Integrare a doua coduri program arduino in unul singur
uSIZ1970
Buna ziua
Am nevoie de  ajutor in a face sa functioneze un cod program arduino format din doua coduri. (timer + push button).Subliniez ca nu  prea sunt avansat in programare Arduino.
Atasez codul program  cu mentiunea ca dupa integrare  timmer-ul functioneaza dar push button-ul  nu.
Independente functioneaza corect. Astept sfaturi sau corecturi ale programului.
// Import required libraries
#ifdef ESP32
  #include <WiFi.h>
  #include <AsyncTCP.h>
#else
  #include <ESP8266WiFi.h>
  #include <ESPAsyncTCP.h>
#endif
#include <ESPAsyncWebServer.h>
// Replace with your network credentials
const char* ssid = "MERCUSYS_2116";
const char* password = "Alexandru@1970";
const char* PARAM_INPUT_1 = "state";
const char* PARAM_INPUT_2 = "value";
const int output = 2;
const int iesire = 0;
String timerSliderValue = "10";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <title>ESP Web Server</title>
  <style>
    html {font-family: Arial; display: inline-block; text-align: center;}
    h2 {font-size: 2.4rem;}
    p {font-size: 2.2rem;}
    body {max-width: 600px; margin:0px auto; padding-bottom: 25px;}
    .switch {position: relative; display: inline-block; width: 120px; height: 68px}
    .switch input {display: none}
    .slider {position: absolute; top: 0; left: 0; right: 0; bottom: 0; background-color: #ccc; border-radius: 34px}
    .slider:before {position: absolute; content: ""; height: 52px; width: 52px; left: 8px; bottom: 8px; background-color: #fff; -webkit-transition: .4s; transition: .4s; border-radius: 68px}
    input:checked+.slider {background-color: #2196F3}
    input:checked+.slider:before {-webkit-transform: translateX(52px); -ms-transform: translateX(52px); transform: translateX(52px)}
    .slider2 { -webkit-appearance: none; margin: 14px; width: 300px; height: 20px; background: #ccc;
    outline: none; -webkit-transition: .2s; transition: opacity .2s;}
    .slider2::-webkit-slider-thumb {-webkit-appearance: none; appearance: none; width: 30px; height: 30px; background: #2f4468; cursor: pointer;}
    .slider2::-moz-range-thumb { width: 30px; height: 30px; background: #2f4468; cursor: pointer; }
    <style>
      body { font-family: Arial; text-align: center; margin:0px auto; padding-top: 30px;}
      .button {
        padding: 10px 20px;
        font-size: 24px;
        text-align: center;
        outline: none;
        color: #fff;
        background-color: #2f4468;
        border: none;
        border-radius: 5px;
        box-shadow: 0 6px #999;
        cursor: pointer;
        -webkit-touch-callout: none;
        -webkit-user-select: none;
        -khtml-user-select: none;
        -moz-user-select: none;
        -ms-user-select: none;
        user-select: none;
        -webkit-tap-highlight-color: rgba(0,0,0,0);
      .button:hover {background-color: #1f2e45}
      .button:active {
        background-color: #1f2e45;
        box-shadow: 0 4px #666;
        transform: translateY(2px);
  </style>
</head>
<body>
  <h2>ESP Web Server</h2>
  <p><span id="timerValue">%TIMERVALUE%</span> s</p>
  <p><input type="range" onchange="updateSliderTimer(this)" id="timerSlider" min="1" max="40" value="%TIMERVALUE%" step="1" class="slider2"></p>
  %BUTTONPLACEHOLDER%
  <button class="button" onmousedown="toggleCheckbox('on');" ontouchstart="toggleCheckbox('on');" onmouseup="toggleCheckbox('off');" ontouchend="toggleCheckbox('off');">  ALIMENTARE APA  </button>
<script>
function toggleCheckbox(element) {
  var sliderValue = document.getElementById("timerSlider").value;
  var xhr = new XMLHttpRequest();
  if(element.checked){ xhr.open("GET", "/update?state=0", true); xhr.send();
    var count = sliderValue, timer = setInterval(function() {
      count--; document.getElementById("timerValue").innerHTML = count;
      if(count == 0){ clearInterval(timer); document.getElementById("timerValue").innerHTML = document.getElementById("timerSlider").value; }
    }, 1000);
    sliderValue = sliderValue*1000;
    setTimeout(function(){ xhr.open("GET", "/update?state=1", true);
    document.getElementById(element.id).checked = false; xhr.send(); }, sliderValue);
     xhr.open("GET", "/" + x, true);
     xhr.send();
function updateSliderTimer(element) {
  document.getElementById("timerValue").innerHTML = sliderValue;
  xhr.open("GET", "/slider?value="+sliderValue, true);
  xhr.send();
</script>
</body>
</html>
)rawliteral";
// Replaces placeholder with button section in your web page
String processor(const String& var){
  //Serial.println(var);
  if(var == "BUTTONPLACEHOLDER"){
    String buttons = "MANCARE";
    String outputStateValue = outputState();
    buttons+= "<p><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"output\" " + outputStateValue + "><span class=\"slider\"></span></label></p>";
    return buttons;
  else if(var == "TIMERVALUE"){
    return timerSliderValue;
  return String();
String outputState(){
  if(digitalRead(output)){
    return "checked";
  else {
    return "";
  return "";
// Set your Static IP address
IPAddress local_IP(192, 168, 1, 181);
// Set your Gateway IP address
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(89, 38, 8, 1);   //optional
IPAddress secondaryDNS(89, 38, 8, 133); //optional
void setup(){
  // Serial port for debugging purposes
  Serial.begin(115200);
  pinMode(output, OUTPUT);
  digitalWrite(output, LOW);
  pinMode(iesire, OUTPUT);
  digitalWrite(iesire, LOW);
  // Configures static IP address
  if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
    Serial.println("STA Failed to configure");
  // Connect to Wi-Fi
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(1000);
    Serial.println("Connecting to WiFi..");
  // Print ESP Local IP Address
  Serial.println(WiFi.localIP());
  // Route for root / web page
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html, processor);
  // Send a GET request to <ESP_IP>/update?state=<inputMessage>
  server.on("/update", HTTP_GET, [] (AsyncWebServerRequest *request) {
    String inputMessage;
    // GET input1 value on <ESP_IP>/update?state=<inputMessage>
    if (request->hasParam(PARAM_INPUT_1)) {
      inputMessage = request->getParam(PARAM_INPUT_1)->value();
      digitalWrite(output, inputMessage.toInt());
    else {
      inputMessage = "No message sent";
    Serial.println(inputMessage);
    request->send(200, "text/plain", "OK");
  // Send a GET request to <ESP_IP>/slider?value=<inputMessage>
  server.on("/slider", HTTP_GET, [] (AsyncWebServerRequest *request) {
    // GET input1 value on <ESP_IP>/slider?value=<inputMessage>
    if (request->hasParam(PARAM_INPUT_2)) {
      inputMessage = request->getParam(PARAM_INPUT_2)->value();
      timerSliderValue = inputMessage;
    else {
  // Send web page to client
    request->send_P(200, "text/html", index_html);
  // Receive an HTTP GET request
  server.on("/on", HTTP_GET, [] (AsyncWebServerRequest *request) {
    digitalWrite(iesire, HIGH);
    request->send(200, "text/plain", "ok");
  server.on("/off", HTTP_GET, [] (AsyncWebServerRequest *request) {
  // Start server
  server.begin();
void loop() {
Pe viitor foloseste simbolul "<>" in editor pentru inserarea de cod!
  • Răspunsuri 0
  • uSIZ1970
Zile populare
