/s, 7200 RPM  - pret: 15lei
      detalii: https://www.hdsentinel.com/storageinfo_details.php?lang=en&model=WDC WD1600AAJS
      https://postimg.cc/kRy8nZbn
      https://postimg.cc/pyM6LFF7
      https://postimg.cc/G9PS8mPp
21. Card reader Apacer AE161, intern, 3.5", Hi-Speed USB - rezervat
      https://postimg.cc/7fW1bFR6
      https://postimg.cc/G4TFDM0j
22. Procesor AMD Athlon(tm) 64 X2 Dual Core Processor 5000+, 2.6GHz, AM2 - pret: 25lei
       Se vinde impreuna cu stock cooler si back-plate.
      detalii: https://www.cpubenchmark.net/cpu.php?cpu=AMD+Athlon+64+X2+Dual+Core+5000%2B&id=83
      https://postimg.cc/RNNKrP0z
      https://postimg.cc/N5STQ1y2
      https://postimg.cc/bGjttp9z
      https://postimg.cc/75zzhf7s
      https://postimg.cc/7bPS9P8h
      https://postimg.cc/hhCT5Fcr
23. LCD panel laptop, Samsung, LTN150XB-L01, 15.0", RGB 1024x768, xga, LVDS (1 ch, 6-bit) , 30 pins; pret: 20lei.
      https://postimg.cc/rDCqgjV5
      https://postimg.cc/QK9XbrCM
      https://postimg.cc/K4wcY4p3
      https://postimg.cc/c6r4ZfhN
Editat de nexus
Adaugati la mine daca e perfect functionala si se da exact ce este in poza , am nevoie la un PC , ca PCI-E 1x :
17. Placa retea pentru laptop Wifi BCM943228HMB, 2.4G/5G Dual Band, 802.11a/b/g/n, Bluetooth 4.0, Mini PCI-E - pret: 18lei
Editat de nostromo
Acum 19 ore, rosmarin a spus:
Primit coletul ! Totul in regula. Va multumesc frumos !
Cu mare placere! Sa le folositi sanatos.
Valabile componentele din lista de mai jos:
      detalii aici:
        Optocoupler        2
MCP41100-I/SN    1       SO-8            montat          Single/Dual Digital Potentiometer with SPI™ Interface      5
                                                            pe
                                                            adaptor
                                                            DIP8
        REGULATORS        2
                                                            montat
                                                            pe
                                                           adaptor
                                                           DIP10
(TBA810/A210)
        with 10-Bit A/D        13
PIC16F84-04/P        1     DIP16         nou                 18-pin Flash/EEPROM 8-Bit Microcontrollers                          8
        Microcontrollers with nanoWatt Technology                           10
        Microcontrollers with nanoWatt Technology                            7
                                       CLIPWATT
       detalii:
      detalii:
22. Procesor AMD Athlon(tm) 64 X2 Dual Core Processor 5000+, 2.6GHz, AM2 - pret: 20lei
      detalii:
Se adauga la vanzare:
24. doua difuzoare 8ohm/1W + grilele si ramele aferente - 5lei si un difuzor 8ohm/5W - 3lei
https://postimg.cc/xX1cKGWj
25. set de 3 perii de dimensiuni diferite, pentru curatare cablaje, componente, ESD -  15lei
      No.7#: 11.5cm x 2.5cm x 3.1cm
      No.8#: 11.5cm x 2.5cm x 4.5cm
      No.9#: 14.5cm x 2.5cm x 5.5cm
https://postimg.cc/R6pgj3W7
26. 4 cabluri de silicon de test cu conector banana standard 4mm, conectabile in stiva(stackable), 1m,
       20A, pentru multimetru, sursa - 10lei/buc.
https://postimg.cc/SJMgvxk9
27. placa de baza Gigabyte, AM2, defecta; se vinde pentru piese: 10lei
https://postimg.cc/bdKTkfkw
