dezmembrari audio
  • Răspunsuri 182
  • okean
    18
  • carageae
    12
  • aureli67
    11
  • Simion Irinel
    10
Doar acest post mai e valabil. Rezervari pana in 10 decembrie. Comanda minima 30 lei, eventuale comenzi doar in topic.
1. stk0049 bun 25 lei
https://ibb.co/t3X5pg7
2. picioruse aparate, 10 lei setul cele mari, 5 lei setul cele mici
https://ibb.co/jGRx30Z
3. trafuri din amplificatoare 15 lei bucata sau 50 lei toate
https://ibb.co/4ppKj14
https://ibb.co/m5cMDC3
4. radiatoare aluminiu 10 lei bucata sau 50 lei toate
https://ibb.co/94HLkbY
https://ibb.co/Rhz45Mv
5. vumetre mari cu ace 50 lei
https://ibb.co/WPs8c0p
https://ibb.co/MSTmTzX
6. placa amplif philips pentru potentiometre 15 lei
https://ibb.co/0D5XmsR
7. preu phono philips 10lei
https://ibb.co/4TQbhPq
8. placi deck philips 20 lei toate
https://ibb.co/j5f1Q6w
9. traf retea deck philips 10lei
https://ibb.co/5xJvKqN
10. placa amplif sony pt potentiometre 15 lei
https://ibb.co/StTdsQD
11. radiatoare aluminiu 20 lei cele doua identice si 10 lei cel singur
https://ibb.co/rt0CyYd
https://ibb.co/sJWR7WJ
12. traf capsulat sony 2x32v 50lei
https://ibb.co/zmF02Mt
https://ibb.co/X7PXddv
13. traf akai 2x40v 30 lei
https://ibb.co/nb2m8Hg
14. butoane aluminiu boombox toshiba 10 lei
https://ibb.co/VJKjJWQ
https://ibb.co/Xz24JLn
15. placi toshiba finali ok 25 lei
https://ibb.co/02fW8Xf
16. difuzoare toshiba 25 lei toate, traf alimentare 10 lei
https://ibb.co/yWnw5t1
https://ibb.co/ZSRJ7S7
17. vumetre cu ace toshiba 25 lei
https://ibb.co/jDWsnJm
18. lot punti redresoare din amplifuri 15 lei
https://ibb.co/TYBcB3J
19. butoane aluminiu sony 15 lei
https://ibb.co/GtyQbX0
https://ibb.co/1d6kZyp
20. mufe difuzoare 5 lei ambele
https://ibb.co/pd6QgDN
21. 2 stk1050, cred ca unul este bun 25 lei ambele
https://ibb.co/cbsZtsh
https://ibb.co/bzqGZH8
22. placa radio 10 lei
https://ibb.co/g7KPQZc
23. placa tuner 25 lei
https://ibb.co/4msNWd3
24. variabil blocat plus ceva ferite 15 lei totul
https://ibb.co/6rPThHX
25. filtraje 10 lei perechea
https://ibb.co/0Xm1zPK
26. vumetru cu leduri 30lei
https://ibb.co/g7tDqBt
https://ibb.co/y8P973D
cele mici din dreapta jos, legate cu fir rosu
toate
Vreau doua, cel de jos de tot si cel de deasupra lui in dreapta, adica 31,5x8x6 si 23x8x6.
Daca e nevoie, am trimis si poza editata pe FB messenger.
Astea le vreau eu. Cand e data terminus?
Editat de carageae
Acum 6 ore, carageae a spus:
toate
La radiatoare e dat doar cel in forma de fagure, restul disponibile, data terminus scrie clar in topic 10 decembrie.
27. etaj final cu 2xtca830 bune 25 lei
https://ibb.co/jrB6Tq0
28. placa cu 5 x njm4558 plus un la2730 10 lei
https://ibb.co/8s1DwT4
29. pereche finali gd150/gd160 10 lei
https://ibb.co/7pNS1DN
30. module cu potentiometre cursor liniar 15 lei toate
https://ibb.co/B3f7tk4
31. trafuri amplificatoare 30 lei bucata sau 150 lei toate
https://ibb.co/DQFgLjJ
32. tranzistori finali 2sc4468/2sa1695 25 lei perechea, 2sc3853/2sa1489 20 lei perechea, restul 20 lei perechea
https://ibb.co/P57WmS1
33. tranzistori finali 2sd587/2sb617 30 lei perechea, 2sc1986/2sa714 15 lei perechea
https://ibb.co/DDpZxcM
34. tranzistori medie putere 10 lei perechea oricare
https://ibb.co/grgJ8yp
35. tranzistori finali bdx77/bdx78 15 lei perechea
https://ibb.co/VWJjxcj
36. tranzistori 2sc1162/2sa715 15 lei perechea
https://ibb.co/LkJcZnK
37. tranzistori 2sd414/2sb548 15 lei perechea
https://ibb.co/QHhd8dB
38. trafuri retea din aparate audio 15 lei bucata sau 50 lei toate
https://ibb.co/3kznhLW
https://ibb.co/Ld0JPDW
Editat de fluffy37
