costi_b Postat Ianuarie 10, 2023 Partajează Postat Ianuarie 10, 2023 Am un sistem de monitorizare a energiei produse de panourile fotovoltaice. Până la sfârșitul anului trecut a funcționat pe Blynk, dar au oprit serverul gratuit. Am decis să trec monitorizarea pe ThingSpeak. Am reușit să fac un program care funcționează. /* INA226 Bi-directional Current/Power Monitor. Simple Example. Read more: http://www.jarzebski.pl/arduino/czujniki-i-sensory/cyfrowy-czujnik-pradu-mocy-ina226.html GIT: https://github.com/jarzebski/Arduino-INA226 Web: http://www.jarzebski.pl (c) 2014 by Korneliusz Jarzebski */ #include <ArduinoOTA.h> #include <ESP8266WiFi.h> #include <INA226.h> #include <Wire.h> #include <ThingSpeak.h> //#include <aREST.h> //#include <EthernetClient.h> #define SSID "XXXXX" #define PASSWORD "XXXXXX" unsigned long myChannelNumber = XXXXX; // Thingspeak channel ID here const char * myWriteAPIKey = "XXXXXXX"; // Write API key here const char * myReadAPIKey = "XXXXXX"; char server[] = "api.thingspeak.com"; // Serverul ThingSpeak INA226 ina; void checkConfig() { Serial.print("Mode: "); switch (ina.getMode()) { case INA226_MODE_POWER_DOWN: Serial.println("Power-Down"); break; case INA226_MODE_SHUNT_TRIG: Serial.println("Shunt Voltage, Triggered"); break; case INA226_MODE_BUS_TRIG: Serial.println("Bus Voltage, Triggered"); break; case INA226_MODE_SHUNT_BUS_TRIG: Serial.println("Shunt and Bus, Triggered"); break; case INA226_MODE_ADC_OFF: Serial.println("ADC Off"); break; case INA226_MODE_SHUNT_CONT: Serial.println("Shunt Voltage, Continuous"); break; case INA226_MODE_BUS_CONT: Serial.println("Bus Voltage, Continuous"); break; case INA226_MODE_SHUNT_BUS_CONT: Serial.println("Shunt and Bus, Continuous"); break; default: Serial.println("unknown"); } Serial.print("Samples average: "); switch (ina.getAverages()) { case INA226_AVERAGES_1: Serial.println("1 sample"); break; case INA226_AVERAGES_4: Serial.println("4 samples"); break; case INA226_AVERAGES_16: Serial.println("16 samples"); break; case INA226_AVERAGES_64: Serial.println("64 samples"); break; case INA226_AVERAGES_128: Serial.println("128 samples"); break; case INA226_AVERAGES_256: Serial.println("256 samples"); break; case INA226_AVERAGES_512: Serial.println("512 samples"); break; case INA226_AVERAGES_1024: Serial.println("1024 samples"); break; default: Serial.println("unknown"); } Serial.print("Bus conversion time: "); switch (ina.getBusConversionTime()) { case INA226_BUS_CONV_TIME_140US: Serial.println("140uS"); break; case INA226_BUS_CONV_TIME_204US: Serial.println("204uS"); break; case INA226_BUS_CONV_TIME_332US: Serial.println("332uS"); break; case INA226_BUS_CONV_TIME_588US: Serial.println("558uS"); break; case INA226_BUS_CONV_TIME_1100US: Serial.println("1.100ms"); break; case INA226_BUS_CONV_TIME_2116US: Serial.println("2.116ms"); break; case INA226_BUS_CONV_TIME_4156US: Serial.println("4.156ms"); break; case INA226_BUS_CONV_TIME_8244US: Serial.println("8.244ms"); break; default: Serial.println("unknown"); } Serial.print("Shunt conversion time: "); switch (ina.getShuntConversionTime()) { case INA226_SHUNT_CONV_TIME_140US: Serial.println("140uS"); break; case INA226_SHUNT_CONV_TIME_204US: Serial.println("204uS"); break; case INA226_SHUNT_CONV_TIME_332US: Serial.println("332uS"); break; case INA226_SHUNT_CONV_TIME_588US: Serial.println("558uS"); break; case INA226_SHUNT_CONV_TIME_1100US: Serial.println("1.100ms"); break; case INA226_SHUNT_CONV_TIME_2116US: Serial.println("2.116ms"); break; case INA226_SHUNT_CONV_TIME_4156US: Serial.println("4.156ms"); break; case INA226_SHUNT_CONV_TIME_8244US: Serial.println("8.244ms"); break; default: Serial.println("unknown"); } Serial.print("Max possible current: "); Serial.print(ina.getMaxPossibleCurrent()); Serial.println(" A"); Serial.print("Max current: "); Serial.print(ina.getMaxCurrent()); Serial.println(" A"); Serial.print("Max shunt voltage: "); Serial.print(ina.getMaxShuntVoltage()); Serial.println(" V"); Serial.print("Max power: "); Serial.print(ina.getMaxPower()); Serial.println(" W"); } void setup() { Serial.begin(115200); Serial.println("Initialize INA226"); Serial.println("-----------------------------------------------"); // Default INA226 address is 0x40 ina.begin(); // Configure INA226 ina.configure(INA226_AVERAGES_4, INA226_BUS_CONV_TIME_4156US, INA226_SHUNT_CONV_TIME_4156US, INA226_MODE_SHUNT_BUS_CONT); // Calibrate INA226. Rshunt = 0.01 ohm, Max excepted current = 4A // ina.calibrate(0.01, 4); // ina.calibrate(0.01, 0.4); // ina.calibrate(0.47, 1); ina.calibrate(0.005, 16.384); // ina.calibrate(0.047, 1); // Display configuration checkConfig(); Serial.println("-----------------------------------------------"); WiFi.hostname("INA226_OTA"); // DHCP Hostname (useful for finding device for static lease) WiFi.mode(WIFI_STA); WiFi.begin(SSID, PASSWORD); while (WiFi.waitForConnectResult() != WL_CONNECTED) { delay(50); } ArduinoOTA.setHostname("INA226_OTA"); ArduinoOTA.setPassword(""); ArduinoOTA.begin(); Serial.print("IP address:\t"); IPAddress myIP = WiFi.localIP(); Serial.println(myIP); WiFiClient client; ThingSpeak.begin(client); delay(100); } float watthour(0); //float watthour = ThingSpeak.readFloatField(myChannelNumber, 5, myReadAPIKey); unsigned long lastMeasureMs; unsigned long lastReportMs; float Power(0); float ppower(0); const int deltat = 1000; const int ReportTime = 137000; unsigned long deltath(0); float Voltage(0); float Current(0); void loop() { if (millis() - lastMeasureMs > 999) { //Serial.print("Bus voltage: "); //Serial.print(ina.readBusVoltage() * 10, 5); //Serial.println(" V"); Voltage = ina.readBusVoltage() * 10; //Serial.print("Bus power: "); // Serial.print(ina.readBusPower(), 5); // Serial.println(" W"); Power = ina.readBusPower() * 10; //Serial.print("Shunt voltage: "); //Serial.print(ina.readShuntVoltage() * 1000, 5); //Serial.println(" mV"); //Serial.print("Shunt current: "); //Serial.print(ina.readShuntCurrent() * 1000, 5); //Serial.println(" mA"); Current = ina.readShuntCurrent() * 1000; deltath = deltat / 3.6e6; // sampling period in hours (deltat in [ms]) watthour = watthour + (Power + ppower) / 2.0 * deltath; // integer for trapezoids ppower = Power; // then updates the power // Serial.print("Energy: "); //Serial.print(watthour); //Serial.println(" Wh"); //Serial.println(""); lastMeasureMs = millis(); } if (millis() - lastReportMs > ReportTime) { WiFiClient client; ThingSpeak.begin(client); ThingSpeak.setField(1, Voltage); ThingSpeak.setField(2, Power); ThingSpeak.setField(3, watthour); ThingSpeak.setField(4, Current); // Write to ThingSpeak. There are up to 8 fields in a channel, allowing you to store up to 8 different // pieces of information in a channel. Here, we write to field 1. int x = ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey); if (x == 200) { Serial.println("Channel update successful."); Serial.print("Energy: "); Serial.print(watthour); Serial.println(" Wh"); } else { Serial.println("Problem updating channel. HTTP error code " + String(x)); } lastReportMs = millis(); } ArduinoOTA.handle(); delay(1); } Doresc să inițializez o variabilă la pornire cu ultima valoare din câmpul ThingSpeak. Dacă o inițializez cu 0 totul merge perfect float watthour(0); Dacă ințializez float watthour = ThingSpeak.readFloatField(myChannelNumber, 5, myReadAPIKey); programul se compilează dar placa se resetează în continuu la pornire, nu apucă să facă nici conectarea la Wifi. Am testat un program care citește o valoare din server cu instrucțiunea respectivă și funcționează, diferența este că citirea se face în bucla principală, dar eu vreau să citesc valoarea o singură dată la pornire, nu la fiecare rular a buclei. Menționez că nu sunt programator. Link spre comentariu
costi_b Postat Ianuarie 11, 2023 Autor Partajează Postat Ianuarie 11, 2023 Multumesc, o să testez diseară, acum sunt la muncă. Link spre comentariu
costi_b Postat Ianuarie 11, 2023 Autor Partajează Postat Ianuarie 11, 2023 Mulțumesc încă odată, funcționează. Urmează să testez pe placa reală, am testat pe un Wemos D1 că e mai ușor de programat, dar partea de inițializare merge cum doream. 22:57:47.250 -> Channel update successful. 22:57:47.250 -> Energy: 8.50 Wh Link spre comentariu
