led panasonic
codrut
model:TX-L32X5B
mb:TNP4G527 1 A
Acest tv ,dupa ce il alimentez,se aprinde backlicht-ul pt 2 secunde ,apoi led-ul de stand by face 3 blink-uri.
Aveti idee ce semnifica cele 3 blink-uri?Tv -ul a avut facut reflow la procesor.
  • Răspunsuri 1
  • codrut
  • iuliantv
Zile populare
https://elektrotanya.com/panasonic_tx-l32x5b_chassis_km16e.pdf/download.html
Panasonic TV blinking red light 3 times occurs for over-current or over-voltage protection. When there is an interrupted boot program caused by the A board, the TV starts blinking 3 times.
Due to 3.3V SOS on the D board or missing voltage on the P board, the situation occurs. As the over-voltage condition can occur for short circuits located on the AP board, A board, or the LCD panel, these boards can be the reason behind the 3-blink issue on the Panasonic TV.
Restart your TV to check if it can resolve the issue. If not, you may need further action. So, to know in detail, keep an eye out for the article
Editat de iuliantv
