VFO cu scala retro tip LCD
hpavictor
  • Răspunsuri 23
  • Marele Savant
    13
  • roadrunner
  • hpavictor
  • telefunken
da ceva de felul de mai jos:
FO_CTRL_V5:250:33: error: 'PCNT_UNIT_0' was not declared in this scope
          pcnt_get_counter_value(PCNT_UNIT_0, &RE_Count);
VFO_CTRL_V5:250:10: error: 'pcnt_get_counter_value' was not declared in this scope
VFO_CTRL_V5:252:10: error: 'pcnt_counter_clear' was not declared in this scope
          pcnt_counter_clear(PCNT_UNIT_0);
C:\Users\emil\Downloads\vfo-test\VFO_CTRL_V5\VFO_CTRL_V5.ino:252:10: note: suggested alternative: 'bintime_clear'
          bintime_clear
C:\Users\emil\Downloads\vfo-test\VFO_CTRL_V5\VFO_CTRL_V5.ino: In function 'void setup()':
VFO_CTRL_V5:322:5: error: 'pcnt_config_t' was not declared in this scope
     pcnt_config_t pcnt_config_A;// structure for A
C:\Users\emil\Downloads\vfo-test\VFO_CTRL_V5\VFO_CTRL_V5.ino:322:5: note: suggested alternative: 'gpio_config_t'
     gpio_config_t
VFO_CTRL_V5:323:18: error: expected ';' before 'pcnt_config_B'
     pcnt_config_t pcnt_config_B;// structure for B
VFO_CTRL_V5:325:5: error: 'pcnt_config_A' was not declared in this scope
     pcnt_config_A.pulse_gpio_num = PULSE_INPUT_PIN;
C:\Users\emil\Downloads\vfo-test\VFO_CTRL_V5\VFO_CTRL_V5.ino:325:5: note: suggested alternative: 'gpio_config_t'
     gpio_config_t
VFO_CTRL_V5:327:32: error: 'PCNT_MODE_REVERSE' was not declared in this scope
     pcnt_config_A.lctrl_mode = PCNT_MODE_REVERSE;
Asa cum am spus, cu un .ino asemanator, dar o versiune mai nou, functioneaza! Compilat cu aceleasi biblioteci! dar da, eroarea este in jurul encoderului, asa ca voi instala si versiune specifica pentru esp32.
in rest, afisarea si butoanele functioneaza, am sa-i pun si un modul cu si5351 poate chiar in seara asta.
multumesc
edit: facea tot la fel! pina la urma se pare ca atunci cind m-am uitat prin sursa am adaugat/sters un caracter sau ceva asemanator prin cod, pentru ca dupa ce am incercat pe o copie noua a fisierului, a functionat! il voi incarca in modul sa vad daca sint diferente fata de cel gasit in alta parte.
Editat de Marele Savant
  • 11 luni mai târziu...
Salutari!
iar nu vrea sa se compileze fisierul .ino
nu imi este deloc clar ce s-a intimplat, ultima data, anul trecut cred a mers, acuma nu mai merge nici pe PC nici pe laptop. Nu am facu update-uri la IDE, doar cele facute de SO. Nu ma pricep la programare, poate are cineva timp sa-mi dea o idee. Erorile sint:
c:/users/emil/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\emil\AppData\Local\Temp\arduino-sketch-6B10E530E490639BE5B9D624D5F0D509/VFO_CTRL_V5.ino.elf section `.dram0.bss' will not fit in region `dram0_0_seg'
c:/users/emil/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: DRAM segment data does not fit.
c:/users/emil/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: region `dram0_0_seg' overflowed by 3536 bytes
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
Pachetele ESP32 2.0.6 și 2.0.7 provoacă erori în timpul compilării. Trebuie utilizată versiunea 2.0.5 sau anterioară.
Am testat cu versiunea 2.0.5 si se compileaza fara probleme pentru board  ESP32 Dev Module si ESP32 Wrover Module.
    Am observat, dar nu am mai apucat sa scriu aici pentru ca am avut impresia ca subiectul nu prezinta interes.
oricum, multumesc mult pentru ajutor!
