Vand diverse electronice
nexus
1. DVD-RW LG functional, IDE, usa cand se deschide, cand nu; pret: 10lei.
    https://postimg.cc/nXKLDscy
2. HD WD, 80GB, IDE, functional, cred ca are windows 7 instalat, nu mai stiu; pret: 10lei.
    https://postimg.cc/McWpbWnv
3. LCD panel laptop, Samsung, LTN154X3-L01, 15.4", 1280x800, wxga, LVDS (1 ch, 6-bit) , 30 pins; pret: 30lei.
    https://postimg.cc/bDrYW3HP
4. Motor SANKO, M9J90U16-M, 9Vcc; pret: 10lei.
    https://postimg.cc/HJBs6fM3
5. Motor HC385XLG, ax de 2mm, dimensiuni in poza; pret: 10lei.
    https://postimg.cc/vx6YHTNS
6. Motoare DC imprimanta, 9Vcc, ax de 2mm, dimensiuni in poza, 4buc; pret: 5lei/buc.
    https://postimg.cc/tZcRjW2x
    https://postimg.cc/9DHM0PVP
    https://postimg.cc/5jZ9K5Hc
    https://postimg.cc/qzyJPtnN
7. Motorase dintr-o unitate optica; pret: 5lei.
      https://postimg.cc/hX0SGH2g
      https://postimg.cc/HrKN0pLH
8.   Motor pas cu pas, Mitsumi M35SP-9T, 24Vcc, 400mA; pret: 15lei.
      https://postimg.cc/yDK1sVXv
9.   Variator dintr-un aspirator Philips, cu HT46C47 si BTB12-600BW, conductori silicon; pret: 15lei.
      https://postimg.cc/N5qYkgVB
10. Lot placi pentru recuperare componente; pret: 20lei.
      https://postimg.cc/n98qFPTv
      https://postimg.cc/rRSxKNY7
      https://postimg.cc/YGL1wHNr
11.  Display TFT recuperat dintr-o imprimanta, TD024THEB5, 2.4", 480×240; pret: 10lei.
      https://postimg.cc/sQbz8ygP
       Mai multe detalii aici: http://www.gotolcd.com/panel/201401/TD024THEB5_14219.html
12. Telecomanda LG, model AKB732955, si adaptor wireless; pret: 15lei.
      https://postimg.cc/5jFbzHss
13. Ceas cu PIC16F84; este un proiect mai vechi care a ramas fara carcasa, dar functional.
       Afisajele sunt SC23-11SRWA, digit de 56mm, cu catod comun, montate pe barete de pini
      si pot fi reutilizate; pret: 40lei.
      https://postimg.cc/wy8q7VzX
      https://postimg.cc/f30WzPGW
      https://postimg.cc/8JR1W6kq
      https://postimg.cc/WdybPVff
14. Aparat foto Canon PowerShot A550, 7.1Mpx, si card de 1Gb; pret: 40lei.
      https://postimg.cc/06Xy0Kwj
      https://postimg.cc/9RvXv31j
      https://postimg.cc/kVg5SvDL
      https://postimg.cc/0M62W5Yf
15. Placa electronica din centrala termica Vaillant Turbo Tec Plus VUW RO 242/3-5
      Da eroarea F.28. Mai multe detalii in acest topic: https://www.elforum.info/topic/156342-vand-placa-electronica-centrala-termica-vaillant/
      Se vinde ca defecta. Se poate incerca depanarea sau pentru recuperare piese; pret: 50lei
  https://postimg.cc/LYMZ42G2
      https://postimg.cc/McBQ8vP9
16. Grile de protectie ventilator 50 mm, din otel, argintiu, 6buc.; pret: 5lei/buc. 25lei, toate.
      https://postimg.cc/hXpDKQMs
Comanda minima este 50lei.
Plata este ramburs prin Posta Romana; cheltuielile de expediere sunt suportate de cumparator.
Editat de nexus
  • Răspunsuri 95
  • nexus
    83
  • BRANCA
  • nostromo
  • rosmarin
Lista si preturile actualizate mai jos:
1. DVD-RW LG 4167RBB 16x/8x/48x/24x/16x, negru, bulk, IDE, acum se deschide si usa; pret: 10lei.
13. Afisaje led, Kingbright Electronic, SC23-11SRWA,  1 digit, 56.9mm(2.3"), rosu, 88-190mcd, catod                 comun, disponibile 4buc.; pret: 10lei/buc.
15. Placa electronica din centrala termica Vaillant Turbo Tec Plus VUW RO 242/3-5. Da eroarea F.28.
     Mai multe detalii in acest topic: https://www.elforum.info/topic/156342-vand-placa-electronica-                 centrala-termica-vaillant/ . Se vinde ca defecta. Se poate incerca depanarea sau pentru recuperare           piese; vanduta
16. Grile de protectie ventilator 50 mm, din otel, argintiu, 6buc.; pret: 4lei/buc. 20lei, toate.
17. Incarcator acumulatori Ni-Mh tip 2xAA/2xAAA, Duracell CEF-20; pret: 10lei.
     https://postimg.cc/64WwqsS7
     https://postimg.cc/WFnLQW3s
18. Extractor de fum cu filtru cu carbune activ, cu ventilator 80mm, alimentare 12V; pret: 15lei.
      https://postimg.cc/68vs953j
      https://postimg.cc/PLsgNsvt
      https://postimg.cc/ykW4bTzz
19. Cooler laptop Cooler-Master NotePal X2, negru, pentru laptopuri cu dimensiuni de pana la 15.4 inch;
      controlul vitezei nu mai merge; functioneaza doar pe turatie maxima; pret: 15lei.
      https://postimg.cc/zLL5FK1D
      https://postimg.cc/9DgC91KN
      https://postimg.cc/gx2Gr1SZ
Toate preturile sunt negociabile pentru valori si in limite rezonabile.
Comanda minima este 50lei, iar transportul este gratuit cu Posta la comenzile
cu valoarea mai mare de 80lei.
Editat de nexus
Up! Preturile scad la unele repere:
1. DVD-RW LG 4167RBB 16x/8x/48x/24x/16x, negru, bulk, IDE, acum se deschide si usa; pret: 10 8lei.
2. HD WD, 80GB, IDE, functional, cred ca are windows 7 instalat, nu mai stiu; pret: 10 8lei.
3. LCD panel laptop, Samsung, LTN154X3-L01, 15.4", 1280x800, wxga, LVDS (1 ch, 6-bit) , 30 pins; pret: 30 25lei.
4. Motor SANKO, M9J90U16-M, 9Vcc; pret: 10 7lei.
5. Motor HC385XLG, ax de 2mm, dimensiuni in poza; pret: 10 7lei.
6. Motoare DC imprimanta, 9Vcc, ax de 2mm, dimensiuni in poza, 4buc; pret: 5 3lei/buc - 10lei toate.
8.   Motor pas cu pas, Mitsumi M35SP-9T, 24Vcc, 400mA; pret: 15 10lei.
9.   Variator dintr-un aspirator Philips, cu HT46C47 si BTB12-600BW, conductori silicon; pret: 15 10lei.
12. Telecomanda LG, model AKB732955, si adaptor wireless; pret: 15 10lei.
14. Aparat foto Canon PowerShot A550, 7.1Mpx, si card de 1Gb; pret: 40 30lei.
16. Grile de protectie ventilator 50 mm, din otel, argintiu, 6buc.; pret: 4 3lei/buc. 20 15lei, toate.
17. Incarcator acumulatori Ni-Mh tip 2xAA/2xAAA, Duracell CEF-20; pret: 10 5lei.
18. Extractor de fum cu filtru cu carbune activ, cu ventilator 80mm, alimentare 12V; pret: 15 10lei.
      controlul vitezei nu mai merge; functioneaza doar pe turatie maxima; pret: 15 10lei.
1. DVD-RW LG 4167RBB 16x/8x/48x/24x/16x, negru, bulk, IDE, acum se deschide si usa; pret: 8lei.
2. HD WD, 80GB, IDE, functional, are Win7 instalat; pret: 8lei.
3. LCD panel laptop, Samsung, LTN154X3-L01, 15.4", 1280x800, wxga, LVDS (1 ch, 6-bit) , 30 pins; pret: 25lei.
4. Motor SANKO, M9J90U16-M, 9Vcc; pret: 5lei.
5. Motor HC385XLG, ax de 2mm, dimensiuni in poza; pret: 5lei.
6. Motoare DC imprimanta, 9Vcc, ax de 2mm, dimensiuni in poza, 4buc; pret: 3lei/buc - 10lei toate.
8.   Motor pas cu pas, Mitsumi M35SP-9T, 24Vcc, 400mA; pret: 10lei.
9.   Variator dintr-un aspirator Philips, cu HT46C47 si BTB12-600BW, conductori silicon; pret: 10lei.
12. Telecomanda LG, model AKB732955, si adaptor wireless; pret: 10lei.
13. Afisaje led, Kingbright Electronic, SC23-11SRWA,  1 digit, 56.9mm(2.3"), rosu, 88-190mcd, catod                 comun, disponibile 4buc.; pret: 8lei/buc.
14. Aparat foto Canon PowerShot A550, 7.1Mpx, si card de 1Gb; pret: 30lei.
16. Grile de protectie ventilator 50 mm, din otel, argintiu, 6buc.; pret: 3lei/buc. 15lei, toate.
17. Incarcator acumulatori Ni-Mh tip 2xAA/2xAAA, Duracell CEF-20; pret: 5lei.
18. Extractor de fum cu filtru cu carbune activ, cu ventilator 80mm, alimentare 12V; pret: 10lei
      controlul vitezei nu mai merge; functioneaza doar pe turatie maxima; pret: 10lei.
Comanda minima este acum doar 40lei + posta.
Editat de nexus
  • 2 săptămâni mai târziu...
