Ovidanie Postat Ianuarie 4, 2023 Partajează Postat Ianuarie 4, 2023 Foarte interesant articolul. Preluat din audioXpress, November 2004, pag 28: Why Power Tubes Arc 28 audioXpress 11/04 Many years ago, this causality was noted in power output tubes, but it was pointed out that this occurrence was quite rare. At that time, outside of theaters and PA systems, the average house did not place any heavy demands on output tubesa few watts were all that were needed. The heavy users always replaced their tubes on a regular basis, which prevented the tubes from suffering premature or oldage maladies. Changing tubes regularly was cheaper than repairing amplifiers. Today, with bigger and bigger power amplifiers, output tubes are being called upon to supply ever-increasing power levels, which they can! The problem is that these tubes will wear out faster, become unbalanced quicker, and, without due diligence on the part of the owner, will become susceptible to this type of failure mode far more often than ever thought of before. Since most owners aren’t sure when tubes should be changed, they keep using them until something happens. Either the sound quality falls enough to be noticed or tubes start arcing and failing, the latter being the rarer event. Often, even when the owner pays attention to keeping the tubes balanced, they are used beyond the point at which they should be replaced, because of the power demand put on them. The tube is still “good,” even checking out okay on a tube tester, but its ability to provide a sufficient space charge for proper operation is declining. You should replace these tubes before their space charge reaches a dangerous level. Tube arcing is not necessarily a result of a “bad” tube or a “bad” design. It is far more likely the result of using the tube longer than you should for the application you’re using it. An emissions-type tube tester is of some small help here, but unfortunately it cannot test for peak emission capability, so it is of somewhat limited use. One way to tell that your tubes are in need of a change-out is by how much their bias points have changed since you first put them into the amplifier. Most tubes’ bias will have changed significantly as the tube ages. This can be of some help in determining when the tube is becoming weak. However, the problem is that each individual amplifier is going to be different, so that no set number can be easily assigned to “when” to change the tubes. By the time it becomes difficult or impossible for your matched tubes to hold a “normal” match percentage, your tubes are likely already past the point at which they should have been changed. I’m not saying that every amplifier will suffer this problem or that it will occur often, but the fact is that it can occur often enough to cause significant damage to your amplifier. Much has to do with how and how often you use that amplifier. If it is ridden hard, it is much more likely to happen. One thing is abundantly true: arcing is rarely ever seen in amplifiers that are not ridden hard; that is, called upon to supply very high power levels frequently. If you want to make those expensive output tubes last longer, turn down the volume a bit. Otherwise, be prepared to get out your wallet more frequently. It isn’t just the big power amplifiers that have this problem, any amplifier can arc. Consider someone who has a pair of very expensive, high powered amplifiers, is diligent to keep bias set on them, doesn’t run them too hard, but has experienced several seemingly unexplained arcing tubes, which blow plate fuse resistors (which is what they are for). In every instance, the factory said the tube was defective despite no evidence to support that conclusion. In some cases the tube that arced remained serviceable, others were damaged beyond use. In either case, a tube that has suffered an arc should not be used again. The arc will have caused damage to the cathode whether or not a tube tester shows it. The condition that causes a tube to arc is not a defect, the tube is simply too worn out to work properly under demand. The owners who refused to believe that defective tubes were the sole cause were right. This problem has occurred both with NOS tubesno matter the brandand with recently made tubes. This failure mode doesn’t care whose tubes are in the amplifier; they can all suffer the arcing problem given the right conditions. Forty years ago, manufacturers such as Mullard recommended replacing an output tube when its power output fell to 50% of normal. This was fine forty years ago, when amplifiers weren’t driven as they often are today. Power amps rarely were bigger than 40 or 50W, and two or four tubes could provide that much power easily. The vast majority of amplifiers were under 20−25W, which a pair of tubes could output for a long time. A pair of KT88/6550s could put out 50−60W and have a good long life. Things have changed over the years. Many of today’s owners don’t have the knowledge they need to take care of their amplifiers, and neither do the manufacturers. It is not entirely the owner’s fault. Amplifier manufacturers rarely provide such information to their customers, and there is a wealth of poor or just plain wrong information on the web. Self-proclaimed tube gurus propagate much of this misinformation. Others who operate with a modicum of knowledge make assumptions based on little real knowledge and put that out on the web for others to read, and so it propagates all over, more myth becoming “fact.” It is doubtful that many tube amplifier manufacturers’ technical departments are that well versed in all of the nuances of tube operation either, because little if any documentation has been printed by them addressing this problem. Since this is something of a “new” problem that has shown up in recent years in amplifiers, little thought has been given to this mode of failure. SOLUTIONS Because the method of turning on filaments and preheating the tubes before applying plate voltage has been observed for many, many years in transmitters, the same practice has been observed in some power amplifiers. This alleviates cathode stripping in cold tubes, but does not protect tubes from arcing during operation. This is an entirely different situation calling for different procedures. It is virtually up to the amplifier’s owner to guard against the possibility of arcing, and there are no pat answers on what numbers to use. You could make educated calculations, but they would be different for each particular amplifier. The easiest solution to this problem is to just turn the volume down and not push the tubes so hard. They will reward you with a longer lifespan and no arcing. Cathode stripping has been addressed to some degree in publications, but cathode stripping at cold turn-on has largely been misaddressed. In the case of cathode stripping, arcing occurs only when sufficient damage has been caused by cold cathode stripping. Most amplifiers will not cause cathode stripping at turn-on. Delayed turn-on is a good idea in general but is not that important to tube life unless something has not been done righta bad circuit design, for example. In fact, receiving tubes are designed to withstand higher than maximum-rated voltage when cold. Cathode damage results only when current is drawn sufficiently before the cathode has reached a minimum operating temperature. This condition does not normally exist in audio amplifiers, even larger power ampsunless the designer has done a poor job designing it. Contrary to popular belief, slow turn-on rectifiers such as the 5AR4/GZ34 is not a prerequisite to safe, long-life operation of your tubes. This “myth” was partially derived from the pre-heating requirements for high power transmitter tubes. This requirement does not extend to those transmitter tubes of “lower” power. The tubes’ data sheet will specify whether preheating filaments is required. Popular tubes such as the 211 and 845 do not require pre-heating, however I would recommend pre-heating filaments of any tube with a plate voltage in excess of 750V as a matter of good practice. These power tubes are biased well below any danger zone for cathode stripping in audio applications. Even if the bias is derived from a tube rectifier, the bias voltage will be there soon enough to prevent any possibility of cathode stripping. There is one exception to this situation, that is the use of solid-state rectifiers in the power supply. If solid-state rectifiers are used, it would be a very good idea to use pre-heating and delay plate voltage. Pre-heating your amplifier’s tubes isn’t a bad idea, it just isn’t necessary in most instances. It will not make your tubes last any longer! audioXpress November 2004 31 Link spre comentariu
simson Postat Ianuarie 5, 2023 Partajează Postat Ianuarie 5, 2023 Orice postare pe Elforum se face in limba romana. Nu cred ca cineva are rabdare la traducere pe google.Postare nula. Link spre comentariu
Ovidanie Postat Ianuarie 7, 2023 Autor Partajează Postat Ianuarie 7, 2023 Cu mulți ani în urmă, această cauzalitate a fost notat în tuburile de ieșire de putere, dar a fost a subliniat că acest eveniment a fost destul de rar. Pe vremea aceea, în afara teatrelor și sisteme PA, media casa nu punea nicio solicitare grea pe tuburile de ieșire câțiva wați erau tot ce era nevoie. Greutatea utilizatorii își înlocuiau întotdeauna tuburile pe a în mod regulat, ceea ce a împiedicat tuburi de suferință prematură sau bătrânețe boli. Schimbarea tuburilor regulat a fost mai ieftin decât repararea amplificatoarelor. Astăzi, cu putere din ce în ce mai mare amplificatoare, tuburi de ieșire sunt chemat să aprovizioneze tot mai mare niveluri de putere, pe care le pot! Problema este că aceste tuburi se vor uza mai repede, dezechilibrat mai repede, și, fără diligența cuvenită din partea al proprietarului, va deveni susceptibil la acest tip de mod de eșec mult mai mult de multe ori decât s-a gândit vreodată. Deoarece majoritatea proprietarilor nu sunt siguri când tuburile trebuie schimbate, se păstrează folosindu-le până când se întâmplă ceva. Fie calitatea sunetului scade suficient fi observat sau tuburile încep să se arcuiască și să se cedeze, acesta din urmă fiind evenimentul mai rar. Adesea, chiar și atunci când proprietarul este atent pentru a menține tuburile echilibrate, sunt folosite dincolo de punctul la pe care ar trebui să fie înlocuite, deoarece a cererii de putere impuse acestora. The tubul este încă „bun”, chiar și verificarea bine pe un tester cu tuburi, dar are capacitatea de a sigurați o taxă suficientă de spațiu pentru funcționarea corectă este în scădere. Ar trebui să înlocuiți aceste tuburi înainte încărcătura lor spațială atinge un nivel periculos nivel. Arcul tubului nu este neapărat un rezultat al unui tub „rău” sau al unui tub „rău” proiecta. Este mult mai probabil rezultatul folosind tubul mai mult decât ar trebui pentru aplicația pe care o utilizați. Un tester cu tuburi de tip emisii este de un mic ajutor aici, dar din păcate nu poate testa capacitatea de emisie de vârf, deci are o utilizare oarecum limitată. O modalitate de a spune că tuburile tale sunt în interior nevoie de o schimbare este de cât punctele lor de părtinire s-au schimbat de atunci le pui mai întâi în amplificator. Majoritatea tuburilor se vor schimba semnificativ pe măsură ce tubul îmbătrânește. Acesta poate fi de un oarecare ajutor pentru a determina când tubul devine slab. Însă problema este ca fiecare amplificator individual va fi diferit, astfel încât nici un set numărul poate fi atribuit cu ușurință „când” să schimbi tuburile. Până când devine dificil sau imposibil pentru tuburile tale potrivite păstrați un procent de potrivire „normal”, tuburile dvs. sunt probabil deja trecute punctul în care ar fi trebuit să fie schimbat. Nu spun că fiecare amplificator va suferi această problemă sau că ea va apărea des, dar adevărul este că poate apărea destul de des pentru a provoca semnificative deteriorarea amplificatorului dvs. Mult are legătură cu cât și cât de des foloseste acel amplificator. Dacă este călărit greu, e este mult mai probabil să se întâmple. Un lucru este foarte adevărat: arcul este rar întâlnit în amplificatoare care nu sunt călărit greu; adică chemat să furnizeze niveluri de putere foarte ridicate frecvent. Dacă vrei să faci acele rezultate scumpe tuburile durează mai mult, reduceți volumul putin. În caz contrar, fii pregătit să primești scoateți mai des portofelul. nu este doar marile amplificatoare de putere care au această problemă, orice amplificator poate arc. Luați în considerare pe cineva care are o pereche de amplificatoare foarte scumpe, de mare putere, este sârguincios să păstreze părtinirea asupra lor, nu le execută prea tare, dar a experimentat mai multe aparent inexplicabile tuburi cu arc, care suflare cu plăci fuzibile rezistențe (pentru care sunt). În în fiecare caz, fabrica a spus tubul era defect, în ciuda faptului că nu există dovezi susțin această concluzie. In unele cazuri tubul care s-a arcuit a rămas funcțional, altele au fost deteriorate dincolo de uz. În ambele cazuri, un tub care a avut de suferit un arc nu trebuie folosit din nou. Arcul va fi cauzat daune catodul indiferent dacă este sau nu un tub testerul o arata. Afecțiunea care provoacă un tub la arc nu este un defect, tubul pur și simplu este prea uzat pentru a funcționa corect sub cerere. Proprietarii care au refuzat a crede că tuburile defecte unde singura cauză avea dreptate. Acest problema a apărut atât cu NOS tuburiindiferent de marcăși cu tuburi realizate recent. Acest mod de eșec nu-i pasă ale cui tuburi sunt în amplificator; toți pot suferi arcul problemă în condițiile potrivite. Cu patruzeci de ani în urmă, astfel de producători după cum Mullard a recomandat înlocuirea unui tubul de ieșire când puterea sa de ieșire a scăzut la 50% din normal. Asta a fost bine patruzeci cu ani în urmă, când amplificatoarele nu erau conduse așa cum sunt adesea astăzi. Puterea era rareori mai mare de 40 sau 50W și două sau patru tuburi ar putea furniza atata putere usor. Marea majoritate a amplificatoarelor au fost sub 20−25W, care o pereche de tuburi ar putea ieși pentru o lungă perioadă de timp. O pereche de KT88/6550-urile ar putea stinge 50-60W și sa aiba o viata lunga buna. Lucrurile au schimbat de-a lungul anilor. Multe dintre cele de azi proprietarii nu au cunoștințele pe care le au trebuie să aibă grijă de amplificatoarele lor, si nici producatorii. Nu este în totalitate vina proprietarului. Amplificator producătorii furnizează rar astfel de informații pentru clienții lor și există o bogăție de săraci sau pur și simplu informații greșite pe web. Autoproclamat tub gurus propaga mult din această dezinformare. Alții care operează cu un minim de cunoștințe faceți presupuneri bazată pe puține cunoștințe reale și pune asta pe web pentru alții citește, și așa se propagă peste tot, mai mult mitul devenind „fapt”. Este îndoielnic că multe amplificatoare cu tuburi departamentele tehnice ale producatorilor sunt atât de versați în toate nuanțe de funcționare a tubului fie, deoarece puţină documentaţie, dacă nu are fost tipărit de ei abordând acest lucru problemă. Deoarece acesta este ceva de a „nouă” problemă care a apărut recent ani în amplificatoare, puțin gândit a fost dat acestui mod de eșec. SOLUȚII Deoarece metoda de pornire a filamentelor și preîncălzirea tuburilor înainte s-a observat aplicarea tensiunii pe placă de mulți, mulți ani în transmițătoare, aceeași practică a fost observată la unele amplificatoare de putere. Acest atenuează decaparea catodului la rece tuburi, dar nu protejează tuburile de arcul electric în timpul funcționării. Acesta este un în întregime situație diferită care cere diferit proceduri. Este practic până la proprietarul amplificatorului de care să se ferească posibilitatea de arc și există nu răspunde la ce numere utilizare. Ai putea face calcule educate, dar ar fi altfel pt fiecare amplificator anume. Cea mai ușoară soluție la această problemă este pentru a reduce doar volumul și nu împinge tuburile atât de tare. Ei vor recompensa tu cu o durată de viață mai lungă și fără arc. S-a abordat eliminarea catodului într-o oarecare măsură în publicații, dar decaparea catodului la pornire la rece are în mare parte greșit. În cazul de stripare catodică are loc numai arcul când au fost suficiente pagube cauzate de striparea catodului rece. Cel mai amplificatoarele nu vor cauza stripping catod la pornire. Pornirea întârziată este a idee bună în general, dar nu este atât de importantă a tubul de viață dacă nu ceva nu a fost făcut corect – un circuit prost design, de exemplu. De fapt, primind tuburile sunt proiectate pentru a rezista mai sus decât tensiunea nominală maximă la rece. Deteriorarea catodului rezultă numai atunci când curentul este absorbit suficient înainte de catodul a atins un nivel minim de funcționare temperatura. Această condiție face nu există în mod normal în amplificatoarele audio, amplificatoare de putere chiar mai maricu excepția cazului în care proiectantul a făcut o treabă proastă proiectând-o. Contrar credinței populare, pornire lentă redresoare precum 5AR4/GZ34 nu este o condiție prealabilă pentru o funcționare sigură și de lungă durată a tuburilor tale. Acest „mit” a fost derivat parțial din cerintele de preincalzire pt tuburi transmițătoare de mare putere. Această cerință nu se extinde asupra celor tuburi transmițătoare de putere „mai mică”. The fișa tehnică a tuburilor va specifica dacă este necesară preîncălzirea filamentelor. Popular tuburi precum 211 și 845 nu necesită preîncălzire, oricum aș face-o recomandă filamentele de preîncălzire ale oricăror tub cu o tensiune de placă peste 750V ca o chestiune de bună practică. Aceste tuburile de putere sunt părtinitoare mult sub oricare zona de pericol pentru decaparea catodului aplicații audio. Chiar dacă părtinirea este derivată de la un redresor cu tub, tensiunea de polarizare va fi acolo destul de curând pentru a preveni orice posibilitate de stripare a catodului. Există o excepție de la această situație, adică utilizarea redresoarelor cu stare solidă în sursa de alimentare. Dacă în stare solidă sunt folosite redresoare, ar fi foarte o idee bună să folosiți preîncălzirea și întârzierea tensiunea plăcii. Preîncălziți tuburile amplificatorului dvs nu este o idee rea, pur și simplu nu este necesar majoritatea cazurilor. Nu vă va face tuburile durează mai mult! Link spre comentariu
Kuki Postat Ianuarie 7, 2023 Partajează Postat Ianuarie 7, 2023 Traducere aiurea, nu inteleg nimic Link spre comentariu
Vizitator Postat Ianuarie 7, 2023 Partajează Postat Ianuarie 7, 2023 (editat) Articolul e aici https://audioxpress.com/article/why-power-tubes-arc Cu un pic de engleză, e ușor de intuit. Editat Ianuarie 7, 2023 de Vizitator Link spre comentariu
Kuki Postat Ianuarie 7, 2023 Partajează Postat Ianuarie 7, 2023 Asta ziceam, e mai inteligibil in engleza, o traducere ne-automata ar fi ajutat.. Link spre comentariu
Ovidanie Postat Ianuarie 7, 2023 Autor Partajează Postat Ianuarie 7, 2023 Nu am traducere "neautomata". Din pacate astea sunt variantele, articolul in engleza ori traducerea cu Google. Link spre comentariu
validae Postat Ianuarie 8, 2023 Partajează Postat Ianuarie 8, 2023 Traducerea corectă a articolului necesită înţelegerea bună a termenilor utilizaţi şi a ,,jargonului,, tehnic, un program de traducere automată nu poate face decât să dea un rezultat hilar, cum s-a şi văzut de altfel. Am citit articolul respectiv şi voi reda pe scurt câteva din ideile esenţiale. Ideea de bază e că descărcările în tuburi se produc de obicei nu din cauză că tuburile în cauză sunt proaste (ca model), defecte sau schema lor de utilizare e proastă. De cele mai multe ori, tuburile respective sunt utilizate foarte intens şi prea mult la putere maximă sau forţate des la vârfuri de putere mare. Când un amplificator cu tuburi e ,,forjat,, intens la peste 50% din puterea maximă, există după un timp riscul să apară efectul descărcărilor interne. Acestea pot apărea în absolut orice tub, nu numai la tuburile de putere, mai ales când tubul e forţat să funcţioneze cu catodul insuficient de bine încălzit. Utilizatorii care folosesc intensiv amplificatoarele e de preferat să înlocuiască tuburile atunci când acestea depăşesc un anumit număr de ore de funcţionare, evitând astfel defectele generate de îmbătrânirea lor. Înlocuirea preventivă a tuburilor după un timp de utilizare e în general mai ieftină decât repararea amplificatorului defectat când acestea cedează. Printre altele, recomandarea de acum 40 de ani acelor de la Mullard ca un tub să fie schimbat îndată ce emisia lui a scăzut la 50% rămâne încă valabilă şi astăzi, iar evitarea ,,forjării,, amplificatorului când tuburile depăşesc un anumit număr de ore de funcţionare ajută la împiedicarea apariţiei descărcărilor interne. O cauză ar fi pierderea în timp a vidului iniţial. Printre altele, se recomandă şi ca un tub care a prezentat descărcări interne să nu mai fie folosit, chiar dacă pe tester el nu apare ca defect.Catodul va fi ireversibil afectat din această cauză. Se dau explicaţii foarte amănunţite despre fenomenul ,,smulgerii,, de electroni direct de pe suprafaţa catodului (sputtering), atunci când tubul este forţat să funcţioneze la curenţi mari şi emisia lui catodică e slăbită de uzura stratului de oxid. Dacă există un interes deosebit, aş putea traduce aşa cum trebuie tot articolul, dar asta ar mai dura fiindcă trebuie să mă mai documentez în paralel despre terminologia şi teoria tuburilor, eu nefiind ,,lămpar,, în jargonul utilizatorilor de tuburi... Link spre comentariu
simson Postat Ianuarie 8, 2023 Partajează Postat Ianuarie 8, 2023 Multumim, foarte frumos si pe inteles facut traducerea. Banuiesc ca s-a depus ceva timp cu traducerea. Pai asa ar trebui postat un link strain cu traducerea facuta.Nu doar aruncat pe forum sa citeasca cine intelege. Conform regulamentului ar trebui sterse postarile netraduse sau traduse in scarba. Link spre comentariu
telefunken Postat Ianuarie 23, 2023 Partajează Postat Ianuarie 23, 2023 L-am citit pe sarite, poate mi-a scapat, dar nu se indica cauza descarcarilor. Dupa umila mea parere arcul electric nu se poate amorsa in incinta vidata din tuburi la tensiuni de 1000-2000V. In 99% din cazuri descarcarea are loc atunci cand vid-ul nu mai este chiar atat de ... vid. Link spre comentariu
string Postat Ianuarie 23, 2023 Partajează Postat Ianuarie 23, 2023 După Legea lui Paschen, funcție de gaz, (de)presiune și spațiu între electrozi (nu și în funcție de temperatură), cam așa ar fi cu tensiunea de străpungere: Link spre comentariu
string Postat Ianuarie 23, 2023 Partajează Postat Ianuarie 23, 2023 (editat) Spre exemplu, tubul GU50, suportă tensiuni anodice limită de 1000V la lungimi de undă peste 6,5m și doar 600V la lungimi de undă sub 3,5m: https://frank.pocnet.net/sheets/018/g/GU50.pdf Editat Ianuarie 23, 2023 de string Link spre comentariu
validae Postat Ianuarie 24, 2023 Partajează Postat Ianuarie 24, 2023 Eu zic că dacă ,,forjezi,, un tub mult timp, inevitabil şi sticla lui se deteriorează iar vidul nu mai poate fi menţinut corespunzător.Asta în afară de efectul de ,,sputtering,, adică de smulgere de particule metalice de pe electrozi, ori chiar de scăderea emisiei stratului de oxid.De aceea şi recomandarea Mullard de a nu (mai) folosi un tub peste un anumit număr de ore, dacă-l utilizezi intens....or fi tuburile mult mai ,,tolerante,, la abuzuri decât semiconductorii, dar totuşi, nu sunt veşnice sau indestructibile. Link spre comentariu
telefunken Postat Ianuarie 24, 2023 Partajează Postat Ianuarie 24, 2023 Exista posibilitatea ca integritatea vid-ului din incinta tubului sa fie afectata de fenomene ca: - pentru tuburi stocate pe o perioada indelungata, pot patrunde gaze in balon prin fenomenul de difuzie - la zona de sudura sticla-terminal pot apare imperfectiuni de etansare (desi aliajul - kovar, dumet, FeNiCo, din care este realizat terminalul are coeficientul de dilatare egal cu al sticlei) in urma stresului mecanic sau al actiunii indelungate a oxigenului asupra terminalului si astfel patrund gaze in interior - exista o anumita cantitate de gaze stocate in structura metalica a tubului care sunt eliberate treptate in interiorul balonului Invariabil gazele patrunse in interior se vor ioniza si vom avea conditii de amorsare a arcului/descarcarii electrice. Link spre comentariu
string Postat Ianuarie 24, 2023 Partajează Postat Ianuarie 24, 2023 Da, asta rezultă și din diagrama (Paschen) postată mai sus: ”îmbătrânirea vidului” la Ar (Argon) de la 0,1 la 0,2 conduce la reducerea drastică a tensiunii de străpungere de la 1000V spre sub 500V. Link spre comentariu
