dezmembrari audio
  • Răspunsuri 182
  • okean
    18
  • carageae
    12
  • aureli67
    11
  • Simion Irinel
    10
Comanda minima 30lei, rezervari pana in 20.11, prioritate are cine scrie in topic.
1. analizator spectral din amplif fisher 30 lei
https://ibb.co/zrF7Q8F
https://ibb.co/Fz6kM8k
3. module mixer activ dynacord, 1xne5532 si 3x operationale 4559 pe fiecare modul, disponibile 12 module 15 lei bucata sau 150 lei toate
https://ibb.co/J2R968F
4. perechi filtraje, 30 lei cei mari, 25 lei oricare din restul.
https://ibb.co/xmYz7LJ
5. difuzoare inalte visonik, 50 lei ambele, sunt ok.
https://ibb.co/8BMYLsT
https://ibb.co/HzKc2RN
6. lot butoane volum amplifuri 20 lei , nu dau la bucata
https://ibb.co/n0nBpPZ
https://ibb.co/9cJJ8wd
7. 3 perechi finali mj15003/15004 motorola la 35 lei perechea sau 100 lei toti
https://ibb.co/LC6TKSG
8. modul cu tc9177 5 lei
https://ibb.co/Z1kV3Kg
9. stk496-270 bun 20 lei
https://ibb.co/g7963Zd
10. radio rft complet 40 lei
https://ibb.co/sb4yy0c
https://ibb.co/vBpg7V1
https://ibb.co/0mswt6Q
https://ibb.co/TmkxH9f
11. 2 radiatoare aluminiu identice 20 lei
https://ibb.co/8MLkQRs
12. traf toroidal 2x22v 40 lei
https://ibb.co/rbxYLHW
https://ibb.co/QCSX086
13. mecanica completa cu kss213 verificat ok 20 lei
https://ibb.co/YfL9p8k
https://ibb.co/GMxN7Xh
14. 2 module dynacord  15 lei ambele
https://ibb.co/SJzTr18
15. picioruse aparate 10 lei setul sau 30 lei toate
https://ibb.co/wy1ZZG0
16. stk0049 original bun 25 lei
https://ibb.co/t3X5pg7
17. mufe difuzoare 5 lei bucata--------cele rotunde (cu surub) rezervate
https://ibb.co/WGFR6s1
18. placa cd yamaha cu pcm84 25 lei
https://ibb.co/1z38LzG
19. module dynacord 1xne5532 si 5xupc4559 pe fiecare, 15 lei bucata
https://ibb.co/Lp7L8NX
20. module dynacord 15 lei bucata sau 25 ambele
https://ibb.co/1G2LGQs
21. modul dynacord 1xne5532, 2xupc4559, 2xbf860, 2xbf857, 20 lei
https://ibb.co/2t5v1tV
22. egalizator stereo 5 benzi 30 lei
https://ibb.co/X5stMVZ
23. volum motorizat 15 lei
https://ibb.co/r50x9L2
24. etaj final complet si bun 30 lei
https://ibb.co/9ZrHyh2
https://ibb.co/mXjfSsz
25. vumetru vfd 35 lei
https://ibb.co/BCg7jfY
https://ibb.co/yyQky5L
26. filtraje roe 2200/100v, 20 lei perechea sau 50 lei toti
https://ibb.co/1TkxFFm
27. 2 stk-uri din amplificator philips, neverificate 30 lei ambele sau 20 lei bucata
https://ibb.co/wsz8kkj
28. filtraje 5 lei perechea oricare---unele s-au dat
https://ibb.co/Sr1KzHC
29. 2 radiatoare aluminiu identice  25 lei ambele
https://ibb.co/L1mGnDV
30. front-end 5 lei, 2 module radio 15 lei bucata
https://ibb.co/NsrxSbh
31. traf toroidal din mixer activ dynacord 40 lei
https://ibb.co/NjNLX0v
https://ibb.co/SyHYCNS
32. radiator aluminiu 15 lei
https://ibb.co/NtL6kDX
33. decodor stereo 20 lei
https://ibb.co/T8ysyBJ
34. comutatoare 5 lei toate
https://ibb.co/dGdgmVc
35. lot relee 15 lei
https://ibb.co/89gphDq
36. finali sony mn/mp 15 lei perechea sau 80 lei toti
https://ibb.co/YZY9mB1
37. finali 2sc5200/2sa1943 2 perechi 50 lei toti
https://ibb.co/3zN6rj1
38. tranzistori finali 10-25 lei perechea, disponibile mai multe perechi
https://ibb.co/3FJh3HS
39. 3 lasere recuperate, neverificate 25 lei toate
https://ibb.co/nCy8vnz
40. placa amplif kenwood neverificata 40 lei
https://ibb.co/CnMgrvy
41. trafuri retea 30 lei bucata
https://ibb.co/sqFQw3M
42. radiatoare aluminiu 10 lei bucata sau 2 bucati la 15 lei, egal care
https://ibb.co/hZfRcJQ
https://ibb.co/94Y3sm6
43. filtraje 10 lei perechea
https://ibb.co/nwC7GSg
44. modul intrari 10 lei
https://ibb.co/wh3RtNb
45. placa technics 20 lei
https://ibb.co/N34b879
46. condensator variabil 5 lei
https://ibb.co/KDDBxcS
47. module deckuri 15 lei ambele
https://ibb.co/qxk0p3M
48. volume motorizate 15 lei bucata
https://ibb.co/LzK9Zr3
49. module cu potentiometre 10 lei bucata sau 2 la 15 lei
https://ibb.co/cN2wWsX
50. trafuri din module de soft start tensiuni iesire 8-14v, montare pcb, 5 lei bucata sau 25 lei toate
https://ibb.co/jMnNgZ3
51. lot rezistente putere 15 lei
https://ibb.co/RYBc6s9
52. butoane aluminiu grundig (cele de comutatoare sunt de plastic) 15 lei toate
https://ibb.co/BTSwRkJ
53. tot ce se vede in poza 10 lei
https://ibb.co/s2XJVZ3
54. encodere 10 lei toate
https://ibb.co/fFFgqfW
55. tot ce se vede in poza 20 lei
https://ibb.co/nc2J49P
56. tranzistori perechi 10 lei perechea, oricare
https://ibb.co/vVLKN70
57. tranzistori dubli 5 lei bucata
https://ibb.co/tKgCHPg
58. lot 30 surse 1a 20 lei
https://ibb.co/PQY4nVP
59. lada de banane plina cu module complete si incomplete din amplificatoare, 90 lei
https://ibb.co/S3ZnPr9
60. module 10 lei oricare
https://ibb.co/HxFx5jN
https://ibb.co/RyQRwcw
https://ibb.co/HTtrKYB
https://ibb.co/TgPbbWB
https://ibb.co/wd4TQX0
61. module radio 15 lei bucata
https://ibb.co/TgpL16k
https://ibb.co/RpJWGd5
62. modul radio grundig 20 lei
https://ibb.co/mXzCSC1
63. modul cu stk4133 20 lei
https://ibb.co/4sYwST7
poz 52, 56, 57 rezervate ,  de asemenea toate comenzile din topic.
adaug
64. 2 trafo identice 2x26v 60 lei sau 30 lei bucata
https://ibb.co/RjjGP5T
65. trafo 36v 25 lei
https://ibb.co/nksjMHz
66. placa cu stk drivere 15 lei
https://ibb.co/K5XCZMX
67. placa amplif grundig 20 lei
https://ibb.co/dcvKHp0
68. modul dynacord 15 lei
https://ibb.co/CPKTtj4
69. module tunere 10 lei bucata sau 30 lei toate
https://ibb.co/2jDb39X
70. module cu tba231 155 lei tot ce se vede in poza
https://ibb.co/ZSgj6H1
71. comutatoare 5 lei, modul intrari cu tc9152 15 lei, iar cel din dreapta 10 lei
https://ibb.co/G39ffc5
72. module etaj final 10 lei bucata
https://ibb.co/G33qBx8
73. potentiometre , 15 lei tot ce se vede in poza
https://ibb.co/TgX99xS
74. indicator cu ac 5 lei
https://ibb.co/BtcMzHp
75. preu phono 10 lei
https://ibb.co/ZBd67rs
76. diverse 15 lei totul
https://ibb.co/RvhK06q
Editat de fluffy37
