Parere Deck MT3220
Mitrut20
  • Răspunsuri 8
  • yo3fhm
  • Mitrut20
  • sh0t
  • franzm
La 22.11.2022 la 12:27, Mitrut20 a spus:
Va salut! doresc sa achizitionez un astfel de deck si doresc sa aud parerile dvs despre acesta.
Daca aveti cumva si ideei pentru modificari :)
Ziua buna,
E vorba de cel din miniturnul de la Electronica ?
Daca e ala, evitati-l. E o catastrofa tehnica. Hi :)
Vreti un casetofon deck de buna calitate? Tintiti la preturi in jur de 250-350 EUR.
Vizati modele cu 3 capete, preferabil din ferita/sendust, mecanica solida si cu review-uri bune.
Cautati daca se poate tipurile cu calibrare de banda, cel putin Dolby C sau HX Pro / DBX, raport semnal/zgomot cel putin 65dB, preferabil mai mare (de la 70dB in sus).
Va pot sugera cateva modele pe care le-am avut in exploatare, fabricate in epoca de glorie, anii 80-90.
Succes!
JVC TD-V661 (1993), 2 capete, 3 motoare, Dolby B,C, HX Pro, 15Hz-19KHz (metal), SNR=74dB (DolbyC)
https://www.hifiengine.com/manual_library/jvc/td-v661.shtml
Akai DX-57 (1991-1993) 3 capete, 2 motoare, DolbyB,C ,  15Hz-20KHz (metal), SNR=72dB (DolbyC)
https://www.hifiengine.com/manual_library/akai/dx-57.shtml
Sony TC-K670 (1991-1992), 3 capete, 3 motoare, Dolby B,C, HX Pro, 20Hz-21KHz (metal), SNR=75dB (DolbyC)
https://www.hifiengine.com/manual_library/sony/tc-k670.shtml
Akai GX-65 (1990-1993), 3 capete, 2 motoare, DolbyB,C ,  15Hz-21KHz (metal), SNR=72dB (DolbyC)
https://www.hifiengine.com/manual_library/akai/gx-65.shtml
Aiwa AD-WX777 (1989-1992), 3 capete, 2 motoare, Dolby B,C, 20Hz-18KHz (metal), SNR=73dB (dolbyC)
https://www.hifiengine.com/manual_library/aiwa/ad-wx777.shtml
TEAC V-970X (1987-90), 2 capete, 3 motoare, Dolby B,C, DBX, 20Hz-21KHz (metal), SNR=92dB (DBX)
https://www.hifiengine.com/manual_library/teac/v-970x.shtml
TEAC R-888X (1984-86), 2 capete, 3 motoare, Dolby B,C, DBX, 20Hz-21KHz (metal), SNR=92dB (DBX)
https://www.hifiengine.com/manual_library/teac/r-888x.shtml
Akai GX-F91 (1982-1985), 3 capete, 2 motoare, DolbyB,C ,  20Hz-21KHz (metal), SNR=75dB (DolbyC)
https://www.hifiengine.com/manual_library/akai/gx-f91.shtml
Akai GX-F31 (1982-1983), 2 capete, 2 motoare, DolbyB,C ,  20Hz-19KHz (metal), SNR=75dB (DolbyC)
https://www.hifiengine.com/manual_library/akai/gx-f31.shtml
Denon DR-330 (1980), 2 capete, 2 motoare, DolbyB, 25Hz-21KHz (metal), SNR=67dB (DolbyB)
https://www.hifiengine.com/manual_library/denon/dr-330.shtml
Akai GX-F90 (1979-1982), 3 capete, 2 motoare, DolbyB, 25Hz-21KHz (metal), SNR=72dB (DolbyB)
https://www.hifiengine.com/manual_library/akai/gx-f90.shtml
Aiwa AD-6900 (1979-1980), 2 capete, 2 motoare, DolbyB, 20Hz-19KHz (CrO2), SNR=68dB (DolbyB)
https://www.hifiengine.com/manual_library/aiwa/ad-6900.shtml
Editat de yo3fhm
Amu o luna am aruncat (pentru ca nu le-a vrut nimeni):
- Yamaha KX680 dbx (cu FETuri duble Sony în preampliful de cap) în perfecta stare de functionare. Se gasesc capete pe toate drumurile.
- AIWA AD-M 770, curele lipsa, capete în stare f. buna dar imposibil de gasit noi, integrate Sony seria CX.
- Technics RS-M 12 în stare buna.
Acum 9 minute, franzm a spus:
Ma doare sufletul ... :91
N ai stiut unde sa le pui , nu ca nu le ai putut da - franzm
Evitati dublu-deckurile , evitati deck urile technics facute dupa 89.
Chestii cheie care trebuie sa le iei in vedere daca vrei un deck de calitate:
3head (minimum sa fie hard permalloy)
3motor (de preferat mecanisme sankyo / pioneer)
Comutare sursa/banda pe releu
Single capstan solid , cu w/f declarat de fabrica sub 0.065% , sau un dublu cabestan.
OBLIGATORIU reglaj bias , de preferat si reglaj level (daca inregistrezi cu dolby C des).
La 27.11.2022 la 11:45, yo3fhm a spus:
Ziua buna,
Succes!
Deck uri cu 3 capete am 2, dar restu sunt dublu deck uri, de ex :Technics RS-TR 474,373 Technics RS T55R si inca 2 3 de la yamaha pioneer si kenwood. Voiam sa cumpar Deckul 3220 deoarece am restul liniei, si eram curios sa vad ce "performante" are. :)
Acum 14 minute, Mitrut20 a spus:
Pai daca aveti "restul" liniei (probabil amplificatorul si tunerul), concluzia ar fi trebuit sa vina fara a mai cumpara si chiar fara a mai intreba pe altcineva.
Dar daca chiar vreti sa experimentati, sa stiti ca si noi suntem foarte curiosi sa vedem ce veti obtine.
Banuiesc ca pretul va fi modic.
Ramanem in asteptarea impresiilor dvs. si eventual a unui review ptr. 3220 !
